  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.5k Views 20 Watching
  • W
    W
    wergeld
    I am seeing 5.0 μA at sleep and 12.4 mA when transmitting. Seems kind of high. I did the poor man's test as well - put an LED across the HTU21D power pins and it lit up. Same when I did it across the nrf's power pins. Shouldn't the MySensors code turn off the power rails during sleep?
    • W wergeld
      GertSandersG
      GertSandersG
      GertSanders
      @wergeld
      No, the powerrails are not turned off, just the devices themselves.
      5uA during sleep is about right. The 12.4mA during transmit is also normal, but the transmit time should be very short, so on average the total consumption of power will be low.
      W 1 Reply Last reply
      • GertSandersG GertSanders
        @wergeld
        W
        W
        wergeld
        @GertSanders Excellent! I was hoping I hadn't wired it up wrong. So far the 2 nodes have been flawless for the past 3 days. Next step is to await the direct attached NRF serial gateway to be v2 compatible. Been following along with this thread. Looks like we are getting closer! I have 2 RPis (one a first gen B and the other a Pi2 B ) with this adapter by ceech:
        https://www.openhardware.io/view/100/Raspberry-PI-NRF24l01-hat
        • clempatC
          clempatC
          clempat
          wrote on last edited by clempat
          #113
          Hi everyone,
          First thanks for sharing. I love this slim node. But I am facing some issues I did not success to debug. So I use the code shared here for mysensors 2. I try with the mysensors exemple library (did not work at all). I try with the https://github.com/LowPowerLab/SI7021 which worked (at least for getting separately temperature and humidity and using the example file) on an arduino nano. But when I run this sensor with the slim node (red, boot loader 8mhz) and the code (for 2.0.0) I always get -46.85 for temperature and 118 for humidity. Otherwise the radio work normally.
          Winter is coming and I don't know what I could do anymore. Thanks to share you idea on this.
          With the example code I use on the nano. I get with the slim node:
          T: -46.85
          H: 118
          device ID: 50
          With Arduino nano:
          T: 24.34
          H: 43
          device ID: 50
          clempatC 1 Reply Last reply
          • clempatC clempat
            Hi everyone,
            T: -46.85
            H: 118
            device ID: 50
            With Arduino nano:
            T: 24.34
            H: 43
            device ID: 50
            clempatC
            clempatC
            clempat
            Why actually my device id is 50 ? for what 50 stands !?!?!
            m26872M 1 Reply Last reply
            • clempatC clempat
              m26872M
              m26872M
              m26872
              @clempat Please post your sketch and maybe some hardware photo or diagram too.
              • m26872M m26872
                clempatC
                clempatC
                clempat
                @m26872 Sure I can do that. So I simplified the code to only focus on the si7021.
                Here it is: https://github.com/clempat/example-si7021
                And there the photo:
                • clempatC clempat
                  m26872M
                  m26872M
                  m26872
                  @clempat Don't think I can help you. Maybe clock related. What voltages do you use on Nano and Slim respectively? Do you have multiple parts to try with and get the same result? Why do you include and start wire.h, isn't already in Si7021.h ? My guess on "device Id 50" is that it's just a chinese clone reply.
                  Photos look nice btw. :thumbsup:
                  • m26872M m26872
                    clempatC
                    clempatC
                    clempat
                    @m26872 Thank you. Yes I wanted to try with a pro mini 8Mhz but I need to prepare the pin 4 and 5. I will keep inform when I do it this week end.
                    Thanks for the picture but with this nice setup it is difficult to make it bad :)...
                    I includes wire.h like in the exemple in https://github.com/LowPowerLab/SI7021 but of course after I tried without. The nano was directly connected to usb and the slim through 3,3V USB to serial.
                    • clempatC
                      clempatC
                      clempat
                      Ok with the arduino micro 8Mhz all works good too.
                      Reading...
                      T: 20.29
                      H: 54
                      device ID: 50
                      • clempatC
                        clempatC
                        clempat
                        So sad I still not getting it working with the slim node :( !!! Always same result either with internal 1mhz or 8mhz...
                        • clempatC clempat
                          m26872M
                          m26872M
                          m26872
                          @clempat Make it with external 8MHz then ? Then it should be like a Pro Mini 3.3V.
                          • m26872M m26872
                            clempatC
                            clempatC
                            clempat
                            @m26872 I will give a try and let you know... Thanks.
