  3. Rain Guage
Rain Guage
128 Posts 23 Posters 158.7k Views 21 Watching
  • Ivan ZI
    Ivan ZI
    Ivan Z
    Sensor manufacturer has sent information about the sensor. 0.3 mm to 1 tick
    petewillP 1 Reply Last reply
    • Ivan ZI Ivan Z
      petewillP
      petewillP
      petewill
      @Ivan-Z :thumbsup: Thanks for the info.
      • petewillP petewill
        @BulldogLowell Awesome, thank you very much! I know what it's like to lose code that way. I have done the same thing myself...
        Yes, I will test this. I'll do my best to get it tested tonight. I'm combining it with some other sensors (light and temp/humidity) so once I get everything merged I'll be able to upload it.
        I'll let you know what I find.
        Thanks again!
        Pete
        TheekshanaT
        TheekshanaT
        Theekshana
        Hey guys,
        Sorry if this is a stupid question but how does the Arduino interact with the tipping bucket to detect rain?
        • TheekshanaT Theekshana
          Hey guys,
          petewillP
          petewillP
          petewill
          @Theekshana There is a magnet on the tipping bucket and a reed switch that detects the magnet each time it passes by. So each time the bucket tips it will trigger to the Arduino and it can count from there.
          • N
            N
            niccodemi
            Has anyone converted this sketch to Mysensors 2.0 already? I've tried but received following error when compiling:
            Rain-gauge.ino: In function 'void setup()':
            Rain-gauge.ino:151:28: error: too many arguments to function 'void requestTime()'
            In file included from D:\Programs\Arduino\Sketchbook\libraries\libraries\MySensors/MySensors.h:293:0,
                         from Rain-gauge.ino:71:
            D:\Programs\Arduino\Sketchbook\libraries\libraries\MySensors/core/MySensorsCore.cpp:296:6: note: declared here
             void requestTime() {
            Rain-gauge.ino: In function 'void loop()':
            Rain-gauge.ino:323:28: error: too many arguments to function 'void requestTime()'
            Modified sketch below:
             Arduino Tipping Bucket Rain Gauge
             April 26, 2015
             Version 1.4.1 alpha
             Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
             gateway you can measure and sense local rain.  This sketch will create two devices on your
             Vera controller.  One will display your total precipitation for the last 5 days.  The other,
             a sensor that changes state if there is recent rain (up to last 120 hours)  above a threshold.
             Both these settings are user definable.
             There is a build overview video here: https://youtu.be/1eMfKQaLROo
             * Allows you to set the rain threshold in mm
             * Allows you to determine the tripped indicator window up to 120 hours.
             * Displays the last 5 days of rain in Variable1 through Variable5
               of the Rain Sensor device
             * Configuration changes to Sensor device updated every hour
             * Should run on any Arduino
             * Will retain Tripped/Not Tripped status and data in a power interruption, saving small amount
               of data to EEPROM (Circular Buffer to maximize life of EEPROM)
             * LED status indicator
             * Optional Temp/Humidity (DHT-22 or DHT-11) and Light LUX (BH1750) sensors. To use, uncomment
               #define DHT_ON  and/or #define LUX_ON
             * Optionally send total accumulation of each day's rainfall or send only individual days rainfall totals.
               Comment out #define USE_DAILY to display individual daily rainfall.
             by @BulldogLowell and @PeteWill for free public use
            #include <math.h>
            #include <Time.h>
            //#define NODE_ID AUTO //or AUTO to let controller assign
            #define SKETCH_NAME "Rain Gauge"
            #define SKETCH_VERSION "1.4.1a"
            #define DWELL_TIME 125  // this allows for radio to come back to power after a transmission, ideally 0
            //#define DEBUG_ON  // comment out this line to disable serial debug
            //#define DHT_ON // uncomment out this line to enable DHT sensor
            //#define LUX_ON // uncomment out this line to enable BH1750 sensor
            //#define USE_DAILY // displays each time segment as an accumulation of prior periods inclusive.  Comment out to display individual daily rainfall totals in the variables sent to your controller.
            #define CALIBRATE_FACTOR 60 // amount of rain per rain bucket tip e.g. 5 is .05mm
            #define DHT_LUX_DELAY 300000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
            #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
            #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
            #define EEPROM_BUFFER_LOCATION 0  // location of the EEPROM circular buffer
            #define E_BUFFER_LENGTH 240
            #define RAIN_BUCKET_SIZE 120
            #ifdef  DEBUG_ON
            MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
            MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
            MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
            MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
            MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
            MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
            MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
            MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
            MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
            MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
            #ifdef DHT_ON
              #define CHILD_ID_HUM 0
              #define CHILD_ID_TEMP 1
              #define HUMIDITY_SENSOR_DIGITAL_PIN 8
              DHT dht;
              float lastTemp;
              float lastHum;
              boolean metric = true;
            #ifdef LUX_ON
              //BH1750 is connected to SCL (analog input A5) and SDA (analog input A4)
              #include <BH1750.h>
              #define CHILD_ID_LIGHT 2
              BH1750 lightSensor;
              unsigned int lastlux;
              byte heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
            unsigned long sensorPreviousMillis;
            int eepromIndex;
            int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
            int ledPin = 5; // Pin the LED is connected to.  PWM capable pin required
            unsigned long dataMillis;
            unsigned long serialInterval = 600000UL;
            const unsigned long oneHour = 3600000UL;
            unsigned long lastTipTime;
            unsigned long lastRainTime; //Used for rainRate calculation
            unsigned int rainBucket [RAIN_BUCKET_SIZE] ; /* 24 hours x 5 Days = 120 hours */
            unsigned int rainRate = 0;
            byte rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
            volatile int wasTippedBuffer = 0;
            int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
            byte state = 0;
            byte oldState = -1;
            int lastRainRate = 0;
            int lastMeasure = 0;
            boolean gotTime = false;
            byte lastHour;
            byte currentHour;
              SERIAL_START(115200);
              // Set up the IO
              pinMode(tipSensorPin, INPUT_PULLUP);
              attachInterrupt (1, sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
              pinMode(ledPin, OUTPUT);
              digitalWrite(ledPin, HIGH);
              //Let's get the controller talking to the Arduino
              //begin(getVariables, NODE_ID);
              //Sync time with the server, this will be called hourly in order to keep time from creeping with the crystal
              unsigned long functionTimeout = millis();
              while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
            //    process();
                requestTime(receiveTime);
                DEBUG_PRINTLN(F("Getting Time"));
                wait(1000); // call once per second
                DEBUG_PRINTLN(F("."));
              currentHour = hour();
              lastHour = hour();
              //retrieve from EEPROM stored values on a power cycle.
