  3. MQTT Broker gateway
MQTT Broker gateway
132 Posts 34 Posters 147.8k Views 7 Watching
  • JohnJ
    JohnJ
    John
    @Damme
    Ok, my plugin will then just try to reconnect.
    Ok, i will check that then probably the day after tomorrow, i will make my code take no translation as first and if not found try the naming (internally), because the server takes over the semantics anyway because it also is going to include a MQTT broker service.
    Currently the MQTT implementation is being tested with an end user. Maybe he will help test the new possibility without V_TYPE translation when your changes are implemented.
    • JohnJ
      JohnJ
      John
      @Damme
      When does exactly the messages like "MyMQTT/[NODEID]/255/V_SKETCH_NAME" and/or "MyMQTT/[NODEID]/255/V_SKETCH_VERSION" appear? is this only when an address is assigned or always when a node is started?
      DammeD 1 Reply Last reply
      • JohnJ John
        @Damme
        DammeD
        DammeD
        Damme
        Code Contributor
        wrote on last edited by Damme
        #37
        @John then node is started, There was a bug not processing that message which is fixed now.
        hasn't been pulled to official yet but can be found at https://github.com/Damme/MQTTGateway/commit/f10843f5efd9c37900624fe57275be11c69e3942
        JohnJ 1 Reply Last reply
        • DammeD Damme
          JohnJ
          JohnJ
          John
          @Damme
          Thnx, was struggling with this with a user. Will need to wait for the next release :).
          • FrancoisF
            FrancoisF
            Francois
            @Damme when will the new release be available?
            • A
              adrianmihai83
              wrote on last edited by adrianmihai83
              #40
              Dear colleagues,
              I have been using OpenHAB for a couple of days now, everything is going the right way, I've been using it with mosquitto broker for Windows, everything is solid, working well an fast. Decided to go a step further and use the MQTT Gateway presented here.
              I've made a MQTT Gateway but get the "Not connected to broker" message from OpenHAB. First of all, the Gateway is an arduino uno with a w5100 shield on top in which I inserted the RF module (NRF24L01). Configured my ip in the gateway sketch (192.168.1.11) and uploaded to the arduino.
              The first test was to connect with a phone (using MQTT from Playstore - used it many times before) and with a PC (using WMQTT Utility - used it many times before) and things don't look that promising, the problem beeing that client somethimes disconnects, and I cannot receive the message published in a topic (topic that I am subscribed to on the phone, pc and tablet using MQTT clients). I somethimes get the message in the serial monitor of the arduino, somethimes not.
              Configured openhab.cfg to use the mqtt broker at 192.168.1.11 (before I was using mosquitto on pc 192.168.1.10 and working without problems) and everythime I change state of something in the dashboard of openhab I get this Broker Connection not Started even if after starting openhab I get serial output from arduino for some time, after this everything drops. Here is the serial output:serial_output.txt
              Last two entries are: I opened the MQTT client on my phone, connected to MQTT Gateway and subscribed to topic home/# and the last one is me publishing from the phone to topic home/test the message "test message". None of the messages come back to the clients on the phone, tablet, pc, all of them subscribed to home/#
              And here is the output from openhab: openhab_output.txt Ignore the samsung connect stuff, I have pull it off the network, i have managed to get it working well.
              Best regards,
              Adrian
              • DammeD
                DammeD
                Damme
                Code Contributor
                #41
                @adrianmihai83 "home/openHAB/out/Temperature_GF_Corridor/state" is probobly long string, 47 chars. I have not investigated exacly how long it can be but keep it short. And the adress layout is also wrong, is should be something like MyMQTT/21/1/V_LIGHT . MQTTGateway is not compatible with the mosquitto broker you're using.
                • A
                  adrianmihai83
                  #42
                  @Damme , your instructions were highly appreciated, got it working the first time. I will start creating the network now, I guess that everything will be ok. Will follow this forum for info and knowledge.
                  Now I will migrate openHAB to Rasberry Pi and add all the sensors one by one, there are a few.
                  A question though: I am using the humidity sketch and get MyMQTT/0/1/V_TEMP and MyMQTT/0/0/V_HUM reading fine but I cannot get sketch name... I don't know what I am doing wrong... Read above and I guess I have to wait for new version?
                  Thank you.
                  Adrian
                  Edit: Read more about Rasbery Pi capabilities regarding openHAB and I think I will use a cubietruck... Does anybody use one, cubieboard 2 or cubietruck?
                  • A adrianmihai83
                    Thank you.
                    Adrian
                    DammeD
                    DammeD
                    Damme
                    Code Contributor
                    @adrianmihai83 Sketch-name was a bug that I fixed in development branch, thought @hek updated master branch also. I can post the fix later on in here.
                    • A
                      adrianmihai83
                      Maybe a dumb question but I don't figure things, here is my problem:
                      Uploaded the relay sketch to the same arduino that I used for humidity/temperature node (I don't know if this is relevant, the network has only one node, this one). Modified the pin that the relay is connected to: #define RELAY_1 4.
                      I am using the MQTT Gateway openHAB and cannot activate the relay...
                      Serial output of relay sketch is:
                      repeater started, id 0
                      send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=3,st=ok:1.4
                      send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                      send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
                      send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                      send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=3,st=ok:1.4
                      Serial output of gateway is:
                      Started!
