  3. Radio stop emitting after a few hours...
8 Posts 3 Posters 3.0k Views 3 Watching
  • ybycodeY Offline
    ybycodeY Offline
    ybycode
    I replaced the thermostat of my old fridge by an sensor made of arduino nano + nrf24l01+ DS18B20 temp sensor + relay.
    And it works great. Except that after a few hours, and although the temperature control works ok, the sensor stops emitting to the controller.
    If I reset the arduino the radio communication is good again, and then a few hours later, same thing, it does't send anything (no messages appear in the log of the controller).
    In the meantime I added a 47µF capacitor on the radio, but it didn't help.
    The arduino is not on battery..
    Today when I saw the radio didn't send data anymore I plugged the serial, and here's what I read (the T:X.XX comp:1 are the temperature and the boolean indicating if the compressor is on or off):
    T:6.70 comp:1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    T:6.70 comp:1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    T:6.70 comp:1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    T:6.70 comp:1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    T:6.60 comp:1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    T:6.60 comp:1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    T:6.60 comp:1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    T:6.50 comp:1
    TSM:FPAR
    TSP:MSG:SEND 142-142-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    T:6.50 comp:1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    Reading a bit of the MySensors source code I understood that TNR means "Transport Not Ready", but... why ?
    In any case, here's the sketch I'm using:
    #include <OneWire.h>
    #include "FridgeThermostat.h"
    #define SLEEP_TIME 30000 // Sleep time between reads (in milliseconds)
    #define GPIO_THERMOSTAT 8
    #define TEMP_LOW 5.0
    #define TEMP_HIGH 6.0
    #define NB_HOT_READS_NO_ACTION 1
    MyMessage msg(0, V_TEMP);
    MyMessage msgCompressorStatus(1, V_STATUS);
    FridgeThermostat thermostat(GPIO_THERMOSTAT, TEMP_LOW, TEMP_HIGH, NB_HOT_READS_NO_ACTION);
    int16_t conversionTime;
    void presentation()  {
      sendSketchInfo("Fridge thermostat", "0.4");
      present(0, S_TEMP, "Temperature");
      present(1, S_BINARY, "Compressor on/off");
      sensors.begin();
      conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
      // sleep until conversion completed
      sleep(conversionTime);
      float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(0):sensors.getTempFByIndex(0)) * 10.)) / 10.;
      // Send in the temperature to the controller even if error, to have a clue
      // something goes wrong:
      send(msg.set(temperature,1));
      boolean compressorIsOn;
      // Only tell the thermostat if no error:
        compressorIsOn = thermostat.act(temperature);
        send(msgCompressorStatus.set(compressorIsOn));
      Serial.print("T:");
      Serial.print(temperature);
      Serial.print(" comp:");
      Serial.println(compressorIsOn);
      sleep(SLEEP_TIME);
    Any help appreciated !
    Yann
    TheoLT 1 Reply Last reply
    • ybycodeY ybycode
      T:6.70 comp:1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      T:6.70 comp:1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      T:6.70 comp:1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      T:6.70 comp:1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      T:6.60 comp:1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      T:6.60 comp:1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      T:6.60 comp:1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      T:6.50 comp:1
      TSM:FPAR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      T:6.50 comp:1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
        sensors.begin();
        Serial.print("T:");
        sleep(SLEEP_TIME);
      Yann
      TheoLT Offline
      TheoLT Offline
      TheoL
      wrote on last edited by TheoL
      @ybycode I'll see if I can find strange things in your sketch later on. But most of these problems are power related. And I know that sounds fuzzy ;-). At least for me in the beginning. But in the end, it's 90% of the cause.
      1. How do you power the radio? Directly from the radio?
      2. Did you try an other radio? Radio might be defect
      edit. I don't see anything strange in your code.
      • ybycodeY Offline
        ybycodeY Offline
        ybycode
        The whole is powered with a 5V 1A power supply from an old phone, connected to the USB port of the arduino nano. The radio module is powered by the VCC port of teh arduino.
        I'll change the power supply this evening, see what happens. I'll try another radio module tomorrow if needed.
        I'll keep you posted.
        Thanks !
        YveauxY TheoLT 2 Replies Last reply
        • ybycodeY ybycode
          Thanks !
          YveauxY Offline
          YveauxY Offline
          nRF24 is only rated at 3.6V maximum. You should not run it at VCC of the Nano, which is at 5V!
          ybycodeY 1 Reply Last reply
          • ybycodeY ybycode
            Thanks !
            TheoLT Offline
            TheoLT Offline
            TheoL
            @ybycode If nothing else is being powered directly from the Arduino you should be okay.
            But it is always better to power everything you attach to the Arduino by an adapter. You could use a cheap LE33 power regulator between the adapter and the gnd and vcc of the radio. If you're lazy like me a buck converter is always your friend.
            • YveauxY Yveaux
              ybycodeY Offline
              ybycodeY Offline
              ybycode
              @Yveaux sorry, correction: it's connected to 3V3
              • ybycodeY Offline
                ybycodeY Offline
                ybycode
                Changing the power supply didn't change anything. I'll try changing the radio today.
                In the meantime, I have a question. Everytime the problem has happened, the last temperature that was sent is always either the limit low, or the limit high temperature defined in my sketch, meaning when the relay is passed from close to open or from open to close, when the fridge compressor is turned on or off.
                This makes me think: could my problem be du to an inductive spike, like described in this thread http://electronics.stackexchange.com/questions/128310/arduino-crashes-switching-230v-relay-off ?
                • ybycodeY ybycode
                  TheoLT Offline
                  TheoLT Offline
                  TheoL
                  @ybycode could be. I once had a MySensors project which used a speaker. The speaker was very close to the radio and that Node behaved just like yours. When I move the speaker away from the node it became stable. Not sure if an inductive speak could be the cause, when you use the break-out relays. But that's a good question for someone with more electronics knowledge.
                  I've found a tutorial about watch dogs. It is a last resort, but adding a watchdog will reset your arduino if it stalls. It doesn't resolve the cause though. But I'm thinking about adding a watchdog to all of my sensors. Just to make sure they can't stall in case hardware related issues.
                  11.9k
                  113.3k
