  2. Announcements
  3. Converting a sketch from 1.5.x to 2.0.x
52 Posts 21 Posters 37.9k Views 26 Watching
    @Maurizio-Collu
    2.0 should work with home assistant, but all new features of 2.0 are not supported yet. WIP.
    Maurizio ColluM
    Maurizio ColluM
    Maurizio Collu
    @martinhjelmare
    Thanks Martin.
    I uploaded the GatewaySerial to the arduino working as gateway, but if I upload the sketch and I open the monitor, I obtain this error:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    What does it mean?
    Maurizio ColluM martinhjelmareM 2 Replies Last reply
    • Maurizio ColluM Maurizio Collu
      @martinhjelmare
      Thanks Martin.
      0;255;3;0;9;TSM:PDT
      What does it mean?
      Maurizio ColluM
      Maurizio ColluM
      Maurizio Collu
      @martinhjelmare
      Plus, when starting home assistant, I get this error
      16-07-26 23:03:44 homeassistant.bootstrap: Error during setup of component mysensors
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 62, in setup_gateway
      socket.inet_aton(device)
      OSError: illegal IP address string passed to inet_aton
      During handling of the above exception, another exception occurred:
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 150, in _setup_component
      if not component.setup(hass, config):
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 109, in setup
      device, persistence_file, baud_rate, tcp_port)
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 73, in setup_gateway
      baud=baud_rate)
      File "/home/pi/.homeassistant/deps/mysensors/mysensors.py", line 326, in init
      persistence_file, protocol_version)
      File "/home/pi/.homeassistant/deps/mysensors/mysensors.py", line 40, in init
      self.const = _const
      UnboundLocalError: local variable '_const' referenced before assignment
        @martinhjelmare
        baud=baud_rate)
        self.const = _const
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        #40
        @Maurizio-Collu
        Regarding the error in home assistant, that's a bug, due to specifying mysensors version other than 1.4 or 1.5. Use 1.5 and you should be fine. The bug is fixed in the dev branch of pymysensors and will be fixed in home assistant when real mysensors 2.0 support is merged. WIP.
        Please post home assistant topics in the home assistant category under controllers. This is off topic in this thread.
          @martinhjelmare
          Thanks Martin.
          0;255;3;0;9;TSM:PDT
          What does it mean?
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Maurizio-Collu said:
          @martinhjelmare
          Thanks Martin.
          0;255;3;0;9;TSM:PDT
          What does it mean?
          @tekka knows this best, and he wrote a post explaining some of those messages here:
          https://forum.mysensors.org/topic/4347/can-t-get-sensors-talking/3
          Maurizio ColluM 1 Reply Last reply
            @martinhjelmare
            Thanks Martin.
            0;255;3;0;9;TSM:PDT
            What does it mean?
            Maurizio ColluM
            Maurizio ColluM
            Maurizio Collu
            @martinhjelmare Thanks a ot.
            Is there any guide/manual where all these messages are explained?
            Plus, is there anywhere written what all these terms mean?
            TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
            Kind Regards
            mfalkviddM tekkaT 2 Replies Last reply
              Kind Regards
              @Maurizio-Collu do you mean except the link martinhjelmare provided?
                Maurizio ColluM
                Maurizio ColluM
                Maurizio Collu
                @mfalkvidd Yes, basically this part (I'm sure it is explained somewhere, but I can't find where)
                SOrry for my newbieness...
                  Kind Regards
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #45
                  @Maurizio-Collu Yes, the doc is in preparation, the meaning of these messages is described here (this is a PR that harmonizes the log message and will be pushed to 2.0.1).
                  In brief:
                  TSP:MSG:SEND refers to message sending function in the transport state machine
                  255-255-0-0 is the routing information, i.e. sender-last-next-destination
                  • s=sensor ID (255 = internal)
                  • c=command (3 = C_INTERNAL)
                  • t=type (3 = I_ID_REQUEST)
                  • pt=payload type (0 = P_STRING)
                  • l=message length (0)
                  • sg=signature flag (0 = not signed)
                  • ft=failed transmission counter (0 = no failed uplink transmission at this* oint)
                  • st=send status (OK)
                  • : actual message (empty)
                  => Your node has no assigned ID (=255) and is requesting a new ID from the controller.
                  Please refer to the serial protocol or API for additional information.
                  Good luck!
                  • pndgt0P
                    pndgt0P
                    pndgt0
                    I was trying to implement the irrigation controller but realized that was not migrated to MySensors 2.0.
                    I followed the instructions provided in the first post and arrived to a version that compiles with no errors. Nonetheless, as I am newbie, I would appreciate if someone could review some changes that I am not sure about. Those changes are related with the original sketch which has direct calls to process() in several while statements. First I tried to change the process() with _process() but several errors appeared, so finally I removed all the calls to process() but am not sure. I have the modified code here IrrigationController.ino in which I commented the lines added / deleted / modified. Any help / direction would be greatly appreciated.
                    Boots33B 1 Reply Last reply
                    • pndgt0P pndgt0
                      Boots33B
                      Boots33B
                      Boots33
                      @pndgt0
                      The sketches that require external libraries are not included in the V2 install anymore but they are available here in the new V2 format. You will find the irrigation sketch there.
                      pndgt0P 1 Reply Last reply
                      • Boots33B Boots33
                        @pndgt0
                        pndgt0P
                        pndgt0P
                        pndgt0
                        @Boots33 Great! Thank you for the quick response and the URL. I took that version. Just wanted to let you know that to successfully compile it was needed to remove the #include <LiquidCrystal.h> and probably an update to that sketch would be needed at Github respository.
                        Thank you again!
                        • pndgt0P pndgt0
                          Thank you again!
                          Boots33B
                          Boots33B
                          Boots33
                          @pndgt0 That may be because you do not have the LiquidCrystal library installed. They have the external libraries there as well
                          • paqorP
                            paqorP
                            paqor
                            • siodS
                              siodS
                              siod
                              wrote on last edited by siod
                              #51
                              I built a 2.0 MQTT gateway and am experimenting with a sensor using 1.5 library. I can see incoming data in the serial monitor, but the data is a bit different then when I was using the 1.5 MQTT gateway. In openhab I used this:
                              {mqtt="<[mysensor:MyMQTT/3/2/1/V_TRIPPED:state:CLOSED:1],<[mysensor:MyMQTT/3/2/1/V_TRIPPED:state:OPEN:0]"}
                              But now I must skip the V_Tripped part to make it work like this:
                              {mqtt="<[mysensor:mygateway1-out/3/2/1/0/16:state:OPEN:1],<[mysensor:mygateway1-out/3/2/1/0/16:state:CLOSED:0]"}
                              Is this how it is supposed to be or do I have to make the sensor node 2.0 compatible first? I thought the payload is saved in the V_TRIPPED variable, but it doesn´t seem to work in the new 2.0 library. Pls advise-
                              edit:
                              Ok, digged a bit deeper: if I understand it right, I don´t need "V_TRIPPED" or any other value in my controllers code (which is openhab actually) anymore but still in my sensor node code of course. So the gateway will transform "V_Tripped" into sub-typ "16". Correct? So all I´ll have to change is my openhab code, right?
                              still learning...
                              • siodS siod
                                edit:
                                @siod correct. The conversion of value code to text has been removed in the 2.0.0 implementation, so now the raw values codes are reported in the topic.
