  3. Porting MySensors to work with the RadioHead library
portingradiohead
288 Posts 24 Posters 254.8k Views 12 Watching
  • Z Zeph
    @kolaf said:
    As for the dynamic mesh, this is a feature I find especially useful for one of my dream applications. We have horses, and it would be really fun to place a radio module with a accelerometer, and maybe GPS receiver, on each horse to track their movements. This could also be combined with a breakable wire in the harness which would let us know if the radio had been ripped off of the horse. Having a dynamic mesh will greatly increase the range of flexibility of such a monitoring network.
    Just brainstorming, but what if we consider adding the concept of a roving node to the MySensors network, without the overhead of a full mesh? Your use case doesn't require that all nodes be meshed with each other, just that a class of leaf nodes be able to move around.
    If I understand, a gateway or repeater node will forward a packet from anybody, if it recognizes the destination (as a node id in its routing table). Suppose you had coverage of your corral (or whatever) via gateway and various repeaters. In theory (perhaps naive theory) the roving node could report to the gateway by broadcasting a message picked up by whatever repeater is nearest; being addressed to node 0, the repeater knows what to do with it.
    There would be no network ack and no way for the gateway to send to the roving node as described so far. That is, unless this special "rover packet" caused each relay to rewrite that entry of its routing table as it was passed to the gateway, to enable an updated path back to the roving node. If your horses run around among many nodes often, EEPROM wear could be a concern, unless there was a small "routing override table" in RAM to handle roving nodes.
    One part I'm not clear about is how to avoid two or more nearby repeaters both forwarding this broadcast packet from the roving node. That might be tricky if it often causes OTA collisions. It could also complicate the back route logic, IF that was implemented. If we could avoid or gracefully recover from collisions, the gateway and controller may be able to deal with multiple copies of the same packet (not unlike the MQTT level 1 "deliver at least once").
    And - it might be technically infeasible to enhance MySensors networking to support roving nodes. But in that case I'm sure I'll learn something from the manner in which it's shot down :-)
    @Zeph @kolaf
    The rovering node will be able to send its message (after a few failed attempts) in the current solution.
    If even faster parent-search is required you can change the #define SEARCH_FAILURES in MySensor.h.
      Yep, both pros and cons. :)
      A nice feature you can do with MySensors is to set a static parent (when calling gw.begin()). This could be useful for a presence sensor e.g. mounted on a car set statically to contact a repeater node mounted near the garage. The car sensor won't try to find or contact any other node than the garage one.
      K
      K
      kolaf
      @hek Just to be clear, I'm not dependent on the mesh functionality. I think I could be very happy with the current MySensors functionality with the added part of supporting my radio :-)
      • K kolaf
        @Yveaux said:
        @kolaf said:
        an optional address byte
        The trouble is you have to distinguish between broadcasts and direct messages, so you need to listen at 2 addresses at a time, so to say.
        There is a separate optional broadcast address byte. I'm not sure how this is used, but I'm guessing that the radio checks against both addresses before deciding what to do with the message. That should solve the broadcast problem.
        That's good!
        • K kolaf
          Z
          Z
          Zeph
          wrote on last edited by Zeph
          #159
          Aha, I see that on page 57 now.
          I think that would handle it! (I see no need for 6 address-filtered pipes, two addresses will do).
          Yes, it would be nice if the RH library could take advantage of address filtering for those radios which support it. I'm not so sure auto-ack is important tho.
          • YveauxY
            So, anyone still developing on RadioHead integration, or did all of you just give up? ;-)
            I spend some time on writing Wireshark dissectors for RadioHead and integration of MySensors, to be used with the sniffer (http://forum.mysensors.org/topic/242/wireless-nrf24l01-sniffer-for-mysensors)
            Code is almost final (still have to test dessection of routing tables).
            Just as a preview, here's a screenshot to hopefully get you enthusiastic again!
            upload-2e15da80-1b44-4113-a6ac-e0077160d77b
            hekH T 2 Replies Last reply
            • YveauxY Yveaux
              @Yveaux
              Looks good @Yveaux!
              • YveauxY
                I'm still a bit in doubt how sleeping nodes fit in when using RadioHead.
                It has no notion of sleeping nodes and just expects all nodes to be available anytime.
                When a route is e.g. discovered which uses a node that is about to go to sleep, routing will fail, but probably the route will then be rediscovered and finally settle using a node that is continuously powered.
                How long this will take and the likelyhood of such scenarios (depends ofcourse on the amount of nodes and how often/when they are awake) is still unclear to me.
                Hopefully I can analyze some real-world behavior using the sniffer.
                • YveauxY Yveaux
                  ToSa
                  Code Contributor
                  no progress on my end - but that's rather related to the fact that this was my first week back in the office after vacation...