                      0;0;3;0;9;read: 0-0-0 s=255,c=0,t=18,pt=0,l=3:1.4
                      0;0;3;0;9;read: 0-0-0 s=255,c=3,t=6,pt=1,l=1:0
                      0;0;3;0;9;read: 0-0-0 s=255,c=3,t=11,pt=0,l=5:Relay
                      0;0;3;0;9;read: 0-0-0 s=255,c=3,t=12,pt=0,l=3:1.0
                      0;0;3;0;9;read: 0-0-0 s=1,c=0,t=3,pt=0,l=3:1.4
                      My openHAB configuration is:
                      Switch node2_sw1 "sw2" (node2,all) {mqtt=">mysensor:MyMQTT/0/1/V_LIGHT:command:ON:1],>[mysensor:MyMQTT/0/1/V_LIGHT:command:OFF:0]"}
                      What am I doing wrong?
                      Thank you!
                      • FrancoisF
                        FrancoisF
                        Francois
                        If I run the MQTTGateway my temperature shows in fahrenheit when I run the same nodes on a SerialGateway it is showing Celsius why will this be the case?
                        • A
                          adrianmihai83
                          #46
                          Downloaded from https://github.com/Damme/MQTTGateway latest MQTT Gateway (the one that responds on serial with "Ok!" not "Started!", with the modifications to MySensors.cpp) but no difference, still no sketch name and with the above settings, openHAB cannot control the relay sensor...
                          I used the same arduino that is working with Temp_Humidity sensor so the setup is good, the relay pins are specified in the sketch. I used the Clean_Eeprom_Config before uploading, I even used other Arduino Uno, no diffrerence, still cannot control the relay sensor from openHAB.
                          Anyone has a clue, a hint or something? The serial output from both the sensor and the gateway, together with openHAB configuration are two posts up.
                          Edit: 3 hours later and managed to make many of the sensors (Door, Distance, Dust, Gas, Humidity, Light, Motion) everyone working in conjunction with MQTT Gateway and openHAB except the Relay one...
                          Any help is appreciated.
                          Regards,
                          Adrian
                          • A
                            adrianmihai83
                            Callback for incomming messages does not occur so I guess that the message does not get to the relay sensor. Is there someone that is using this with MQTT Gateway and openHAB?
                            • FrancoisF
                              FrancoisF
                              Francois
                              wrote on last edited by Francois
                              #48
                              @adrianmihai83 I was testing this today and it was working with the MQTTGateway. Here is my config file same as above:
                              Switch node2_sw2 "Study Lights" (node2,all) { mqtt=">[mysensor:MyMQTT/2/1/V_LIGHT:command:ON:1],>[mysensor:MyMQTT/2/1/V_LIGHT:command:OFF:0],<[mysensor:MyMQTT/2/1/V_LIGHT:command:MAP(1on0off.map)]" }
                              Here is the info from the serial port monitor.
                              upload-805fea56-06b2-4632-a2c0-fb8cd80a8ec5
                              • A
                                adrianmihai83
                                #49
                                Will test it tomorrow morning and come back with result, what i see is exactly the same configuration, the only difference is that your's is on the 3'rd node and mine on 1'st node. Anyway, will see.
                                Thank you for your answer.
                                I am still waiting for my other NRF24L01 ( I ordered 30 pcs), they will arive this week. Maybe there is a problem running the sketch on node one, id 0. Tomorrow I will go and buy 2 of the NRF24 from a store even if they are 4 times more expensive, this not working is killing me :)
                                • A
                                  adrianmihai83
                                  #50
                                  Why is the broker offering me the same id for all of the sensors? I start the first one, broker offers me id 0, without disconnecting it I connect the second sensor and the gateway offers me same id, id=0.
                                  I have cleared eeprom to both of them and see the requesting id first time i power them up, but still same id for both...
                                  Edit 1:
                                  Defined static ID and the relay works, didn't modify anything, just static ID 2 to the relay...
                                  Edit 2:
                                  Just tested with ID 0, 1 and 2 and I can confirm that the relay does NOT work with ID 0, it's almost a week now and I have tried everything and the answer was as simple as this: does not work with ID 0.
                                  • Z
                                    Z
                                    Zeph
                                    By ID do you mean node ID? If so, the gateway has node ID 0, so I'm not surprised if it's not good for other nodes.
                                    But you may be talking about a child ID or something else.
                                    • A
                                      adrianmihai83
                                      Yes, I am talking about node ID, but what I can tell you is that until two days ago I didn't assigned node ID manual and I didn't have 3 NRF's to test with gateway + 2 nodes. Only when I got other RF's and made a couple of sensors saw that the gateway is assigning node ID 0 to all of the sensors, and all sensors worked, for example:
                                      1. temp humidity node had Node ID 0 and Child 0 and 1, and from openHAB I could use them at MYMQTT/0/0/V_HUM and MYMQTT/0/1/V_TEMP
                                      2. motion sensor at MYMQTT/0/2/V_MOTION
                                      3. and do on, other 2 sensors, all I had to take care is that all of them had distinct Child ID
                                      Only when I got other NRF's and could make sensors and use them in paralel saw that the gateway is offering NODE ID 0 to all of my sensors, I don't know why, checked MYMQTT.h and it was set to auto assign Node ID, even in the statemant gateway.begin() assumes that the gateway should auto assign Node ID, and gw.begin(incomingMessage, AUTO, true) states it clear that relay sensor should get Node ID from the gateway.
                                      All I did is manual assigned nodes for every one and workking like a charm. I simply like it this way, it let's more control, it's simply more "my way".
                                      Now I want to combine some of the sensors and use a Mega2560 for this, hoping for a nice outcome.
                                      • JohnJ
                                        JohnJ
                                        John
                                        wrote on last edited by John
                                        #53
                                        • JohnJ John
                                          [[topic:post-is-deleted]]
                                          DammeD
                                          DammeD
                                          Damme
                                          Code Contributor
                                          @John Could you send me log from MQTTgateway also? (or tcpdump)
