  3. [Solved] Node not reconnecting
17 Posts 5 Posters 6.4k Views 6 Watching
  • kk02067K Offline
    kk02067K Offline
    kk02067
    wrote on last edited by tekka
    I have a node that is causing problems for me. When I have the node and the gateway in the same room all works fine. But when I move them apart the node stops sending the messages after a random couple of hours. This I think is because of the range. But if I move the node closer to the gatway again it doesn't reconnect. And the debug from the node outputs:
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    RF24:write register, reg=0, value=12
    RF24:power down
    and repeats until I reset the node.
    It seems that my auto reset of the nod fails also.
    The sketch looks like this:
    #include <SoftReset.h>
    I2C_ReadAllData.ino
    BME280 Arduino and Teensy example
    Marshall Taylor @ SparkFun Electronics
    May 20, 2015
    https://github.com/sparkfun/SparkFun_BME280_Arduino_Library
    This sketch configures the BME280 to read all measurements.  The sketch also
    displays the BME280's physical memory and what the driver perceives the
    calibration words to be.
    Resources:
    Uses Wire.h for I2C operation
    Uses SPI.h for SPI operation
    Development environment specifics:
    Arduino IDE 1.6.4
    Teensy loader 1.23
    This code is released under the [MIT License](http://opensource.org/licenses/MIT).
    Please review the LICENSE.md file included with this example. If you have any questions
    or concerns with licensing, please contact techsupport@sparkfun.com.
    Distributed as-is; no warranty is given.
    #include <stdint.h>
    #include "SparkFunBME280.h"
    //Library allows either I2C or SPI, so include both.
    #include "Wire.h"
    #include "SPI.h"
    #define MY_DEBUG_VERBOSE_RF24
    #define SKETCH_NAME "Min väderstation"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "1"
    #define CHILD_ID_1 1
    #define CHILD_ID_2 2
    #define CHILD_ID_3 3
    //Global sensor object
    BME280 Sensor;
    MyMessage msg1(CHILD_ID_1, V_TEMP);
    MyMessage msg2(CHILD_ID_2, V_HUM);
    MyMessage msg3(CHILD_ID_3, V_PRESSURE);
    	//***Driver settings********************************//
    	//commInterface can be I2C_MODE or SPI_MODE
    	//specify chipSelectPin using arduino pin names
    	//specify I2C address.  Can be 0x77(default) or 0x76
    	//For I2C, enable the following and disable the SPI section
    	Sensor.settings.commInterface = I2C_MODE;
    	Sensor.settings.I2CAddress = 0x76;
    	//For SPI enable the following and dissable the I2C section
    	//Sensor.settings.commInterface = SPI_MODE;
    	//Sensor.settings.chipSelectPin = 10;
    	//***Operation settings*****************************//
    	//renMode can be:
    	//  0, Sleep mode
    	//  1 or 2, Forced mode
    	//  3, Normal mode
    	Sensor.settings.runMode = 3; //Normal mode
    	//tStandby can be:
    	//  0, 0.5ms
    	//  1, 62.5ms
    	//  2, 125ms
    	//  3, 250ms
    	//  4, 500ms
    	//  5, 1000ms
    	//  6, 10ms
    	//  7, 20ms
    	Sensor.settings.tStandby = 5;
    	//filter can be off or number of FIR coefficients to use:
    	//  0, filter off
    	//  1, coefficients = 2
    	//  2, coefficients = 4
    	//  3, coefficients = 8
    	//  4, coefficients = 16
    	Sensor.settings.filter = 0;
    	//tempOverSample can be:
    	//  0, skipped
    	//  1 through 5, oversampling *1, *2, *4, *8, *16 respectively
    	Sensor.settings.tempOverSample = 1;
    	//pressOverSample can be:
    	//  0, skipped
        Sensor.settings.pressOverSample = 1;
    	//humidOverSample can be:
    	//  0, skipped
    	Sensor.settings.humidOverSample = 1;
    //	Serial.begin(57600);
    	Serial.print("Program Started\n");
    	Serial.print("Starting BME280... result of .begin(): 0x");
    	//Calling .begin() causes the settings to be loaded
    	delay(10);  //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up.
