  3. nRF24L01+PA+LNA MAX power
13 Posts 5 Posters 6.8k Views 5 Watching
  • Fat FlyF Offline
    Fat FlyF Offline
    Fat Fly
    wrote on last edited by Fat Fly
    How to connect this module to use max power ? In config i know but voltage from external adapter ?
    • S Offline
      @Fat-Fly - well, you could use a voltage regulator like LE33ACZ or NRF24L01+ Socket Adapter Board (also found in store). The problem might occur if you connect it through the arduino.
      • Fat FlyF Offline
        Fat FlyF Offline
        Fat Fly
        This ? Power from adapter, not from arduino.
        R 1 Reply Last reply
        • S Offline
          @Fat-Fly - think so, I have not tested it myself but as long as you have enough mA on your charger/power and that chip doesnt limit it somehow i think it will work great.
          • Fat FlyF Fat Fly
            R Offline
            R Offline
            r-nox
            I have used this adapter and it works well.
            • Fat FlyF Offline
              Fat FlyF Offline
              Fat Fly
              I try. I bought these from China friends 20 pcs.
              • K Offline
                K Offline
                karl261
                I also use this small board for powering the nrf+pa+ln. So far no problems with it!
                • Fat FlyF Offline
                  Fat FlyF Offline
                  Fat Fly
                  I need solder power wire to Nano mini usb connector directly? I use for power meter Arduino Nano.
                  • K Offline
                    K Offline
                    karl261
                    wrote on last edited by karl261
                    If I remember correctly, then this little board has a nice and strong power regulator for 3.3 V on board. On my repeater node I have connected my 5V usb charger to this little board and I use the 3.3 V output to power directly both the pro mini and the nrf.
                    If you use the socket on the board to put you nrf in, I would feed the board with a strong 5V source.
                    • Fat FlyF Offline
                      Fat FlyF Offline
                      Fat Fly
                      Okay. I solder wire from nrf socket power directly to arduino nano mini usb connector power wire.
                      • Fat FlyF Offline
                        Fat FlyF Offline
                        Fat Fly
                        I connect nrf socket + pin to Nano 5V pin. Working perfect.
                        • Fat FlyF Offline
                          Fat FlyF Offline
                          Fat Fly
                          Hey.
                          If i need change nrf tx power in arduino sketch. This is right ?
                            Replace LOW with HIGH or MAX for the highest power settings
                            12.1k
