  3. rfm69 and atc
rfm69 and atc
49 Posts 13 Posters 21.4k Views 12 Watching
  • FleischtorteF
    FleischtorteF
    Fleischtorte
    Hi Scalz,
    any progress here? Cant wait to use ATC and the rssi-value for my nodes :D
    Thanks for your work :thumbsup:
    regards
    david
    carlierdC 1 Reply Last reply
    • FleischtorteF Fleischtorte
      Hi Scalz,
      regards
      david
      carlierdC
      carlierdC
      carlierd
      @Fleischtorte So I am not the only one David waiting for ATC and RSSI ;)
      David.
      • FleischtorteF
        FleischtorteF
        Fleischtorte
        @carlierd Yeah Davids FTW :D
        • frenchoF
          frenchoF
          frencho
          @lafleur @scalz
          Hi guys,
          Have one of you succed with the PR, so we can enjoy at least the ATC feature.
          This is really the down side with the RFM69HW, power consumption so your work could be really helpfull !
          Really thank you for that
          Your second life begins when you understand you only have one !
          L 1 Reply Last reply
          • frenchoF frencho
            @lafleur @scalz
            Hi guys,
            L
            L
            lafleur
            wrote on last edited by lafleur
            #31
            @frencho
            I have it all working, but my development environment and Jenkins are not in alignment, so my PR was rejected by the development team. They provide me NO help in resolving the issue... They tend to favor and support only the older NRF24L01 radio and have little interests in the newer, better preforming RFM69 or RFM95 radios. So have a look at my code changes in the close PR. It was not hard to implement. I have move on.....
            frenchoF 1 Reply Last reply
              wrote on last edited by hek
              #32
              @lafleur
              I'm sorry if your feelings got hurt. But you simply wouldn't do what the team instructed you in PR #440 to get it merged.
              https://github.com/mysensors/MySensors/pull/440
              • L lafleur
                @frencho
                frenchoF
                frenchoF
                frencho
                Thanks @lafleur, found your PR, I will try to do my own thing based on your work. Shouldn't be a big deal.
                • L
                  L
                  lafleur
                  I did exactly what you ask, but it continued to fail in building the examples... In another PR, you pointed out that there were issue in building the examples under IDE 1.6.9.
                  My feeling were not hurt, but I did NOT want to wast anymore time in dealing with Jenkins with out guidance.... Also there is NO guide on what Jenkins expect to see in its development environment. it all trial and error...
                  FYI... I have developed RFM95 and TTN transport layers for my snapshot of your code.
                    @frencho @lafleur
                    sorry for this delay. i'm busy, running..sometimes i refresh myself doing some sw but I admit i spent more time on hw than looking how to cleanly do this PR. ouch :sweat: but for me it has to be hobby even if I'm always rushing myself.
                    you're not true ;) in fact mysensors team is not nrf24 only :)
                    as soon as i can, i will look. it could be a bit time consuming as it would be my first PR, why i always delay..boo lazy i am :blush: The best way I think (as, now, I'm not up to date with dev branch, I will need diffchecking my stuff):
                    • I would start/improve PR437 with minor changes needed. As mysensors drivers compiles ok, i would do in this way than taking lowpowerlab lib first (all warnings enabled of course)
                    • then a separated for ATC + or another one for ListenMode. to have a better history and not breaking anything.
                    so, I would separate the PR. I don't know if you tried like this (if i'm overhead), or what were your PR issue. I will look a bit later for curiosity or in case I would run in similar issue hihi.
                    Cool if you have it working :)
                    • FleischtorteF
                      FleischtorteF
                      Fleischtorte
                      @lafleur thanks for your work! On the weekend i was able to upgrade the driver and enable ATC with RSSI-Report. With the instructions from PR440 it was very easy :thumbsup:
                      • L
                        L
                        lafleur
                        It's great to see that you got it all working from the PR440. I hope others will find your work useful....
                        I'm my test,it works very well.....
                        B 1 Reply Last reply
                          frenchoF
                          frenchoF
                          frencho
                          @Fleischtorte would you accept to share the work ? I started to play with the RFM69, but didn't get to the ATC part yet. It could save me a couple of hours, and debug ^^
                          • L lafleur
                            B
                            B
                            BenCranston
                            @lafleur @Fleischtorte @frencho I think I'm a bit dense today. I don't understand where the code currently sits in terms of something that could be tested. I see that PR440 was closed and referenced to go back to PR437 or open a new PR? I'd love to give ATC code a go on my RFM69HW's. Is it being integrated into the development branch? How would I go about testing at this time? I did a quick look at the codebase in git and there is no mention of ATC in the MySensors dev branch... A quick diff of the RFM69.cpp code from Felix and MySensors shows a few differences, so they are not 100% in sync. Alas, I'm at a loss on how to apply the work already done to test.. I can "git clone" like a banshee, but beyond that I'm lost with Jenkins. Sorry, again, dense today...
                            Any advice on how I can help is appreciated. I can test pretty easily. All of my nodes are Moteino's with RFM69HW radios.
                            Thanks again for everyone's efforts and work to make ATC a reality in the MySensors codebase!
