  2. Feature Requests
  3. Possibility to add custom variables
Scheduled Pinned Locked Moved Feature Requests
3 Posts 2 Posters 1.9k Views 2 Watching
  • KnuppelK Offline
    KnuppelK Offline
    Knuppel
    Setup: Arduino Dallas temperature sensor, in combination with Vera Serial Gateway.
    I'm trying to compare LastTemperature value to CurrentTemperature so I can start the bathroomfan, when temperature rises. Doing so using Vera's 'temperature goes above/below' is too slow. The hot water pipe cools down too slowly.
    Problem is, there is only 1 variable sent (CurrentTemperature). I can add custom variables to a temperature device in Vera, but can they be updated by my sketch / Vera Arduino nodes? If so how?
    • KnuppelK Offline
      KnuppelK Offline
      Knuppel
      I have a workaround installed now. It's not pretty though. :grin:
      Created a second temperature sensor in my sketch and did the mathmetics there also. In Vera I monitor this device for +2 or -2.
           send(msg.setSensor(0).set(temperature,1));
            // Custom
            temp_diff=temperature-lastTemperature[0];
            Serial.println("Temperatures compared: ");
            Serial.println(temp_diff);
            send(msg.setSensor(1).set(temp_diff,1));
      • KnuppelK Knuppel
              // Custom
        T Offline
        T Offline
        TheoL
        @Knuppel great and creative solution.
        12.2k
