  3. MySensors.h error when compiling: "No forward link or gateway feature activated"
12 Posts 5 Posters 5.3k Views 4 Watching
  • chippey5C Offline
    chippey5C Offline
    chippey5
    Hi!
    I am trying to make my first DS18B20 sensor with MySensors and trying the example found here. When compiling I get the error message:
    Even after trying to configuring MySensors.h by defining the hardware I use (with my logic thinking) in the file. The hardware I'm using at the moment is:
    • Arduino Mini Pro
    • NRF24 tranceiver
    • DS18B20
    Below is the code I am using in MySensors.h. Search for #error to find the failsafe code part.
     * @file MySensors.h
     * MySensors main interface (includes all necessary code for the library)
    #ifndef MySensors_h
    #define MySensors_h
    #include "core/MySensorsCore.h"
    // Detect node type
     * @def MY_GATEWAY_SERIAL
     * @brief Is set for gateway sketches.
     * @def MY_IS_GATEWAY
     * @brief Is true when @ref MY_GATEWAY_SERIAL is set.
       @def MY_NODE_TYPE
       @brief Contain a string describing the class of sketch/node (gateway/repeater/sensor).
    #if defined(MY_GATEWAY_SERIAL) || defined(MY_GATEWAY_W5100) || defined(MY_GATEWAY_ENC28J60) || defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_MQTT_CLIENT)
    	#define MY_GATEWAY_SERIAL
    	#define MY_IS_GATEWAY (false)
    	#define MY_NODE_TYPE "gateway"
    #elif defined(MY_REPEATER_FEATURE)
    	#define MY_NODE_TYPE "repeater"
    	#define MY_IS_GATEWAY (true)
    	#define MY_NODE_TYPE "sensor"
    // Enable radio "feature" if one of the radio types was enabled
    #if defined(MY_RADIO_NRF24) || defined(MY_RADIO_RFM69) || defined(MY_RS485)
    // HARDWARE
    	// Remove PSTR macros from debug prints
    	#undef PSTR
    	#define PSTR(x) (x)
    	//#undef F
    	//#define F(x) (x)
    	#include "core/MyHwESP8266.cpp"
    #elif defined(ARDUINO_ARCH_AVR)
    	#include "core/MyHwATMega328.cpp"
            #include "core/MyHwSAMD.cpp"
    // INCLUSION MODE
    #if defined(MY_INCLUSION_MODE_FEATURE)
    	#include "core/MyInclusionMode.cpp"
    // SIGNING
    #if defined(MY_SIGNING_ATSHA204) || defined(MY_SIGNING_SOFT)
    	#define MY_SIGNING_SOFT
    #include "core/MySigning.cpp"
    #include "drivers/ATSHA204/sha256.cpp"
    #if defined(MY_SIGNING_FEATURE)
    	// SIGNING COMMON FUNCTIONS
    	#if defined(MY_SIGNING_ATSHA204) && defined(MY_SIGNING_SOFT)
    		#error Only one signing engine can be activated
    		#include "core/MySigningAtsha204.cpp"
    		#include "drivers/ATSHA204/ATSHA204.cpp"
    	#elif defined(MY_SIGNING_SOFT)
    		#include "core/MySigningAtsha204Soft.cpp"
    // FLASH
    #if defined(MY_OTA_FIRMWARE_FEATURE)
    	#include "drivers/SPIFlash/SPIFlash.cpp"
    	#include "core/MyOTAFirmwareUpdate.cpp"
    // GATEWAY - TRANSPORT
    #if defined(MY_GATEWAY_MQTT_CLIENT)
    		// We assume that a gateway having a radio also should act as repeater
    		#define MY_REPEATER_FEATURE
    	// GATEWAY - COMMON FUNCTIONS
    	// We only support MQTT Client using W5100 and ESP8266 at the moment
    	#if !(defined(MY_CONTROLLER_URL_ADDRESS) || defined(MY_CONTROLLER_IP_ADDRESS))
    		#error You must specify MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS
    	#if !defined(MY_MQTT_PUBLISH_TOPIC_PREFIX)
    		#error You must specify a topic publish prefix MY_MQTT_PUBLISH_TOPIC_PREFIX for this MQTT client
    	#if !defined(MY_MQTT_SUBSCRIBE_TOPIC_PREFIX)
    		#error You must specify a topic subscribe prefix MY_MQTT_SUBSCRIBE_TOPIC_PREFIX for this MQTT client
    	#if !defined(MY_MQTT_CLIENT_ID)
    		#error You must define a unique MY_MQTT_CLIENT_ID for this MQTT client
    	#include "drivers/PubSubClient/PubSubClient.cpp"
    	#include "core/MyGatewayTransport.cpp"
    	#include "core/MyGatewayTransportMQTTClient.cpp"
    #elif defined(MY_GATEWAY_SERIAL)
    	// We currently only support one protocol at the moment, enable it.