    	Serial.println(Sensor.begin(), HEX);
    	Serial.print("Displaying ID, reset and ctrl regs\n");
    	Serial.print("ID(0xD0): 0x");
    	Serial.println(Sensor.readRegister(BME280_CHIP_ID_REG), HEX);
    	Serial.print("Reset register(0xE0): 0x");
    	Serial.println(Sensor.readRegister(BME280_RST_REG), HEX);
    	Serial.print("ctrl_meas(0xF4): 0x");
    	Serial.println(Sensor.readRegister(BME280_CTRL_MEAS_REG), HEX);
    	Serial.print("ctrl_hum(0xF2): 0x");
    	Serial.println(Sensor.readRegister(BME280_CTRL_HUMIDITY_REG), HEX);
    	Serial.print("\n\n");
    	Serial.print("Displaying all regs\n");
    	uint8_t memCounter = 0x80;
    	uint8_t tempReadData;
    	for(int rowi = 8; rowi < 16; rowi++ )
    		Serial.print("0x");
    		Serial.print(rowi, HEX);
    		Serial.print("0:");
    		for(int coli = 0; coli < 16; coli++ )
    			tempReadData = Sensor.readRegister(memCounter);
    			Serial.print((tempReadData >> 4) & 0x0F, HEX);//Print first hex nibble
    			Serial.print(tempReadData & 0x0F, HEX);//Print second hex nibble
    			Serial.print(" ");
    			memCounter++;
    		Serial.print("\n");
    	Serial.print("Displaying concatenated calibration words\n");
    	Serial.print("dig_T1, uint16: ");
    	Serial.println(Sensor.calibration.dig_T1);
    	Serial.print("dig_T2, int16: ");
    	Serial.println(Sensor.calibration.dig_T2);
    	Serial.print("dig_T3, int16: ");
    	Serial.println(Sensor.calibration.dig_T3);
    	Serial.print("dig_P1, uint16: ");
    	Serial.println(Sensor.calibration.dig_P1);
    	Serial.print("dig_P2, int16: ");
    	Serial.println(Sensor.calibration.dig_P2);
    	Serial.print("dig_P3, int16: ");
    	Serial.println(Sensor.calibration.dig_P3);
    	Serial.print("dig_P4, int16: ");
    	Serial.println(Sensor.calibration.dig_P4);
    	Serial.print("dig_P5, int16: ");
    	Serial.println(Sensor.calibration.dig_P5);
    	Serial.print("dig_P6, int16: ");
    	Serial.println(Sensor.calibration.dig_P6);
    	Serial.print("dig_P7, int16: ");
    	Serial.println(Sensor.calibration.dig_P7);
    	Serial.print("dig_P8, int16: ");
    	Serial.println(Sensor.calibration.dig_P8);
    	Serial.print("dig_P9, int16: ");
    	Serial.println(Sensor.calibration.dig_P9);
    	Serial.print("dig_H1, uint8: ");
    	Serial.println(Sensor.calibration.dig_H1);
    	Serial.print("dig_H2, int16: ");
    	Serial.println(Sensor.calibration.dig_H2);
    	Serial.print("dig_H3, uint8: ");
    	Serial.println(Sensor.calibration.dig_H3);
    	Serial.print("dig_H4, int16: ");
    	Serial.println(Sensor.calibration.dig_H4);
    	Serial.print("dig_H5, int16: ");
    	Serial.println(Sensor.calibration.dig_H5);
    	Serial.print("dig_H6, uint8: ");
    	Serial.println(Sensor.calibration.dig_H6);
    	Serial.println();
            pinMode(8,OUTPUT);  //pin8 as output for battcheck
            digitalWrite(8,LOW); //see to that pin is low to save power
            analogReference(INTERNAL);  //internal 1.1V reference for battcheck
      present(CHILD_ID_1, S_TEMP);
      present(CHILD_ID_2, S_HUM);
      present(CHILD_ID_3, S_BARO);
            double  temperature;
            double  humidity;
            double  pressure;
            double  oldtemperature;
            double  oldhumidity;
            double  oldpressure;
            unsigned char fail;
    	//Each loop, take a reading.
