  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.5k Views 20 Watching
  • W
    W
    wergeld
    Okay, seeing something odd. The force transmit does not appear to be working.
    Here is my current sketch:
    #include <MyConfig.h>
    by m26872, 20151109
    //#include <MySensors.h>
    #include <SparkFunHTU21D.h>
    #include <RunningAverage.h>
    //#define DEBUG
    #ifdef DEBUG
    #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    // #define SLEEP_TIME 15000 // 15s for DEBUG
    #define SLEEP_TIME 300000   // 5 min
    #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
    #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
    #define VMIN 1900
    #define VMAX 3300
    #define AVERAGES 2
    int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
    int measureCount = 0;
    float lastTemperature = -100;
    int lastHumidity = -100;
    HTU21D humiditySensor;
    //MySensor gw;
      sendSketchInfo("HTU21D", "1.0");
      present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
      present(CHILD_ID_HUM, S_HUM);
      DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
      DEBUG_PRINT("Voltage: ");
      DEBUG_PRINT(readVcc());
      DEBUG_PRINTLN(" mV");
      delay(500);
      DEBUG_PRINTLN(" *C");
      //gw.begin(NULL,NODE_ID);
      //sendSketchInfo("HTU21D", "1.0");
      //present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
      //present(CHILD_ID_HUM, S_HUM);
      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
      raHum.clear();
      measureCount ++;
      batteryReportCounter ++;
      bool forceTransmit = false;
      if (measureCount > FORCE_TRANSMIT_CYCLE) {
        forceTransmit = true;
      // Read and print internal temp
      float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
      DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
      // Check battery
      if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
        long batteryVolt = readVcc();
        DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
        DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
        batteryReportCounter = 0;
      sleep(SLEEP_TIME);
    // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
    long readVcc() {
    // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
    double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
      unsigned int wADC;
      double t;
      // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
      ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
      ADCSRA |= _BV(ADEN);  // enable the ADC
      delay(20);            // wait for voltages to become stable.
      ADCSRA |= _BV(ADSC);  // Start the ADC
      while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
      wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
      t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
      return (t);   // The returned temperature in degrees Celcius.
     * Parameters
      bool tx = force;
      float temperature = humiditySensor.readTemperature();
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
        send(msgTemp.set(temperature,1));
        measureCount = 0;
        DEBUG_PRINTLN("T sent!");
      int humidity = humiditySensor.readHumidity();
      raHum.addValue(humidity);
      if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
        send(msgHum.set(humidity));
        lastHumidity = humidity;
        measureCount = 0;
        DEBUG_PRINTLN("H sent!");
    I am at 1+ hours since last transmission.
    m26872M 1 Reply Last reply
    • W wergeld
      by m26872, 20151109
      //#define DEBUG
      #ifdef DEBUG
      #define VMIN 1900
      #define VMAX 3300
      #define AVERAGES 2
      //MySensor gw;
        delay(500);
        raHum.clear();
        measureCount ++;
        // Check battery
        sleep(SLEEP_TIME);
      long readVcc() {
        unsigned int wADC;
        double t;
       * Parameters
        bool tx = force;
          measureCount = 0;
          measureCount = 0;
      m26872M
      m26872M
      m26872
      @wergeld It looks like it's set to 3 hrs.
      W 1 Reply Last reply
      • m26872M m26872
        W
        W
        wergeld
        @m26872
        Indeed it does. Just was throwing me off with the wording. I read it as "1/2 hour" or "1/3 hour". So far I am prepping up more nodes. Have 4 more 328s to programs and build out. I am thinking at the end I will have:
        1. Gateway (serial or the direct connect nrf+ once it supports v2)
        2. Temp/Hum node using HTU21D for back porch sending every 5 minutes and force send every 30 minutes.
        3. Temp/Hum node using HTU21D inside using same send times.
        4. Parking sensor in garage hardwired to mains.
          5 & 6 I am not sure yet.
        Lots of fun so far.
        • W
          W
          wergeld
          I am seeing 5.0 μA at sleep and 12.4 mA when transmitting. Seems kind of high. I did the poor man's test as well - put an LED across the HTU21D power pins and it lit up. Same when I did it across the nrf's power pins. Shouldn't the MySensors code turn off the power rails during sleep?
          • W wergeld
            GertSandersG
            GertSandersG
            GertSanders
            @wergeld
            No, the powerrails are not turned off, just the devices themselves.
