  3. ESP8266 gateway + WebServer = Awesome!
33 Posts 10 Posters 15.7k Views 16 Watching
  • JapioJ Japio
    @hek Indeed, the ESP has both plenty of processing power and memory compared to the arduino.
    This implementing a receive method, is that a method I can implement in my sketch, with a specific name and signature, and it will be called automatically (like the indication handler)? or does it require changes in de library code? Sounds promising, I can just take out the data I need and store it in a separate structure until the webpage is requested.
    Another thing I found "somewhere on the Internet" is an ESP8266 program that, when the wifi connection is not established, or the stored network SSID and password are empty, places the ESP in Access point mode. You can connect to this wifi network and configure the wifi settings. That way you don't need your SSID and password in the sketch.
    Too many things to do, and too little time I am afraid.:grinning:
    @Japio perhaps you mean https://github.com/tzapu/WiFiManager ? I'm using that. It is pretty ok, but I would prefer something that had support for the async web server.
    pihomeP 1 Reply Last reply
    • JapioJ
      JapioJ
      Japio
      Hmm I implemented a receive function like this:
        Serial.println("@@@@@@@#####@@@@@Message");
      And when I connect my smartmeter sensor I get the following output in the serial console of my MQTT gateway:
      0;255;3;0;9;TSP:MSG:READ 20-20-0 s=6,c=1,t=17,pt=7,l=5,sg=0:350
      0;255;3;0;9;Sending message on topic: mygateway1-out/20/6/1/0/17
      0;255;3;0;9;TSP:MSG:READ 20-20-0 s=7,c=1,t=17,pt=7,l=5,sg=1: 0
      0;255;3;0;9;Sending message on topic: mygateway1-out/20/7/1/0/17
      So I assume the receive function is not called?
      Still, as with the indication function it is fuzzy to me how it i possible that a function is called when it is implemented, but the compiler does not complain when it is not :confused:
      Is this some kind of inheritance relation?
      • JapioJ Japio
        The function is defined as weak in the library.
        This means the user can implement its own version and then the pointer to the function will be non-null, or you can leave it unimplemented and the pointer to the function becomes null. It's up to the caller (the MySensors library in this case) to test if the pointer is null before calling the function.
        • JapioJ
          JapioJ
          Japio
          @Yveaux ok, thanks, I just have learned something ;-)
          So I can assume the receive function is not called from the library then? So which function is called, on reception of data from a node?
          • JapioJ Japio
            @Japio Looks like you hit a bug in 2.0.0 (receive() was not called for gateways), which has been fixed in development: https://github.com/mysensors/MySensors/commit/24e3dfa36c711b4174ed615408994e8624a2b1f3#diff-9ff5690366e84c42d1e97f40dfe3b8a1R580
            Please try with development branch (2.0.1 beta) https://github.com/mysensors/MySensors/tree/development and see if that fixes your issue.
            • JapioJ
              JapioJ
              Japio
              Yes, I see the difference. I'll try the bèta version tomorrow.
              • JapioJ Japio
                I used the indications feature of MySensors 2.0 and a webserver to have the gateway provide status information through a web page:
                This is how I did it:
                In the global section I added this:
                #include <ESP8266WiFi.h>
                #include <ESP8266WebServer.h>
                #include <WiFiClient.h>
                ESP8266WebServer WebServer(80);
                unsigned long startTime=millis();
                unsigned long gwMsgSent = 0;
                unsigned long gwMsgRec = 0;
                String WebPage = "<h1>ESP8266 MQTT client for Mysensors</h1>";
                void setupWebServer();
                void showRootPage();
                String readableTimestamp(unsigned long milliseconds);
                In the setup() Added this:
                  Serial.begin(9600);
                  setupWebServer();
                Defined the following functions:
                  WebServer.on("/", HTTP_GET, showRootPage);
                  WebServer.begin();
                  Serial.println("WebServer started...");
                void indication( const indication_t ind )
                  switch (ind)
                    case INDICATION_GW_TX:
                      gwMsgSent++;
                    case INDICATION_GW_RX:
                      gwMsgRec++;
                    default:
                void showRootPage()
                  unsigned long runningTime = millis() - startTime;
                  String page = WebPage;
                  page+="<br>General information</br>";
                  page+= "<style> table, th, td { border: 1px solid black;}</style>";
                  page+="<table style=\"width:400\">";
                  page+="<tr>"; page+=  "<th>Item</th>";        page+=  "<th>Value</th>";                                            page+="</tr>";
                  page+="<tr>"; page+=  "<td>Running for</td>";               page+=  "<td>"; page += readableTimestamp(runningTime) ; page+= "</td>";                 page+="</tr>";
                  page+="<tr>"; page+=  "<td>Gateway messages sent</td>";     page+=  "<td>"; page += gwMsgSent; page+= "</td>";                                page+="</tr>";
                  page+="</table>";
                  page+="<br>MySensors gateway information</br>";
                  page+="<tr>"; page+=  "<td>Gateway messages received</td>";     page+=  "<td>"; page += gwMsgRec; page+= "</td>";                                page+="</tr>";
                  page+="</table>";
                  Serial.println("WS: Send root webpage");
                  WebServer.send(200, "text/html", page);
                  int days = milliseconds / 86400000;
                  milliseconds=milliseconds % 86400000;
                  int hours = milliseconds / 3600000;
                  milliseconds = milliseconds %3600000;
                   int minutes = milliseconds / 60000;
                   milliseconds = milliseconds % 60000;
                   int seconds = milliseconds / 1000;
                   milliseconds = milliseconds % 1000;
                    String timeStamp;
                    timeStamp = days; timeStamp += " days, ";
                    timeStamp += hours; timeStamp += ":";
                    timeStamp += minutes ; timeStamp +=  ":";
                    timeStamp +=seconds; timeStamp += ".";
                    timeStamp +=milliseconds;
                    Serial.println(timeStamp);
                    return timeStamp;
                And in loop() added the following:
                  WebServer.handleClient();
                If you have any more idaes on what to add to this page (I am thinking about maintaining a list of registered nodes and sensors) just post a reply!
