  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 71.9k Views 37 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    How would a sketch for this PIR look like? I tried combining the PIR and RelayActuator but my skills are not enough.
    This is what I have came up with:
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define RELAY_1  9  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define SECONDARY_CHILD_ID 4
    void before() {
        pinMode(pin, OUTPUT);
    // Initialize motion message
    void presentation()  {
      sendSketchInfo("Light/Motion Sensor ikea", "1.0");
      present(CHILD_ID, S_MOTION);
        present(sensor, S_LIGHT);
      // Read digital motion value
      Serial.println(tripped);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    But it does not complie after the last part is added. And I would also like to get the vcc -stuff into the same sketch. Could someone post a working sketch for this?
    dynamiteD 1 Reply Last reply
      Ok, but if I measured right when talking the power from the regulator you could get 3v or ~4.5v witch i guess is directly from the batteries. If I connect the 4.5v to the power input on the same side as the tx/rx can I still not use the vcc library?
      dynamiteD
      dynamiteD
      dynamite
      @Cliff-Karlsson you can only use the VCC sketch if you by pass the voltage regulators. So power the arduino from two batteries by a separate wire.
        void before() {
        dynamiteD
        dynamiteD
        dynamite
        @Cliff-Karlsson the receive routine is out of the repeat loop
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Ok, tried placing it in the loop to but with the same result. In the RelayActuator it looks like it really is placed outside the loop: RelayActuator
          What would the prefered way be to connect the power to the a 3.3v arduino for the best battery time?
          4.5v from the PIR regulator --> Arduino RAW (using 3 batteries)
          3v from the PIR regulator --> Arduino VCC (3batteries)
          And how would I power it from only 2 batteries? would not the PIR or leds need higher voltage than 3v ?
            @Cliff-Karlsson see here: https://forum.mysensors.org/topic/3756/multisensor-pir-based-on-ikea-molgan/58
            • pjblinkP
              pjblinkP
              pjblink
              Hi guys,
              I'm struggling with this one unfortunately, i can't get it to trip/untrip.
              Sketch is identical to the motion example.
              I've removed the photo diode (not bridged the gap, it looks like bridging the gap stops it from tripping at all, leaving it open means it trips whatever the light level is). This was tested without connecting to the arduino, working as normal.
              So i've removed resistor 17, and connected my arduino pin 4 up to the chip side of where R17 was. I'm running the main board of the existing power lines, but i've tapped into the + of the middle battery and that's going to VCC on the arduino. Arduino nano GND is connected to the main board -.
              Where am I going wrong? I've tried this on two boards now and they're both acting the same. Serial monitor is just showing me:
              send: 14-14-4-0 s=1,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
              Patrick
              • pjblinkP pjblink
                Hi guys,
                Patrick
                dynamiteD
                dynamiteD
                dynamite
                @pjblink hi your setup sounds ok to me! And from your debug I think it is transmitting a value. Is this value submitted after activating the pir?
                After activation the is high for about 30 sec then it sound be low again. Maybe you can verify this procedure. Can you debug on the receiving side?
                • gijssG
                  gijssG
                  gijss
                  I have build a couple of these and they work fine. Replacing batteries with the baseplate is really a huge advantage, and battery life seems to be pretty good.
                  I have one issue though: I have built one including an LDR. But this seems to freeze after a random time, no longer reacting to movement.
                  @dynamite , can you may be share your code and the way you have attached your LDR to the arduino etc?
                  Many thanks!
                  dynamiteD 2 Replies Last reply
                  • gijssG gijss
                    Many thanks!
                    dynamiteD
                    dynamiteD
                    dynamite
                    @gijss Hi I will try to find the code tonight and post it on github.
                    • Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      Guys,
                      This is fantastic. Can someone summarise the best practises for using an Arduino Pro mini, to benefit from maximum battery life and voltage monitoring?
                      Thank you!
                      • Mark SwiftM Mark Swift
                        Guys,
                        Thank you!
                        @Mark-Swift https://www.mysensors.org/build/battery has information on how to get good battery life
                        • gijssG gijss
                          Many thanks!
                          dynamiteD
                          dynamiteD
                          dynamite
                          @gijss the code can be found here. But I don't know the actual status of this code as I have not used it for a while and I was busy creating a dimmer. But maybe you can copy parts out of it.
                          https://github.com/rspaargaren/My-sensors-IKEA/blob/master/multisensor.ino
                          gijssG 1 Reply Last reply
                          • dynamiteD dynamite
                            gijssG
                            gijssG
                            gijss
                            @dynamite Thanks for the code, I am sure it will prove to be useful. Will try to experiment this weekend. Can you also share how you connected the LDR to the arduino? I have the feeling I might be using a suboptimal wiring scheme (or wrong resistor) resulting in shorter battery life.
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              @Yveaux Did you finish the PCB for the molgan?, If so is it possible for you to share the files?
                              YveauxY 2 Replies Last reply
                              • L
                                L
                                LastSamurai
                                I would be interested too!
                                  @Cliff-Karlsson Yes, works like a charm!
                                  It has been on my ToDo list for quite a long time to publish the files -- please hold on a little longer ;-)
                                  • YveauxY Yveaux
                                    dynamiteD
                                    dynamiteD
                                    dynamite
                                    @Yveaux great as my project was on hold for a while but still on the to do list...:-)
                                      @Cliff-Karlsson @LastSamurai @dynamite I just published the PCB on [OpenHardware.io].(https://www.openhardware.io/view/274/Ikea-Molgan-Hack)
                                      A sketch will follow soon.
                                      Enjoy!
                                      • gijssG gijss
                                        gijssG
                                        gijssG
                                        gijss
                                        @dynamite
                                        It has been a while (mainly because the PIR was out of order for other reasons) but now I am restarting the project and again it happened that the PIR no longer responded. So I took a look at your code, but it seems your are using a BH1750 light sensor, is that correct? And are you using that in fact at the moment, or did you switch to LDR and is this perhaps not the latest version of the code?
                                        Gijss
                                        • gijssG gijss
                                          @dynamite
                                          Gijss
                                          dynamiteD
                                          dynamiteD
                                          dynamite
                                          @gijss Hi let me check upon that as the PIR has not been on the top of my priority list. I have one of the PIR based on LDR sensor. But I was working on a BH1750 sensor. So most probably the code is related to that version.