    	#include "core/MyProtocolMySensors.cpp"
    	// GATEWAY - CONFIGURATION
    	#if defined(MY_CONTROLLER_IP_ADDRESS)
    		#define MY_GATEWAY_CLIENT_MODE
    	#if !defined(MY_PORT)
    		#error You must define MY_PORT (controller or gatway port to open)
    	#if defined(MY_GATEWAY_ESP8266)
    		// GATEWAY - ESP8266
    		#include "core/MyGatewayTransportEthernet.cpp"
    	#elif defined(MY_GATEWAY_W5100)
    		// GATEWAY - W5100
    	#elif defined(MY_GATEWAY_ENC28J60)
    		// GATEWAY - ENC28J60
    		#if defined(MY_USE_UDP)
    			#error UDP mode is not available for ENC28J60
    		// GATEWAY - SERIAL
    		#include "core/MyGatewayTransportSerial.cpp"
    // RADIO
    	// SOFTSPI
    	#ifdef MY_SOFTSPI
    			#error Soft SPI is not available on ESP8266
    		#include "drivers/AVR/DigitalIO/DigitalIO.h"
    	#include "core/MyTransport.cpp"
    	#if (defined(MY_RADIO_NRF24) && defined(MY_RADIO_RFM69)) || (defined(MY_RADIO_NRF24) && defined(MY_RS485)) || (defined(MY_RADIO_RFM69) && defined(MY_RS485))
    		#error Only one forward link driver can be activated
    		#if defined(MY_RF24_ENABLE_ENCRYPTION)
    			#include "drivers/AES/AES.cpp"
    		#include "drivers/RF24/RF24.cpp"
    		#include "core/MyTransportNRF24.cpp"
    	#elif defined(MY_RS485)
    		#include "drivers/AltSoftSerial/AltSoftSerial.cpp"
    		#include "core/MyTransportRS485.cpp"
    	#elif defined(MY_RADIO_RFM69)
    		#include "drivers/RFM69/RFM69.cpp"
    		#include "core/MyTransportRFM69.cpp"
    // Make sure to disable child features when parent feature is disabled
    #if !defined(MY_RADIO_NRF24)
    	#undef MY_OTA_FIRMWARE_FEATURE
    	#undef MY_REPEATER_FEATURE
    	#undef MY_SIGNING_NODE_WHITELISTING
    	#undef MY_SIGNING_FEATURE
    #if !defined(MY_GATEWAY_SERIAL)
    	#undef MY_INCLUSION_MODE_FEATURE
    #if !defined(MY_CORE_ONLY)
    	#if !defined(MY_GATEWAY_FEATURE) && !defined(MY_RADIO_FEATURE)
    		#error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    #include "core/MyCapabilities.h"
    #include "core/MyMessage.cpp"
    #include "core/MySensorsCore.cpp"
    #include <Arduino.h>
    		#include "core/MyMainESP8266.cpp"
    		#include "core/MyMainDefault.cpp"
    #if DOXYGEN
    I am greatful for any help
    • chippey5C chippey5
      Hi!
