  3. NRF24L01 can't find parent on gateway
7 Posts 3 Posters 3.3k Views 1 Watching
  • alfredbA Offline
    alfredbA Offline
    alfredb
    Hi there,
    I'm using an ethernet gateway on an UNO R3 with some locally attached sensors and an NRF24L01 attached to it. The locally attached sensors work fine (sending to Domoticz).
    Now I have another Robotdyn UNO with one sensor attached and an NRF24L01 but I can't get it to find the parent on the gateway.
    Tried lowering the power and moving the two closer and further away from each other, but all makes no difference. The node id get's assigned. Below are the logs from both gateway and client:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;RF24:write register, reg=0, value=14
    0;255;3;0;9;RF24:write register, reg=3, value=3
    0;255;3;0;9;RF24:write register, reg=4, value=95
    0;255;3;0;9;RF24:write register, reg=5, value=76
    0;255;3;0;9;RF24:write register, reg=6, value=35
    0;255;3;0;9;RF24:read register, reg=6, value=35
    0;255;3;0;9;RF24:read register, reg=5, value=76
    0;255;3;0;9;RF24:write register, reg=16, value=115
    0;255;3;0;9;RF24:write register, reg=29, value=6
    0;255;3;0;9;RF24:write register, reg=2, value=2
    0;255;3;0;9;RF24:write register, reg=1, value=0
    0;255;3;0;9;RF24:write register, reg=28, value=3
    0;255;3;0;9;RF24:flushRX
    0;255;3;0;9;RF24:flushTX
    0;255;3;0;9;RF24:write register, reg=7, value=112
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;RF24:write register, reg=2, value=3
    0;255;3;0;9;RF24:write register, reg=1, value=1
    0;255;3;0;9;RF24:start listening
    0;255;3;0;9;RF24:write register, reg=0, value=15
    0;255;3;0;9;RF24:write register, reg=10, value=0
    0;255;3;0;9;TSM:READY
    IP: 192.168.2.230
    Humid sensor setup complete
    presented data...
    T: 23.00
    H: 51.00
    0;255;3;0;9;Eth: connect
    presented data...
    0;255;3;0;9;Eth: 0;0;3;0;2;
    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    0;255;3;0;9;TSP:SANCHK:OK
    H: 52.00
    Client:
    verbose:
    TSM:INIT
    RF24:flushRX
    RF24:flushTX
    TSM:RADIO:OK
    RF24:write register, reg=10, value=5
    TSP:ASSIGNID:OK (ID=5)
    TSM:FPAR
    RF24:stop listening
    RF24:open writing pipe, recipient=255
    RF24:write register, reg=10, value=255
    RF24:write register, reg=16, value=255
    RF24:send message to 255, len=7
    RF24:flushTX
    RF24:write register, reg=7, value=48
    RF24:MAX_RT
    RF24:flushTX
    TSP:MSG:SEND 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    RF24:stop listening
    RF24:flushTX
    RF24:MAX_RT
    RF24:flushTX
    TSM:FPAR
    RF24:stop listening
    RF24:flushTX
    RF24:MAX_RT
    RF24:flushTX
    TSM:FPAR
    RF24:stop listening
    RF24:flushTX
    RF24:MAX_RT
    RF24:flushTX
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    RF24:write register, reg=0, value=12
    RF24:power down
    TSM:INIT
    Anyone an idea?
    • alfredbA alfredb
      Hi there,
      IP: 192.168.2.230
      presented data...
      T: 23.00
      H: 51.00
      presented data...
      H: 52.00
      Client:
      verbose:
      TSM:INIT
      RF24:flushRX
      RF24:flushTX
      TSM:RADIO:OK
      TSM:FPAR
      RF24:stop listening
      RF24:flushTX
      RF24:MAX_RT
      RF24:flushTX
      TSM:FPAR
      RF24:stop listening
      RF24:flushTX
      RF24:MAX_RT
      RF24:flushTX
      TSM:FPAR
      RF24:stop listening
      RF24:flushTX
      RF24:MAX_RT
      RF24:flushTX
      TSM:FPAR
      RF24:stop listening
      RF24:flushTX
      RF24:MAX_RT
      RF24:flushTX
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      RF24:power down
      TSM:INIT
      Anyone an idea?
      T Offline
      T Offline
      tekka
      @alfredb Please upload your GW & node sketch. Are you using nRF24L01 or nRF24L01+ radios?
      • alfredbA Offline
        alfredbA Offline
        alfredb
        Hi Tekka,
        Thanks for your reply. I'm using the nRF24L01 (without the +). Hereby the sketches (the gw one is not complete yet as got stuck getting the gw and node talking.