              boolean isDataOnEeprom = false;
              for (int i = 0; i < E_BUFFER_LENGTH; i++)
                byte locator = loadState(EEPROM_BUFFER_LOCATION + i);
                if (locator == 0xFE)  // found the EEPROM circular buffer index
                  eepromIndex = EEPROM_BUFFER_LOCATION + i;
                  DEBUG_PRINT(F("EEPROM Index "));
                  DEBUG_PRINTLN(eepromIndex);
                  //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
                  loadRainArray(eepromIndex);
                  isDataOnEeprom = true;
              if (!isDataOnEeprom) // Added for the first time it is run on a new Arduino
                DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
                eepromIndex = EEPROM_BUFFER_LOCATION;
                saveState(eepromIndex, 0xFE);
                saveState(eepromIndex + 1, 0xFE);
                //then I will clear out any bad data
                for (int i = 2; i <= E_BUFFER_LENGTH; i++)
                  saveState(i, 0x00);
              dataMillis = millis();
              lastTipTime = millis() - oneHour; //why is this -oneHour?? Doesn't millis() start at 0 when first powered on?
              request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
              wait(DWELL_TIME);
              request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
              wait(DWELL_TIME);
            #ifdef DHT_ON
              present(CHILD_ID_HUM, S_HUM);
              wait(DWELL_TIME);
              wait(DWELL_TIME);
              .wait(DWELL_TIME);
            #ifdef LUX_ON
              wait(DWELL_TIME);
              lightSensor.begin();
              DEBUG_PRINTLN(F("Radio Setup Complete!"));
              transmitRainData();
              wait(DWELL_TIME);
              present(CHILD_ID_RAIN_LOG, S_RAIN);
              wait(DWELL_TIME);
              present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
              wait(DWELL_TIME);
            //  process();
              if (state)
                prettyFade();  // breathe if tripped
                slowFlash();   // blink if not tripped
            #ifdef DEBUG_ON  // Serial Debug Block
              if ( (millis() - dataMillis) >= serialInterval)
                for (int i = 24; i <= 120; i = i + 24)
                  updateSerialData(i);
              // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
              int measure = 0; // Check to see if we need to show sensor tripped in this block
              for (int i = 0; i < rainWindow; i++)
                measure += rainBucket [i];
                if (measure != lastMeasure)
                  //      DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                  //      DEBUG_PRINTLN(measure);
                  lastMeasure = measure;
              state = (measure >= (rainSensorThreshold * 100));
              if (state != oldState)
                send(msgTripped.set(state));
                wait(DWELL_TIME);
                DEBUG_PRINT(F("New Sensor State... Sensor: "));
                DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
                oldState = state;
              unsigned long tipDelay = millis() - lastRainTime;
              if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
                DEBUG_PRINTLN(F("Sensor Tipped"));
                DEBUG_PRINT(F("rainBucket [0] value: "));
                DEBUG_PRINTLN(rainBucket [0]);
                send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); //Calculate the total rain for the day
                wait(DWELL_TIME);
                wasTippedBuffer--;
                rainRate = ((oneHour) / tipDelay);
                if (rainRate != lastRainRate)
                  send(msgRainRate.set(rainRate, 1));
                  wait(DWELL_TIME);
                  DEBUG_PRINT(F("RainRate= "));
                  DEBUG_PRINTLN(rainRate);
                  lastRainRate = rainRate;
                lastRainTime = lastTipTime;
              if (currentHour != lastHour)
                DEBUG_PRINTLN(F("One hour elapsed."));
                send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); // send today's rainfall
                wait(DWELL_TIME);
                saveState(eepromIndex, highByte(rainBucket[0]));
                saveState(eepromIndex + 1, lowByte(rainBucket[0]));
                DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
                DEBUG_PRINTLN(rainBucket[0]);
                for (int i = RAIN_BUCKET_SIZE - 1; i >= 0; i--)//cascade an hour of values back into the array
                  rainBucket [i + 1] = rainBucket [i];
                wait(DWELL_TIME);
                wait(DWELL_TIME);
                rainBucket[0] = 0;
                eepromIndex = eepromIndex + 2;
                if (eepromIndex > EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH)
                DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
                requestTime(receiveTime); // sync the time every hour
                wait(DWELL_TIME);
                transmitRainData();
                rainRate = 0;
                wait(DWELL_TIME);
                DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
                lastHour = currentHour;
              if (millis() - sensorPreviousMillis > DHT_LUX_DELAY)
                #ifdef DHT_ON  //DHT Code
                  doDHT();
                #ifdef LUX_ON
                  doLUX();
                sensorPreviousMillis = millis();
            #ifdef DHT_ON
            void doDHT(void)
                if (isnan(temperature))
                  DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
