  3. Battery power (cr2032) on 2.0?
batterycr2032
12 Posts 5 Posters 5.7k Views 3 Watching
  • CrankyCoderC Offline
    CrankyCoder
    Having no end of problems getting a sensor to run on a cr2032 with 2.0. Anyone get this working? Would you mind sharing your setup?
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC CrankyCoder
      M Offline
      M Offline
      m26872
      @Jason-Brunk So, it is working with <2.0 ?
        CrankyCoder
        well, i am fairly new and came in right before the 2.0 release. But i have seen other projects that worked with the cr2032 in older mysensors versions.
        www.CrankyCoder.net
        MySensors: 2.3
        • N Offline
          N Offline
          wrote on last edited by Nca78
          I have door/window sensors working with CR2032 cells with good results.
          Problem with those batteries is they can only provide a very low current, they have a relatively high internal resistance, so the more current you draw from them, the more energy you waste through this internal resistance, and the more the voltage drops. You need to use a few tricks to compensate, and then it's all fine.
          I do the following things to have good results and from what I see until now, good battery life:
          • use pro mini 3.3V / 8 MHz, put 1MHz bootloader so you can set BOD at 1.8V. No regulator/step up or anything similar, it would kill the battery.
          • put a 200uF capacitor in parallel with your battery. If you have a temp/humidity sensor sending with long intervals you could be fine with 100uF but it's not the case if I open/close a few times my door/windows.
          • never have 2 data sending actions without a sleep in the middle. I use a 250ms sleep between sending in the presentation() method, and 100ms in the code (when I send battery level after status, it's not all the time)
          • use branded cells and not the cheap chinese stuff from aliexpress/ebay, there is really a difference !
          Y CrankyCoderC 2 Replies Last reply
          • N Nca78
            Y Offline
            Y Offline
            There's no way to guarantee this without modifying the library...
            N 1 Reply Last reply
            • Y Yveaux
              N Offline
              N Offline
              Yes I'm talking about the "user" sketch. The 200uF capacitor can keep up with the sendings from the library from what I have seen so far. Only the sketch startup is problematic that's why I put longer pauses, including one before the presentation messages.
              • N Nca78
                CrankyCoder
                @Nca78
                great feed back :) couple of follow up questions :).
                1. i am using a 3.3v 8mhz. I put a 1mhz boot loader on it and set my BOD. - This seems to have helped ALOT on my node. Question, my wake up out of sleep doesn't seem to be working (timing issue?) and my serial communications do not work. Is there something I have to do to tell the mysensors sketch I am running at 1mhz to keep the timing correct?
                2. I have not put a 200uF on mine yet. I have a 100uf on this node and it's just 2 buttons to send on/off and the battery level. So I may not need more than 100uf
                3. This is something I had not touched yet, and will definitely add those pauses on boot up. This might help some more!!
                4. I have energizers no cheapy ali express batteries for me :)
                BIG thanks here!!
                www.CrankyCoder.net
                MySensors: 2.3
                N M 2 Replies Last reply
                  @Nca78
                  BIG thanks here!!
                  N Offline
                  N Offline
                  @Jason-Brunk
                  1. Serial communication must be at 9600 bauds max if you are at 1MHz with internal clock. There is a define you can set in your sketch to fix it :
                  #define MY_BAUD_RATE 9600
                  I don't know for the waking up, I didn't notice any problem until now. Do you use the default sleep function from MySensors to set this duration ? Maybe post your sketch, it could help ;)
                  2) I think it's better to put 200 instead of 100 in your case, you can just add another 100 in parallel. If you click on-off on-off in a relatively short time, with the addition of sending battery level your voltage will probably start to drop. Put voltage measurement+sending just after sending the on/off value, you will know if it's fine or not.
                  CrankyCoderC 1 Reply Last reply
                  • N Nca78
                    @Jason-Brunk
                    CrankyCoder
                    @Nca78 ok, I added that baud rate to mine just like that. Still can't see the serial :/
                    Below is my sketch.
                    #define SKETCH_NAME "WallSwitch"
                    #define SKETCH_MAJOR_VER "1"
                    #define SKETCH_MINOR_VER "1"
                    #define MY_NODE_ID 1
                    int oldBatteryPcnt = 0;
                    #define CHILD_LIGHT_ID 1
                    #define ON_PIN 3
                    #define OFF_PIN 2
                    int OFF_VAL = 0;
                    int ON_VAL = 0;
                    MyMessage msg_light(CHILD_LIGHT_ID,V_LIGHT);
                      // Setup the buttons
                      pinMode(ON_PIN,INPUT);
                      pinMode(OFF_PIN,INPUT);
                      digitalWrite(ON_PIN,HIGH);
                      digitalWrite(OFF_PIN,HIGH);
                       analogReference(INTERNAL1V1);
                       analogReference(INTERNAL);
                      present(CHILD_LIGHT_ID, S_LIGHT);
                     CheckBattery();
                    int whichbutton = 0;
                    whichbutton = sleep(digitalPinToInterrupt(2),LOW,digitalPinToInterrupt(3),LOW,3600000);//86400000);
                    switch (whichbutton) {
                      case digitalPinToInterrupt(2):
                          {//off
                          send(msg_light.set(0),true);
                          wait(300);
                      case digitalPinToInterrupt(3):
                          {//on
                          send(msg_light.set(1),true);
                          wait(300);
                    CheckBattery();
                    void CheckBattery()
                        // battery stuff
                       // get the battery Voltage
                       #ifdef MY_DEBUG
                       Serial.println(sensorValue);
                       #ifdef MY_DEBUG
                       float batteryV  = sensorValue * 0.0029325513196481;
                       Serial.print(batteryV);
                       Serial.println(" V");
                       Serial.print(batteryPcnt);
                       Serial.println(" %");
                         // Power up radio after sleep
                         oldBatteryPcnt = batteryPcnt;
                    www.CrankyCoder.net
                    MySensors: 2.3
                      @Nca78
                      BIG thanks here!!
                      M Offline
                      M Offline
                      m26872
                      @Jason-Brunk Also remember to have the cap on battery side if you're starting with some kind of power on.
                        CrankyCoder
                        So in my case 2 caps. 1 at the main power rail between battery and controller and then 1 on the radio. Any recommendations on the values?
                        www.CrankyCoder.net
                        MySensors: 2.3
                        • S Offline
                          You can put 100uf on each ;) even 200uf would not be able to handle only one tx, so..
                          but you need them at least for coin cells.
                          you would need more capa to handle tx..but the more capa the more time they take for recharging, and the recharging if big, increase internal res of the coin cell and that's not so good too; to prevent this that would need a current resistor limiter..etc a whole balance!
                          On mine for instance, I have 100uF for coincell, 100uF for PIR and 86uf on radio. Fresh varta coincell 3.02V, after multiple presentation tx 2.85V if I remember, not so bad. but that's an homemade pcb.
                          Another notes, it's better to use ceramic capacitor (because of leakage, if you want to optimize), and better smd, but that's not your case I think.
                          12.2k