                            • FleischtorteF
                              FleischtorteF
                              Fleischtorte
                              wrote on last edited by Fleischtorte
                              #40
                              @frencho @BenCranston
                              This is my implementation of PR440
                              first download new RFM69 driver from LowPowerLab https://github.com/LowPowerLab/RFM69/archive/master.zip
                              Replace the files from libraries\MySensors\drivers\RFM69 (copy all and replace)
                              Change in file RFM69.cpp line 31-32
                              #include <RFM69.h>
                              #include <RFM69registers.h>
                              to
                              #include "RFM69.h"
                              #include "RFM69registers.h"
                              in RFM69_ATC.cpp line 32-34
                              #include <RFM69_ATC.h>
                              #include <RFM69.h>   // include the RFM69 library files as well
                              to
                              #include "RFM69_ATC.h"
                              #include "RFM69.h"   // include the RFM69 library files as well
                              i think this was the driver..
                              next was mysensors
                              in file libraries/MySensors/MySensor.h line 268
                              #include "drivers/RFM69/RFM69_ATC.cpp"
                              in file libraries/MySensors/core/MyTransportRFM69.cpp
                              first in line 24
                              #include "drivers/RFM69/RFM69_ATC.h"
                              line 25-26
                              RFM69 _radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
                              uint8_t _address;
                              to
                              #ifdef MY_RFM69_Enable_ATC
                                 RFM69_ATC 	_radio(MY_RF69_SPI_CS, MY_RF69_IRQ_PIN, MY_RFM69HW, MY_RF69_IRQ_NUM);
                              uint8_t _address;
                              and line 53 idk if this is necessary
                              return _radio.sendWithRetry(to,data,len);
                              to
                              	return _radio.sendWithRetry(to,data,len,5);
                              btw i use not the dev version
                              https://github.com/mysensors/MySensors/pull/440 see comment from trlafleur
                              there is my testing node (molgan PIR )
                               * Version 1.0 - Henrik Ekblad
                              // Enable debug prints
                              #define MY_NODE_ID 4
                              #define MY_RADIO_RFM69
                              #define MY_RFM69_FREQUENCY RF69_868MHZ
                              #define MY_RFM69_NETWORKID 121
                              #define MY_RFM69_ENABLE_ENCRYPTION
                              #define MY_RFM69_Enable_ATC
                              #define CHILD_ID_RSSI 7 // Id for RSSI Value
                              // Initialize motion message
                              // Initialize RSSI message
                              MyMessage rssiMsg(CHILD_ID_RSSI,V_TEXT);
                                  _radio.enableAutoPower(-70);
                                  Serial.println("ATC Aktiviert");
                              void presentation()  {
                                sendSketchInfo("Molgan-PIR", "1.0");
                                present(CHILD_ID, S_DOOR);
                                present(CHILD_ID_RSSI, S_INFO);
                                // Read digital motion value
                                Serial.println(tripped);
                                int var1 = _radio.RSSI;
                                send(rssiMsg.set(var1));  // Send RSSI value to gw
                              i hope this helps :) im just learing mysensors & co :expressionless:
                              david
                              B frenchoF 3 Replies Last reply
                                #include <RFM69.h>
                                to
                                #include "RFM69.h"
                                to
                                next was mysensors
                                first in line 24
                                line 25-26
                                uint8_t _address;
                                to
                                uint8_t _address;
                                to
                                david
                                B
                                B
                                BenCranston
                                @Fleischtorte Sweet!! This I can do. I'll make the changes and start testing tonight. thanks for the explicit help.
                                -Ben
                                  #include <RFM69.h>
                                  to
                                  #include "RFM69.h"
                                  to
                                  next was mysensors
                                  first in line 24
                                  line 25-26
                                  uint8_t _address;
                                  to
                                  uint8_t _address;
                                  to
                                  david
                                  frenchoF
                                  frenchoF
                                  frencho
                                  @Fleischtorte
                                  thanks for the details, I'll look into it, as soon as I have my RFM69 GW talking to my RFM69 node
                                    #include <RFM69.h>
                                    to
                                    #include "RFM69.h"
                                    to
                                    next was mysensors
                                    first in line 24
                                    line 25-26
                                    uint8_t _address;
                                    to
                                    uint8_t _address;
                                    to
                                    david
                                    frenchoF
                                    frenchoF
                                    frencho
                                    @Fleischtorte is your code example working ? I mean do you see the RSSI going down to -70 ?
                                    Cause on this page https://lowpowerlab.com/2015/11/11/rfm69_atc-automatic-transmission-control/ Felix says we must use a radio.sendwithretry ?!
                                    I'm a little confused it not working so I'm digging
                                    • B BenCranston
                                      -Ben
                                      frenchoF
                                      frenchoF
                                      frencho
                                      @BenCranston did you get it to work ?
                                      • FleischtorteF
                                        FleischtorteF
                                        Fleischtorte
                                        #45
                                        @Frencho radio.sendwithretry is used (see line 53 in libraries/MySensors/core/MyTransportRFM69.cpp) and ATC must be enabled on GW/Node (use _radio.enableAutoPower(-70); only on the node side).
                                        It seems you need continous traffic to see the effect of ATC (i use a simple relay sketch which reports the rssi with every switch command).
                                        • nagelcN
                                          nagelcN
                                          nagelc
                                          How is the ATC working out? I think it is a neat feature, but am reluctant to mess with the core MySensors libraries.
                                          12.5k