                } else if (temperature != lastTemp)
                  lastTemp = temperature;
                  if (!metric)
                  gw.wait(DWELL_TIME);
                  DEBUG_PRINT(F("Temperature is: "));
                  DEBUG_PRINTLN(temperature);
                float humidity = dht.getHumidity();;
                if (isnan(humidity))
                  DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
                } else if (humidity != lastHum)
                  lastHum = humidity;
                  DEBUG_PRINT(F("Humidity is: "));
                  DEBUG_PRINTLN(humidity);
            #ifdef LUX_ON
            void doLUX(void)
              unsigned int lux = lightSensor.readLightLevel();// Get Lux value
              DEBUG_PRINT(F("Current LUX Level: "));
              DEBUG_PRINTLN(lux);
              heartbeat++;
              if (lux != lastlux || heartbeat > 10)
                gw.send(msg.set(lux));
                lastlux = lux;
              if (heartbeat > 10)
                heartbeat = 0;
            void sensorTipped()
              unsigned long thisTipTime = millis();
              if (thisTipTime - lastTipTime > 100UL)
                rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
                wasTippedBuffer++;
              lastTipTime = thisTipTime;
            int rainTotal(int hours)
              int total = 0;
              for ( int i = 0; i <= hours; i++)
                total += rainBucket [i];
              return total;
            void updateSerialData(int x)
              DEBUG_PRINT(F("Rain last "));
              DEBUG_PRINT(x);
              DEBUG_PRINTLN(F(" hours: "));
              float tipCount = 0;
              for (int i = 0; i < x; i++)
                tipCount = tipCount + rainBucket [i];
              tipCount = tipCount / 100;
              DEBUG_PRINTLN(tipCount);
            void loadRainArray(int value) // retrieve stored rain array from EEPROM on powerup
              for (int i = 0; i < RAIN_BUCKET_SIZE; i++)
                value = value - 2;
                if (value < EEPROM_BUFFER_LOCATION)
                  value = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
                DEBUG_PRINT(F("EEPROM location: "));
                DEBUG_PRINTLN(value);
                byte rainValueHigh = loadState(value);
                byte rainValueLow = loadState(value + 1);
                unsigned int rainValue = rainValueHigh << 8;
                rainValue |= rainValueLow;
                rainBucket[i + 1] = rainValue;
                DEBUG_PRINT(F("rainBucket[ value: "));
                DEBUG_PRINT(i + 1);
                DEBUG_PRINT(F("] value: "));
                DEBUG_PRINTLN(rainBucket[i + 1]);
            void transmitRainData(void)
              DEBUG_PRINT(F("In transmitRainData. currentHour = "));
              DEBUG_PRINTLN(currentHour);
              int rainUpdateTotal = 0;
              for (int i = currentHour; i >= 0; i--)
                rainUpdateTotal += rainBucket[i];
                DEBUG_PRINT(F("Adding rainBucket["));
                DEBUG_PRINT(i);
                DEBUG_PRINTLN(F("] to rainUpdateTotal."));
              DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
              DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
              send(msgRainVAR1.set((float)rainUpdateTotal / 100.0, 1)); //Send current day rain totals (resets at midnight)
              wait(DWELL_TIME);
            #ifdef USE_DAILY
              for (int i = currentHour + 24; i > currentHour; i--)
                DEBUG_PRINT(i);
              DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
              send(msgRainVAR2.set((float)rainUpdateTotal / 100.0, 1));
              wait(DWELL_TIME);
            #ifdef USE_DAILY
              for (int i = currentHour + 48; i > currentHour + 24; i--)
                DEBUG_PRINT(i);
              DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
              send(msgRainVAR3.set((float)rainUpdateTotal / 100.0, 1));
              wait(DWELL_TIME);
            #ifdef USE_DAILY
              for (int i = currentHour + 72; i > currentHour + 48; i--)
                DEBUG_PRINT(i);
              DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
              send(msgRainVAR4.set((float)rainUpdateTotal / 100.0, 1));
              wait(DWELL_TIME);
            #ifdef USE_DAILY
              for (int i = currentHour + 96; i > currentHour + 72; i--)
                DEBUG_PRINT(i);
              DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
              send(msgRainVAR5.set((float)rainUpdateTotal / 100.0, 1));
              wait(DWELL_TIME);
              if (message.sensor == CHILD_ID_RAIN_LOG)
                // nothing to do here
              else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
                if (message.type == V_VAR1)
                  rainWindow = atoi(message.data);
                  if (rainWindow > 120)
                    rainWindow = 120;
                  else if (rainWindow < 1)
                    rainWindow = 1;
                  if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                    send(msgTrippedVar1.set(rainWindow));
                  rainSensorThreshold = atoi(message.data);
                  if (rainSensorThreshold > 10000)
                    rainSensorThreshold = 10000;
                  else if (rainSensorThreshold < 1)
                    rainSensorThreshold = 1;
                  if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                    send(msgTrippedVar2.set(rainSensorThreshold));
            void prettyFade(void)