                  I think we should do one thing first: decouple the "network layer" from the "application layer" in MySensors:
                  • not having MySensors derived from RF24
                  • have a "generic" interface between MySensors and the radio
                  That way it would be rather easy to make use of other radios and other network topologies - could be RH or something else. I've taken a shot at that (a lot of this based on what Kolaf and Yveaux did adjusting MySensors to RH) and will provide a link once it compiles and is tested and I hope I can keep the overhead small enough to be acceptable for the gained flexibility.
                  • K
                    K
                    kolaf
                    It is great to see that something is still happening. I wonder if I can build a packet sniffer for the RF69 radios? I guess it shouldn't be that difficult since they receive everything that is sent...
                    The reason for my lack of progress late the has several reasons.
                    1. I have a version of the library networks for my simplifications. This means that I can start building small sensors instead of spending all my time on the library :-)
                    2. My kids think I spent way too much time on this project already :-(
                    3. I'm waiting for some kind of consensus to emerge.
                    My hope has been to get this new radio library thing to a point where the community would adopt it so that I would not have to do any specific maintenance to keep my copy up to date with the official version. Based on this very long discussion thread there seems to be interest among you guys to achieve this, so I hope we will be able to get there at some point. However, we need to agree on how it is to be done, how much of the Radiohead library we want to use (or maybe even use a different library?). This obviously depends mostly on resource constraints considerations, and I'm not the best to judge this since I have not used MySensors extensively.
                    It is great to see effort being spent on trying to reduce the footprint, and as an experiment it makes sense to do this. Once we have seen how small it is possible to make it, then we can perhaps agree on what features we want (everything, or just the device interface, maybe with RHDatagram manager class (without acknowledgements)).
                    I'm holding back on developing any more this until we have reached some kind of consensus since I do not really have time to play around too much without being a relatively sure that the results will be useful.
                    • T ToSa
                      ToSa
                      Code Contributor
                      Initial version - tested with a simple DallasTemperatureSensor setup successfully here
                      Note that this fork/branch does not include the "1.4 update 1" changes for nodeID / CRLF.
                      Overhead is limited (~150b flash / ~20b ram):
                      Sketch uses 20,426 bytes (66%) of program storage space. Maximum is 30,720 bytes.
                      Global variables use 575 bytes (28%) of dynamic memory, leaving 1,473 bytes for local variables. Maximum is 2,048 bytes.
                      hekH 1 Reply Last reply
                      • K
                        K
                        kolaf
                        Care to share any details on which parts you took from where? Is it basically the Radiohead drivers with the MySensors network layer? Or did you make more effort on trying to split everything up to a larger extent
                        • K kolaf
                          ToSa
                          Code Contributor
                          @kolaf it's only splitting the MySensor application layer form the underlying network layer. Still using the MySensor tree network topology and the RF24 driver. It's adding the framework to allow others to easily integrate other topologies (e.g. mesh) and other radio modules (e.g. RF69). The interface expects a reliable submission - no matter if that's achieved by software (like radiohead) or hardware (nRF24).
                          The MyDriver header file includes a short description of the routines and it should be fairly easy to attach it to radiohead. The main benefit is that the original MySensor tree setup still works as before if wished.
                          K 1 Reply Last reply
                          • T ToSa
                            Looks good @ToSa!
                            • T ToSa
                              K
                              K
                              kolaf
                              @ToSa Could you give me the link to your repository?
                              • K kolaf
                                ToSa
                                Code Contributor
                                @kolaf click the "here" in my post above - or use this:
                                https://github.com/ToSa27/Arduino/commit/328757d5bdb2681257326761fe1a0d90cdc3eba3
                                K 2 Replies Last reply
                                • T ToSa
                                  K
                                  K
                                  kolaf
                                  @ToSa Got it. My apologies for being slow, it was getting late ;).
                                  Itlooks like this should be quite easy to work with. For the RF69 driver, maybe I could even use the unreliable datagram service from Radiohead And Configure the Driver to Use Hardware Acknowledgements (I Believe They Exist).
                                  I will make an effort in this direction during the next few days, I hope. I'm curious to see how much space this requires compared to the NRF24 solution
                                  • T ToSa
                                    K
                                    K
                                    kolaf
                                    @ToSa I was trying to fork your repository in order to build the driver for the RF69 based on Radiohead. It does not seem to work, maybe because I already have a fork of the main mysensors repository?
                                    Maybe I can just check out your code, add the necessary files and be allowed to push it back to you?
                                    • K kolaf
                                      ToSa
                                      Code Contributor
                                      yes - Git doesn't allow two forks with the same base name (Arduino) for one user. We are about to move the changes into the mysensors/development branch. That way you can pick it up from there...
                                      • T ToSa
                                        K
                                        K
                                        kolaf
                                        @ToSa Great, I will add my changes when you have done this.
                                        • K
                                          K
                                          kolaf
                                          It has been implemented, but I won't bother testing it until your changes have been merged with development, I don't want to mess up my existing development environment. My biggest uncertainty is whether this set up will allow the Radiohead library to be installed as a regular library in the "libraries" folder or if it has to be put directly into the MySensors folder.
