  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.5k Views 20 Watching
  • W
    W
    wergeld
    I am trying to build the code using the HTU21D sensors. This built fine under 1.4 and 1.5 but now under v2 of MySensors I am getting this error:
    C:\Users\wergeld\Documents\Arduino\SlimNodeSi7021\SlimNodeSi7021.ino:4:24: fatal error: MySensor.h: No such file or directory
    compilation terminated.
    exit status 1
    Error compiling for board APM Optiboot internal 1MHz noBOD 9600baud.
    Okay, so I change my reference to:
    And I get this lovely error:
    In file included from C:\Users\wergeld\Documents\Arduino\SlimNodeSi7021\SlimNodeSi7021.ino:4:0:
    C:\Users\wergeld\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    So, other than slamming my head against my desk how can I solve this?
    • W
      W
      wergeld
      Well, I solved it by modifying the code to 2.0 spec. Good lord I need sleep. :anguished:
      Working on debugging temp outputs now to Ethernet Gateway running on my Uno. Or I will sleep...
      • W
        W
        wergeld
        Okay, I now have a soldered node and serial gateway setup to my laptop for testing. It presents the sensor node! The name and available sensors is correct. Howevr, it never sends any message payload with temp/hum or battery values. I am using the HTU21D without soldering those 3 pads on it together. I need to get myself a 3.3v FTDI cable so I can serially debug I guess. But, still! Progress.
        • W
          W
          wergeld
          After soldering the 3 pads on the HTU21D I am now reading data and it is being sent to my test serial gateway. Need to measure current usage but at least it is functional.
          • W
            W
            wergeld
            Okay, seeing something odd. The force transmit does not appear to be working.
            Here is my current sketch:
            #include <MyConfig.h>
            by m26872, 20151109
            //#include <MySensors.h>
            #include <SparkFunHTU21D.h>
            #include <RunningAverage.h>
            //#define DEBUG
            #ifdef DEBUG
            #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
            #define CHILD_ID_TEMP 0
            #define CHILD_ID_HUM 1
            // #define SLEEP_TIME 15000 // 15s for DEBUG
            #define SLEEP_TIME 300000   // 5 min
            #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
            #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
            #define VMIN 1900
            #define VMAX 3300
            #define AVERAGES 2
            int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
            int measureCount = 0;
            float lastTemperature = -100;
            int lastHumidity = -100;
            HTU21D humiditySensor;
            //MySensor gw;
              sendSketchInfo("HTU21D", "1.0");
              present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
              present(CHILD_ID_HUM, S_HUM);
              DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
              DEBUG_PRINT("Voltage: ");
              DEBUG_PRINT(readVcc());
              DEBUG_PRINTLN(" mV");
              delay(500);
              DEBUG_PRINTLN(" *C");
              //gw.begin(NULL,NODE_ID);
              //sendSketchInfo("HTU21D", "1.0");
              //present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
              //present(CHILD_ID_HUM, S_HUM);
              DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
              raHum.clear();
              measureCount ++;
              batteryReportCounter ++;
              bool forceTransmit = false;
              if (measureCount > FORCE_TRANSMIT_CYCLE) {
                forceTransmit = true;
              // Read and print internal temp
              float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
              DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
              // Check battery
              if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                long batteryVolt = readVcc();
                DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                batteryReportCounter = 0;
              sleep(SLEEP_TIME);
            // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
            // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
            long readVcc() {
            // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
            double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
              unsigned int wADC;
              double t;
              // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
              ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
              ADCSRA |= _BV(ADEN);  // enable the ADC
              delay(20);            // wait for voltages to become stable.
              ADCSRA |= _BV(ADSC);  // Start the ADC
              while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
              wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
              t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
              return (t);   // The returned temperature in degrees Celcius.
             * Parameters
              bool tx = force;
              float temperature = humiditySensor.readTemperature();
              if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                send(msgTemp.set(temperature,1));
                measureCount = 0;
                DEBUG_PRINTLN("T sent!");
              int humidity = humiditySensor.readHumidity();
              raHum.addValue(humidity);
              if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                send(msgHum.set(humidity));
                lastHumidity = humidity;
                measureCount = 0;
                DEBUG_PRINTLN("H sent!");
            I am at 1+ hours since last transmission.
            m26872M 1 Reply Last reply
            • W wergeld
              by m26872, 20151109
              //#define DEBUG
              #ifdef DEBUG
              #define VMIN 1900
              #define VMAX 3300
              #define AVERAGES 2
              //MySensor gw;
                delay(500);
                raHum.clear();
                measureCount ++;
                // Check battery
                sleep(SLEEP_TIME);
              long readVcc() {
                unsigned int wADC;
                double t;
               * Parameters
                bool tx = force;
                  measureCount = 0;
                  measureCount = 0;
              m26872M
              m26872M
              m26872
              @wergeld It looks like it's set to 3 hrs.
