  3. Duplicate Child ID 0
6 Posts 2 Posters 1.8k Views 2 Watching
  • T Offline
    T Offline
    Tris
    Im hoping there is a simple fix, ive gone through the forum for over a week and cant believe no-one else has experienced the same issue.
    I have multiple sensors on a node that all report as Child ID 0, not what i'd like. We are supposed to have different child id for each sensor.
    There are different types of sensors (so topics are different) so the readings go through MQTT ok and even read and sent by openhab ok, but i know its not how its meant to be.
    This is from serial monitor (with added sensor type comment)
    TSP:MSG:SEND 9-9-0-0 s=0,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=ok:1 SWITCHES
    TSP:MSG:SEND 9-9-0-0 s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=ok:1 SWITCHES
    TSP:MSG:SEND 9-9-0-0 s=2,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=ok:1 SWITCHES
    TSP:MSG:SEND 9-9-0-0 s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=ok:1 SWITCHES
    TSP:MSG:SEND 9-9-0-0 s=4,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=ok:1 SWITCHES
    TSP:MSG:SEND 9-9-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.4 DALLAS
    TSP:MSG:SEND 9-9-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.2 DALLAS
    TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:64.7 DHT HUMID
    TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.5 DHT TEMP
    TSP:MSG:SEND 9-9-0-0 s=40,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok: LIGHT LEVEL
    TSP:MSG:SEND 9-9-0-0 s=45,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok: UV FLAME LIGHT
    TSP:MSG:SEND 9-9-0-0 s=50,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=ok: POWER WATT
    TSP:MSG:SEND 9-9-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok: RELAYS x8
    TSP:MSG:SEND 9-9-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 9-9-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 9-9-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 9-9-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 9-9-0-0 s=6,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 9-9-0-0 s=7,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 9-9-0-0 s=8,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    As you can see, for example there are duplicates of s=0, s-1 etc
    I have used sketches that allow multiple relays/dallas/swicthes and the first child id of each set of sensors is 0, so i have many id 0, 1, 2, 3 etc as its seems the child id is being auto generated.
    I think its something to do with these lines but i have changed i=0 or sensors=0 to say =60 and when i upload child id 60 isnt showing in serial monitor.
    for (int i = 0; i < NUMBER_OF_SWITCHES; i++)
    Anyone have any ideas?
    • T Offline
      T Offline
      Tris
      wrote on last edited by Tris
      • T Offline
        T Offline
        Tris
        [code]
        • Mysensors node talks to mqtt ethernet gateway client
        • dht 1 (2 VALUES)
        • relays 8
        • light level 1
        • uv flame level 1
        • energy 1
        • servo speed 4
        • dallas 2
        • switches 4
        #define MY_NODE_ID 9
        // Enable debug prints
        #include <VarSpeedServo.h>
        #include <DallasTemperature.h> // For Dallas temp sensor
        #include <OneWire.h> // For Dallas temp sensor
        #define CHILD_ID_HUM 10
        #define CHILD_ID_TEMP 11
        #define HUMIDITY_SENSOR_DIGITAL_PIN 48
        #define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
        unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
        #define RELAY_1 22 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define NUMBER_OF_RELAYS 8 // Total number of attached relays
        #define RELAY_ON 0 // GPIO value to write to turn on attached relay
        #define CHILD_ID_LIGHT 40
        #define CHILD_ID_FLAME 45
        #define FLAME_SENSOR_ANALOG_PIN 1
        #define ONE_WIRE_BUS 49 // DALLAS pin
        #define MAX_ATTACHED_DS18B20 2 // DALLAS max nr. of sensors
        #include <EmonLib.h> // Include Emon Library
        EnergyMonitor emon1; // Create an instance
        #define CHILD_ID_ENERGY 50 //Current Sense Pin
        #define NUMBER_OF_SWITCHES 5
        Bounce debouncer[NUMBER_OF_SWITCHES];
        int oldValue[NUMBER_OF_SWITCHES];
        byte switchPin[NUMBER_OF_SWITCHES] = {34,35,36,37,38}; //<<<<<<<<<<< set your switch pins here
        unsigned long lastSend;
        unsigned long SEND_FREQUENCY = 10000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
        // Store variables
        //long previousMillis = 0; // last time the sensors are updated
        long sensorInterval = 20000; // interval at which we will take a measurement ( 5 seconds)
        int lastLightLevel; // Holds last light level
        int lastFlameLevel; // Holds last FLAME level
        float lastTemperature[MAX_ATTACHED_DS18B20]; // Holds DALLAS temperatures
        int numSensors=0; // Holds number of sensors
        //boolean metric = true; // Celcius or fahrenheid
        int calibrationTime = 30; // the time we give the sensor to calibrate (10-60 secs according to the datasheet)
        const int NBR_SERVOS = 4; // the number of servos
        VarSpeedServo Servos[NBR_SERVOS]; // servo objects
        int servoPins[NBR_SERVOS] = {44, 45, 6, 5}; // servo pins
        int servoSpeeds[NBR_SERVOS] = {5, 10, 100, 255}; // sweep speed, 1 is slowest, 255 fastest)
        int servoMinPosition[NBR_SERVOS] = {45, 20, 30, 40}; // the minumum servo angle
        int servoMaxPosition[NBR_SERVOS] = {135, 130, 140, 150};
        // Initialize dallas
        DHT dht(HUMIDITY_SENSOR_DIGITAL_PIN, DHTTYPE);
        float lastTemp;
        float lastHum;
        MyMessage msgLLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
        MyMessage msgFLight(CHILD_ID_FLAME, V_LIGHT_LEVEL);
        MyMessage msgDallas(ONE_WIRE_BUS,V_TEMP);
        MyMessage IrmsMsg(CHILD_ID_ENERGY,V_WATT);
        MyMessage msgDoor(0,V_TRIPPED);
        pinMode(switchPin[i],INPUT_PULLUP);
        debouncer[i] = Bounce();
        debouncer[i].attach(switchPin[i]);
        debouncer[i].interval(5);
        present(i, S_DOOR);
        delay(250);
        for(int i=0; i < NBR_SERVOS; i++)
        Servos[i].attach(servoPins[i]);
        Servos[i].slowmove(servoMinPosition[i],servoSpeeds[i]) ; // start sweeping from min position
        dht.begin();
        pinMode(pin, OUTPUT);
        sensors.begin();
        present(i, S_TEMP);
        sendSketchInfo("Terrace", "Garden");
        present(CHILD_ID_HUM, S_HUM);
        present(CHILD_ID_FLAME, S_LIGHT_LEVEL);
        present(CHILD_ID_ENERGY, S_POWER);
        present(sensor, S_LIGHT);
        emon1.current(A2, 29.0); // Current: input pin, calibration.