              float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
              analogWrite(ledPin, val);
            void slowFlash(void)
              static boolean ledState = true;
              static unsigned long pulseStart = millis();
              if (millis() - pulseStart < 100UL)
                digitalWrite(ledPin, !ledState);
              DEBUG_PRINTLN(F("Time received..."));
              setTime(time);
              char theTime[6];
              sprintf(theTime, "%d:%2d", hour(), minute());
              DEBUG_PRINTLN(theTime);
            AWIA 1 Reply Last reply
            • N niccodemi
               April 26, 2015
               Version 1.4.1 alpha
              #include <math.h>
              #include <Time.h>
              #ifdef  DEBUG_ON
              #ifdef DHT_ON
                DHT dht;
                float lastTemp;
                float lastHum;
              #ifdef LUX_ON
                #include <BH1750.h>
                BH1750 lightSensor;
              int eepromIndex;
              byte state = 0;
              byte oldState = -1;
              byte lastHour;
              byte currentHour;
                // Set up the IO
              //    process();
                lastHour = hour();
                    saveState(i, 0x00);
                wait(DWELL_TIME);
                wait(DWELL_TIME);
              #ifdef DHT_ON
                wait(DWELL_TIME);
                wait(DWELL_TIME);
                .wait(DWELL_TIME);
              #ifdef LUX_ON
                wait(DWELL_TIME);
                transmitRainData();
                wait(DWELL_TIME);
                wait(DWELL_TIME);
                wait(DWELL_TIME);
              //  process();
                if (state)
                  wait(DWELL_TIME);
                  oldState = state;
                  wait(DWELL_TIME);
                  wasTippedBuffer--;
                    wait(DWELL_TIME);
                  wait(DWELL_TIME);
                  wait(DWELL_TIME);
                  wait(DWELL_TIME);
                  rainBucket[0] = 0;
                  wait(DWELL_TIME);
                  transmitRainData();
                  rainRate = 0;
                  wait(DWELL_TIME);
                    doDHT();
                  #ifdef LUX_ON
                    doLUX();
              #ifdef DHT_ON
              void doDHT(void)
                    if (!metric)
                    lastHum = humidity;
              #ifdef LUX_ON
              void doLUX(void)
                DEBUG_PRINTLN(lux);
                heartbeat++;
                  lastlux = lux;
                if (heartbeat > 10)
                  heartbeat = 0;
              void sensorTipped()
                  wasTippedBuffer++;
                int total = 0;
                return total;
                DEBUG_PRINT(x);
                float tipCount = 0;
                  value = value - 2;
                  DEBUG_PRINT(i + 1);
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
              #ifdef USE_DAILY
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
              #ifdef USE_DAILY
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
              #ifdef USE_DAILY
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
              #ifdef USE_DAILY
                  DEBUG_PRINT(i);
                wait(DWELL_TIME);
                      rainWindow = 120;
                      rainWindow = 1;
                setTime(time);
                char theTime[6];
              AWIA
              AWIA
              AWI
              @niccodemi syntax for time functions is:
              requestTime();						// Request latest time from controller
              N 1 Reply Last reply
              • AWIA AWI
                N
                N
                niccodemi
                @AWI thank you. Sketch compiles now but after uploading it still doesn't work - serial monitor is blank (debug on).
                • mrc-coreM
                  mrc-coreM
                  mrc-core
                  wrote on last edited by mrc-core
                  #118
                  Using the new code for version 2.0.0 i'm getting this errors:
                  C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void setup()':
                  RainGauge:145: error: 'timeStatus' was not declared in this scope
                  RainGauge:145: error: 'timeNotSet' was not declared in this scope
                  RainGauge:152: error: 'hour' was not declared in this scope
                  C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void loop()':
                  RainGauge:299: error: 'hour' was not declared in this scope
                  C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void receiveTime(long unsigned int)':
                  RainGauge:597: error: 'setTime' was not declared in this scope
                  setTime(time);
                  RainGauge:599: error: 'hour' was not declared in this scope
                  RainGauge:599: error: 'minute' was not declared in this scope
                  Using library MySensors at version 2.0.0 in folder: C:\Users\marco\Documents\Arduino\libraries\MySensors
                  Using library SPI at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI
                  Using library Wire at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire
                  exit status 1
                  Does anyone now how to fix this ??
                  • mrc-coreM mrc-core
                    setTime(time);
                    exit status 1
                    N
                    N
                    niccodemi
                    @mrc-core is this the sketch you are using?
