  3. MyController.org
  4. MyController 0.0.3.Alpha2 released!! :)
Scheduled Pinned Locked Moved MyController.org
new-releasemycontroller.orgcontrollertopologyinfluxdb
17 Posts 7 Posters 8.0k Views 7 Watching
  • DidiD
    DidiD
    Didi
    Good work :+1:
    • F
      F
      Fabien
      I'm trying the demo and I think it will be my next controller !
      • F
        F
        Fabien
        After quick read the doc. I have few question. I use serial gateway and is it possible to publish sensors data to an external MQTT server ? And Is it possible to import MQTT topic and use it in scripts.
        Actually I have for example milight bulbs or Kodi connected to my MQTT broker.
        Another question : OTA will work with sleeping node ? When node wake up (and correctly configured) is it possible to send new firmware ?
        Finally, an update would be fine to select node in list and sensors too to send raw data.
        J 1 Reply Last reply
        • cimba007C
          cimba007C
          cimba007
          wrote on last edited by cimba007
          Just a quick test. "GatewayESP8266MQTTClient" on mosquitto mqtt-server works fine. I currently have only one test-node but it is successfully detected and all sensors on this node are listed fine!
          One thing I noticed is somewhat unclear to me. If some rules tripp an action. e.g. "Send a mail" .. is there a way to specify how often this should happen? I see an option to completely disable the rule after one time trigger but it would be nice to have a way to reset this.
          e.g.
          1. rule is triggered
          2. mail is send
          3. rule is disable
          4. after configurable time elapsed (1 hour?) the rule is automatically reenabled
          This would prevent spam in case of broken sensor or unintended triggers.
          To clarify: I have noticed the dampening feature .. but this might still not be enough. My case is when a sensor goes rogue for whatever reason .. and I send a notification to my work email address. Under NO NO circumstances the email should be send multiple time and I don't want to reenable the rule after triggering.
          PS: Very well done. I like the webpage and the overall user experience.
          Addition: The Values from my sensors are not auto refreshed in the dashboard and Resources->Sensors. Would be really nice to be able to refresh these values constantly (configurable) to get an even better "live" user experience.
          Noticed the widget refresh interval is configurable. Nice!
          • cimba007C cimba007
            e.g.
            2. mail is send
            3. rule is disable
            J
            J
            jkandasa
            @cimba007 This is good feature request! I can implement this one.
            For now we have workaround for this option.
            Create a rule for your sensor with auto disable option.
            Create a simple timer with one hour interval (3600 seconds) and repeat count as 1
            • Create the following operations,
            1. Send email for your work email
            2. Enable your rule
            3. Enable your timer
            Now map operations like mentioned here,
            • In the Rule select Operation's, 1 and 3
            • In the timer select Operation 2
            cimba007C F 2 Replies Last reply
            • F Fabien
              J
              J
              jkandasa
              wrote on last edited by jkandasa
              For now it supports only for InfluxDB, emoncms.org and sparkfun. Please create a feature request to support MQTT. Please note this one way communication, it means pushes data to external server. Not listening from external servers.
              EDIT: MQTT external server support added at https://github.com/mycontroller-org/mycontroller/commit/9c179f9f88022fd5e7cee782c884f4c9bc38fcea
              For these kind of things we have to add gateway support. If we have support in gateway for these devices we can control these device as like normal MySensors device. Please create a feature request with these device documentations with API details, I will add it when I get time.
              For now MyController doesn't support for sleeping nodes.
              I'm sorry I could not get this one?
              • J jkandasa
                2. Enable your rule
                cimba007C
                cimba007C
                cimba007
                @jkandasa said:
                Enable your rule
                Looking at operations I see only operations to send notifications and no operation to enable/disable a rule? Might the functionality I am looking for hidden in the "scripting" part? If so I could not find any documentation of the scripting stuff.
                PS: Found the documentation, slightly hidden on the download page.
                PPS: Found it, "send payload" might not be too intuitive to find operations to manipulate rules ;_)
                Do I even need a timer? Looks like this simple rule might fulfill my needs:
                0_1470241804296_upload-e889ed01-09fc-4ca5-91ea-2b1a494ceece
                  @jkandasa said:
                  Enable your rule
                  J
                  J
                  jkandasa
                  @cimba007
                  Name it we may change it on next release, If the current name confuses.
                  Yes, I forgot this delay field, This simple rule is enough for you. You can map this operation also along with your Rule definition. This delay is in seconds.
                  cimba007C 1 Reply Last reply
                    mvader
                    how can i reset the login and password.
                    no matter what i do i get "invalid username and password"
                    I've tried admin/admin a million times
                    • M mvader
                      J
                      J
                      jkandasa
                      I'm sorry, for now we do not have direct way to reset password.
                      We have a workaround to reset password by accessing database directly. I know this is not a good solution :( I will try to give new option to reset password in friendly manner.
                      To reset admin password,
                      Note: First you have to STOP(mycontroller/bin/stop.sh) MyController server
                      Download and extract http://www.h2database.com/h2-2014-04-05.zip in to your raspberry PI.
                      java -cp h2/bin/h2*.jar org.h2.tools.Shell
                      URL       jdbc:h2:/opt/mycontroller/conf/mycontroller
                      Driver    org.h2.Driver
                      User      mycontroller
                      Password  mycontroller
                      Set your path exactly with the above command.
                      Update user admin password UPDATE USER SET PASSWORD='Wm1vE8jvQXE=' WHERE USERNAME='admin';
                      Note: In database passwords are encrypted. for admin encrypted string is Wm1vE8jvQXE.
                      You can also check admin with default password by running SELECT * FROM USER;
                      EDIT: created new ticket: https://github.com/mycontroller-org/mycontroller/issues/233
                      • J jkandasa
                        @cimba007
                        cimba007C
                        cimba007C
                        cimba007
                        @jkandasa
                        Just a suggestion: 0_1470305410775_upload-6bf4a0ed-44a8-42cb-9161-864003de09b5
                        Send notification would include all further kinds of notifications you might include but grouping this is not that important. The current way it is is already very easy to understand so a change might not be necessary.
                        Send payload might be better split into three different points as it would be very clear from the beginning what you are dealing with.
                        • Dealing with Resources (manipulating stuff that is only known to the controller )
                        • Manipulating Devices (reboot etc. .. this is more like a "command")
                        • Update Sensor variables is an 1:1 mapping of the request/set concept of mysensors
                        • J jkandasa
                          User      mycontroller
                          mvader
                          @jkandasa
                          Thanks for the info. I'm not sure what was wrong. when i looked at my password, it was the encrypted one you posted above.
                          i ended up just removing everything and copying up the files from scratch. and it's working now.
                          thanks!!
                            @jkandasa
                            J
                            J
                            jkandasa
                            @cimba007 Thank you! I have created a ticket to track this one, https://github.com/mycontroller-org/mycontroller/issues/235
                            • J jkandasa
                              2. Enable your rule
                              F
                              F
                              Fabien
                              wrote on last edited by Fabien
                              @jkandasa
                              Thank you for the update. I will use this controller in production in few days. Eactly what I want. For non-msensors devices I Will use node-red as glue !