        ///INSTANST READINGS/COMMANDS SECTION
        debouncer[i].update();
        if (value != oldValue[i])
        send(msgDoor.setSensor(i).set(value == HIGH? true : false), false);
        oldValue[i] = value;
        // sweep the servos
        if( Servos[i].read() == servoMinPosition[i])
        Servos[i].slowmove(servoMaxPosition[i],servoSpeeds[i]) ;
        else if( Servos[i].read() == servoMaxPosition[i])
        ///START LONG INTERVAL READINGS ONLY
        boolean needRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
        if (needRefresh)
        lastRefreshTime = millis();
              float temperature = dht.readTemperature();
              if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              Serial.print("Temperature: ");
           // dht readings
              float humidity = dht.readHumidity();
              if (isnan(humidity)) {
              else if (humidity != lastHum) {
              lastHum = humidity;
              Serial.print("Humidity: ");
              Serial.println(humidity);
           // light level
              int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
              Serial.print("Light Percentage: ");
              Serial.println(lightLevel);
              send(msgLLight.set(lightLevel));
              lastLightLevel = lightLevel;
           // flame level
              int flameLevel = (1023-analogRead(FLAME_SENSOR_ANALOG_PIN))/10.23;
              Serial.print("Flame Percentage: ");
              Serial.println(flameLevel);
              if (flameLevel != lastFlameLevel) {
              send(msgFLight.set(flameLevel));
              lastFlameLevel = flameLevel;
              unsigned long now = millis();
              double Irms = emon1.calcIrms(1480);  // Calculate Irms only
              if (sendTime) {
              send(IrmsMsg.set((Irms*232.0), 1));
              Serial.print("Watt: ");
              Serial.println(Irms*232.0);
           // send(kWhMsg.set((Irms*232.0)/1000, 1));
           // Serial.print("kWH: ");
           // Serial.println((Irms*232.0)/1000);
              lastSend = now;
           // Begin dallas temperature
              float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
              Serial.print("Dallas ");
              Serial.print(i);
              Serial.print(" ");
              if (lastTemperature[i] != temperature && temperature != -127.00) {
              send(msgDallas.setSensor(i).set(temperature,1));
            // End dallas temperarures
        // END LONG READ/SAMPLE INTERVAL
        if (message.type==V_STATUS) {
        // Change relay state
        // Store state in eeprom
        [/code]
        • T Tris
          [code]
          • dht 1 (2 VALUES)
          • relays 8
          • light level 1
          • uv flame level 1
          • energy 1
          • servo speed 4
          • dallas 2
          • switches 4
          // Store variables
          float lastTemp;
          float lastHum;
          present(i, S_DOOR);
          delay(250);
          dht.begin();
          sensors.begin();
          present(i, S_TEMP);
          // sweep the servos
          if (needRefresh)
                if (!metric) {
             // dht readings
                lastHum = humidity;
             // light level
             // flame level
                if (sendTime) {
                lastSend = now;
                Serial.print(i);
                Serial.print(" ");
          [/code]
          Welcome to the MySensors community @Tris !
          Code is marked as code by three backticks (`) or just press the code button (</>) on the toolbar. It is possible to edit previous posts by clicking on the three dots in the lower right corner of the post.
          You are on the right track with solving the problem. Each loop starts over at 0 and that makes it re-use the same IDs. You need to do something like this for the second and third loop, change
          present(i, S_TEMP);
          to
          present(NUMBER_OF_SWITCHES + i, S_TEMP);
          You will also have to define all CHILD_ID_xxx to be outside of the numbers used by the for loops.
          I would not want to manage so many sensors on a single node though. The wires and the code will be a mess. If you can, consider using a few different Arduinos to make each sketch simpler. A complex sketch will be harder to troubleshoot.
          • T Offline
            T Offline
            Tris
            Thanks @mfalkvidd, im very grateful!
            I am confident handling the hardware of that many sensors on a Mega, and I cut and paste all the code in small increments, and by doing so, learnt how most of it works - so its reasonably manageable....
            I have another Mega handling the more intricate code/sensors like gas/smoke so i would really like to keep this Arduino to the big amount of simple sensors.
            Im now stuck on adding the relays, to the switches and dallas that you combined -which resulted in unique, sequential sensors ID's..
            How do i add
            to this
            Ive tried every combination i can think of, but everything ive done either duplicates sets of sensors or ignores them!
            Any pointers would be great
            • T Tris
              How do i add
              to this
              @Tris I think this would work:
              present(sensor + MAX_ATTACHED_DS18B2 + NUMBER_OF_SWITCHES, S_LIGHT);
              11.9k
              113.3k
