[Solved] Node not reconnecting
I have a node that is causing problems for me. When I have the node and the gateway in the same room all works fine. But when I move them apart the node stops sending the messages after a random couple of hours. This I think is because of the range. But if I move the node closer to the gatway again it doesn't reconnect. And the debug from the node outputs:
!TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR RF24:write register, reg=0, value=12 RF24:power downand repeats until I reset the node.
It seems that my auto reset of the nod fails also.
The sketch looks like this:
#include <SoftReset.h> /****************************************************************************** I2C_ReadAllData.ino BME280 Arduino and Teensy example Marshall Taylor @ SparkFun Electronics May 20, 2015 https://github.com/sparkfun/SparkFun_BME280_Arduino_Library This sketch configures the BME280 to read all measurements. The sketch also displays the BME280's physical memory and what the driver perceives the calibration words to be. Resources: Uses Wire.h for I2C operation Uses SPI.h for SPI operation Development environment specifics: Arduino IDE 1.6.4 Teensy loader 1.23 This code is released under the [MIT License](http://opensource.org/licenses/MIT). Please review the LICENSE.md file included with this example. If you have any questions or concerns with licensing, please contact techsupport@sparkfun.com. Distributed as-is; no warranty is given. ******************************************************************************/ #include <stdint.h> #include "SparkFunBME280.h" //Library allows either I2C or SPI, so include both. #include "Wire.h" #include "SPI.h" #define MY_DEBUG #define MY_DEBUG_VERBOSE_RF24 #define MY_RADIO_NRF24 #include <MySensors.h> #define SKETCH_NAME "Min väderstation" #define SKETCH_MAJOR_VER "1" #define SKETCH_MINOR_VER "1" #define CHILD_ID_1 1 #define CHILD_ID_2 2 #define CHILD_ID_3 3 //Global sensor object BME280 Sensor; MyMessage msg1(CHILD_ID_1, V_TEMP); MyMessage msg2(CHILD_ID_2, V_HUM); MyMessage msg3(CHILD_ID_3, V_PRESSURE); void setup() { //***Driver settings********************************// //commInterface can be I2C_MODE or SPI_MODE //specify chipSelectPin using arduino pin names //specify I2C address. Can be 0x77(default) or 0x76 //For I2C, enable the following and disable the SPI section Sensor.settings.commInterface = I2C_MODE; Sensor.settings.I2CAddress = 0x76; //For SPI enable the following and dissable the I2C section //Sensor.settings.commInterface = SPI_MODE; //Sensor.settings.chipSelectPin = 10; //***Operation settings*****************************// //renMode can be: // 0, Sleep mode // 1 or 2, Forced mode // 3, Normal mode Sensor.settings.runMode = 3; //Normal mode //tStandby can be: // 0, 0.5ms // 1, 62.5ms // 2, 125ms // 3, 250ms // 4, 500ms // 5, 1000ms // 6, 10ms // 7, 20ms Sensor.settings.tStandby = 5; //filter can be off or number of FIR coefficients to use: // 0, filter off // 1, coefficients = 2 // 2, coefficients = 4 // 3, coefficients = 8 // 4, coefficients = 16 Sensor.settings.filter = 0; //tempOverSample can be: // 0, skipped // 1 through 5, oversampling *1, *2, *4, *8, *16 respectively Sensor.settings.tempOverSample = 1; //pressOverSample can be: // 0, skipped // 1 through 5, oversampling *1, *2, *4, *8, *16 respectively Sensor.settings.pressOverSample = 1; //humidOverSample can be: // 0, skipped // 1 through 5, oversampling *1, *2, *4, *8, *16 respectively Sensor.settings.humidOverSample = 1; // Serial.begin(57600); Serial.print("Program Started\n"); Serial.print("Starting BME280... result of .begin(): 0x"); //Calling .begin() causes the settings to be loaded delay(10); //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up. Serial.println(Sensor.begin(), HEX); Serial.print("Displaying ID, reset and ctrl regs\n"); Serial.print("ID(0xD0): 0x"); Serial.println(Sensor.readRegister(BME280_CHIP_ID_REG), HEX); Serial.print("Reset register(0xE0): 0x"); Serial.println(Sensor.readRegister(BME280_RST_REG), HEX); Serial.print("ctrl_meas(0xF4): 0x"); Serial.println(Sensor.readRegister(BME280_CTRL_MEAS_REG), HEX); Serial.print("ctrl_hum(0xF2): 0x"); Serial.println(Sensor.readRegister(BME280_CTRL_HUMIDITY_REG), HEX); Serial.print("\n\n"); Serial.print("Displaying