  3. Soil Humidity and temperature sensor - SHT1x
6 Posts 2 Posters 6.1k Views 1 Watching
  • epierreE
    epierreE
    epierre
    Here is the one I have (not from this store): Digital Temperature & humidity sensor (With Stainless Steel Probe)
    It is calibrated and use the SHT1x library yet not present in MySensors.
    Here is my first code, that I have adapted but found in principles very close to the DHT11 example:
    https://github.com/empierre/arduino/blob/master/SoilMoistSensorSHT1x.ino
    Mine does not seems to be immersible, there are some other around that are given such:
    • SHT10 with protection
    • Davis/Watermark reference
    • alternative for existing sketch with immersion gold treatment
    z-wave - Vera -> Domoticz
    • epierreE
      epierreE
      epierre
      @hek a new unit if properly done !
      cb (centibar) http://www.irrometer.com/basics.html
      0-10 Saturated Soil. Occurs for a day or two after irrigation
      10-20 Soil is adequately wet (except coarse sands which are drying out at this range)
      30-60 Usual range to irrigate or water (except heavy clay soils).
      60-100 Usual range to irrigate heavy clay soils
      100-200 Soil is becoming dangerously dry for maximum production. Proceed with caution.
      hekH 1 Reply Last reply
      • epierreE epierre
        @epierre said:
        cb (centibar)
        Nice to leran new things every day. Irrometer!
        • epierreE
          epierreE
          epierre
          now I have an issue: I wired it (correctly) yesterday and readings give me -40°C and 5.5 Humidity...
          adafruit description
          Also this kind of sensor can be partially buried, only the front part, not the whole, I may consider having a look to the Watermark/Davis one they use in libellium or make myself one.
          • epierreE
            epierreE
            epierre
            Here are my readings:
            Temperature: -258.4599914550C / -433.2279968261F. Humidity: -1732.49%
            Temperature: 285.2200012207C / -41.5480003356F. Humidity: -1732.49%
            Temperature: 285.1900024414C / -46.1559982299F. Humidity: -1732.49%
            Temperature: 178.4499969482C / -44.6080017089F. Humidity: -1732.49%
            epierreE 1 Reply Last reply
            • epierreE epierre
              epierreE
              epierreE
              epierre
              ok found, you need the Sensirion Version 2.0 - 10Dec2010 !!!
              Temperature: 26.12 C, Humidity: 61.71 %, Dewpoint: 18.19 C
              Temperature: 26.10 C, Humidity: 61.70 %, Dewpoint: 18.17 C
              Temperature: 26.10 C, Humidity: 61.76 %, Dewpoint: 18.19 C
              Temperature: 26.10 C, Humidity: 61.82 %, Dewpoint: 18.20 C
              Temperature: 26.09 C, Humidity: 61.88 %, Dewpoint: 18.21 C
