  3. Porting MySensors to work with the RadioHead library
portingradiohead
288 Posts 24 Posters 254.8k Views 12 Watching
  • K
    K
    kolaf
    Nevermind the sink word recognition, this appears to function as some kind of network ID has to be the same for both the sender and receiver. However, there is also an optional address byte which is considered by the radio before the packet enters the FIFO queue. Page 55 of http://www.hoperf.com/upload/rfchip/RF69-V1.2.pdf
    • K kolaf
      The trouble is you have to distinguish between broadcasts and direct messages, so you need to listen at 2 addresses at a time, so to say.
      K 1 Reply Last reply
      • K kolaf
        Looking at the documentation for the RF69 (page 41) it talks about sync word recognition. This is a programmable word that apparently can be used as the node's hardware address, similarly to the NRF24. Perhaps it is possible to expand the Radiohead drivers to utilise this functionality where it is available for filtering incoming packets?
        As for the dynamic mesh, this is a feature I find especially useful for one of my dream applications. We have horses, and it would be really fun to place a radio module with a accelerometer, and maybe GPS receiver, on each horse to track their movements. This could also be combined with a breakable wire in the harness which would let us know if the radio had been ripped off of the horse. Having a dynamic mesh will greatly increase the range of flexibility of such a monitoring network. I know that this is somewhat outside of the normal use case, but how fun wouldn't it be to build this? :-).
        Personally I'm also a bit interested in direct sensor to sensor configurations to allow for tightly coupled control systems without the need for a central controller in the loop (all the time). I know, we have resource limits so that I can probably not have everything, but one can dream...
        Yep, both pros and cons. :)
        A nice feature you can do with MySensors is to set a static parent (when calling gw.begin()). This could be useful for a presence sensor e.g. mounted on a car set statically to contact a repeater node mounted near the garage. The car sensor won't try to find or contact any other node than the garage one.
        • K kolaf
          Z
          Z
          Zeph
          wrote on last edited by Zeph
          #154
          Just brainstorming, but what if we consider adding the concept of a roving node to the MySensors network, without the overhead of a full mesh? Your use case doesn't require that all nodes be meshed with each other, just that a class of leaf nodes be able to move around.
          If I understand, a gateway or repeater node will forward a packet from anybody, if it recognizes the destination (as a node id in its routing table). Suppose you had coverage of your corral (or whatever) via gateway and various repeaters. In theory (perhaps naive theory) the roving node could report to the gateway by broadcasting a message picked up by whatever repeater is nearest; being addressed to node 0, the repeater knows what to do with it.
          There would be no network ack and no way for the gateway to send to the roving node as described so far. That is, unless this special "rover packet" caused each relay to rewrite that entry of its routing table as it was passed to the gateway, to enable an updated path back to the roving node. If your horses run around among many nodes often, EEPROM wear could be a concern, unless there was a small "routing override table" in RAM to handle roving nodes.
          One part I'm not clear about is how to avoid two or more nearby repeaters both forwarding this broadcast packet from the roving node. That might be tricky if it often causes OTA collisions. It could also complicate the back route logic, IF that was implemented. If we could avoid or gracefully recover from collisions, the gateway and controller may be able to deal with multiple copies of the same packet (not unlike the MQTT level 1 "deliver at least once").
          And - it might be technically infeasible to enhance MySensors networking to support roving nodes. But in that case I'm sure I'll learn something from the manner in which it's shot down :-)
          hekH 1 Reply Last reply
          • YveauxY Yveaux
            K
            K
            kolaf
            There is a separate optional broadcast address byte. I'm not sure how this is used, but I'm guessing that the radio checks against both addresses before deciding what to do with the message. That should solve the broadcast problem.
            hekH Z 2 Replies Last reply
            • Z Zeph
              @Zeph @kolaf
              The rovering node will be able to send its message (after a few failed attempts) in the current solution.
              If even faster parent-search is required you can change the #define SEARCH_FAILURES in MySensor.h.
                K
                K
                kolaf
                @hek Just to be clear, I'm not dependent on the mesh functionality. I think I could be very happy with the current MySensors functionality with the added part of supporting my radio :-)
                • K kolaf
                  That's good!
                  • K kolaf
                    Z
                    Z
                    Zeph
                    #159
                    Aha, I see that on page 57 now.
                    I think that would handle it! (I see no need for 6 address-filtered pipes, two addresses will do).
                    Yes, it would be nice if the RH library could take advantage of address filtering for those radios which support it. I'm not so sure auto-ack is important tho.
                    • YveauxY
                      So, anyone still developing on RadioHead integration, or did all of you just give up? ;-)
                      I spend some time on writing Wireshark dissectors for RadioHead and integration of MySensors, to be used with the sniffer (http://forum.mysensors.org/topic/242/wireless-nrf24l01-sniffer-for-mysensors)
                      Code is almost final (still have to test dessection of routing tables).