all regs\n"); uint8_t memCounter = 0x80; uint8_t tempReadData; for(int rowi = 8; rowi < 16; rowi++ ) { Serial.print("0x"); Serial.print(rowi, HEX); Serial.print("0:"); for(int coli = 0; coli < 16; coli++ ) { tempReadData = Sensor.readRegister(memCounter); Serial.print((tempReadData >> 4) & 0x0F, HEX);//Print first hex nibble Serial.print(tempReadData & 0x0F, HEX);//Print second hex nibble Serial.print(" "); memCounter++; } Serial.print("\n"); } Serial.print("\n\n"); Serial.print("Displaying concatenated calibration words\n"); Serial.print("dig_T1, uint16: "); Serial.println(Sensor.calibration.dig_T1); Serial.print("dig_T2, int16: "); Serial.println(Sensor.calibration.dig_T2); Serial.print("dig_T3, int16: "); Serial.println(Sensor.calibration.dig_T3); Serial.print("dig_P1, uint16: "); Serial.println(Sensor.calibration.dig_P1); Serial.print("dig_P2, int16: "); Serial.println(Sensor.calibration.dig_P2); Serial.print("dig_P3, int16: "); Serial.println(Sensor.calibration.dig_P3); Serial.print("dig_P4, int16: "); Serial.println(Sensor.calibration.dig_P4); Serial.print("dig_P5, int16: "); Serial.println(Sensor.calibration.dig_P5); Serial.print("dig_P6, int16: "); Serial.println(Sensor.calibration.dig_P6); Serial.print("dig_P7, int16: "); Serial.println(Sensor.calibration.dig_P7); Serial.print("dig_P8, int16: "); Serial.println(Sensor.calibration.dig_P8); Serial.print("dig_P9, int16: "); Serial.println(Sensor.calibration.dig_P9); Serial.print("dig_H1, uint8: "); Serial.println(Sensor.calibration.dig_H1); Serial.print("dig_H2, int16: "); Serial.println(Sensor.calibration.dig_H2); Serial.print("dig_H3, uint8: "); Serial.println(Sensor.calibration.dig_H3); Serial.print("dig_H4, int16: "); Serial.println(Sensor.calibration.dig_H4); Serial.print("dig_H5, int16: "); Serial.println(Sensor.calibration.dig_H5); Serial.print("dig_H6, uint8: "); Serial.println(Sensor.calibration.dig_H6); Serial.println(); pinMode(8,OUTPUT); //pin8 as output for battcheck digitalWrite(8,LOW); //see to that pin is low to save power analogReference(INTERNAL); //internal 1.1V reference for battcheck } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER); // Register binary input sensor to sensor_node (they will be created as child devices) // You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage. // If S_LIGHT is used, remember to update variable type you send in. See "msg" above. present(CHILD_ID_1, S_TEMP); present(CHILD_ID_2, S_HUM); present(CHILD_ID_3, S_BARO); } double temperature; double humidity; double pressure; double oldtemperature; double oldhumidity; double oldpressure; unsigned char fail; void loop() { //Each loop, take a reading. //Start with temperature, as that data is needed for accurate compensation. //Reading the temperature updates the compensators of the other functions //in the background. /* Serial.print("Temperature: "); Serial.print(Sensor.readTempC(), 2); Serial.println(" degrees C"); Serial.print("Temperature: "); Serial.print(Sensor.readTempF(), 2); Serial.println(" degrees F"); Serial.print("Pressure: "); Serial.print(Sensor.readFloatPressure(), 2); Serial.println(" Pa"); Serial.print("Altitude: "); Serial.print(Sensor.readFloatAltitudeMeters(), 2); Serial.println("m"); Serial.print("Altitude: "); Serial.print(Sensor.readFloatAltitudeFeet(), 2); Serial.println("ft"); Serial.print("%RH: "); Serial.print(Sensor.readFloatHumidity(), 2); Serial.println(" %"); Serial.println(); delay(1000); */ float batt; digitalWrite(8,HIGH); delay(10); batt=analogRead(0); batt=batt-900; batt=batt/1.23; Serial.print("Batt%: "); Serial.print(batt); digitalWrite(8,LOW); sendBatteryLevel(batt); temperature=Sensor.readTempC(); humidity=Sensor.readFloatHumidity(); pressure=Sensor.readFloatPressure()/100; if(temperature != oldtemperature){ if(!send(msg1.set(temperature,2))){fail++;}; oldtemperature=temperature; } if(humidity != oldhumidity){ if(!send(msg2.set(humidity,2))){fail++;}; oldhumidity=humidity; } if(pressure != oldpressure){ if(!send(msg3.set(pressure,2))){fail++;}; oldpressure=pressure; } if (fail>6){fail=0; Serial.print("Transmit error, Reseting!");soft_restart();} fail=0; sleep(30000);What does the message:
!TSP:SEND:TNR
mean and how do I handle it?