    	//Start with temperature, as that data is needed for accurate compensation.
    	//Reading the temperature updates the compensators of the other functions
    	//in the background.
    /*	Serial.print("Temperature: ");
    	Serial.print(Sensor.readTempC(), 2);
    	Serial.println(" degrees C");
    	Serial.print(Sensor.readTempF(), 2);
    	Serial.println(" degrees F");
    	Serial.print("Pressure: ");
    	Serial.print(Sensor.readFloatPressure(), 2);
    	Serial.println(" Pa");
    	Serial.print("Altitude: ");
    	Serial.print(Sensor.readFloatAltitudeMeters(), 2);
    	Serial.println("m");
    	Serial.print(Sensor.readFloatAltitudeFeet(), 2);
    	Serial.println("ft");
    	Serial.print("%RH: ");
    	Serial.print(Sensor.readFloatHumidity(), 2);
    	Serial.println(" %");
    	Serial.println();
    	delay(1000);
            float  batt;
            digitalWrite(8,HIGH);
            delay(10);
            batt=analogRead(0);
            batt=batt-900;
            batt=batt/1.23;
            Serial.print("Batt%: ");
           	Serial.print(batt);
            sendBatteryLevel(batt);
            temperature=Sensor.readTempC();
            humidity=Sensor.readFloatHumidity();
            pressure=Sensor.readFloatPressure()/100;
            if(temperature != oldtemperature){
            if(!send(msg1.set(temperature,2))){fail++;};
            oldtemperature=temperature;
            if(humidity != oldhumidity){
            if(!send(msg2.set(humidity,2))){fail++;};
            oldhumidity=humidity;
            if(pressure != oldpressure){
            if(!send(msg3.set(pressure,2))){fail++;};
            oldpressure=pressure;
            if (fail>6){fail=0; Serial.print("Transmit error, Reseting!");soft_restart();}
            fail=0;
         sleep(30000);
    What does the message:
    !TSP:SEND:TNR
    mean and how do I handle it?
    • kk02067K kk02067
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      RF24:power down
      I2C_ReadAllData.ino
      May 20, 2015
      Resources:
      Arduino IDE 1.6.4
      Teensy loader 1.23
      #include <stdint.h>
      #include "Wire.h"
      #include "SPI.h"
      BME280 Sensor;
      	//renMode can be:
      	//  0, Sleep mode
      	//  3, Normal mode
      	//tStandby can be:
      	//  0, 0.5ms
      	//  1, 62.5ms
      	//  2, 125ms
      	//  3, 250ms
      	//  4, 500ms
      	//  5, 1000ms
      	//  6, 10ms
      	//  7, 20ms
      	//  0, filter off
      	//  0, skipped
      	//  0, skipped
      	//  0, skipped
      		Serial.print("0x");
      		Serial.print("0:");
      			Serial.print(" ");
      			memCounter++;
      		Serial.print("\n");
      	Serial.println();
              double  temperature;
              double  humidity;
              double  pressure;
              double  oldhumidity;
              double  oldpressure;
              unsigned char fail;
      	Serial.println();
      	delay(1000);
              float  batt;
              delay(10);
              batt=analogRead(0);
              batt=batt-900;
              batt=batt/1.23;
             	Serial.print(batt);
              fail=0;
           sleep(30000);
      !TSP:SEND:TNR
      @kk02067 see @tekka's explanation in this post (especially step 7 and 8) https://forum.mysensors.org/topic/4347/can-t-get-sensors-talking/3
      • kk02067K Offline
        kk02067K Offline
        kk02067
        I have read that thread Before but it doesn't explain what:
        !TSP:SEND:TNR => Transport:SEND:Transport Not Ready
        really means. What has happend and what needs to be done.