                      Just as a preview, here's a screenshot to hopefully get you enthusiastic again!
                      upload-2e15da80-1b44-4113-a6ac-e0077160d77b
                      hekH T 2 Replies Last reply
                      • YveauxY Yveaux
                        @Yveaux
                        Looks good @Yveaux!
                        • YveauxY
                          I'm still a bit in doubt how sleeping nodes fit in when using RadioHead.
                          It has no notion of sleeping nodes and just expects all nodes to be available anytime.
                          When a route is e.g. discovered which uses a node that is about to go to sleep, routing will fail, but probably the route will then be rediscovered and finally settle using a node that is continuously powered.
                          How long this will take and the likelyhood of such scenarios (depends ofcourse on the amount of nodes and how often/when they are awake) is still unclear to me.
                          Hopefully I can analyze some real-world behavior using the sniffer.
                          • YveauxY Yveaux
                            ToSa
                            Code Contributor
                            no progress on my end - but that's rather related to the fact that this was my first week back in the office after vacation...
                            I think we should do one thing first: decouple the "network layer" from the "application layer" in MySensors:
                            • not having MySensors derived from RF24
                            • have a "generic" interface between MySensors and the radio
                            That way it would be rather easy to make use of other radios and other network topologies - could be RH or something else. I've taken a shot at that (a lot of this based on what Kolaf and Yveaux did adjusting MySensors to RH) and will provide a link once it compiles and is tested and I hope I can keep the overhead small enough to be acceptable for the gained flexibility.
                            • K
                              K
                              kolaf
                              It is great to see that something is still happening. I wonder if I can build a packet sniffer for the RF69 radios? I guess it shouldn't be that difficult since they receive everything that is sent...
                              The reason for my lack of progress late the has several reasons.
                              1. I have a version of the library networks for my simplifications. This means that I can start building small sensors instead of spending all my time on the library :-)
                              2. My kids think I spent way too much time on this project already :-(
                              3. I'm waiting for some kind of consensus to emerge.
                              My hope has been to get this new radio library thing to a point where the community would adopt it so that I would not have to do any specific maintenance to keep my copy up to date with the official version. Based on this very long discussion thread there seems to be interest among you guys to achieve this, so I hope we will be able to get there at some point. However, we need to agree on how it is to be done, how much of the Radiohead library we want to use (or maybe even use a different library?). This obviously depends mostly on resource constraints considerations, and I'm not the best to judge this since I have not used MySensors extensively.
                              It is great to see effort being spent on trying to reduce the footprint, and as an experiment it makes sense to do this. Once we have seen how small it is possible to make it, then we can perhaps agree on what features we want (everything, or just the device interface, maybe with RHDatagram manager class (without acknowledgements)).
                              I'm holding back on developing any more this until we have reached some kind of consensus since I do not really have time to play around too much without being a relatively sure that the results will be useful.
                              • T ToSa
                                ToSa
                                Code Contributor
                                Initial version - tested with a simple DallasTemperatureSensor setup successfully here
                                Note that this fork/branch does not include the "1.4 update 1" changes for nodeID / CRLF.
                                Overhead is limited (~150b flash / ~20b ram):
                                Sketch uses 20,426 bytes (66%) of program storage space. Maximum is 30,720 bytes.
                                Global variables use 575 bytes (28%) of dynamic memory, leaving 1,473 bytes for local variables. Maximum is 2,048 bytes.
                                • K
                                  K
                                  kolaf
                                  Care to share any details on which parts you took from where? Is it basically the Radiohead drivers with the MySensors network layer? Or did you make more effort on trying to split everything up to a larger extent
                                  • K kolaf
                                    ToSa
                                    Code Contributor
                                    @kolaf it's only splitting the MySensor application layer form the underlying network layer. Still using the MySensor tree network topology and the RF24 driver. It's adding the framework to allow others to easily integrate other topologies (e.g. mesh) and other radio modules (e.g. RF69). The interface expects a reliable submission - no matter if that's achieved by software (like radiohead) or hardware (nRF24).
                                    The MyDriver header file includes a short description of the routines and it should be fairly easy to attach it to radiohead. The main benefit is that the original MySensor tree setup still works as before if wished.
                                    • T ToSa
                                      Looks good @ToSa!
                                      • T ToSa
                                        K
                                        K
                                        kolaf
                                        @ToSa Could you give me the link to your repository?
                                        • K kolaf
                                          ToSa
                                          Code Contributor
                                          @kolaf click the "here" in my post above - or use this:
                                          https://github.com/ToSa27/Arduino/commit/328757d5bdb2681257326761fe1a0d90cdc3eba3
                                          K 2 Replies Last reply