!TSP:SEND:TNR
I have read that thread Before but it doesn't explain what:
!TSP:SEND:TNR => Transport:SEND:Transport Not Ready
really means. What has happend and what needs to be done.
I have corrected my sketch regarding the autoreset of the node. I hope that helps to keep the node communicating.
#include <SoftReset.h> /****************************************************************************** I2C_ReadAllData.ino BME280 Arduino and Teensy example Marshall Taylor @ SparkFun Electronics May 20, 2015 https://github.com/sparkfun/SparkFun_BME280_Arduino_Library This sketch configures the BME280 to read all measurements. The sketch also displays the BME280's physical memory and what the driver perceives the calibration words to be. Resources: Uses Wire.h for I2C operation Uses SPI.h for SPI operation Development environment specifics: Arduino IDE 1.6.4 Teensy loader 1.23 This code is released under the [MIT License](http://opensource.org/licenses/MIT). Please review the LICENSE.md file included with this example. If you have any questions or concerns with licensing, please contact techsupport@sparkfun.com. Distributed as-is; no warranty is given. ******************************************************************************/ #include <stdint.h> #include "SparkFunBME280.h" //Library allows either I2C or SPI, so include both. #include "Wire.h" #include "SPI.h" #define MY_DEBUG #define MY_DEBUG_VERBOSE_RF24 #define MY_RADIO_NRF24 #include <MySensors.h> #define SKETCH_NAME "Min väderstation" #define SKETCH_MAJOR_VER "1" #define SKETCH_MINOR_VER "1" #define CHILD_ID_1 1 #define CHILD_ID_2 2 #define CHILD_ID_3 3 //Global sensor object BME280 Sensor; MyMessage msg1(CHILD_ID_1, V_TEMP); MyMessage msg2(CHILD_ID_2, V_HUM); MyMessage msg3(CHILD_ID_3, V_PRESSURE); void setup() { //***Driver settings********************************// //commInterface can be I2C_MODE or SPI_MODE //specify chipSelectPin using arduino pin names //specify I2C address. Can be 0x77(default) or 0x76 //For I2C, enable the following and disable the SPI section Sensor.settings.commInterface = I2C_MODE; Sensor.settings.I2CAddress = 0x76; //For SPI enable the following and dissable the I2C section //Sensor.settings.commInterface = SPI_MODE; //Sensor.settings.chipSelectPin = 10; //***Operation settings*****************************// //renMode can be: // 0, Sleep mode // 1 or 2, Forced mode // 3, Normal mode Sensor.settings.runMode = 3; //Normal mode //tStandby can be: // 0, 0.5ms // 1, 62.5ms // 2, 125ms // 3, 250ms // 4, 500ms // 5, 1000ms // 6, 10ms // 7, 20ms Sensor.settings.tStandby = 5; //filter can be off or number of FIR coefficients to use: // 0, filter off // 1, coefficients = 2 // 2, coefficients = 4 // 3, coefficients = 8 // 4, coefficients = 16 Sensor.settings.filter = 0; //tempOverSample can be: // 0, skipped // 1 through 5, oversampling *1, *2, *4, *8, *16 respectively Sensor.settings.tempOverSample = 1; //pressOverSample can be: // 0, skipped // 1 through 5, oversampling *1, *2, *4, *8, *16 respectively Sensor.settings.pressOverSample = 1; //humidOverSample can be: // 0, skipped // 1 through 5, oversampling *1, *2, *4, *8, *16 respectively Sensor.settings.humidOverSample = 1; // Serial.begin(57600); Serial.print("Program Started\n"); Serial.print("Starting BME280... result of .begin(): 0x"); //Calling .begin() causes the settings to be loaded delay(10); //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up. Serial.println(Sensor.begin(), HEX); Serial.print("Displaying ID, reset and ctrl regs\n"); Serial.print("ID(0xD0): 0x"); Serial.println(Sensor.readRegister(BME280_CHIP_ID_REG), HEX); Serial.print("Reset register(0xE0): 0x"); Serial.println(Sensor.readRegister(BME280_RST_REG), HEX); Serial.print("ctrl_meas(0xF4): 0x"); Serial.println(Sensor.readRegister(BME280_CTRL_MEAS_REG), HEX); Serial.print("ctrl_hum(0xF2): 