              W 1 Reply Last reply
              • m26872M m26872
                W
                W
                wergeld
                @m26872
                Indeed it does. Just was throwing me off with the wording. I read it as "1/2 hour" or "1/3 hour". So far I am prepping up more nodes. Have 4 more 328s to programs and build out. I am thinking at the end I will have:
                1. Gateway (serial or the direct connect nrf+ once it supports v2)
                2. Temp/Hum node using HTU21D for back porch sending every 5 minutes and force send every 30 minutes.
                3. Temp/Hum node using HTU21D inside using same send times.
                4. Parking sensor in garage hardwired to mains.
                  5 & 6 I am not sure yet.
                Lots of fun so far.
                • W
                  W
                  wergeld
                  I am seeing 5.0 μA at sleep and 12.4 mA when transmitting. Seems kind of high. I did the poor man's test as well - put an LED across the HTU21D power pins and it lit up. Same when I did it across the nrf's power pins. Shouldn't the MySensors code turn off the power rails during sleep?
                  • W wergeld
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @wergeld
                    No, the powerrails are not turned off, just the devices themselves.
                    5uA during sleep is about right. The 12.4mA during transmit is also normal, but the transmit time should be very short, so on average the total consumption of power will be low.
                    • GertSandersG GertSanders
                      @wergeld
                      W
                      W
                      wergeld
                      @GertSanders Excellent! I was hoping I hadn't wired it up wrong. So far the 2 nodes have been flawless for the past 3 days. Next step is to await the direct attached NRF serial gateway to be v2 compatible. Been following along with this thread. Looks like we are getting closer! I have 2 RPis (one a first gen B and the other a Pi2 B ) with this adapter by ceech:
                      https://www.openhardware.io/view/100/Raspberry-PI-NRF24l01-hat
                      • clempatC
                        clempatC
                        clempat
                        wrote on last edited by clempat
                        #113
                        Hi everyone,
                        First thanks for sharing. I love this slim node. But I am facing some issues I did not success to debug. So I use the code shared here for mysensors 2. I try with the mysensors exemple library (did not work at all). I try with the https://github.com/LowPowerLab/SI7021 which worked (at least for getting separately temperature and humidity and using the example file) on an arduino nano. But when I run this sensor with the slim node (red, boot loader 8mhz) and the code (for 2.0.0) I always get -46.85 for temperature and 118 for humidity. Otherwise the radio work normally.
                        Winter is coming and I don't know what I could do anymore. Thanks to share you idea on this.
                        With the example code I use on the nano. I get with the slim node:
                        T: -46.85
                        H: 118
                        device ID: 50
                        With Arduino nano:
                        T: 24.34
                        H: 43
                        device ID: 50
                        clempatC 1 Reply Last reply
                        • clempatC clempat
                          Hi everyone,
                          T: -46.85
                          H: 118
                          device ID: 50
                          With Arduino nano:
                          T: 24.34
                          H: 43
                          device ID: 50
                          clempatC
                          clempatC
                          clempat
                          Why actually my device id is 50 ? for what 50 stands !?!?!
                          • clempatC clempat
                            m26872M
                            m26872M
                            m26872
                            @clempat Please post your sketch and maybe some hardware photo or diagram too.
                            • m26872M m26872
                              clempatC
                              clempatC
                              clempat
                              @m26872 Sure I can do that. So I simplified the code to only focus on the si7021.
                              Here it is: https://github.com/clempat/example-si7021
                              And there the photo:
                              • clempatC clempat
                                m26872M
                                m26872M
                                m26872
                                @clempat Don't think I can help you. Maybe clock related. What voltages do you use on Nano and Slim respectively? Do you have multiple parts to try with and get the same result? Why do you include and start wire.h, isn't already in Si7021.h ? My guess on "device Id 50" is that it's just a chinese clone reply.
                                Photos look nice btw. :thumbsup:
                                • m26872M m26872
                                  clempatC
                                  clempatC
                                  clempat
                                  @m26872 Thank you. Yes I wanted to try with a pro mini 8Mhz but I need to prepare the pin 4 and 5. I will keep inform when I do it this week end.
                                  Thanks for the picture but with this nice setup it is difficult to make it bad :)...
                                  I includes wire.h like in the exemple in https://github.com/LowPowerLab/SI7021 but of course after I tried without. The nano was directly connected to usb and the slim through 3,3V USB to serial.
                                  • clempatC
                                    clempatC
                                    clempat
                                    Ok with the arduino micro 8Mhz all works good too.
                                    Reading...
                                    T: 20.29
                                    H: 54
                                    device ID: 50
                                    • clempatC
                                      clempatC
                                      clempat
                                      So sad I still not getting it working with the slim node :( !!! Always same result either with internal 1mhz or 8mhz...
                                      • clempatC clempat
                                        m26872M
                                        m26872M
                                        m26872
                                        @clempat Make it with external 8MHz then ? Then it should be like a Pro Mini 3.3V.
                                        • m26872M m26872
                                          clempatC
                                          clempatC
                                          clempat
                                          @m26872 I will give a try and let you know... Thanks.
