  3. [Solved] MySensors 2.0 Ethernet gateway (ENC28J60) restart / IP issue
49 Posts 9 Posters 28.1k Views 8 Watching
  • intelliumI intellium
    May have spoken to soon....
    Although the gateway now runs, after a few mins it seems to die. LAN leds keep blinking everything seems in order, but it's not pingable anymore and Domoticz starts logging messages that the gateway is unreachable. Is this somehow related? Or is this a whole different issue?
    @tekka probably knows what to do, right? :D
    tekkaT
    tekkaT
    tekka
    @intellium can you add a serial print in loop() to see if the GW or the lan module freezes?
    intelliumI 1 Reply Last reply
    • tekkaT tekka
      intelliumI
      intelliumI
      intellium
      @tekka Sorry it took a while.
      I gave it a try, but ever since adding print statements to the gateway loop(), the sensor nodes stopped communicating with it given FPAR failures. Even when I remove the print statements and return to the previous state, it keeps on giving FPAR failures on all sensor nodes... What would cause this ?
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @intellium hmm, hard to diagnose without additional information - could be power-related. Can you add a better/stronger power-supply?
        • tekkaT tekka
          intelliumI
          intelliumI
          intellium
          @tekka Before I go the route of messing with the power supply, I did some fiddling...
          I added the following statements to both the gateway and the sensor sketches:
          //LOW POWER MODE RADIO
          //DEBUG FOR RADIO
          #define MY_DEBUG_VERBOSE_RF24
          //RADIO THROUGHPUT
          #define MY_RF24_DATARATE RF24_1MBPS
          Next I put them a little bit closer together (around 80cm apart). The FPAR:FAIL message are gone now. I see in the output on the Sensor node that it communicates with the gateway. Currently, the gateway is running with this setup and the controller (Domoticz) gets values. So this seems to be working OK.
          However, on the sensor node, the log sometimes indicates an error. Something like this :
          RF24:write register, reg=0, value=14
          RF24:open writing pipe, recipient=0
          RF24:write register, reg=10, value=0
          RF24:write register, reg=16, value=0
          RF24:send message to 0, len=12
          RF24:flushTX
          RF24:write register, reg=7, value=48
          RF24:MAX_RT
          RF24:flushTX
          RF24:start listening
          RF24:write register, reg=0, value=15
          RF24:write register, reg=10, value=1
          !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=fail:29.0
          T: 29.00
          RF24:write register, reg=0, value=12
          RF24:power down
          RF24:power down
          RF24:stop listening
          RF24:flushTX
          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=ok:36.0
          H: 36.00
          RF24:power down
          From what I've read, the st:fail means there was an error transmitting the value. Could this still be power related ? It seems so intermittent to me that my gut tells me power isn't the issue.
          • intelliumI
            intelliumI
            intellium
            @tekka Next I tried is adding a capacitor to both the gateway and node RF module. I added a 10uF capacitor to both of them. This seems to have stabilized RF communication. I'm not seeing any failures anymore and data is flowing...
            Back to the original issue... The gateway that seems to die...
            I've added some debug statements to the loop() to see if this would keep on running when the gateway seemingly dies.
            After 2 hours of operation, the gateway stopped responding to pings, and the controller also noticed the gateway was not alive anymore. When this happens, the output of the serial console is :
            New loop iteration: 21734
            New loop iteration: 21735
            New loop iteration: 21736
            New loop iteration: 21737
            New loop iteration: 21738
            New loop iteration: 21739
            New loop iteration: 21740
            New loop iteration: 21741
            New loop iteration: 21742
            New loop iteration: 21743
            New loop iteration: 21744
            As you can see, my loop code keeps on running at this point, suggesting it's just the ENC interface thats no longer reachable or has an issue. When I close and re-open the serial port monitor from the Arduino IDE, the gateway springs back to life and everything starts working again.
            • intelliumI
              intelliumI
              intellium
              The next run it only took 20 mins. before the gateway stopped responding....
                tekkaT
                tekkaT
                tekka
                @intellium Issues with ENC: https://forum.arduino.cc/index.php?topic=398258.0
                sounds pretty much the same...
                • tekkaT tekka
                  intelliumI
                  intelliumI
                  intellium
                  @tekka Yeah, I was afraid of that....
                  I think I might just build a serial gateway and use that for Domoticz as those seem a lot more stable. Then when I find a good source for a w5100 module, I'll get some of those for building an ethernet gateway.
                  • intelliumI
                    intelliumI
                    intellium
                    Just a little update:
                    I build a serial gateway and attached it to Domoticz. Been working ever since, even during the night. Guess this is the way to go for now.
                      tekkaT
                      tekkaT
                      tekka
                      @intellium Sounds good - fyi, I'm using both, W5100 and ESP8266-based GWs, w/o issues.
                      intelliumI 2 Replies Last reply
                      • tekkaT tekka
                        intelliumI
                        intelliumI
                        intellium
                        @tekka I've got a bunch of esp8266 modules laying around. Maybe I'll just search how to wire those up to my nano's and find some code to run it as a dedicated gateway / sensor node. I've noticed the site uses a NodeMCU board for this instead of an Arduino (Nano) ?
                        • GizMoCuzG
                          GizMoCuzG
                          GizMoCuz
                          wrote on last edited by GizMoCuz
                          #26
                          Having the exact issue as the OP, but then with a W5100 shield and a NRF24.
                          Reverting back to MySensors 1.5.4 solves the problem.
                          Now i was on a beta of 2.0 that i uploaded to the gateway quite some time ago, and this worked without issues
                          Something has changed in the final 2.0 release... and i want to revert that change ;)
                          • GizMoCuzG GizMoCuz
                            tekkaT
                            tekkaT
                            tekka
                            @GizMoCuz You mean W5100 freezes and MCU remains responsive? SoftSPI?
                            • GizMoCuzG
                              GizMoCuzG
                              GizMoCuz
                              No, the Node is resetting itself with the messages in the first post.
                              If i disable debug, it is logging the IP Address over and over again (each second), connection is reset at that moment
                                tekkaT
                                tekkaT
                                tekka
                                @GizMoCuz Please upload your sketch and describe your configuration, I will try to reproduce with my HW.
                                • GizMoCuzG
                                  GizMoCuzG
                                  GizMoCuz
                                  #30
                                  The sketch is 99,999% the same as 'GatewayW5100' except i changed:
                                  #define MY_IP_ADDRESS 192,168,0,50
                                  The default Arduino ethernet server examples work perfectly
                                  Thanks in advance !
                                    Thanks in advance !
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @GizMoCuz did you uncomment
                                    as suggested above?
                                    GizMoCuzG 1 Reply Last reply
                                    • tekkaT tekka
                                      as suggested above?
                                      GizMoCuzG
                                      GizMoCuzG
                                      GizMoCuz
                                      #32
                                      as suggested above?
                                      Yep, see three posts up (If i disable debug, it is logging the IP Address over and over again (each second), connection is reset at that moment)
                                      And unfortunately does not explain why version 1.5 is running (but missing important features/fixes)
                                        as suggested above?
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @GizMoCuz I cannot reproduce your observation with a UNO and W5100 shield. How about power-supply, SPI settings/pins in yor setup?
                                          Maks_K
                                          I have the same problem:
                                          Mega 2560+ w5100
                                          Lib 1.5.4 all good
                                          Lib 2.0 restart again and again