                            • miljumeM
                              miljumeM
                              miljume
                              Hello
                              I also have big problems with getting the node to send temp and hum values
                              It starts up and presents itself to the GW but then nothing happens
                              I have tested the SI721 module with a simple arduino code and then it reads and prints both values just fine
                              My code is below, in practice its a version of Sensebender Micro code. I have changed the force transmit value to 1
                              Exactly as @clempat I have tried both 1MHz optiboot and 8MHz internal oscillator without any success
                              * Version 1.0 - Thomas Bowman MC8rch
                              * Version 1.3 - Thomas Bowman MC8rch
                              * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
                              * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
                              * Version 1.4 - Thomas Bowman MC8rch
                              * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
                              * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
                              * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
                              // Define a static node address, remove if you want auto address assignment
                              //#deine MY_NODE_ID 3
                              #include <SI7021-master\SI7021.h>
                              #include <RunningAverage.h>
                              // Uncomment the line below, to transmit battery voltage as a normal sensor value
                              #define BATT_SENSOR    199
                              #define RELEASE "1.4"
                              #define AVERAGES 2
                              // Child sensor ID's
                              #define CHILD_ID_TEMP  1
                              #define CHILD_ID_HUM   2
                              #define FORCE_TRANSMIT_INTERVAL 1
                              SI7021 humiditySensor;
                              // Sensor messages
                              #ifdef BATT_SENSOR
                              MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                              // Global settings
                              int measureCount = 0;
                              int sendBattery = 0;
                              boolean isMetric = true;
                              boolean highfreq = true;
                              boolean transmission_occured = false;
                              float lastTemperature = -100;
                              int lastHumidity = -100;
                              long lastBattery = -100;
                              * Setup code
                              	Serial.begin(9600);
                              	Serial.print(RELEASE);
                              	Serial.flush();
                              	humiditySensor.begin();
                              	Serial.flush();
                              	isMetric = getConfig().isMetric;
                              	Serial.print(F("isMetric: ")); Serial.println(isMetric);
                              	raHum.clear();
                              	sendTempHumidityMeasurements(false);
                              	sendBattLevel(false);
                              	sendSketchInfo("TempHum", RELEASE);
                              	present(CHILD_ID_HUM, S_HUM);
                              #ifdef BATT_SENSOR
                              	present(BATT_SENSOR, S_POWER);
                              *  Main loop function
                              	measureCount++;
                              	sendBattery++;
                              	bool forceTransmit = false;
                              	if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                              		forceTransmit = true;
                              		measureCount = 0;
                              	/*  if (sendBattery > 60)
                              	sendBattLevel(forceTransmit); // Not needed to send battery info that often
                              	sendBattery = 0;
                              	sleep(MEASURE_INTERVAL);
                              * Sends temperature and humidity from Si7021 sensor
                              * Parameters
                              void sendTempHumidityMeasurements(bool force)
                              	bool tx = force;
                              	raHum.addValue(data.humidityPercent);
                              	Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                              	Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                              	if (isnan(diffHum)) tx = true;
                              	if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                              	if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
                              	if (tx) {
                              		measureCount = 0;
                              		float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                              		Serial.print("T: ");Serial.println(temperature);
                              		Serial.print("H: ");Serial.println(humidity);
                              		send(msgHum.set(humidity));
                              		lastHumidity = humidity;
                              		transmission_occured = true;
                              		if (sendBattery > 60) {
                              			sendBattLevel(true); // Not needed to send battery info that often
                              			sendBattery = 0;
                              * Parameters
                              	if (force) lastBattery = -1;
                              	long vcc = readVcc();
                              	if (vcc != lastBattery) {
                              		lastBattery = vcc;
                              #ifdef BATT_SENSOR
                              		float send_voltage = float(vcc) / 1000.0f;
                              		send(msgBatt.set(send_voltage, 3));
                              		// Calculate percentage
                              		long percent = vcc / 14.0;
                              		sendBatteryLevel(percent);
                              long readVcc() {
                              	uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
                              • m26872M
                                m26872M
                                m26872
                                It would be interesting if someone with issues also tried older versions of libs for Si7021 and/or MySensors.
                                • W
                                  W
                                  wergeld
                                  So, after a few months of 2 nodes up and running using the HTU21D sensor I have come the conclusion that the HTU21D is no good for where I live. Lately it has been getting cooler outside (down to mid 50s F) but humidity is still high. As the evening progresses the humidity gets to 100% and the node no longer sends data. This happens around 6pm every day (about half and hour after sunset). It then comes back online at about 10 am the next day. The node that I have inside does not have this issue (same shipment of arduino, pcb, and HTU21D sensors and the same arduino code). Both running off of fresh AAs. May need to upgrade to the SI7021 for outside node.
                                  Here is the graph showing last 7 days. As you can see it flatlines (literally!) at 100% humidity!
                                  All good times with the learning!
                                  • W wergeld
                                    m26872M
                                    m26872M
                                    m26872
                                    @wergeld Relative humidity at 100% during night sounds very realistic to me. Are you confusing it with the "absolute humidity"? Or is your concern that the "force transmit" isn't working?
                                    • bjacobseB
                                      bjacobseB
                                      bjacobse
                                      Mine does the same, but it's also very humid at night - I think this is normal behavoir
                                      • W
                                        W
                                        wergeld
                                        @m26872 & @bjacobse - Yes, 100% humidity is normal here. Good old Florida! My concern is that the node stops reporting. Possibly due to condensation shorting out something. During the summer here we also hit 100% humidity but it is also a lot hotter (high 90s). Now, I think that the cooler temps are forcing a dew point that is allowing water to condense on the node. Then during the morning it drys out and resumes transmitting. I would like to find a way to stop this.
                                        • W wergeld
                                          m26872M
                                          m26872M
                                          m26872
                                          @wergeld
                                          https://forum.mysensors.org/topic/1560/how-to-protect-your-outdoor-sensor