                     April 26, 2015
                     Version 1.4.1 alpha
                    //#define MY_NODE_ID 7
                    #include <math.h>
                    #include <Time.h>
                    #define TIP_SENSOR_PIN 3
                    #ifdef  DEBUG_ON
                    #ifdef DHT_ON
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                    #ifdef LUX_ON
                      #include <BH1750.h>
                      BH1750 lightSensor;
                    int eepromIndex;
                    byte state = 0;
                    byte oldState = -1;
                    unsigned int lastRainRate = 0;
                    byte lastHour;
                    byte currentHour;
                      // Set up the IO
                      pinMode(TIP_SENSOR_PIN, INPUT_PULLUP);
                      attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
                        requestTime();
                      lastHour = hour();
                          saveState(i, 0x00);
                      wait(DWELL_TIME);
                      wait(DWELL_TIME);
                    #ifdef DHT_ON
                      wait(DWELL_TIME);
                    #ifdef LUX_ON
                      wait(DWELL_TIME);
                      transmitRainData();
                    void presentation()  {
                      wait(DWELL_TIME);
                      wait(DWELL_TIME);
                      wait(DWELL_TIME);
                    #ifdef DHT_ON
                      wait(DWELL_TIME);
                      wait(DWELL_TIME);
                    #ifdef LUX_ON
                      if (state)
                        wait(DWELL_TIME);
                        oldState = state;
                        wait(DWELL_TIME);
                        wasTippedBuffer--;
                          wait(DWELL_TIME);
                        wait(DWELL_TIME);
                        wait(DWELL_TIME);
                        wait(DWELL_TIME);
                        rainBucket[0] = 0;
                        requestTime(); // sync the time every hour
                        wait(DWELL_TIME);
                        transmitRainData();
                        rainRate = 0;
                        wait(DWELL_TIME);
                          doDHT();
                        #ifdef LUX_ON
                          doLUX();
                    #ifdef DHT_ON
                    void doDHT(void)
                          if (!metric)
                          wait(DWELL_TIME);
                          lastHum = humidity;
                          wait(DWELL_TIME);
                    #ifdef LUX_ON
                    void doLUX(void)
                      DEBUG_PRINTLN(lux);
                      heartbeat++;
                        send(msg.set(lux));
                        lastlux = lux;
                      if (heartbeat > 10)
                        heartbeat = 0;
                    void sensorTipped()
                        wasTippedBuffer++;
                      int total = 0;
                      return total;
                      DEBUG_PRINT(x);
                      float tipCount = 0;
                        value = value - 2;
                        DEBUG_PRINT(i + 1);
                        DEBUG_PRINT(i);
                      wait(DWELL_TIME);
                    #ifdef USE_DAILY
                        DEBUG_PRINT(i);
                      wait(DWELL_TIME);
                    #ifdef USE_DAILY
                        DEBUG_PRINT(i);
                      wait(DWELL_TIME);
                    #ifdef USE_DAILY
                        DEBUG_PRINT(i);
                      wait(DWELL_TIME);
                    #ifdef USE_DAILY
                        DEBUG_PRINT(i);
                      wait(DWELL_TIME);
                            rainWindow = 120;
                            rainWindow = 1;
                      setTime(time);
                      char theTime[6];
                    It compiles fine with Arduino IDE 1.6.5, Mysensors 2.0.0 and libraries (Time, BH1750).
                    • mrc-coreM
                      mrc-coreM
                      mrc-core
                      Yes that's the one.
                      • mrc-coreM
                        mrc-coreM
                        mrc-core
                        Using IDE 1.6.5 i get this:
                        In file included from C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:10:0:
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:18:18: error: variable 'monthStr1' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr1[] PROGMEM = "January";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:19:18: error: variable 'monthStr2' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr2[] PROGMEM = "February";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:20:18: error: variable 'monthStr3' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr3[] PROGMEM = "March";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:21:18: error: variable 'monthStr4' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr4[] PROGMEM = "April";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:22:18: error: variable 'monthStr5' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr5[] PROGMEM = "May";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:23:18: error: variable 'monthStr6' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr6[] PROGMEM = "June";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:24:18: error: variable 'monthStr7' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr7[] PROGMEM = "July";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:25:18: error: variable 'monthStr8' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr8[] PROGMEM = "August";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:26:18: error: variable 'monthStr9' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr9[] PROGMEM = "September";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:27:19: error: variable 'monthStr10' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr10[] PROGMEM = "October";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:28:19: error: variable 'monthStr11' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr11[] PROGMEM = "November";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:29:19: error: variable 'monthStr12' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthStr12[] PROGMEM = "December";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:31:22: error: variable 'monthNames_P' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        PGM_P monthNames_P[] PROGMEM =
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:37:26: error: variable 'monthShortNames_P' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char monthShortNames_P[] PROGMEM = "ErrJanFebMarAprMayJunJulAugSepOctNovDec";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:39:16: error: variable 'dayStr0' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayStr0[] PROGMEM = "Err";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:40:16: error: variable 'dayStr1' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayStr1[] PROGMEM = "Sunday";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:41:16: error: variable 'dayStr2' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayStr2[] PROGMEM = "Monday";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:42:16: error: variable 'dayStr3' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayStr3[] PROGMEM = "Tuesday";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:43:16: error: variable 'dayStr4' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayStr4[] PROGMEM = "Wednesday";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:44:16: error: variable 'dayStr5' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayStr5[] PROGMEM = "Thursday";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:45:16: error: variable 'dayStr6' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayStr6[] PROGMEM = "Friday";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:46:16: error: variable 'dayStr7' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayStr7[] PROGMEM = "Saturday";
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:48:20: error: variable 'dayNames_P' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        PGM_P dayNames_P[] PROGMEM = { dayStr0,dayStr1,dayStr2,dayStr3,dayStr4,dayStr5,dayStr6,dayStr7};
                        C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:49:24: error: variable 'dayShortNames_P' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                        char dayShortNames_P[] PROGMEM = "ErrSunMonTueWedThrFriSat";
                        Erro ao compilar.
                          Erro ao compilar.
                          N
                          N
                          niccodemi
                          @mrc-core Remove folder "Time" from your libraries folder, then download the "MySensorsArduinoExamples" zip from this link and extract Time library to your libraries folder. Restart Arduino IDE and try again.