0x"); Serial.println(Sensor.readRegister(BME280_CTRL_HUMIDITY_REG), HEX); Serial.print("\n\n"); Serial.print("Displaying all regs\n"); uint8_t memCounter = 0x80; uint8_t tempReadData; for(int rowi = 8; rowi < 16; rowi++ ) { Serial.print("0x"); Serial.print(rowi, HEX); Serial.print("0:"); for(int coli = 0; coli < 16; coli++ ) { tempReadData = Sensor.readRegister(memCounter); Serial.print((tempReadData >> 4) & 0x0F, HEX);//Print first hex nibble Serial.print(tempReadData & 0x0F, HEX);//Print second hex nibble Serial.print(" "); memCounter++; } Serial.print("\n"); } Serial.print("\n\n"); Serial.print("Displaying concatenated calibration words\n"); Serial.print("dig_T1, uint16: "); Serial.println(Sensor.calibration.dig_T1); Serial.print("dig_T2, int16: "); Serial.println(Sensor.calibration.dig_T2); Serial.print("dig_T3, int16: "); Serial.println(Sensor.calibration.dig_T3); Serial.print("dig_P1, uint16: "); Serial.println(Sensor.calibration.dig_P1); Serial.print("dig_P2, int16: "); Serial.println(Sensor.calibration.dig_P2); Serial.print("dig_P3, int16: "); Serial.println(Sensor.calibration.dig_P3); Serial.print("dig_P4, int16: "); Serial.println(Sensor.calibration.dig_P4); Serial.print("dig_P5, int16: "); Serial.println(Sensor.calibration.dig_P5); Serial.print("dig_P6, int16: "); Serial.println(Sensor.calibration.dig_P6); Serial.print("dig_P7, int16: "); Serial.println(Sensor.calibration.dig_P7); Serial.print("dig_P8, int16: "); Serial.println(Sensor.calibration.dig_P8); Serial.print("dig_P9, int16: "); Serial.println(Sensor.calibration.dig_P9); Serial.print("dig_H1, uint8: "); Serial.println(Sensor.calibration.dig_H1); Serial.print("dig_H2, int16: "); Serial.println(Sensor.calibration.dig_H2); Serial.print("dig_H3, uint8: "); Serial.println(Sensor.calibration.dig_H3); Serial.print("dig_H4, int16: "); Serial.println(Sensor.calibration.dig_H4); Serial.print("dig_H5, int16: "); Serial.println(Sensor.calibration.dig_H5); Serial.print("dig_H6, uint8: "); Serial.println(Sensor.calibration.dig_H6); Serial.println(); pinMode(8,OUTPUT); //pin8 as output for battcheck digitalWrite(8,LOW); //see to that pin is low to save power analogReference(INTERNAL); //internal 1.1V reference for battcheck } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER); // Register binary input sensor to sensor_node (they will be created as child devices) // You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage. // If S_LIGHT is used, remember to update variable type you send in. See "msg" above. present(CHILD_ID_1, S_TEMP); present(CHILD_ID_2, S_HUM); present(CHILD_ID_3, S_BARO); } double temperature; double humidity; double pressure; double oldtemperature; double oldhumidity; double oldpressure; unsigned char fail; void loop() { //Each loop, take a reading. //Start with temperature, as that data is needed for accurate compensation. //Reading the temperature updates the compensators of the other functions //in the background. float batt; digitalWrite(8,HIGH); delay(10); batt=analogRead(0); batt=batt-900; batt=batt/1.23; Serial.print("Batt%: "); Serial.println(batt); digitalWrite(8,LOW); sendBatteryLevel(batt); temperature=Sensor.readTempC(); humidity=Sensor.readFloatHumidity(); pressure=Sensor.readFloatPressure()/100; if(temperature != oldtemperature){ if(!send(msg1.set(temperature,2))){fail++;} else{ fail=0;} oldtemperature=temperature; } if(humidity != oldhumidity){ if(!send(msg2.set(humidity,2))){fail++;} else{ fail=0; } oldhumidity=humidity; } if(pressure != oldpressure){ if(!send(msg3.set(pressure,2))){fail++;} else{ fail=0; } oldpressure=pressure; } if (fail>6){fail=0; Serial.print("Transmit error, Reseting!");soft_restart();} Serial.print("Number of errors before reset: "); Serial.println(fail); sleep(30000); } -
I'm having trouble to log the node since it is in a remote place when it stops working.
