  3. ESP8266 gateway + WebServer = Awesome!
33 Posts 10 Posters 15.5k Views 16 Watching
  • JapioJ Japio
    @Yveaux ok, thanks, I just have learned something ;-)
    So I can assume the receive function is not called from the library then? So which function is called, on reception of data from a node?
    @Japio Looks like you hit a bug in 2.0.0 (receive() was not called for gateways), which has been fixed in development: https://github.com/mysensors/MySensors/commit/24e3dfa36c711b4174ed615408994e8624a2b1f3#diff-9ff5690366e84c42d1e97f40dfe3b8a1R580
    Please try with development branch (2.0.1 beta) https://github.com/mysensors/MySensors/tree/development and see if that fixes your issue.
    • JapioJ
      JapioJ
      Japio
      Yes, I see the difference. I'll try the bèta version tomorrow.
      • JapioJ Japio
        I used the indications feature of MySensors 2.0 and a webserver to have the gateway provide status information through a web page:
        This is how I did it:
        In the global section I added this:
        #include <ESP8266WiFi.h>
        #include <ESP8266WebServer.h>
        #include <WiFiClient.h>
        ESP8266WebServer WebServer(80);
        unsigned long startTime=millis();
        unsigned long gwMsgSent = 0;
        unsigned long gwMsgRec = 0;
        String WebPage = "<h1>ESP8266 MQTT client for Mysensors</h1>";
        void setupWebServer();
        void showRootPage();
        String readableTimestamp(unsigned long milliseconds);
        In the setup() Added this:
          Serial.begin(9600);
          setupWebServer();
        Defined the following functions:
          WebServer.on("/", HTTP_GET, showRootPage);
          WebServer.begin();
          Serial.println("WebServer started...");
        void indication( const indication_t ind )
          switch (ind)
            case INDICATION_GW_TX:
              gwMsgSent++;
            case INDICATION_GW_RX:
              gwMsgRec++;
            default:
        void showRootPage()
          unsigned long runningTime = millis() - startTime;
          String page = WebPage;
          page+="<br>General information</br>";
          page+= "<style> table, th, td { border: 1px solid black;}</style>";
          page+="<table style=\"width:400\">";
          page+="<tr>"; page+=  "<th>Item</th>";        page+=  "<th>Value</th>";                                            page+="</tr>";
          page+="<tr>"; page+=  "<td>Running for</td>";               page+=  "<td>"; page += readableTimestamp(runningTime) ; page+= "</td>";                 page+="</tr>";
          page+="<tr>"; page+=  "<td>Gateway messages sent</td>";     page+=  "<td>"; page += gwMsgSent; page+= "</td>";                                page+="</tr>";
          page+="</table>";
          page+="<br>MySensors gateway information</br>";
          page+="<tr>"; page+=  "<td>Gateway messages received</td>";     page+=  "<td>"; page += gwMsgRec; page+= "</td>";                                page+="</tr>";
          page+="</table>";
          Serial.println("WS: Send root webpage");
          WebServer.send(200, "text/html", page);
          int days = milliseconds / 86400000;
          milliseconds=milliseconds % 86400000;
          int hours = milliseconds / 3600000;
          milliseconds = milliseconds %3600000;
           int minutes = milliseconds / 60000;
           milliseconds = milliseconds % 60000;
           int seconds = milliseconds / 1000;
           milliseconds = milliseconds % 1000;
            String timeStamp;
            timeStamp = days; timeStamp += " days, ";
            timeStamp += hours; timeStamp += ":";
            timeStamp += minutes ; timeStamp +=  ":";
            timeStamp +=seconds; timeStamp += ".";
            timeStamp +=milliseconds;
            Serial.println(timeStamp);
            return timeStamp;
        And in loop() added the following:
          WebServer.handleClient();
        If you have any more idaes on what to add to this page (I am thinking about maintaining a list of registered nodes and sensors) just post a reply!
        chrilleC
        chrilleC
        chrille
        @Japio Very nice idea - I just tested it on my ESP8266/RFM69 gateway. However the counters doesn't seem to increment (always shows 0) - is there anything special I need to make sure the indication() handler is called?
        • JapioJ
          JapioJ
          Japio
          No, it worked right out of the box, something that surprised me as well.
          You do need Mysensors 2.0 for this.
          You can check if you have a myindication.h file in the source tree of the Mysensors library. That file also contains the indications sent.
          chrilleC 2 Replies Last reply
          • JapioJ Japio
            chrilleC
            chrilleC
            chrille
            @Japio I am using the latest beta from github - it must be something else
            chrilleC 1 Reply Last reply
            • chrilleC chrille
              chrilleC
              chrilleC
              chrille
              It works on my NRF24 gateway, but not on the RFM69 gateway... Odd...
