  3. [Solved] MySensors 2.0 Ethernet gateway (ENC28J60) restart / IP issue
49 Posts 9 Posters 28.6k Views 8 Watching
  • TheoLT TheoL
    @intellium I'm no expert. But does the simple example work when everything is connected (radio and LED's)?
    intelliumI
    intelliumI
    intellium
    @TheoL Yeah, it's exactly the same setup (hardware wise). Has to be something in the software part (MySensors / UIPEthernet) thats not working correctly.
    Does anybody have a working setup using MySensors 2.0 Gateway with an ENC28J60 module ?
    TheoLT YveauxY tekkaT 3 Replies Last reply
    • intelliumI intellium
      TheoLT
      TheoLT
      TheoL
      @intellium Maybe @mfalkvidd ?
        @intellium with w5100 we currently face an issue, causing the arduino to reset, caused by a bug in the avr gcc tool chain.
        Until fixed in the tool chain and adopted by arduino there is not much more than trial and error to see if it runs stable. Reverting arduino ide won't help either, because this bug has been in for a long time.
        I'm not saying this is what is happening to you, but it just might.
        intelliumI 1 Reply Last reply
        • YveauxY Yveaux
          intelliumI
          intelliumI
          intellium
          @Yveaux Hmm, thats annoying. So, if I'm experiencing this issue, I'm basically S.O.L. ? :(
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            @intellium The avr toolchain bug is related to variadic arguments used for debug prints. If you comment MY_DEBUG, do you still have the issue?
            • tekkaT tekka
              intelliumI
              intelliumI
              intellium
              @tekka You sir, are my new best friend :)
              Sure enough, disabling the debug and uploading the code seems to make everything work. The gateway outputs the correct IP and is now pingable !
              tekkaT TheoLT 2 Replies Last reply
                tekkaT
                tekkaT
                tekka
                @intellium excellent :) Have fun
                  TheoLT
                  TheoLT
                  TheoL
                  @intellium @Tekka is actually the best friend for most of us ;-)
                  tekkaT 1 Reply Last reply
                  • TheoLT TheoL
                    tekkaT
                    tekkaT
                    tekka
                    @TheoL haha, that's the MySensors spirit :sparkles:
                    • intelliumI
                      intelliumI
                      intellium
                      May have spoken to soon....
                      Although the gateway now runs, after a few mins it seems to die. LAN leds keep blinking everything seems in order, but it's not pingable anymore and Domoticz starts logging messages that the gateway is unreachable. Is this somehow related? Or is this a whole different issue?
                      @tekka probably knows what to do, right? :D
                        tekkaT
                        tekkaT
                        tekka
                        @intellium can you add a serial print in loop() to see if the GW or the lan module freezes?
                        • tekkaT tekka
                          intelliumI
                          intelliumI
                          intellium
                          @tekka Sorry it took a while.
                          I gave it a try, but ever since adding print statements to the gateway loop(), the sensor nodes stopped communicating with it given FPAR failures. Even when I remove the print statements and return to the previous state, it keeps on giving FPAR failures on all sensor nodes... What would cause this ?
                            tekkaT
                            tekkaT
                            tekka
                            @intellium hmm, hard to diagnose without additional information - could be power-related. Can you add a better/stronger power-supply?
                            • tekkaT tekka
                              intelliumI
                              intelliumI
                              intellium
                              @tekka Before I go the route of messing with the power supply, I did some fiddling...
                              I added the following statements to both the gateway and the sensor sketches:
                              //LOW POWER MODE RADIO
                              //DEBUG FOR RADIO
                              #define MY_DEBUG_VERBOSE_RF24
                              //RADIO THROUGHPUT
                              #define MY_RF24_DATARATE RF24_1MBPS
                              Next I put them a little bit closer together (around 80cm apart). The FPAR:FAIL message are gone now. I see in the output on the Sensor node that it communicates with the gateway. Currently, the gateway is running with this setup and the controller (Domoticz) gets values. So this seems to be working OK.
                              However, on the sensor node, the log sometimes indicates an error. Something like this :
                              RF24:write register, reg=0, value=14
                              RF24:open writing pipe, recipient=0
                              RF24:write register, reg=10, value=0
                              RF24:write register, reg=16, value=0
                              RF24:send message to 0, len=12
                              RF24:flushTX
                              RF24:write register, reg=7, value=48
                              RF24:MAX_RT
                              RF24:flushTX
                              RF24:start listening
                              RF24:write register, reg=0, value=15
                              RF24:write register, reg=10, value=1
                              !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=fail:29.0
                              T: 29.00
                              RF24:write register, reg=0, value=12
                              RF24:power down
                              RF24:power down
                              RF24:stop listening
                              RF24:flushTX
                              TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=ok:36.0
                              H: 36.00
                              RF24:power down
                              From what I've read, the st:fail means there was an error transmitting the value. Could this still be power related ? It seems so intermittent to me that my gut tells me power isn't the issue.
                              • intelliumI
                                intelliumI
                                intellium
                                @tekka Next I tried is adding a capacitor to both the gateway and node RF module. I added a 10uF capacitor to both of them. This seems to have stabilized RF communication. I'm not seeing any failures anymore and data is flowing...
                                Back to the original issue... The gateway that seems to die...
                                I've added some debug statements to the loop() to see if this would keep on running when the gateway seemingly dies.
                                After 2 hours of operation, the gateway stopped responding to pings, and the controller also noticed the gateway was not alive anymore. When this happens, the output of the serial console is :
                                New loop iteration: 21734
                                New loop iteration: 21735
                                New loop iteration: 21736
                                New loop iteration: 21737
                                New loop iteration: 21738
                                New loop iteration: 21739
                                New loop iteration: 21740
                                New loop iteration: 21741
                                New loop iteration: 21742
                                New loop iteration: 21743
                                New loop iteration: 21744
                                As you can see, my loop code keeps on running at this point, suggesting it's just the ENC interface thats no longer reachable or has an issue. When I close and re-open the serial port monitor from the Arduino IDE, the gateway springs back to life and everything starts working again.
                                • intelliumI
                                  intelliumI
                                  intellium
                                  The next run it only took 20 mins. before the gateway stopped responding....
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @intellium Issues with ENC: https://forum.arduino.cc/index.php?topic=398258.0
                                    sounds pretty much the same...
                                    • tekkaT tekka
                                      intelliumI
                                      intelliumI
                                      intellium
                                      @tekka Yeah, I was afraid of that....
                                      I think I might just build a serial gateway and use that for Domoticz as those seem a lot more stable. Then when I find a good source for a w5100 module, I'll get some of those for building an ethernet gateway.
                                      • intelliumI
                                        intelliumI
                                        intellium
                                        Just a little update:
                                        I build a serial gateway and attached it to Domoticz. Been working ever since, even during the night. Guess this is the way to go for now.
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @intellium Sounds good - fyi, I'm using both, W5100 and ESP8266-based GWs, w/o issues.
                                          intelliumI 2 Replies Last reply