Can you please explain a little more what you mean with "send the node to sleep before the communication is fully re-established"?
I'm a bit lost in all this it seems. I must have missed someting when reading about sending new values to the controller. But I thought that when the "send()" is executed the program is waiting here until Everything is finished for that transmission and we can move on to the transmission.
Is there something I must do before sending the cpu to sleep?
Sorry for my slow understanding.
@kk02067 If your node is out of range, all uplink messages will fail and after 5 consecutive uplink fails, the node will search for a new parent and try to (re)establish the link to the GW.
If you put your node asleep while the link is being established (last line in loop() ), the node won't reconnect. You can prevent this from happening by substitutingsleep(30000);with
if(isTransportOK()){ sleep(30000); // transport is OK, node can sleep } else { wait(5000); // transport is not operational, allow the transport layer to fix this } -
Ok. Will try something like that.
Is mysensors libraryfunctions interuptdriven? If so I understand why my sketch fails. Is there a complete list of useful functions besides going thru the sourcecode?
Thanks alot for your support.
@kk02067 Haven't played with 2.0 yet. But looked at the Api which doesn't say what the return value of msg means. In your code you presume that the return values of msg states the success of sending the message. I'm however not sure whether msg() is a blocking call. Meaning that the message is immediately send when you call send. It might be queued until MySensors is ready to handle the sending of messages. And in that case it just can't predict whether it might be able to send a msg in the future. If it could, I'd hire the engineer who developed that algorithm. He'd probably make me rich in no time ;-)
If msg is a non-blocking call, than determining whether the msg was successfully by MySensors, by checking the return value of the call to msg doesn't make sense. And you actually disturb the whole resend and connect mechanism by doing a soft restart after 6 consecutive fails.
But then again haven't played with it. But thought this might help. I think I'd would first try to improve the sending range and try to find out what the cause is. Because it might be a hardware problem. And if you can tackle it, it might solve all of your problems.
@kk02067 As @TheoL pointed out, there is no need to reset the node after 6 failed messages, the transport layer takes care of that:
- After 5 consecutive uplink fails, the node search for a new parent (with an established GW-link)
- After 3 unsuccessful find parent attempts, the radio is re-initialised.
Send() returns true if the message was successfully delivered to the next (i.e. parent node), however, this does not imply that the GW/controller received the message.
@tekka Thanks for the info, I will now rework the sketch after this new information.
My understanding of the library grows with every question.
This is so fun. So much to build, so little time.
@tekka wouldn't it be better if the library handled that automatically? The library is so good at taking care of everything else. Or maybe I'm just getting spoiled :)
I have now implemented the changes discussed here. It now seems to work flawlessly. I tested the node to see its behaviour when i powered down the gateway. As it said in the thread the node tried to reconnect after a couple of failed transmissions. And when I powered up the gateway again the node reconnected and started to go to sleep again.
Thanks for the help on this.
A Quick question a bit of topic Before I go build new nodes. If I want to run the cpu at only 1 MHz, do I have to do something else other then define the cpu frequency in the sketch? Is it possible to set the cpuclk prescaler at runtime?
if(isTransportOK()){ sleep(30000); // transport is OK, node can sleep } else { wait(5000); // transport is not operational, allow the transport layer to fix this }@tekka said:
if(isTransportOK()){ sleep(30000); // transport is OK, node can sleep } else { wait(5000); // transport is not operational, allow the transport layer to fix this }I've only just found this post, and these lines of code have me excited! fixes my problem, thank you!