                chrilleC
                chrilleC
                chrille
                @Japio Very nice idea - I just tested it on my ESP8266/RFM69 gateway. However the counters doesn't seem to increment (always shows 0) - is there anything special I need to make sure the indication() handler is called?
                • JapioJ
                  JapioJ
                  Japio
                  No, it worked right out of the box, something that surprised me as well.
                  You do need Mysensors 2.0 for this.
                  You can check if you have a myindication.h file in the source tree of the Mysensors library. That file also contains the indications sent.
                  chrilleC 2 Replies Last reply
                  • JapioJ Japio
                    chrilleC
                    chrilleC
                    chrille
                    @Japio I am using the latest beta from github - it must be something else
                    chrilleC 1 Reply Last reply
                    • chrilleC chrille
                      chrilleC
                      chrilleC
                      chrille
                      It works on my NRF24 gateway, but not on the RFM69 gateway... Odd...
                      I'm curious if someone else with a RFM69 based gateway could this this
                      • Jan
                      • JapioJ Japio
                        chrilleC
                        chrilleC
                        chrille
                        @Japio It's very easy to get information about available memory and wifi signal - just add
                        page+="<tr>"; page+=  "<td>Free memory:</td>";               page+=  "<td>"; page += ESP.getFreeHeap() ; page+= " bytes</td>";                 page+="</tr>";
                          page+="<tr>"; page+=  "<td>WIFI signal:</td>";               page+=  "<td>"; page += WiFi.RSSI(); ; page+= " dBm</td>";                 page+="</tr>";
                        • JapioJ
                          JapioJ
                          Japio
                          Great! This will be added.
                          I am going to continue with the node and sensor status tomorrow.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            wrote on last edited by Mark Swift
                            #21
                            Love this, subscribed. It's s such a shame I always has issues with my ESP gateway and had to revert to standard ethernet. The ESP always used to fail upon large amounts of traffic :(
                            I believe this was down to blocking code, is this resolved? (off topic).
                            BTW, is it possible to somehow record any failures?
                            • JapioJ
                              JapioJ
                              Japio
                              Yes, this works!
                              0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=15,pt=2,l=2,sg=0:0
                              0;255;3;0;9;TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                              0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                              0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/0/0/17
                              0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                              0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/6
                              0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=11,pt=0,l=10,sg=0:Smartmeter
                              0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/11
                              0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=12,pt=0,l=3,sg=0:0.1
                              0;255;3;0;9;Sending message on topic: mygateway1-out/20/255/3/0/12
                              0;255;3;0;9;TSF:MSG:READ,20-20-0,s=1,c=0,t=13,pt=0,l=0,sg=0:
                              0;255;3;0;9;Sending message on topic: mygateway1-out/20/1/0/0/13
                              0;255;3;0;9;TSF:MSG:READ,20-20-0,s=2,c=0,t=13,pt=0,l=0,sg=0:
                              0;255;3;0;9;Sending message on topic: mygateway1-out/20/2/0/0/13
                              0;255;3;0;9;TSF:SANCHK:OK
                              The @@@@###@@@ Message is printed in my receive() function!
                              Awesome. :smile:
                              korttomaK 1 Reply Last reply
                              • JapioJ Japio
                                Yes, this works!
                                Awesome. :smile:
                                korttomaK
                                korttomaK
                                korttoma
                                Nice work @Japio
                                I'm working on a ESP8266 RFM69 Gateway myself and will definitely try this also.
                                • Tomas
                                • korttomaK korttoma
                                  Nice work @Japio
                                  chrilleC
                                  chrilleC
                                  chrille
                                  @korttoma I'm looking forward to hear your results, as I couldn't get it to work with RFM69. However, there doesn't seem to be transport specific code for indication(), so I really don't understand why it works with NRF and not RFM
                                  • mfalkviddM
                                    ESP8266+RFM69 discussion forked to https://forum.mysensors.org/topic/4889/esp8266-rfm69-gateway/
                                    • chrilleC chrille
                                      • Jan
                                      chrilleC
                                      chrilleC
                                      chrille
                                      I created an issue for this, but I'm still interested in hearing from other RFM69 users
                                      https://github.com/mysensors/MySensors/issues/584
                                      tekkaT 1 Reply Last reply
                                      • chrilleC chrille
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @chrille Please see my comment on github
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          Would it be possible to add information about if a controller is connected to the GW WebHMI?
                                          • Tomas
