  2. Announcements
  3. MySensors 2.0.0 Released
75 Posts 42 Posters 55.6k Views 37 Watching
    #56
    @Tore-André-Rosander
    for pros, I think serial gw is more secure. I mean esp is wifi, serial gw is only connected to controller. Of course controller is connected to network, but esp is just one more door directly connected to mysensors. Cons, not as verstatile as esp ;)
    • F
      F
      Fabien
      And with RFM69, ESP and MySensors 2.0 doesn't work for me. With serial gateway, it's ok. With Ethernet Gateway W5100 and MYS 1.0, I lost lot of packets (NRF radio).
      • Tore André RosanderT
        Tore André Rosander
        Thanks for the response, i tested the esp gateway and it looks good. But i think im going for the serial gateway just to eliminate the need for WiFi in my setup. So if the WiFi is messing up during the night the mysensors network still works.
          #59
          @Fabien ah weird.. for test, i have a working rfm69, esp mqtt and mysensors 2b gw.. but i don't know for the other esp gw.
          • T
            tante ju
            I like the new setup of the MySensors lib, but after getting some more gray hairs and replacing processors, boards and all the other stuff I noticed, there is something wrong with it.
            Following effect (tried it with Arduino versions 1.6.3 up to 1.6.9 on a Mac with El Capitan):
            I've setup a clean Arduino environment and installed the new MySensors lib. Wrote a program, where I wanted to test some interrupt routines with MySensor and it did not work. ok, seemed to be a bug and watchdog stepped in. Fixed software, rewrote software, created a small test program and always the same issue. I used Node Id 5 for this one.
            Then, after a whole day and changing processors and all other stuff I loaded a file, working with 2.0-beta and using Node Id 7. And what I got where the same messages on the gateway, just with Node Id 7. ???
            In fact I got a presentation of HUM (my tests with Node 5), but with Node 7, although the file never had anything to do with HUM.
            Verseifen with an Arduino Nano board, installed a very small MySensor example script on it and same effect.
            So, some pieces of the initial program were once compiled and resided in the system, regardless what source you are using afterwards.
            Deleted the new 2.0.0 lib, installed my 2.0.0-beta and everything is fine. Switched back to 2.0.0 stable and instantly the old binary was back there.
            Any ideas?
            DrJeffD Tore André RosanderT 2 Replies Last reply
            • T tante ju
              Any ideas?
              DrJeffD
              DrJeffD
              DrJeff
              @tante-ju
              Jumped onto my ESXi server with a windows VM windows setup and the problem you are describing for the mac went away. I have El Cap on my mac with the same type of problems. Don't have an answers but windows worked fine. Wasted a couple of hours trying to fix also.
              • T tante ju
                Any ideas?
                Tore André Rosander
                wrote on last edited by Tore André Rosander
                #62
                @tante-ju Some sort of cache problem? I had a similar issue with the beta, i used the clear eeprom sketch on the node and set a different node id manually and fixed it.
                EDIT: Had the same problem now with the v2 release, clear eeprom on the node solved it
                • Tore André RosanderT Tore André Rosander
                  tante ju
                  Hi, as the same type of old code is written in a new proc, it could not be the EEPROM. The Arduino environment together with the new MySensors lib seems to build some object files only once and then uploads them all the time.
                  • Lior RubinL Lior Rubin
                    Hi, when I'm try to upload the sketch GatewayESP8266 I got the following error:
                    In file included from /Users/liorrubin/Documents/Arduino/libraries/MySensors-2.0.0/MySensors.h:299:0,
                                     from /var/folders/l0/kxrb9wmd6rj651nw4gld5nx00000gn/T/arduino_modified_sketch_982538/GatewayESP8266.ino:137:
                    /Users/liorrubin/Documents/Arduino/libraries/MySensors-2.0.0/core/MyMainESP8266.cpp:4:10: error: #include expects "FILENAME" or <FILENAME>
                     #include “Schedule.h”
                    /Users/liorrubin/Documents/Arduino/libraries/MySensors-2.0.0/core/MyMainESP8266.cpp:13:26: fatal error: core_version.h: No such file or directory
                     #include <core_version.h>
                    compilation terminated.
                    exit status 1
                    Error compiling for board NodeMCU 1.0 (ESP-12E Module).
                    Even when i try to comment the "Include Schedule.h" then i got an error about the "core_version.h" file.
                    anyone ?
                    ninkasiN
                    ninkasiN
                    ninkasi
                    wrote on last edited by ninkasi
                    #64
                    exit status 1
                    anyone ?