              I'm curious if someone else with a RFM69 based gateway could this this
              • Jan
              • JapioJ Japio
                chrilleC
                chrilleC
                chrille
                @Japio It's very easy to get information about available memory and wifi signal - just add
                page+="<tr>"; page+=  "<td>Free memory:</td>";               page+=  "<td>"; page += ESP.getFreeHeap() ; page+= " bytes</td>";                 page+="</tr>";
                  page+="<tr>"; page+=  "<td>WIFI signal:</td>";               page+=  "<td>"; page += WiFi.RSSI(); ; page+= " dBm</td>";                 page+="</tr>";
                • JapioJ
                  JapioJ
                  Japio
                  Great! This will be added.
                  I am going to continue with the node and sensor status tomorrow.
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    wrote on last edited by Mark Swift
                    #21
                    Love this, subscribed. It's s such a shame I always has issues with my ESP gateway and had to revert to standard ethernet. The ESP always used to fail upon large amounts of traffic :(
                    I believe this was down to blocking code, is this resolved? (off topic).
                    BTW, is it possible to somehow record any failures?
                    • JapioJ
                      JapioJ
                      Japio
                      Yes, this works!
                      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=15,pt=2,l=2,sg=0:0
                      0;255;3;0;9;TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                      0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/0/0/17
                      @@@@@@@#####@@@@@Message
                      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/6
                      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=11,pt=0,l=10,sg=0:Smartmeter
                      0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/11
                      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=12,pt=0,l=3,sg=0:0.1
                      0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/12
                      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=1,c=0,t=13,pt=0,l=0,sg=0:
                      0;255;3;0;9;Sending message on topic: mygateway1-out/20/1/0/0/13
                      0;255;3;0;9;TSF:MSG:READ,20-20-0,s=2,c=0,t=13,pt=0,l=0,sg=0:
                      0;255;3;0;9;Sending message on topic: mygateway1-out/20/2/0/0/13
                      0;255;3;0;9;TSF:SANCHK:OK
                      The @@@@###@@@ Message is printed in my receive() function!
                      Awesome. :smile:
                      korttomaK 1 Reply Last reply
                      • JapioJ Japio
                        Yes, this works!
                        Awesome. :smile:
                        korttomaK
                        korttomaK
                        korttoma
                        Nice work @Japio
                        I'm working on a ESP8266 RFM69 Gateway myself and will definitely try this also.
                        • Tomas
                        • korttomaK korttoma
                          Nice work @Japio
                          chrilleC
                          chrilleC
                          chrille
                          @korttoma I'm looking forward to hear your results, as I couldn't get it to work with RFM69. However, there doesn't seem to be transport specific code for indication(), so I really don't understand why it works with NRF and not RFM
                          • mfalkviddM
                            ESP8266+RFM69 discussion forked to https://forum.mysensors.org/topic/4889/esp8266-rfm69-gateway/
                            • chrilleC chrille
                              • Jan
                              chrilleC
                              chrilleC
                              chrille
                              I created an issue for this, but I'm still interested in hearing from other RFM69 users
                              https://github.com/mysensors/MySensors/issues/584
                              tekkaT 1 Reply Last reply
                              • chrilleC chrille
                                tekkaT
                                tekkaT
                                tekka
                                @chrille Please see my comment on github
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  Would it be possible to add information about if a controller is connected to the GW WebHMI?
                                  • Tomas
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    Is this still under development?
                                    • JapioJ
                                      JapioJ
                                      Japio
                                      Yes, it actually is.
                                      Current features:
                                      • Stores wifi and mqtt broker configuration in flash. When no configuration is found, or the flash button of the ESP is pressed for 10 seconds, released, and then the reset button is pressed, it will restart in access point mode, allowing configuration to be done.
                                      • Status page shows all nodes and sensors connected and the last sensors data and presentation time.
                                      • Status indications on the box itself using a neopixel stick of 8 leds:
                                        • Gateway status (operation or access point mode)
                                        • Wifi strength
                                        • Mqtt connection status
                                        • Transmit error
                                        • Receive indication.
                                      I designed a board to nicely fit in a standard Aliexpress housing.
                                      Main problem still is the instability of the ESP, it resets often, and I tried to work around it by maikng sure it resets quickly.
                                      I am planning to make a more elaborate topic, including board designs soon.
                                      R 1 Reply Last reply
                                      • JapioJ Japio
                                        Current features:
                                          • Wifi strength
                                          • Transmit error
                                        R
                                        R
                                        r-nox
                                        @japio
                                        Where did this all end up?
                                          @Japio perhaps you mean https://github.com/tzapu/WiFiManager ? I'm using that. It is pretty ok, but I would prefer something that had support for the async web server.
                                          pihomeP
                                          pihomeP
                                          pihome
                                          @mfalkvidd I know this is very old post but I stumble upon this while looking for esp gateway wifimanager git, can you share ur code if you don’t mind, save me time on re-inventing the wheel again...
                                          PiHome - Smart Heating Control