                          • E
                            E
                            esawyja
                            Hi All,
                            Can you run this of 2 x AA batteries, does it go into sleep? It seems to fade the LED al the time, so I guess it will drain the batteries quick quickly? Does anyone have experience in powering this?
                            Regards
                            • E esawyja
                              Hi All,
                              Regards
                              petewillP
                              petewillP
                              petewill
                              @esawyja No, currently this example is written to be powered by external power so it wouldn't work well with batteries.
                              • EnfeetE
                                EnfeetE
                                Enfeet
                                Hi friends,
                                here is my replica of Rain Guage MySensors project
                                photos:
                                https://goo.gl/photos/4kA7T4d8SsDBRrrS7
                                The sketch is adopted for 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library' just uncomment both DHT_ON and DHT_ADAFRUIT and Yes, I'm using rfm69hw radio with encryption enabled ;-)
                                3d bucket model: proposal to split it on a 3 part (i split on 2 parts now and have some troubles)
                                #define MY_RFM69_ENABLE_ENCRYPTION
                                 April 26, 2015
                                 Version 2.0
                                   Uncomment #define USE_DAILY to display individual daily rainfall.  If it is commented out it will display
                                   a cumulative total rainfall (day4 = day1+day2+day3+day4 etc)
                                //#define MY_DEBUG_VERBOSE
                                #define MY_NODE_ID AUTO
                                //#define MY_RADIO_NRF24
                                #define MY_RADIO_RFM69
                                #define MY_IS_RFM69HW
                                #define MY_RFM69_TX_POWER 31
                                #include <math.h>
                                #include <TimeLib.h>
                                #define SKETCH_VERSION "2.0"
                                #define DWELL_TIME 40  // this allows for radio to come back to power after a transmission, ideally 0
                                //#define DEBUG_ON  // Rain gauge specific debug messages.
                                // 20170621 by Enfeet
                                #define DHT_ADAFRUIT // uncomment out this line to enable DHT with 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library'
                                //#define DHTTYPE           DHT11     // DHT 11
                                #define DHTTYPE           DHT22     // DHT 22 (AM2302)
                                //#define DHTTYPE           DHT21     // DHT 21 (AM2301)
                                // /20170621 by Enfeet
                                //#define USE_DAILY // Uncomment to display individual daily rainfall totals in the variables sent to your controller. If it's commented it will add each day to the next for a cumulative total.
                                //d=112 mm
                                //11689.863832 mm2 =  116,89863832 cm2
                                //42,77209787776081 mm
                                //88 89 91 91 90 = 89,8
                                //0,4763039852757329
                                #define CALIBRATE_FACTOR 48 // amount of rain per rain bucket tip e.g. 5 is .05mm
                                  #ifdef  DEBUG_ON
                                    #define M_DEBUG_PRINT(x)   Serial.print(x)
                                    #define M_DEBUG_PRINTLN(x) Serial.println(x)
                                #ifdef DHT_ON
                                  #ifdef DHT_ADAFRUIT
                                  #include <Adafruit_Sensor.h>
                                  #include <DHT_U.h>
                                  #ifndef DHT_ADAFRUIT // 20170621 by Enfeet
                                    DHT dht;
                                    DHT_Unified dht(HUMIDITY_SENSOR_DIGITAL_PIN, DHTTYPE);
                                    sensors_event_t event;
                                  #endif // /20170621 by Enfeet
                                  float lastTemp;
                                  float lastHum;
                                  bool metric = true;
                                #ifdef LUX_ON
                                  #include <BH1750.h>
                                  BH1750 lightSensor;
                                  uint8_t heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
                                int eepromIndex;
                                #ifdef DEBUG_ON
                                uint8_t rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
                                uint8_t state = 0;
                                uint8_t oldState = 2; //Setting the default to something other than 1 or 0
                                bool gotTime = false;
                                uint8_t lastHour;
                                uint8_t currentHour;
                                  wait(DWELL_TIME);
                                  wait(DWELL_TIME);
                                  wait(DWELL_TIME);
                                #ifdef DHT_ON
                                  wait(DWELL_TIME);
                                  wait(DWELL_TIME);
                                #ifdef LUX_ON
                                  M_DEBUG_PRINTLN(F("Sensor Presentation Complete"));
                                  #ifndef MY_DEBUG
                                  SERIAL_START(115200);  //Start serial if MySensors debugging isn't enabled
                                  // Set up the IO
                                  pinMode(TIP_SENSOR_PIN, INPUT);
                                    requestTime();
                                    M_DEBUG_PRINTLN(F("Getting Time"));
                                    M_DEBUG_PRINTLN(F("."));
                                  lastHour = hour();
                                  bool isDataOnEeprom = false;
                                    uint8_t locator = loadState(EEPROM_BUFFER_LOCATION + i);
                                      M_DEBUG_PRINT(F("EEPROM Index "));
                                      M_DEBUG_PRINTLN(eepromIndex);
                                    M_DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
                                      saveState(i, 0x00);
                                  #ifdef DEBUG_ON
                                  lastTipTime = millis();
                                  wait(DWELL_TIME);
                                  wait(DWELL_TIME);
                                #ifdef DHT_ON
                                    dht.begin();
                                  wait(DWELL_TIME);
                                #ifdef LUX_ON
                                  transmitRainData(); //Setup complete send any data loaded from eeprom to gateway
                                  if (state)
                                      //      M_DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                                      //      M_DEBUG_PRINTLN(measure);
                                    wait(DWELL_TIME);
                                    M_DEBUG_PRINT(F("New Sensor State... Sensor: "));
                                    M_DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
                                    oldState = state;
                                    M_DEBUG_PRINTLN(F("Sensor Tipped"));
                                    M_DEBUG_PRINT(F("rainBucket [0] value: "));
                                    M_DEBUG_PRINTLN(rainBucket [0]);
