  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 71.9k Views 37 Watching
    Haha, right. Last question, if I also want the sensor to report battery-usage. Is there any way to accomplish that without soldering any more resistors?
    @Cliff-Karlsson Yes, there is!
    Use my Vcc library!
    dynamiteD 1 Reply Last reply
    • YveauxY Yveaux
      Use my Vcc library!
      dynamiteD
      dynamiteD
      dynamite
      @Yveaux @Cliff-Karlsson but in the scheme of cliff he is taken the power after the power regulator. So you are not
      Measuring the battery with your VCC library.
      • dynamiteD dynamite
        @dynamite You're right then. I didn't read his howto, just answered how to read battery voltage without voltage divider ;-)
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Ok, but if I measured right when talking the power from the regulator you could get 3v or ~4.5v witch i guess is directly from the batteries. If I connect the 4.5v to the power input on the same side as the tx/rx can I still not use the vcc library?
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            How would a sketch for this PIR look like? I tried combining the PIR and RelayActuator but my skills are not enough.
            This is what I have came up with:
             * Version 1.0 - Henrik Ekblad
            // Enable debug prints
            //#define MY_RADIO_NRF24
            #define MY_RADIO_RFM69
            #define RELAY_1  9  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            #define SECONDARY_CHILD_ID 4
            void before() {
                pinMode(pin, OUTPUT);
            // Initialize motion message
            void presentation()  {
              sendSketchInfo("Light/Motion Sensor ikea", "1.0");
              present(CHILD_ID, S_MOTION);
                present(sensor, S_LIGHT);
              // Read digital motion value
              Serial.println(tripped);
              if (message.type==V_LIGHT) {
                 // Change relay state
                 // Store state in eeprom
            But it does not complie after the last part is added. And I would also like to get the vcc -stuff into the same sketch. Could someone post a working sketch for this?
              dynamiteD
              dynamiteD
              dynamite
              @Cliff-Karlsson you can only use the VCC sketch if you by pass the voltage regulators. So power the arduino from two batteries by a separate wire.
                void before() {
                dynamiteD
                dynamiteD
                dynamite
                @Cliff-Karlsson the receive routine is out of the repeat loop
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  Ok, tried placing it in the loop to but with the same result. In the RelayActuator it looks like it really is placed outside the loop: RelayActuator
                  What would the prefered way be to connect the power to the a 3.3v arduino for the best battery time?
                  4.5v from the PIR regulator --> Arduino RAW (using 3 batteries)
                  3v from the PIR regulator --> Arduino VCC (3batteries)
                  And how would I power it from only 2 batteries? would not the PIR or leds need higher voltage than 3v ?
                    @Cliff-Karlsson see here: https://forum.mysensors.org/topic/3756/multisensor-pir-based-on-ikea-molgan/58
                    • pjblinkP
                      pjblinkP
                      pjblink
                      Hi guys,
                      I'm struggling with this one unfortunately, i can't get it to trip/untrip.
                      Sketch is identical to the motion example.
                      I've removed the photo diode (not bridged the gap, it looks like bridging the gap stops it from tripping at all, leaving it open means it trips whatever the light level is). This was tested without connecting to the arduino, working as normal.
                      So i've removed resistor 17, and connected my arduino pin 4 up to the chip side of where R17 was. I'm running the main board of the existing power lines, but i've tapped into the + of the middle battery and that's going to VCC on the arduino. Arduino nano GND is connected to the main board -.
                      Where am I going wrong? I've tried this on two boards now and they're both acting the same. Serial monitor is just showing me:
                      send: 14-14-4-0 s=1,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
                      Patrick
                      • pjblinkP pjblink
                        Hi guys,
                        Patrick
                        dynamiteD
                        dynamiteD
                        dynamite
                        @pjblink hi your setup sounds ok to me! And from your debug I think it is transmitting a value. Is this value submitted after activating the pir?
                        After activation the is high for about 30 sec then it sound be low again. Maybe you can verify this procedure. Can you debug on the receiving side?
                        • gijssG
                          gijssG
                          gijss
                          I have build a couple of these and they work fine. Replacing batteries with the baseplate is really a huge advantage, and battery life seems to be pretty good.
                          I have one issue though: I have built one including an LDR. But this seems to freeze after a random time, no longer reacting to movement.
                          @dynamite , can you may be share your code and the way you have attached your LDR to the arduino etc?
                          Many thanks!
                          dynamiteD 2 Replies Last reply
                          • gijssG gijss
                            Many thanks!
                            dynamiteD
                            dynamiteD
                            dynamite
                            @gijss Hi I will try to find the code tonight and post it on github.
                            • Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              Guys,
                              This is fantastic. Can someone summarise the best practises for using an Arduino Pro mini, to benefit from maximum battery life and voltage monitoring?
                              Thank you!
                              • Mark SwiftM Mark Swift
                                Guys,
                                Thank you!
                                @Mark-Swift https://www.mysensors.org/build/battery has information on how to get good battery life
                                • gijssG gijss
                                  Many thanks!
                                  dynamiteD
                                  dynamiteD
                                  dynamite
                                  @gijss the code can be found here. But I don't know the actual status of this code as I have not used it for a while and I was busy creating a dimmer. But maybe you can copy parts out of it.
                                  https://github.com/rspaargaren/My-sensors-IKEA/blob/master/multisensor.ino
                                  gijssG 1 Reply Last reply
                                    gijssG
                                    gijssG
                                    gijss
                                    @dynamite Thanks for the code, I am sure it will prove to be useful. Will try to experiment this weekend. Can you also share how you connected the LDR to the arduino? I have the feeling I might be using a suboptimal wiring scheme (or wrong resistor) resulting in shorter battery life.
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      @Yveaux Did you finish the PCB for the molgan?, If so is it possible for you to share the files?
                                      YveauxY 2 Replies Last reply
                                      • L
                                        L
                                        LastSamurai
                                        I would be interested too!
                                          @Cliff-Karlsson Yes, works like a charm!
                                          It has been on my ToDo list for quite a long time to publish the files -- please hold on a little longer ;-)