            5uA during sleep is about right. The 12.4mA during transmit is also normal, but the transmit time should be very short, so on average the total consumption of power will be low.
            • GertSandersG GertSanders
              @wergeld
              W
              W
              wergeld
              @GertSanders Excellent! I was hoping I hadn't wired it up wrong. So far the 2 nodes have been flawless for the past 3 days. Next step is to await the direct attached NRF serial gateway to be v2 compatible. Been following along with this thread. Looks like we are getting closer! I have 2 RPis (one a first gen B and the other a Pi2 B ) with this adapter by ceech:
              https://www.openhardware.io/view/100/Raspberry-PI-NRF24l01-hat
              • clempatC
                clempatC
                clempat
                wrote on last edited by clempat
                #113
                Hi everyone,
                First thanks for sharing. I love this slim node. But I am facing some issues I did not success to debug. So I use the code shared here for mysensors 2. I try with the mysensors exemple library (did not work at all). I try with the https://github.com/LowPowerLab/SI7021 which worked (at least for getting separately temperature and humidity and using the example file) on an arduino nano. But when I run this sensor with the slim node (red, boot loader 8mhz) and the code (for 2.0.0) I always get -46.85 for temperature and 118 for humidity. Otherwise the radio work normally.
                Winter is coming and I don't know what I could do anymore. Thanks to share you idea on this.
                With the example code I use on the nano. I get with the slim node:
                T: -46.85
                H: 118
                device ID: 50
                With Arduino nano:
                T: 24.34
                H: 43
                device ID: 50
                clempatC 1 Reply Last reply
                • clempatC clempat
                  Hi everyone,
                  T: -46.85
                  H: 118
                  device ID: 50
                  With Arduino nano:
                  T: 24.34
                  H: 43
                  device ID: 50
                  clempatC
                  clempatC
                  clempat
                  Why actually my device id is 50 ? for what 50 stands !?!?!
                  • clempatC clempat
                    m26872M
                    m26872M
                    m26872
                    @clempat Please post your sketch and maybe some hardware photo or diagram too.
                    • m26872M m26872
                      clempatC
                      clempatC
                      clempat
                      @m26872 Sure I can do that. So I simplified the code to only focus on the si7021.
                      Here it is: https://github.com/clempat/example-si7021
                      And there the photo:
                      • clempatC clempat
                        m26872M
                        m26872M
                        m26872
                        @clempat Don't think I can help you. Maybe clock related. What voltages do you use on Nano and Slim respectively? Do you have multiple parts to try with and get the same result? Why do you include and start wire.h, isn't already in Si7021.h ? My guess on "device Id 50" is that it's just a chinese clone reply.
                        Photos look nice btw. :thumbsup:
                        • m26872M m26872
                          clempatC
                          clempatC
                          clempat
                          @m26872 Thank you. Yes I wanted to try with a pro mini 8Mhz but I need to prepare the pin 4 and 5. I will keep inform when I do it this week end.
                          Thanks for the picture but with this nice setup it is difficult to make it bad :)...
                          I includes wire.h like in the exemple in https://github.com/LowPowerLab/SI7021 but of course after I tried without. The nano was directly connected to usb and the slim through 3,3V USB to serial.
                          • clempatC
                            clempatC
                            clempat
                            Ok with the arduino micro 8Mhz all works good too.
                            Reading...
                            T: 20.29
                            H: 54
                            device ID: 50
                            • clempatC
                              clempatC
                              clempat
                              So sad I still not getting it working with the slim node :( !!! Always same result either with internal 1mhz or 8mhz...
                              • clempatC clempat
                                m26872M
                                m26872M
                                m26872
                                @clempat Make it with external 8MHz then ? Then it should be like a Pro Mini 3.3V.
                                • m26872M m26872
                                  clempatC
                                  clempatC
                                  clempat
                                  @m26872 I will give a try and let you know... Thanks.