                                    wait(DWELL_TIME);
                                    wasTippedBuffer--;
                                      wait(DWELL_TIME);
                                      M_DEBUG_PRINT(F("RainRate= "));
                                      M_DEBUG_PRINTLN(rainRate);
                                    M_DEBUG_PRINTLN(F("One hour elapsed."));
                                    wait(DWELL_TIME);
                                    M_DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
                                    M_DEBUG_PRINTLN(rainBucket[0]);
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                    rainBucket[0] = 0;
                                    M_DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
                                    wait(DWELL_TIME);
                                    transmitRainData();
                                    rainRate = 0;
                                    wait(DWELL_TIME);
                                    M_DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
                                    lastHour = hour();
                                      doDHT();
                                    #ifdef LUX_ON
                                      doLUX();
                                #ifdef DHT_ON
                                void doDHT(void)
                                    dht.temperature().getEvent(&event);
                                    float temperature = event.temperature;
                                    if (isnan(event.temperature))
                                      M_DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
                                        if (!metric)
                                      wait(DWELL_TIME);
                                      M_DEBUG_PRINT(F("Temperature is: "));
                                      M_DEBUG_PRINTLN(temperature);
                                    dht.humidity().getEvent(&event);
                                    float humidity = event.relative_humidity;
                                    if (isnan(event.relative_humidity))
                                      M_DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
                                      lastHum = humidity;
                                      wait(DWELL_TIME);
                                      M_DEBUG_PRINT(F("Humidity is: "));
                                      M_DEBUG_PRINTLN(humidity);
                                #ifdef LUX_ON
                                void doLUX(void)
                                  M_DEBUG_PRINT(F("Current LUX Level: "));
                                  M_DEBUG_PRINTLN(lux);
                                  heartbeat++;
                                    send(msg.set(lux));
                                    lastlux = lux;
                                  if (heartbeat > 10)
                                    heartbeat = 0;
                                void sensorTipped()
                                    wasTippedBuffer++;
                                  int total = 0;
                                  return total;
                                #ifdef DEBUG_ON
                                  M_DEBUG_PRINT(F("Rain last "));
                                  M_DEBUG_PRINT(x);
                                  M_DEBUG_PRINTLN(F(" hours: "));
                                  float tipCount = 0;
                                  M_DEBUG_PRINTLN(tipCount);
                                void loadRainArray(int eValue) // retrieve stored rain array from EEPROM on powerup
                                  for (int i = 1; i < RAIN_BUCKET_SIZE; i++)
                                    eValue = eValue - 2;
                                    if (eValue < EEPROM_BUFFER_LOCATION)
                                      eValue = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
                                    M_DEBUG_PRINT(F("EEPROM location: "));
                                    M_DEBUG_PRINTLN(eValue);
                                    uint8_t rainValueHigh = loadState(eValue);
                                    uint8_t rainValueLow = loadState(eValue + 1);
                                    rainBucket[i] = rainValue;
                                    M_DEBUG_PRINT(F("rainBucket[ value: "));
                                    M_DEBUG_PRINT(i);
                                    M_DEBUG_PRINT(F("] value: "));
                                    M_DEBUG_PRINTLN(rainBucket[i]);
                                  M_DEBUG_PRINT(F("In transmitRainData. currentHour = "));
                                  M_DEBUG_PRINTLN(currentHour);
                                    M_DEBUG_PRINT(F("Adding rainBucket["));
                                    M_DEBUG_PRINT(i);
                                    M_DEBUG_PRINTLN(F("] to rainUpdateTotal."));
                                  M_DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
                                  M_DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                    M_DEBUG_PRINT(i);
                                  M_DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                    M_DEBUG_PRINT(i);
                                  M_DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                    M_DEBUG_PRINT(i);
                                  M_DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                    M_DEBUG_PRINT(i);
                                  M_DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
                                  wait(DWELL_TIME);
                                        rainWindow = 120;
                                        rainWindow = 1;
                                  static bool ledState = true;
                                void receiveTime(unsigned long newTime)
                                  M_DEBUG_PRINTLN(F("Time received..."));
                                  setTime(newTime);
                                  char theTime[6];
                                  M_DEBUG_PRINTLN(theTime);
                                SY
                                Enfeet
                                dbemowskD 1 Reply Last reply
                                • EnfeetE Enfeet
                                  Hi friends,
                                  photos:
                                   April 26, 2015
                                   Version 2.0
                                  #include <math.h>
                                  //d=112 mm
                                    #ifdef  DEBUG_ON
                                  #ifdef DHT_ON
                                    #ifdef DHT_ADAFRUIT
                                    #include <DHT_U.h>
                                      DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                    bool metric = true;
                                  #ifdef LUX_ON
                                    #include <BH1750.h>
                                    BH1750 lightSensor;
                                  int eepromIndex;
                                  #ifdef DEBUG_ON
                                  uint8_t state = 0;
                                  uint8_t lastHour;
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                  #ifdef DHT_ON
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                  #ifdef LUX_ON
                                    #ifndef MY_DEBUG
                                    // Set up the IO
                                      requestTime();
                                    lastHour = hour();
                                        saveState(i, 0x00);
                                    #ifdef DEBUG_ON
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                  #ifdef DHT_ON
                                      dht.begin();
                                    wait(DWELL_TIME);
