  3. ESP8266 gateway + WebServer = Awesome!
33 Posts 10 Posters 15.7k Views 16 Watching
  • JapioJ
    JapioJ
    Japio
    No, it worked right out of the box, something that surprised me as well.
    You do need Mysensors 2.0 for this.
    You can check if you have a myindication.h file in the source tree of the Mysensors library. That file also contains the indications sent.
    chrilleC 2 Replies Last reply
    • JapioJ Japio
      chrilleC
      chrilleC
      chrille
      @Japio I am using the latest beta from github - it must be something else
      chrilleC 1 Reply Last reply
      • chrilleC chrille
        chrilleC
        chrilleC
        chrille
        It works on my NRF24 gateway, but not on the RFM69 gateway... Odd...
        I'm curious if someone else with a RFM69 based gateway could this this
        • Jan
        • JapioJ Japio
          chrilleC
          chrilleC
          chrille
          @Japio It's very easy to get information about available memory and wifi signal - just add
          page+="<tr>"; page+=  "<td>Free memory:</td>";               page+=  "<td>"; page += ESP.getFreeHeap() ; page+= " bytes</td>";                 page+="</tr>";
            page+="<tr>"; page+=  "<td>WIFI signal:</td>";               page+=  "<td>"; page += WiFi.RSSI(); ; page+= " dBm</td>";                 page+="</tr>";
          • JapioJ
            JapioJ
            Japio
            Great! This will be added.
            I am going to continue with the node and sensor status tomorrow.
            • Mark SwiftM
              Mark SwiftM
              Mark Swift
              wrote on last edited by Mark Swift
              #21
              Love this, subscribed. It's s such a shame I always has issues with my ESP gateway and had to revert to standard ethernet. The ESP always used to fail upon large amounts of traffic :(
              I believe this was down to blocking code, is this resolved? (off topic).
              BTW, is it possible to somehow record any failures?
              • JapioJ
                JapioJ
                Japio
                Yes, this works!
                0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=15,pt=2,l=2,sg=0:0
                0;255;3;0;9;TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/0/0/17
                @@@@@@@#####@@@@@Message
                0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/6
                0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=11,pt=0,l=10,sg=0:Smartmeter
                0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/11
                0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=12,pt=0,l=3,sg=0:0.1
                0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/12
                0;255;3;0;9;TSF:MSG:READ,20-20-0,s=1,c=0,t=13,pt=0,l=0,sg=0:
                0;255;3;0;9;Sending message on topic: mygateway1-out/20/1/0/0/13
                0;255;3;0;9;TSF:MSG:READ,20-20-0,s=2,c=0,t=13,pt=0,l=0,sg=0:
                0;255;3;0;9;Sending message on topic: mygateway1-out/20/2/0/0/13
                0;255;3;0;9;TSF:SANCHK:OK
                The @@@@###@@@ Message is printed in my receive() function!
                Awesome. :smile:
                korttomaK 1 Reply Last reply
                • JapioJ Japio
                  Yes, this works!
                  Awesome. :smile:
                  korttomaK
                  korttomaK
                  korttoma
                  Nice work @Japio
                  I'm working on a ESP8266 RFM69 Gateway myself and will definitely try this also.
                  • Tomas
                  • korttomaK korttoma
                    Nice work @Japio
                    chrilleC
                    chrilleC
                    chrille
                    @korttoma I'm looking forward to hear your results, as I couldn't get it to work with RFM69. However, there doesn't seem to be transport specific code for indication(), so I really don't understand why it works with NRF and not RFM
                    • mfalkviddM
                      ESP8266+RFM69 discussion forked to https://forum.mysensors.org/topic/4889/esp8266-rfm69-gateway/
                      • chrilleC chrille
                        • Jan
                        chrilleC
                        chrilleC
                        chrille
                        I created an issue for this, but I'm still interested in hearing from other RFM69 users
                        https://github.com/mysensors/MySensors/issues/584
                        tekkaT 1 Reply Last reply
                        • chrilleC chrille
                          tekkaT
                          tekkaT
                          tekka
                          @chrille Please see my comment on github
                          • korttomaK
                            korttomaK
                            korttoma
                            Would it be possible to add information about if a controller is connected to the GW WebHMI?
                            • Tomas
                            • Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              Is this still under development?
                              • JapioJ
                                JapioJ
                                Japio
                                Yes, it actually is.
                                Current features:
                                • Stores wifi and mqtt broker configuration in flash. When no configuration is found, or the flash button of the ESP is pressed for 10 seconds, released, and then the reset button is pressed, it will restart in access point mode, allowing configuration to be done.
                                • Status page shows all nodes and sensors connected and the last sensors data and presentation time.
                                • Status indications on the box itself using a neopixel stick of 8 leds:
                                  • Gateway status (operation or access point mode)
                                  • Wifi strength
                                  • Mqtt connection status
                                  • Transmit error
                                  • Receive indication.
                                I designed a board to nicely fit in a standard Aliexpress housing.
                                Main problem still is the instability of the ESP, it resets often, and I tried to work around it by maikng sure it resets quickly.
                                I am planning to make a more elaborate topic, including board designs soon.
                                R 1 Reply Last reply
                                • JapioJ Japio
                                  Current features:
                                    • Wifi strength
                                    • Transmit error
                                  R
                                  R
                                  r-nox
                                  @japio
                                  Where did this all end up?
                                    @Japio perhaps you mean https://github.com/tzapu/WiFiManager ? I'm using that. It is pretty ok, but I would prefer something that had support for the async web server.
                                    pihomeP
                                    pihomeP
                                    pihome
                                    @mfalkvidd I know this is very old post but I stumble upon this while looking for esp gateway wifimanager git, can you share ur code if you don’t mind, save me time on re-inventing the wheel again...
                                    PiHome - Smart Heating Control
                                    • pihomeP pihome
                                      @pihome I have a sketch at https://github.com/mfalkvidd/Arduino-Datormagazin-Pomodoro/blob/datormagazin/Arduino-Datormagazin-Pomodoro.ino but I think it is easier to just follow the instructions in the wifimanager readme.