                                  • miljumeM
                                    miljumeM
                                    miljume
                                    Hello
                                    I also have big problems with getting the node to send temp and hum values
                                    It starts up and presents itself to the GW but then nothing happens
                                    I have tested the SI721 module with a simple arduino code and then it reads and prints both values just fine
                                    My code is below, in practice its a version of Sensebender Micro code. I have changed the force transmit value to 1
                                    Exactly as @clempat I have tried both 1MHz optiboot and 8MHz internal oscillator without any success
                                    * Version 1.0 - Thomas Bowman MC8rch
                                    * Version 1.3 - Thomas Bowman MC8rch
                                    * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
                                    * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
                                    * Version 1.4 - Thomas Bowman MC8rch
                                    * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
                                    * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
                                    * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
                                    // Define a static node address, remove if you want auto address assignment
                                    //#deine MY_NODE_ID 3
                                    #include <SI7021-master\SI7021.h>
                                    // Uncomment the line below, to transmit battery voltage as a normal sensor value
                                    #define BATT_SENSOR    199
                                    #define RELEASE "1.4"
                                    #define AVERAGES 2
                                    // Child sensor ID's
                                    #define CHILD_ID_TEMP  1
                                    #define CHILD_ID_HUM   2
                                    #define FORCE_TRANSMIT_INTERVAL 1
                                    SI7021 humiditySensor;
                                    // Sensor messages
                                    #ifdef BATT_SENSOR
                                    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                                    // Global settings
                                    int sendBattery = 0;
                                    boolean isMetric = true;
                                    boolean highfreq = true;
                                    boolean transmission_occured = false;
                                    long lastBattery = -100;
                                    * Setup code
                                    	Serial.begin(9600);
                                    	Serial.print(RELEASE);
                                    	Serial.flush();
                                    	humiditySensor.begin();
                                    	Serial.flush();
                                    	isMetric = getConfig().isMetric;
                                    	Serial.print(F("isMetric: ")); Serial.println(isMetric);
                                    	raHum.clear();
                                    	sendTempHumidityMeasurements(false);
                                    	sendBattLevel(false);
                                    	sendSketchInfo("TempHum", RELEASE);
                                    #ifdef BATT_SENSOR
                                    	present(BATT_SENSOR, S_POWER);
                                    *  Main loop function
                                    	measureCount++;
                                    	sendBattery++;
                                    	if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                                    		measureCount = 0;
                                    	/*  if (sendBattery > 60)
                                    	sendBattLevel(forceTransmit); // Not needed to send battery info that often
                                    	sendBattery = 0;
                                    	sleep(MEASURE_INTERVAL);
                                    * Parameters
                                    	bool tx = force;
                                    	raHum.addValue(data.humidityPercent);
                                    	Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                                    	Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                                    	if (isnan(diffHum)) tx = true;
                                    	if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                                    	if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
                                    	if (tx) {
                                    		measureCount = 0;
                                    		float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                                    		Serial.print("T: ");Serial.println(temperature);
                                    		Serial.print("H: ");Serial.println(humidity);
                                    		transmission_occured = true;
                                    		if (sendBattery > 60) {
                                    			sendBattLevel(true); // Not needed to send battery info that often
                                    			sendBattery = 0;
                                    * Parameters
                                    	if (force) lastBattery = -1;
                                    	long vcc = readVcc();
                                    	if (vcc != lastBattery) {
                                    		lastBattery = vcc;
                                    #ifdef BATT_SENSOR
                                    		float send_voltage = float(vcc) / 1000.0f;
                                    		send(msgBatt.set(send_voltage, 3));
                                    		// Calculate percentage
                                    		long percent = vcc / 14.0;
                                    		sendBatteryLevel(percent);
                                    long readVcc() {
                                    • m26872M
                                      m26872M
                                      m26872
                                      It would be interesting if someone with issues also tried older versions of libs for Si7021 and/or MySensors.
                                      • W
                                        W
                                        wergeld
                                        So, after a few months of 2 nodes up and running using the HTU21D sensor I have come the conclusion that the HTU21D is no good for where I live. Lately it has been getting cooler outside (down to mid 50s F) but humidity is still high. As the evening progresses the humidity gets to 100% and the node no longer sends data. This happens around 6pm every day (about half and hour after sunset). It then comes back online at about 10 am the next day. The node that I have inside does not have this issue (same shipment of arduino, pcb, and HTU21D sensors and the same arduino code). Both running off of fresh AAs. May need to upgrade to the SI7021 for outside node.
                                        Here is the graph showing last 7 days. As you can see it flatlines (literally!) at 100% humidity!
                                        All good times with the learning!
                                        • W wergeld
                                          m26872M
                                          m26872M
                                          m26872
                                          @wergeld Relative humidity at 100% during night sounds very realistic to me. Are you confusing it with the "absolute humidity"? Or is your concern that the "force transmit" isn't working?
