  3. MyNodes.NET
  4. Problems With Arduino 1.6.11 and MySensor 2.0.0
Scheduled Pinned Locked Moved MyNodes.NET
7 Posts 3 Posters 3.0k Views 3 Watching
  • fahrettineF
    fahrettineF
    fahrettine
    Hi everybody,
    After having problems with Arduino 1.6.5 and old MySensors drivers I decided to load Arduino latest version. After loading Arduino 1.6.11 and installed MySensors 2.0.0 drivers I couldnt compile the Serial Gateway of MyNodes.
    I get the error below. Any idea about the problem? THANKS!!!
    C:\Users\fahrettin\Desktop\MyNodes\SerialGateway\SerialGateway.ino:41:27: fatal error: MySigningNone.h: No such file or directory
    #include <MySigningNone.h>
    compilation terminated.
    exit status 1
    • mfalkviddM
      Looks like the library wasn't installed properly. How did you install it? Using the library manager is the best way, see https://www.mysensors.org/about/arduino#installing-the-sensor-libraries for details.
      Make sure you completely remove the existing MySensors folder before installing.
        The example you tried to compile seems to be picked up from for 1.5 version. Use the examples provided with 2.0.
        • fahrettineF
          fahrettineF
          fahrettine
          @mfalkvidd thanks for your quick response... I installed the library using "Manage Libraries" menu. The library looks OK. There is a folder named "MySensors" under Documents\Arduino\libraries and I can see the library installed on the "Library Manager".
          Dear @derwish ... Is the firmware of MyNodes Serial Gateway up to date or appropriate for latest Arduino and MySensors? What should I do?
          Thanks...
          • fahrettineF
            fahrettineF
            fahrettine
            @hek Hi. Thanks for your response...
            I downloded the Serial Gateway firmware from http://www.mynodes.net/Hardware/Gateway. Which firmware should I instal? The Serial Gateway on the Arduino\File\Examples\MySensors menu?
              Yes
              • fahrettineF
                fahrettineF
                fahrettine
                I installed the Gateway Serial from the Examples menu.
                On the Serial Port I get the messages below. It seems everything is OK.
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                0;255;0;0;18;2.0.0
                0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration
                On the Arduino side everything looks OK.
                But when I choose/start MyNodes web interface-->Serial Port I get the error messages below. Still the same problem.
                Welcome to MyNodes.NET.
                Please configure the system in the web interface.
                Hosting environment: Production
                Now listening on: http://localhost:1312
                Application started. Press Ctrl+C to shut down.
                17.09.2016 00:20:57: SYSTEM: Connecting to database...
                17.09.2016 00:20:57: SYSTEM: Database connected.
                17.09.2016 00:21:08: SYSTEM: Connecting to gateway...
                17.09.2016 00:21:08: GATEWAY: Trying to connect...
                17.09.2016 00:21:08: GATEWAY: Connected to port COM3 at 115200 bits/s.
                17.09.2016 00:21:08: GATEWAY: Trying to communicate...
                17.09.2016 00:21:13: GATEWAY: Gateway is not responding.
                17.09.2016 00:21:18: GATEWAY: Gateway is not responding.
                17.09.2016 00:21:23: GATEWAY: Gateway is not responding.
                17.09.2016 00:21:29: GATEWAY: Gateway is not responding.
                Any idea guys? Thanks!!!
