  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • G
    G
    Gustafsson
    Hi guys,
    I've tried to add my ethernet gateway to openhab2 through but I just cant get the Online-status on, it. Do I have to do anything else than just adding it into the things file?
    andreacioniA 1 Reply Last reply
    • G Gustafsson
      Hi guys,
      andreacioniA
      andreacioniA
      andreacioni
      Hi @Gustafsson,
      Have you read the readme? Readme . Probably you have not configured things? See the readme on how to do that :)
      G 1 Reply Last reply
      • andreacioniA andreacioni
        Hi @Gustafsson,
        G
        G
        Gustafsson
        @andreacioni That's exactly what I did.
        Things
        Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.254.228", tcpPort=5003, sendDelay=200 ]
                door    frontDoor       [ nodeId="102", childId="4" ]
        Items
        Text    frontDoor       "Door"  { channel="mysensors:door:gateway:frontDoor:tripped" }
        Sitemap
        sitemap MySitemap label="Main Menu" {
                Frame {
                        Text item=frontDoor
        This is how everything looks like now. I get the door item green in habmin but still the red cross on the gateway. The door item dosn't show me if it's open or closed.
        • G Gustafsson
          Things
          Items
          Sitemap
                  Frame {
                          Text item=frontDoor
          G
          G
          gonzalonal
          @Gustafsson
          You are missing the opening brackets
          Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.254.228", tcpPort=5003, sendDelay=200 ] {
          • G gonzalonal
            @Gustafsson
            G
            G
            Gustafsson
            @gonzalonal sorry, I missed it when I pasted in my code here, so there is in fact a { in my code. Any other ideas?
            • FutureCowF
              FutureCowF
              FutureCow
              I have a problem with adding one of my nodes.
              My temp en hum nodes are working perfectly, but i try to add a Light Level node. The sensor is sending the amount of Lux and not the percentage:
              18:14:59.572 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:3
              18:14:59.572 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;0;1;0;23;3
              18:14:59.574 [ERROR] [g.mysensors.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from serial port, message: class org.openhab.binding.mysensors.protocol.serial.MySensorsSerialReader
              It is using CHILD_ID_LIGHT inside the skechts. Is this light level node supported?
              • FutureCowF FutureCow
                TimO
                According to this: https://www.mysensors.org/download/serial_api_20
                V_LIGHT_LEVEL	23	Uncalibrated light level. 0-100%. Use V_LEVEL for light level in lux.	S_LIGHT_LEVEL
                V_LEVEL	37	Used for sending level-value	S_DUST, S_AIR_QUALITY, S_SOUND (dB), S_VIBRATION (hz), S_LIGHT_LEVEL (lux)
                Your node should send "1;0;1;0;37;3 if I'm not mistaken.
                The light level message is supported by the binding.
                • T
                  TimO
                  wrote on last edited by TimO
                  #263
                  Small update to the progress:
                  1. Expert mode: I've added a special thing that will allow rule based parsing and sending of MySensors messages. If the binding is limiting your creativity you are now free to go. ;-) You are now able to combine/adapt rules like in this Thread with the easy process of thing/item/sensor configuration. I've added a description to the Wiki. This may solve some problems mentioned above with sensors requesting information like pulse count.
                  2. Last week the OH2 core team has released beta4 of OH2. I've tested the binding against the current beta and it is working fine.
                  3. I've created a PR against the official openhab2-addons repository. I'm now awaiting feedback and hope to introduce the MySensors binding as part of OH2.
                    Great job @Timo!
                    • G
                      G
                      gonzalonal
                      Great news to hear @TimO .
                      I will be testing the binding in a couple of hours. It's really usefull the new RAW messenger things.
                      • xliborX
                        xliborX
                        xlibor
                        Hi all, i am new in mysensors, but i have problem with install this plugin to OpenHab2.0 i tried versions 2.0 and 2.0b4 but i couldn't see this plugin in OpenHab2, i tried with RPi B, RPi3 with Raspian Jessie, and with Windows 10. But all with the same result.
                        I placed org.openhab.binding.mysensors-2.0.0.SNAPSHOT.jar into addons directory, but i can't se it in OpenHab.