        I have corrected my sketch regarding the autoreset of the node. I hope that helps to keep the node communicating.
        I2C_ReadAllData.ino
        May 20, 2015
        Resources:
        Arduino IDE 1.6.4
        Teensy loader 1.23
        #include <stdint.h>
        #include "Wire.h"
        #include "SPI.h"
        BME280 Sensor;
        	//renMode can be:
        	//  0, Sleep mode
        	//  3, Normal mode
        	//tStandby can be:
        	//  0, 0.5ms
        	//  1, 62.5ms
        	//  2, 125ms
        	//  3, 250ms
        	//  4, 500ms
        	//  5, 1000ms
        	//  6, 10ms
        	//  7, 20ms
        	//  0, filter off
        	//  0, skipped
        	//  0, skipped
        	//  0, skipped
        		Serial.print("0x");
        		Serial.print("0:");
        			Serial.print(" ");
        			memCounter++;
        		Serial.print("\n");
        	Serial.println();
                double  temperature;
                double  humidity;
                double  pressure;
                double  oldhumidity;
                double  oldpressure;
                unsigned char fail;
                float  batt;
                delay(10);
                batt=analogRead(0);
                batt=batt-900;
                batt=batt/1.23;
               	Serial.println(batt);
                  else{ fail=0;}
                  else{ fail=0; }
                  else{ fail=0; }
                Serial.print("Number of errors before reset: "); Serial.println(fail);
             sleep(30000);
        • kk02067K kk02067
          I2C_ReadAllData.ino
          May 20, 2015
          Resources:
          Arduino IDE 1.6.4
          Teensy loader 1.23
          #include <stdint.h>
          #include "Wire.h"
          #include "SPI.h"
          BME280 Sensor;
          	//renMode can be:
          	//  0, Sleep mode
          	//  3, Normal mode
          	//tStandby can be:
          	//  0, 0.5ms
          	//  1, 62.5ms
          	//  2, 125ms
          	//  3, 250ms
          	//  4, 500ms
          	//  5, 1000ms
          	//  6, 10ms
          	//  7, 20ms
          	//  0, filter off
          	//  0, skipped
          	//  0, skipped
          	//  0, skipped
          		Serial.print("0x");
          		Serial.print("0:");
          			Serial.print(" ");
          			memCounter++;
          		Serial.print("\n");
          	Serial.println();
                  double  temperature;
                  double  humidity;
                  double  pressure;
                  double  oldhumidity;
                  double  oldpressure;
                  unsigned char fail;
                  float  batt;
                  delay(10);
                  batt=analogRead(0);
                  batt=batt-900;
                  batt=batt/1.23;
                    else{ fail=0;}
                    else{ fail=0; }
                    else{ fail=0; }
               sleep(30000);
          T Offline
          T Offline
          tekka
          @kk02067 the issue is that you send the node to sleep before the communication is fully re-established. Please post the complete debug log for verification.
          • kk02067K Offline
            kk02067K Offline
            kk02067
            I'm having trouble to log the node since it is in a remote place when it stops working.
            Can you please explain a little more what you mean with "send the node to sleep before the communication is fully re-established"?
            I'm a bit lost in all this it seems. I must have missed someting when reading about sending new values to the controller. But I thought that when the "send()" is executed the program is waiting here until Everything is finished for that transmission and we can move on to the transmission.
            Is there something I must do before sending the cpu to sleep?
            Sorry for my slow understanding.
            • kk02067K kk02067
              T Offline
              T Offline
              tekka
              @kk02067 If your node is out of range, all uplink messages will fail and after 5 consecutive uplink fails, the node will search for a new parent and try to (re)establish the link to the GW.