        GW sketch:
        #define MY_DEBUG // Enable debug prints to serial monitor
        #define MY_DEBUG_VERBOSE_RF24
        #include <Time.h>
        #include <Ethernet.h>
        #include <RemoteTransmitter.h>
        #include <RemoteReceiver.h>
        #include <NewRemoteReceiver.h>
        #include <SensorReceiver.h>
        #include <InterruptChain.h>
        #define GATEWAY_FEATURE
        #define MY_GATEWAY_W5100
        #define MY_NODE_ID 0
        //#define MY_RF24_SANITY_CHECK
        #define SS_ETHERNET 10
        #define MY_PORT 5003
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        #define CHILD_ID_RECEIVER 2
        #define CHILD_ID_ACTION_SWITCH_A 3
        #define V_RCODE 0
        const char SYSTEMCODE = char(31); // Adjust this to your own SYSTEMCODE see RemoteTransmitter.h
        // When W5500 is connected we have to move CE/CSN pins for NRF radio
        #define MY_RF24_CE_PIN 5
        #define MY_RF24_CS_PIN 6
        // Intantiate a new KaKuTransmitter remote, also use pin 11 (same transmitter!)
        KaKuTransmitter kaKuTransmitter(8);
        DHT dht;
        float lastTemp;
        float lastHum;
        float RFCode = 0;
        bool metric = true;
        // Protocol handler
        bool RFCodeAvailable = false;
        int value01 = 0;
        #define MY_IP_GATEWAY_ADDRESS 192,168,2,254
        #define MY_IP_ADDRESS 192,168,2,230
        #define MY_MAC_ADDRESS 0x00, 0x08, 0xDC, 0xF4, 0x6D, 0xC1
        int sensorValue = 0; // variable to store the value coming from the sensor
        #include <MyConfig.h>
        MyMessage msgRCode(CHILD_ID_RECEIVER, V_LIGHT);
        MyMessage msgDeviceA( CHILD_ID_ACTION_SWITCH_A, V_LIGHT );
        Serial.println("Humid sensor setup complete");
        //RemoteReceiver::init(-1, 2, showOldCode);
        //NewRemoteReceiver::init(-1, 2, showNewCode);
        //InterruptChain::addInterruptCallback(0, RemoteReceiver::interruptHandler);
        //InterruptChain::addInterruptCallback(0, NewRemoteReceiver::interruptHandler);
        //358694,
        while (!Serial) {
        ; // wait for serial port to connect.
        // shows the received code sent from an old-style remote switch
        void showOldCode(unsigned long receivedCode, unsigned int period) {
        // Print the received code.
        Serial.print("Code: ");
        Serial.print(receivedCode);
        Serial.print(", period: ");
        Serial.print(period);
        Serial.println("us.");
        float RFCode = (receivedCode);
        float RFCodeAvailable = true;
        // Serial.println (RFCodeAvailable);
        // Send the received code.
        if (RFCode=='358694') {
        Serial.println ("detected RFCode");
        send(msgRCode.set(RFCode, 1));
        send(msgDeviceA.set(RFCode, 1));
        // Shows the received code sent from an new-style remote switch
        void showNewCode(NewRemoteCode receivedCode) {
        Serial.print("Addr ");
        Serial.print(receivedCode.address);
        if (receivedCode.groupBit) {
        Serial.print(" group");
        Serial.print(" unit ");
        Serial.print(receivedCode.unit);
        switch (receivedCode.switchType) {
        case NewRemoteCode::off:
        Serial.print(" off");
        case NewRemoteCode::on:
        Serial.print(" on");
        case NewRemoteCode::dim:
        Serial.print(" dim level ");
        Serial.print(receivedCode.dimLevel);
        case NewRemoteCode::on_with_dim:
        Serial.print(" on with dim level ");
        Serial.print(receivedCode.period);
        sendSketchInfo("Temp and Humidity", "1.0");
        present(CHILD_ID_HUM, S_HUM);
        sendSketchInfo("Kaku Receiver", "2.0");
        present(CHILD_ID_RECEIVER, S_LIGHT);
        present (CHILD_ID_ACTION_SWITCH_A, S_LIGHT);
        sendBatteryLevel(100); // It just looks better in Domoticz
        Serial.println("presented data...");
        //Fetch temperatures from DHT sensor
        if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        #ifdef MY_DEBUG
        Serial.print("T: ");
        if (isnan(humidity)) {
        lastHum = humidity;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        // float RFCode = (receivedCode);
        // float RFCodeAvailable = true;
        // kaKuTransmitter.sendSignal('B',2,true);
        Serial.println ("MSG from sensor:");
        Serial.println (message.sensor);
        Serial.println (mGetCommand(message));
        Serial.println (mGetPayloadType(message));
        Serial.println ("Message value:");
        Serial.println (message.getString(_convBuf));
        char *hextstring = (message.getString(_convBuf));
        Serial.println ("Converted:");
        Serial.println (*hextstring);
        if (*hextstring=='1') {
        Serial.println("AAN");
        if (*hextstring=='0') {
        Serial.println ("UIT");
        kaKuTransmitter.sendSignal('B',2,false);
        Node Sketch:
        #define MY_NODE_ID 5
        #define MY_PARENT_NODE_ID 0
        // Set RF24L01 channel number
        //#define MY_RF24_CHANNEL 125
        // Define nRF24L01 datarate
        #define COMPARE_PH 1 // Send PH only if changed? 1 = Yes 0 = No
        unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
        float lastPH;
        boolean receivedConfig = false;
        boolean metric = true;
        //Kraanwater 7,380 28-07-2016
        int ph_pin = A5; //This is the pin number connected to Po
        Serial.begin(9600);
        // Initialize PH message
        MyMessage msg(0, V_PH);
        float getPH() {
        //query your PH sensor here (I2C,Serial,Phidget...)