      • Arduino Mini Pro
      • NRF24 tranceiver
      • DS18B20
       * @file MySensors.h
      #ifndef MySensors_h
      #define MySensors_h
      // Detect node type
         @def MY_NODE_TYPE
      // HARDWARE
      	#undef PSTR
      	#define PSTR(x) (x)
      	//#undef F
      	//#define F(x) (x)
      // INCLUSION MODE
      // SIGNING
      // FLASH
      		// GATEWAY - W5100
      		// GATEWAY - SERIAL
      // RADIO
      	// SOFTSPI
      	#ifdef MY_SOFTSPI
      #if DOXYGEN
      @chippey5 use the example provided with the library instead (open in the Arduino IDE). The examples at mysensors.org are for version 1.5 and you are using version 2.0 of the library.
      chippey5C 1 Reply Last reply
        chippey5C Offline
        chippey5C Offline
        chippey5
        @mfalkvidd Thanks for your reply!
        I can't find the example including "Temp" nor DS18B20 in the example folder. Is it called something else? Thanks in advance
          @chippey5 oh, sorry about that. All examples that require external libraries (like the DallasTemperature library) now need to be downloaded separately. https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
          • chippey5C Offline
            chippey5C Offline
            chippey5
            Splendid, that did the trick! I received the good ol' millisWaitForConversion error, but using the "DallasTemperature" library included in the Github link fixed the problem.
            Thanks a bunch!
            mfalkviddM ninkasiN 2 Replies Last reply
              Thanks a bunch!
              Great @chippey5 ! Thanks for reporting back.
                Thanks a bunch!
                ninkasiN Offline
                ninkasiN Offline
                ninkasi
                Thanks for the suggestions @mfalkvidd, and @chippey5 - thanks for the update - I had exactly the same issue, and could not work out why I was getting that 'millisWait' error. All good now!
                • TheoLT Offline
                  TheoLT Offline
                  TheoL
                  Just adding this for people who come here by looking for the error "No forward link or gateway feature activated". Since you've to configure MySensors 2.0 before you include the library. You'll need to configure the radio you're using.
                  I got this message when I didn't. So just for people who queury for the same error message. Configure you're radio and other options before you include the library. @mfalkvidd do we have a topic with MySensors 2.0 troubleshooting? Might be handy to put this one. I came across this one when I was teaching my colleagues tonight. Not a biggy, put took me a while to sort it out.
                   * Set configuration options for MySensors
                  #define MY_DEBUG // uncomment when compiling for production
                   * Include necessary libraries
                  #include <MySensors.h> // include MySensors library
                  #include <SPI.h>       // include SPI needed for the MySensors Radio
                  • TheoLT TheoL
                    chippey5C Offline
                    chippey5C Offline
                    chippey5
                    wrote on last edited by chippey5
                    @TheoL Bump. That's exactly where I'm stuck at the moment. A link here to the future thread would be awesome for other users encountering the same issue
                    • Nca78N Offline
                      Nca78N Offline
                      wrote on last edited by Nca78
                      What about changing the message text also ? I guess the programmers get it quickly, but for the common folk this message is a bit cryptic ;)
                      What about changing "#error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless."
                      to something like :
                      "#error No forward link or gateway feature activated. Please define radio type (ex: #define MY_RADIO_NRF24) or gateway type (ex: #define MY_GATEWAY_SERIAL) at the beginning of your sketch" ?
                      TheoLT 1 Reply Last reply
                      • Nca78N Nca78
                        to something like :
                        TheoLT Offline
                        TheoLT Offline
                        TheoL
                        @Nca78 Good suggestion. But I'm not sure if the reason for this error is always missing configuration. That's something @hek might know more about.
                        Nca78N 1 Reply Last reply
                        • TheoLT TheoL
                          Nca78N Offline
                          Nca78N Offline
                          @TheoL it is.
                          When you define a radio, it defines MY_RADIO_FEATURE
                          	#define MY_RADIO_FEATURE
                          Same thing when you define a gateway :
                          	#define MY_GATEWAY_FEATURE
                          Then at the end if MY_RADIO_FEATURE and MY_GATEWAY_FEATURE are not defined it generates this compilation error
                          11.8k
                          113.2k