              If you put your node asleep while the link is being established (last line in loop() ), the node won't reconnect. You can prevent this from happening by substituting
              sleep(30000);
              with
              if(isTransportOK()){
                  sleep(30000);  // transport is OK, node can sleep
                else {
                  wait(5000); // transport is not operational, allow the transport layer to fix this
              mfalkviddM corbinC 2 Replies Last reply
              • T tekka
                sleep(30000);
                with
                  else {
                @tekka wouldn't it be better if the library handled that automatically? The library is so good at taking care of everything else. Or maybe I'm just getting spoiled :)
                • kk02067K Offline
                  kk02067K Offline
                  kk02067
                  Ok. Will try something like that.
                  Is mysensors libraryfunctions interuptdriven? If so I understand why my sketch fails. Is there a complete list of useful functions besides going thru the sourcecode?
                  Thanks alot for your support.
                  T T 2 Replies Last reply
                  • kk02067K kk02067
                    T Offline
                    T Offline
                    TheoL
                    @kk02067 Haven't played with 2.0 yet. But looked at the Api which doesn't say what the return value of msg means. In your code you presume that the return values of msg states the success of sending the message. I'm however not sure whether msg() is a blocking call. Meaning that the message is immediately send when you call send. It might be queued until MySensors is ready to handle the sending of messages. And in that case it just can't predict whether it might be able to send a msg in the future. If it could, I'd hire the engineer who developed that algorithm. He'd probably make me rich in no time ;-)
                    If msg is a non-blocking call, than determining whether the msg was successfully by MySensors, by checking the return value of the call to msg doesn't make sense. And you actually disturb the whole resend and connect mechanism by doing a soft restart after 6 consecutive fails.
                    But then again haven't played with it. But thought this might help. I think I'd would first try to improve the sending range and try to find out what the cause is. Because it might be a hardware problem. And if you can tackle it, it might solve all of your problems.
                    • kk02067K Offline
                      kk02067K Offline
                      kk02067
                      • kk02067K kk02067
                        T Offline
                        T Offline
                        tekka
                        @kk02067 As @TheoL pointed out, there is no need to reset the node after 6 failed messages, the transport layer takes care of that:
                        • After 5 consecutive uplink fails, the node search for a new parent (with an established GW-link)
                        • After 3 unsuccessful find parent attempts, the radio is re-initialised.
                        Send() returns true if the message was successfully delivered to the next (i.e. parent node), however, this does not imply that the GW/controller received the message.
                        kk02067K 1 Reply Last reply
                        • T tekka
                          kk02067K Offline
                          kk02067K Offline
                          kk02067
                          @tekka Thanks for the info, I will now rework the sketch after this new information.
                          My understanding of the library grows with every question.
                          This is so fun. So much to build, so little time.
                          • kk02067K kk02067
                            T Offline
                            T Offline
                            tekka
                            @kk02067 Welcome to the club :) Too little time...
                              T Offline
                              T Offline
                              tekka
                              @mfalkvidd Yes, you are spoiled :stuck_out_tongue: - I already implemented that after reading a few comments, just have to push the PR.
                              • kk02067K Offline
                                kk02067K Offline
                                kk02067
                                I have now implemented the changes discussed here. It now seems to work flawlessly. I tested the node to see its behaviour when i powered down the gateway. As it said in the thread the node tried to reconnect after a couple of failed transmissions. And when I powered up the gateway again the node reconnected and started to go to sleep again.
                                Thanks for the help on this.
                                A Quick question a bit of topic Before I go build new nodes. If I want to run the cpu at only 1 MHz, do I have to do something else other then define the cpu frequency in the sketch? Is it possible to set the cpuclk prescaler at runtime?
                                • kk02067K kk02067
                                  T Offline
                                  T Offline
                                  TheoL
                                  @kk02067 if I remember correctly, the example Sensebender sketch (MS 1.5) switches between 8mHz to 1Mhz 1. And there was a reason for that, which I can't remember. You could look at that sketch. Hope it helps you.
                                  • T tekka
                                    sleep(30000);
                                    with
                                      else {
                                    corbinC Offline
                                    corbinC Offline
                                    corbin
                                      else {
                                    I've only just found this post, and these lines of code have me excited! fixes my problem, thank you!
