  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 70.6k Views 37 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Ok, but if I measured right when talking the power from the regulator you could get 3v or ~4.5v witch i guess is directly from the batteries. If I connect the 4.5v to the power input on the same side as the tx/rx can I still not use the vcc library?
    dynamiteD 1 Reply Last reply
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      How would a sketch for this PIR look like? I tried combining the PIR and RelayActuator but my skills are not enough.
      This is what I have came up with:
       * Version 1.0 - Henrik Ekblad
      // Enable debug prints
      //#define MY_RADIO_NRF24
      #define MY_RADIO_RFM69
      #define RELAY_1  9  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define SECONDARY_CHILD_ID 4
      void before() {
          pinMode(pin, OUTPUT);
      // Initialize motion message
      void presentation()  {
        sendSketchInfo("Light/Motion Sensor ikea", "1.0");
        present(CHILD_ID, S_MOTION);
          present(sensor, S_LIGHT);
        // Read digital motion value
        Serial.println(tripped);
        if (message.type==V_LIGHT) {
           // Change relay state
           // Store state in eeprom
      But it does not complie after the last part is added. And I would also like to get the vcc -stuff into the same sketch. Could someone post a working sketch for this?
        dynamiteD
        dynamiteD
        dynamite
        @Cliff-Karlsson you can only use the VCC sketch if you by pass the voltage regulators. So power the arduino from two batteries by a separate wire.
          void before() {
          dynamiteD
          dynamiteD
          dynamite
          @Cliff-Karlsson the receive routine is out of the repeat loop
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            Ok, tried placing it in the loop to but with the same result. In the RelayActuator it looks like it really is placed outside the loop: RelayActuator
            What would the prefered way be to connect the power to the a 3.3v arduino for the best battery time?
            4.5v from the PIR regulator --> Arduino RAW (using 3 batteries)
            3v from the PIR regulator --> Arduino VCC (3batteries)
            And how would I power it from only 2 batteries? would not the PIR or leds need higher voltage than 3v ?
              @Cliff-Karlsson see here: https://forum.mysensors.org/topic/3756/multisensor-pir-based-on-ikea-molgan/58
              • pjblinkP
                pjblinkP
                pjblink
                Hi guys,
                I'm struggling with this one unfortunately, i can't get it to trip/untrip.
                Sketch is identical to the motion example.
                I've removed the photo diode (not bridged the gap, it looks like bridging the gap stops it from tripping at all, leaving it open means it trips whatever the light level is). This was tested without connecting to the arduino, working as normal.
                So i've removed resistor 17, and connected my arduino pin 4 up to the chip side of where R17 was. I'm running the main board of the existing power lines, but i've tapped into the + of the middle battery and that's going to VCC on the arduino. Arduino nano GND is connected to the main board -.
                Where am I going wrong? I've tried this on two boards now and they're both acting the same. Serial monitor is just showing me:
                send: 14-14-4-0 s=1,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
                Patrick
                • pjblinkP pjblink
                  Hi guys,
                  Patrick
                  dynamiteD
                  dynamiteD
                  dynamite
                  @pjblink hi your setup sounds ok to me! And from your debug I think it is transmitting a value. Is this value submitted after activating the pir?
                  After activation the is high for about 30 sec then it sound be low again. Maybe you can verify this procedure. Can you debug on the receiving side?
                  • gijssG
                    gijssG
                    gijss
                    I have build a couple of these and they work fine. Replacing batteries with the baseplate is really a huge advantage, and battery life seems to be pretty good.
                    I have one issue though: I have built one including an LDR. But this seems to freeze after a random time, no longer reacting to movement.
                    @dynamite , can you may be share your code and the way you have attached your LDR to the arduino etc?
                    Many thanks!
                    dynamiteD 2 Replies Last reply
                    • gijssG gijss
                      Many thanks!
                      dynamiteD
                      dynamiteD
                      dynamite
                      @gijss Hi I will try to find the code tonight and post it on github.
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        Guys,
                        This is fantastic. Can someone summarise the best practises for using an Arduino Pro mini, to benefit from maximum battery life and voltage monitoring?
                        Thank you!
                        • Mark SwiftM Mark Swift
                          Guys,
                          Thank you!
                          @Mark-Swift https://www.mysensors.org/build/battery has information on how to get good battery life
                          • gijssG gijss
                            Many thanks!
                            dynamiteD
                            dynamiteD
                            dynamite
                            @gijss the code can be found here. But I don't know the actual status of this code as I have not used it for a while and I was busy creating a dimmer. But maybe you can copy parts out of it.
                            https://github.com/rspaargaren/My-sensors-IKEA/blob/master/multisensor.ino
                            gijssG 1 Reply Last reply
                            • dynamiteD dynamite
                              gijssG
                              gijssG
                              gijss
                              @dynamite Thanks for the code, I am sure it will prove to be useful. Will try to experiment this weekend. Can you also share how you connected the LDR to the arduino? I have the feeling I might be using a suboptimal wiring scheme (or wrong resistor) resulting in shorter battery life.
                              • Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                @Yveaux Did you finish the PCB for the molgan?, If so is it possible for you to share the files?
                                YveauxY 2 Replies Last reply
                                • L
                                  L
                                  LastSamurai
                                  I would be interested too!
                                    @Cliff-Karlsson Yes, works like a charm!
                                    It has been on my ToDo list for quite a long time to publish the files -- please hold on a little longer ;-)
                                    • YveauxY Yveaux
                                      dynamiteD
                                      dynamiteD
                                      dynamite
                                      @Yveaux great as my project was on hold for a while but still on the to do list...:-)
                                        @Cliff-Karlsson @LastSamurai @dynamite I just published the PCB on [OpenHardware.io].(https://www.openhardware.io/view/274/Ikea-Molgan-Hack)
                                        A sketch will follow soon.
                                        Enjoy!
                                        • gijssG gijss
                                          gijssG
                                          gijssG
                                          gijss
                                          @dynamite
                                          It has been a while (mainly because the PIR was out of order for other reasons) but now I am restarting the project and again it happened that the PIR no longer responded. So I took a look at your code, but it seems your are using a BH1750 light sensor, is that correct? And are you using that in fact at the moment, or did you switch to LDR and is this perhaps not the latest version of the code?
                                          Gijss