                    Just started playing with mysensors - in my case trying to use a WeMos D1R2. I was getting the same errors - although I can happily compile other sketches on the boards so I knew it wasn't me.... well, probably not entirely. I think maybe because I've only recently started using it perhaps I don't have older libraries installed as well as the current ones? Anyhow, horrible hack is as follows:
                    1. Go to https://github.com/esp8266/Arduino
                    2. Download the core branch
                    3. Open the zip file and go to the cores/esp8266 directory (yes you can also download just the files below individually, but I have found in the past you can have issues with corrupted files doing it that way - feel free to give it a go if you want)
                    4. Copy the files Schedule.cpp, Schedule.h, and core_version.h and put them into your arduino\libraries\MySensors-master directory
                    Compile away and hopefully it will work this time! Did for me...... ;-)
                    Note - if you decide to use your board for sensors as well you may have to copy over other supporting files.
                    Update - for some weird reason errors came back, and I could not trace the cause easily. Decided to do a clean install - backup up my sketches, and removed the Arduino IDE along with the libraries. Note that on my mac there was a library folder both in my documents as well as in username\Library. Anyhow, reinstalled, re-downloaded everything, and my sketches compiled without an issue.
                    • Борис БашкинцевБ
                      Борис БашкинцевБ
                      Борис Башкинцев
                      wrote on last edited by Борис Башкинцев
                      #65
                      What does it mean?
                      "Gateway just another sensor node! So now you can have wired ethernet sensors and wireless ESP8266 sensors without any radio attach if you want."
                      I have serial gateway with nfr radio, connected to PC with home assistant. How can I add ethernet node without radio to this setup? How it will be talk with gateway?
                      AnticimexA 1 Reply Last reply
                      • Борис БашкинцевБ Борис Башкинцев
                        What does it mean?
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Борис-Башкинцев i believe it is to be interpreted as you set up "many" gateways, but you don't mount radios on them. Instead you connect sensors directly to the gateway and then connect the gateways to your controller. Using WiFi or ethernet. That way, your gateways act as a sort of sensor node network connected using WiFi/ethernet instead of NRF or RFM radios.
                          Yes, this in the new normal... we moved all the examples using external library dependencies into https://github.com/mysensors/MySensorsArduinoExamples until we can figure out which ones work with auto-dependency-download using the IDE Library Manager.
                          We would really appreciate some help doing the verification.
                          Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          How does the auto download work @hek
                            @Mark-Swift, you mean the verification of the moved examples?
                            • Daniel OliveiraD
                              Daniel OliveiraD
                              Daniel Oliveira
                              Hi all,
                              I'm sorry if this was already answered.
                              But how should we manage libraries that were included in the MySensors 1.5.x and are no more in the 2.0.x?
                              For example DHT and BH1750.
                              Thank you in advance,
                              Daniel
                              MySensors rules my home :)
                              • fetsF
                                fetsF
                                fets
                                @Daniel-Oliveira check previous hek's answer
                                • AnticimexA Anticimex
                                  :mega: We are happy to announce a major release of the MySensors library to 2.0.0!
                                  For details, see here.
                                  Doxygen links on the master github frontpage are not working. These are the correct links:
                                  master development
                                  B
                                  B
                                  bomber
                                  @Anticimex Lots of nice features are listed in announcement!
                                  Where I can find documentation for v2?
                                  I'd like to try MQTT gateway on W5500 chip and I'd like to test sensors connected directly to gateway but I have no clue how to start.
                                  Vj
                                  blaceyB alfredbA 2 Replies Last reply
                                  • B bomber
                                    Vj
                                    blaceyB
                                    blaceyB
                                    blacey
                                    @bomber API 2.0
                                    • B bomber
                                      Vj
                                      alfredbA
                                      alfredbA
                                      alfredb
                                      @bomber I'm using a W5500 with locally attached sensors, only thing you have to do is use a customized version of the Ethernet library. Like this one https://github.com/embeddist/WIZ_Ethernet_Library-IDE1.6.x.
                                      • tbowmoT tbowmo
                                        @kenci said:
                                        @gloob said:
                                        I did now also update my gateway but I see two messages in the debug panel that I don't understand:
                                        pm open,type:2 0
                                        0;255;3;0;9;TSP:SANCHK:OK
                                        Does anybody have an idea what that means?
                                        I have this problem too. What does that mean?
                                        The TSP:SANCHK:OK is a sanity check of the radio, this time it's OK. But if we fail in talking with the radio (spi failure etc) it will try to initialize the radio, and also write Fail (I believe)
                                        It's @tekka that is the brain behind this part (and has promised to make some documentation on it :))
                                        mppM
                                        mppM
                                        mpp
                                        Hi @tekka Some documentation on "pm open,type:2 0" and what it means would be useful.
                                        MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
                                        tekkaT 1 Reply Last reply
                                        • mppM mpp
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @mpp said in MySensors 2.0.0 Released:
                                          pm open,type:2 0
                                          This is a message emitted by the ESP8266 core, not MySensors related.