                                  #ifdef LUX_ON
                                    if (state)
                                      wait(DWELL_TIME);
                                      oldState = state;
                                      wait(DWELL_TIME);
                                      wasTippedBuffer--;
                                        wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      rainBucket[0] = 0;
                                      wait(DWELL_TIME);
                                      transmitRainData();
                                      rainRate = 0;
                                      wait(DWELL_TIME);
                                      lastHour = hour();
                                        doDHT();
                                      #ifdef LUX_ON
                                        doLUX();
                                  #ifdef DHT_ON
                                  void doDHT(void)
                                          if (!metric)
                                        wait(DWELL_TIME);
                                        lastHum = humidity;
                                        wait(DWELL_TIME);
                                  #ifdef LUX_ON
                                  void doLUX(void)
                                    heartbeat++;
                                      send(msg.set(lux));
                                      lastlux = lux;
                                    if (heartbeat > 10)
                                      heartbeat = 0;
                                  void sensorTipped()
                                      wasTippedBuffer++;
                                    int total = 0;
                                    return total;
                                  #ifdef DEBUG_ON
                                    M_DEBUG_PRINT(x);
                                    float tipCount = 0;
                                      M_DEBUG_PRINT(i);
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      M_DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                          rainWindow = 120;
                                          rainWindow = 1;
                                    setTime(newTime);
                                    char theTime[6];
                                  SY
                                  Enfeet
                                  dbemowskD
                                  dbemowskD
                                  @Enfeet I am interested in checking out your code (have not looked through it yet). I am to the point with my rain gauge design that I am ready to do the code for the sensor. Out of curiosity, what type of sensor did you use for your tipping bucket? I am using a magnetic reed switch. I had originally done a bucket design like the one you have, actually when I started my project, I modeled my original one off of that one. This is my modified design:
                                  0_1498328811307_upload-735a635e-b322-420b-b644-72ff206e6f3a
                                  0_1498328935089_upload-b2c2b597-4ca0-4954-8893-2052dcef28b8
                                  The magnet fits in the recessed hole in the side, no need to glue it in. The big difference is that the center divider is angled out to help better with the tipping action.
                                  Here is the rest of the sensor:
                                  0_1498329322457_upload-830ba455-dd6c-431a-a3af-2b730c468e26
                                  0_1498329349998_upload-65eaf66b-c81a-4ad0-bf56-b50be7294a55
                                  I just got the OpenSCAD file for the project cleaned up and I will be posting it to thingiverse later today.
                                  EnfeetE 1 Reply Last reply
                                  • dbemowskD dbemowsk
                                    EnfeetE
                                    EnfeetE
                                    Enfeet
                                    @dbemowsk , i take an original .stl files from the link provided: https://drive.google.com/drive/folders/0B3KGTJHUgpw1fkwtM3RreEF2QWg4eUdsUHdSQjl6UWx2Q3dPS19WSGdqd0pZQ3hhQk1TMkE
                                    but in order to save a support material recreate and split it a little ;-)
                                    The result are visible on photos (link in my previous post)
                                    here is an .scad code of my modifications on top of original files, also i print them up side down ;-)
                                    $fn=300;
                                    difference(){
                                    translate([35,0,0])
                                    import("Can.stl");
                                    cube([210,150,150],center=true);
                                    translate([62,0,0])
                                    rotate([0,90,0])
                                    difference(){
                                    cylinder(d=10,h=3,center=true);
                                    cylinder(d=4,h=6,center=true);
                                    difference(){
                                    translate([-88,0,0])
                                    sphere(d=300);
                                    translate([-90,0,0])
                                    sphere(d=300);
                                    translate([61,0,0])
                                    rotate([0,90,0])
                                    cylinder(d=4,h=4,center=true);
                                    rotate([0,90,0])
                                    difference(){
                                    cylinder(d=310,h=208,center=true);
                                    cylinder(d=122.5+4,h=310,center=true);
                                    translate([54,0,0])
                                    rotate([0,90,0])
                                    difference(){
                                    cylinder(d=122.5+4,h=108,center=true);
                                    cylinder(d=122.5,h=310,center=true);
                                    $fn=300;
                                    difference(){
                                    translate([35,0,0])
                                    import("Can.stl");
                                    translate([62,0,0])
                                    rotate([0,90,0])
                                    difference(){
                                    difference(){
                                    sphere(d=300);
                                    sphere(d=300);
                                    translate([61,0,0])
                                    rotate([0,90,0])
                                    rotate([0,90,0])
                                    difference(){
                                    translate([54,0,0])
                                    rotate([0,90,0])
                                    difference(){
                                    cylinder(d=122.5+4,h=40
                                       ,center=true);
                                    translate([32,0,0])
                                    rotate([0,90,0])
                                    difference(){
                                    cylinder(d=122.5+4+4,h=8
                                       ,center=true);
                                    cylinder(d=122.5+4,h=9,center=true);
                                    The arduino code is also from original project (https://www.mysensors.org/build/rain) but i adopt it to Adafruit Unified Sensors Library and last version of Arduino IDE 1.8.3
                                    SY
                                    Enfeet
                                    • EnfeetE
                                      EnfeetE
                                      Enfeet
                                      Lets continue in correct topic https://forum.mysensors.org/topic/4821/rain-gauge/35
