  3. Arduino Nano, W5100 Ethernet, NRF24L01+, wont get or use an ip (dhcp or static)
12 Posts 3 Posters 4.4k Views 3 Watching
  • webstorW webstor
    Hi folks,
    after a long time of googling around I would like to ask you for your help.
    I'm using an arduino nano, a w5100 Ethernet shield and a nrf24l01+.
    The problem is that it doesnt get an ip adress via dhcp or if I configure the ip static it won't also work.
    If I upload a webserver example it is working. So the w5100 ethernet shield is working.
    Here is my sketch: (used the one from this website).
    serial Monitor output:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 0.0.0.0
    sketch:
    • The MySensors Arduino library handles the wireless radio link and protocol
    • between your home built sensors/actuators and HA controller of choice.
    • The sensors forms a self healing radio network with optional repeaters. Each
    • repeater and gateway builds a routing tables in EEPROM which keeps track of the
    • network topology allowing messages to be routed to nodes.
    • Created by Henrik Ekblad henrik.ekblad@mysensors.org
    • Copyright (C) 2013-2015 Sensnology AB
    • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    • Documentation: http://www.mysensors.org
    • Support Forum: http://forum.mysensors.org
    • This program is free software; you can redistribute it and/or
    • modify it under the terms of the GNU General Public License
    • version 2 as published by the Free Software Foundation.
    • REVISION HISTORY
    • Version 1.0 - Henrik EKblad
    • Contribution by a-lurker and Anticimex,
    • Contribution by Norbert Truchsess norbert.truchsess@t-online.de
    • Contribution by Tomas Hozza thozza@gmail.com
    • DESCRIPTION
    • The EthernetGateway sends data received from sensors to the ethernet link.
    • The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
    • The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program.
    • LED purposes:
      • To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h
      • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
      • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
      • ERR (red) - fast blink on error during transmission error or recieve crc error
    • See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,43,66 // If this is disabled, DHCP is used to retrieve address
    #define MY_IP_GATEWAY_ADDRESS 192,168,43,1
    #define MY_PORT 5003
    // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS 0xCA, 0xFE, 0xC0, 0xFF, 0xEE, 0x00
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN 3
    //#define MY_DEFAULT_ERR_LED_PIN 7 // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN 8 // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN 9 // the PCB, on board LED
    #define MY_NODE_ID 0
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    //void presentation() {
    // sendSketchInfo(SN, SV);
    //void loop() {
    Thanx.
    @webstor could you describe what you mean by "won't work"? Have you tried to ping it?
    • webstorW
      webstorW
      webstor
      No IP via dhcp.
      If I change it to static, it isn't pingable. There isn't not even a dhcp discover / offer and so on. Tested it with wireshark.
      • webstorW
        webstorW
        webstor
        To get to the point.
        The ethernetmodule isnt working with the code from mysensors and I don't know why.
        If I upload a webserver code for testing dhcp or static is working.
        And ping wont make sense if the interface isnt working at all. ;-)
          Are you sure you don't take out too much juice from the Arduino? With both radio and ethernet module attached... Could you try powering the eth-module separately?
          • webstorW
            webstorW
            webstor
            @hek said:
            Hi.
            I also tried use an external power supply which.
            Same result.
            The led's of the lan-port are flashing like from every other device.
              And you are't re-using the mac address on some other device?
              • webstorW
                webstorW
                webstor
                @hek said:
                some
                nope.
                I also changed the default mac adress to another one just to make sure.
                Same.
                  Very strange.. did you try disabling the radio just for test (MY_RADIO_NRF24) and unplugging it?
                  • webstorW
                    webstorW
                    webstor
                    HI,
                    I think two of my lan-shields are broken. The problem is that they aren't total broken.
                    I mean, they are working sometimes, and then they dont.
                    Sorry. for stealing your time.
                    • webstorW
                      webstorW
                      webstor
                      The baddest part is, I have to reorder these lan shields and wait till the show up.
                        Why did they die?