        float measure = analogRead(ph_pin);
        Serial.print("Measure: ");
        //Serial.print(measure);
        double voltage = 5 / 1024.0 * measure; //classic digital to voltage conversion
        //double voltage = 5 / 1024.0 * measure; //classic digital to voltage conversion
        Serial.print("\tVoltage: ");
        Serial.print(voltage, 3);
        // PH_step = (voltage@PH7 - voltage@PH4) / (PH7 - PH4)
        // PH_probe = PH7 - ((voltage@PH7 - voltage@probe) / PH_step)
        float Po = 7 + ((2.5 - voltage) / 0.18);
        Serial.print("\tPH: ");
        Serial.print(Po, 3);
        //return Po;
        sendSketchInfo("PH Sensor", "1.1");
        present(0, S_WATER_QUALITY);
        Serial.println("");
        delay(2000);
        float ph = getPH();
        Serial.print(ph);
        #if COMPARE_PH == 1
        if (lastPH != ph) {
        // Send in the new PH value
        send(msg.set(ph, 1));
        // Save new PH value for next compare
        lastPH = ph;
        #if COMPARE_PH == 1
        //sleep(SLEEP_TIME);
        alfredbA 1 Reply Last reply
        • alfredbA alfredb
          Hi Tekka,
          GW sketch:
          #include <Time.h>
          #define V_RCODE 0
          DHT dht;
          float lastTemp;
          float lastHum;
          float RFCode = 0;
          bool metric = true;
          // Protocol handler
          int value01 = 0;
          //358694,
          while (!Serial) {
          if (!metric) {
          #ifdef MY_DEBUG
          lastHum = humidity;
          #ifdef MY_DEBUG
          Node Sketch:
          float lastPH;
          Serial.begin(9600);
          float getPH() {
          //return Po;
          Serial.println("");
          delay(2000);
          float ph = getPH();
          Serial.print(ph);
          #if COMPARE_PH == 1
          if (lastPH != ph) {
          lastPH = ph;
          #if COMPARE_PH == 1
          alfredbA Offline
          alfredbA Offline
          alfredb
          @alfredb
          Hi there, meanwhile I've been testing with another gateway (on a NodeMCU) and this worked right away. So there is an issue here with the NRF24L01 module on the Uno, perhaps it has something to do with using the ICSP connections for the NRF24L01 module or the combination with a W5500?
          Regards
          • O Offline
            O Offline
            Oitzu
            wrote on last edited by Oitzu
            Short: probably. TrY soft spi for the nrf24
            • alfredbA alfredb
              @alfredb
              Regards
              T Offline
              T Offline
              tekka
              wrote on last edited by tekka
              @alfredb nRF24L01 (non-P) are not supported in 2.0.0, these radios have limited data rates (only 1 and 2Mbps, no 250kbps). I assume you used a different module on your NodeMCU GW?
              The good news is, I've added a fix to 2.0.1 (dev) to support non-P modules, you try the dev lib and set
              #define MY_RF24_DATARATE RF24_1MBPS
              on all nodes an GW.
              • T tekka
                on all nodes an GW.
                alfredbA Offline
                alfredbA Offline
                alfredb
                @tekka Thanks again, I'll give it a try! I already defined the limited data rate but I was not aware of the fact that the non-P type was not supported.