                        Can anyone help me?
                        • xliborX xlibor
                          Can anyone help me?
                          TimO
                          @xlibor Did you follow the instructions on the wiki and installed serial transport first? Is there a log file entry? How did you install OH2? Debian Package or Zip File?
                          xliborX 2 Replies Last reply
                          • T TimO
                            xliborX
                            xliborX
                            xlibor
                            • T TimO
                              xliborX
                              xliborX
                              xlibor
                              wrote on last edited by xlibor
                              #269
                              @TimO Yes, i follow instruction on wiki and install serial transport sucesfully. I tried both types, first zip file and next package, but both with the same result :-(
                              In log file is nothing about mysensors or any error.
                              Now i downloaded again from github and now all works without any problem. But i don't know where was problem.
                              • daxjonesD
                                daxjonesD
                                daxjones
                                Hey All. Newbie alert here. I love the work you all do on here and this project is so exciting. I'm hooked after 2 weeks of 'fettling' and building sensors.
                                I've hit a brick wall though. after struggling with openhab1 I decided to make the leap straight to openhab2. Although in early days of testing it seems immediately abit more user friendly.
                                What I've done so far...
                                RaspberryPi3 is acting as controller with openhab2 installed and running fine. bindings to TV and Nest thermostat all working lovely.
                                Clone arduino Uno's with capacitors added for radio with NRF24 radio cards
                                Created GatewayW5100 gateway using the mysensors library sketch for it and set static IP to 192.168.0.11 (Openhab2 is set to 192.168.0.10) and my router gives DHCP from 192.168.0.20 up
                                created a temp and humidity sensor node and a node with a relay to turn a lamp on (both from mysensors library). Tested radio on all before moving ahead.
                                Installed the mysensors binding on OH2
                                Added a ethernet gateway
                                disabled startup connection check as it kept failing to initialise and showed as offline
                                Tried auto discovery of nodes... NOTHING
                                Tried setting node ID manually on the arduinos.. Still NOTHING, even if i add a thing manually to OH2.
                                I'm hoping i'm doing something stupid and its an easy fix.. Any pointers for a newbie??
                                D.
                                • daxjonesD daxjones
                                  D.
                                  TimO
                                  @daxjones
                                  Have you tried to reach your gateway with telnet?
                                  telnet 192.168.2.11 5003
                                  Does it respond? Do you see the messages from the node arriving?
                                  Have you enabled debug output of the binding like described in the wiki? What does the log say?
                                  FleischtorteF 1 Reply Last reply
                                  • T TimO
                                    @daxjones
                                    FleischtorteF
                                    FleischtorteF
                                    Fleischtorte
                                    Hi@TimO
                                    first, thanks for your awesome work :+1:
                                    On the weekend i switched from OH1 to OH2 and your binding is working just out of the box :)
                                    Im only missing the IR_Send and the V_TEXT sensor to integrate all of my sensors :(
                                    could you integrate them in your binding?
                                    • FleischtorteF Fleischtorte
                                      Hi@TimO
                                      TimO
                                      Thanks @Fleischtorte!
                                      There already was a request for IR and I've added one for V_TEXT.
                                      https://github.com/tobof/openhab2-addons/issues
                                      @andreacioni has done some serious refactoring of the code. After looking in the refactoring I'll add the missing sensors.
                                      • Meshx86M
                                        Meshx86M
                                        Meshx86
                                        I have the following setup:
                                        1. MQTT Gateway on Wemos D1 mini (ESP8266)
                                        2. Node on Arduin pro mini
                                        i can't get the openhab binding to distribute address to the nodes, in things in openhab there is no option for MQTT Gateway to add, what is the procedure ?
                                        Q 1 Reply Last reply
                                        • Meshx86M Meshx86
                                          Q
                                          Q
                                          Qu3Uk
                                          @Meshx86 the openhab binding doesnt support MQTT as far as I know.
                                          If you are using the MQTT binding then you need another controller/method to provide the internal functions for my sensors. I use NodeRed workflow to listen for ID requests and it provides them.
                                          Or static assign them in the node stretch.
