  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.7k Views 5 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    wrote on last edited by tekka
    I have my mqtt client gateway up and running and I have a test node setup.
    The debug for the node is
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    Not sure what is causing it. If i reset it a few times it eventually connects. I have tried clearing the eeprom and reuploaded the sketch.
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    tekkaT 1 Reply Last reply
    • CrankyCoderC CrankyCoder
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=1)
      TSM:UPL
      tekkaT
      tekkaT
      tekka
      @Jason-Brunk Please provide additional information such as HW setup and configuration, and also post the complete log from node and GW while booting.
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        Looks like it may have been related to my gateway and sensor being too close.
        www.CrankyCoder.net
        MySensors: 2.3
          tekkaT
          tekkaT
          tekka
          @Jason-Brunk Yes, this is a common issue.
          • X
            X
            xefil
            wrote on last edited by xefil
            Hello!
            I'm having the same issue. How to solve it?
            I've converted a working sensor having API 1.5 with last API and getting this errors:
            Setting S_LIGHT sensor: 1
            Setting S_LIGHT sensor: 2
            Setting S_LIGHT sensor: 3
            Setting S_LIGHT sensor: 4
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=20)
            TSM:FPAR
            TSP:MSG:SEND 20-20-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSP:MSG:READ 0-0-20 s=255,c=3,t=8,pt=1,l=1,sg=0:0
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=20)
            TSM:UPL
            TSP:MSG:SEND 20-20-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
            TSP:MSG:READ 28-28-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
            TSP:MSG:BC
            TSP:CHKUPL:FAIL (hops=255)
            !TSM:UPL:FAIL
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:MSG:BC
            !TSM:UPL:FAIL
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:MSG:BC
            !TSM:UPL:FAIL
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:MSG:BC
            !TSM:UPL:FAIL```
            It has worked without issues until the last update.
            tekkaT CrankyCoderC 2 Replies Last reply
            • X xefil
              Hello!
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:MSG:BC
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:MSG:BC
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:MSG:BC
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:MSG:BC
              !TSM:UPL:FAIL```
              tekkaT
              tekkaT
              tekka
              @xefil Did you also convert the GW to 2.0? If yes, please post the debug log.
              • Pictor LallemandP
                Pictor LallemandP
                Pictor Lallemand
                I have the same problem as do to solve it?
                Starting repeater (RNNRA-, 2.0.0)
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=123)
                TSM:FPAR
                TSP:MSG:SEND 123-123-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSP:MSG:READ 0-0-123 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=123)
                TSM:UPL
                !TSP:MSG:SEND 123-123-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                !TSM:UPL:FAIL
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                • X
                  X
                  xefil
                  I was quite sure the gateway (MQTTClient) was updated with latest API library, but I was wrong. It was on 1.5 version. Updated to the latest, the problem was solved. Hope it helps!
                  Simon
                  • X xefil
                    Hello!
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:BC
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:BC
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:BC
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:BC
                    !TSM:UPL:FAIL```
                    CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    @xefil with my errors. I changed the capacitor value to 100u and that fixed ALOT of problems. Some one mentioned to me that 2.0 uses the radio a little more and may need a higher value cap.
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • Pictor LallemandP Pictor Lallemand
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      tekkaT
                      tekkaT
                      tekka
                      @Pictor-Lallemand Please make sure your GW is at 2.0.
                      • X xefil
                        Simon
                        tekkaT
                        tekkaT
                        tekka
                        @xefil Perfect, have fun! :)
                        • X
                          X
                          xefil
                          @Jason-Brunk I already had a 100u capacitor, thanks for the suggestion.... btw strange, maybe the update was important.
                          @tekka , thank you!! ;)
                          • Pictor LallemandP
                            Pictor LallemandP
                            Pictor Lallemand
                            or find the code for my GW I use an Arduino pro mini card for a ENC28J60 network and nRF24L01 for radio. because I can not find it in the examples mysensors
                            • X
                              X
                              xefil
                              You mean you cannot find the examples from the API library? When you download it, you can find it in there. On github as well:
                              https://github.com/mysensors/MySensors/tree/master/examples
                              In case try to start uploading two examples (1 GW and 1 sensor) and check. They work without issues. If not, maybe a hardware failure.
                              Simon
                              • Pictor LallemandP
                                Pictor LallemandP
                                Pictor Lallemand
                                in the examples of the API (MySensors 2.0.0) I can not find ENC28J60 Gateway
                                send me please you the code in this gateway thank you
                                  https://github.com/mysensors/MySensorsArduinoExamples/tree/master/examples/GatewayENC28J60
                                  • Pictor LallemandP
                                    Pictor LallemandP
                                    Pictor Lallemand
                                    it didnt change anything here is the log for sensors
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:UPL
                                    !TSM:UPL:FAIL
                                    TSM:FPAR
                                    the sketch use
                                     * Version 1.0 - Henrik Ekblad
                                     * Example sketch showing how to control physical relays.
                                     * This example will remember relay state after power failure.
                                     * http://www.mysensors.org/build/relay
                                    #define MY_REPEATER_FEATURE
                                    #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                    void before() {
                                        pinMode(pin, OUTPUT);
                                      sendSketchInfo("Relay", "1.0");
                                        present(sensor, S_LIGHT);
                                      if (message.type==V_LIGHT) {
                                         // Change relay state
                                         // Store state in eeprom
                                    and that of the gateway
                                    0;255;3;0;9;TSM:INIT
                                    0;255;3;0;9;TSM:RADIO:OK
                                    0;255;3;0;9;TSM:GW MODE
                                    0;255;3;0;9;TSM:READY
                                    IP: 192.168.1.15
                                    0;255;3;0;9;Eth: connect
                                    0;255;3;0;9;Eth: 0;0;3;0;2;
                                    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
                                    0;255;3;0;9;Eth: 0;0;3;0;18;PING
                                    0;255;3;0;9;TSP:SANCHK:OK
                                    the sketch use
                                     * Version 1.0 - Henrik EKblad
                                     * LED purposes:
                                    // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
                                    #define MY_RF24_CE_PIN 5
                                    #define MY_RF24_CS_PIN 6
                                    #define MY_GATEWAY_ENC28J60
                                    // Gateway IP address
                                    #define MY_IP_ADDRESS 192,168,1,15
                                    #define MY_PORT 5003
                                    // Flash leds on rx/tx/err
                                    // Set blinking period
                                    // Enable inclusion mode
                                    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                                    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                                    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                                    #include <UIPEthernet.h>
                                      i add a capacitor 220U
                                    • Pictor LallemandP
                                      Pictor LallemandP
                                      Pictor Lallemand
                                      the gateway log
                                      IP: 192.168.1.15
                                      0;255;3;0;9;TSP:MSG:READ 123-123-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:BC
                                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=123)
                                      0;255;3;0;9;TSP:CHKUPL:OK
                                      0;255;3;0;9;TSP:MSG:GWL OK
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-123-123 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                      • X
                                        X
                                        xefil
                                        Do you have some spare-parts to use a different radio? My gateway has a radio with nrf24l01+pa+lna to increase the range. Maybe the gain is needed with the new API? I don't know. How far are the two objects?
                                        Simon
                                        • Pictor LallemandP
                                          Pictor LallemandP
                                          Pictor Lallemand
                                          the gateway and the remote sensors are 100 cm I use these nRF24L01 I'm beginner with mysensors. I'm really frustrated that it does not work properly malgrer all my efforts to get it working properly alt text
