  3. Is it possible to run more than one pin to an interrupt for sleep/wake purposes?
55 Posts 7 Posters 19.3k Views 5 Watching
  • karl261K karl261
    @mfalkvidd Cool stuff, thanks!
    @AWI Here you go. What a chaos... Sorry. :-) I thought of a setup like this. But the interrupt pin of the pcf is not doing anything. Maybe I need another chip?
    The resistor is 10kOhm.
    NRF is also connected. And working.
    The sketch is not ready, but the keyboard works on the serial line.
    #include <Keypad_I2C.h>
    #include <Keypad.h>
    #define I2CADDR 0x38
    #define MY_NODE_ID 8
    unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
    const byte ROWS = 4; //four rows
    const byte COLS = 4; //three columns
    char keys[ROWS][COLS] = {
      {'1','2','3','A'},
      {'4','5','6','B'},
      {'7','8','9','C'},
      {'*','0','#','D'}
    // Digitran keypad, bit numbers of PCF8574 i/o port
    byte rowPins[ROWS] = {0, 1, 2, 3}; //connect to the row pinouts of the keypad
    byte colPins[COLS] = {4, 5, 6, 7}; //connect to the column pinouts of the keypad
    Keypad_I2C kpd( makeKeymap(keys), rowPins, colPins, ROWS, COLS, I2CADDR, PCF8574 );
    void setup(){
        Wire.begin( );
        kpd.begin( makeKeymap(keys) );
    //    Serial.begin(9600);
        Serial.println( "start" );
    void loop(){
        Serial.println("Waking up");
        char key = kpd.getKey();
        if (key){
        Serial.println(key);
        Serial.println("Good Night");
        delay(100);
        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), FALLING, SLEEP_TIME);
    AWIA
    AWIA
    AWI
    @karl261 Nice Job! I have to dive into the Keypad library to determine if the interrupt is activated... just give me a little longer ..
    karl261K 1 Reply Last reply
    • AWIA AWI
      karl261K
      karl261K
      karl261
      @AWI Thanks for the flowers. ;-) Your help is much appreciated!
      AWIA 1 Reply Last reply
      • karl261K karl261
        AWIA
        AWIA
        AWI
        @karl261 It is a pretty hard to find where a possible cause is.. :confused:
        What should happen to generate an interrupt is a change in one of the inputs. In a standard application the outputs (i.e. rows or colums) will be set to low and the inputs (colums or rows) pulled-up.
        I can't figure out what the state of the row's/ column's is in the idle state from the library. YOu can probably measure if the rows en colums have a different level Sorry for now...
        • AWIA AWI
          karl261K
          karl261K
          karl261
          wrote on last edited by karl261
          #25
          @AWI I don't recall that columns and rows have a different level. Of what I measured yesterday was that all 8 pins of the keyboard were at 3.3 V. So the only thing that happens is that there will be a connection made between column and row when a key is pressed. It seems that nothing is pulled up or down. :-/
          So you think the ic can do it? Then we have to re-program the library... :-(
          http://www.ti.com/lit/ds/symlink/pcf8574.pdf
          On page 15 is a wiring example. Maybe we can learn something from this. Some pull up missing?
          EDIT: No, still can"t get it to work. Buh.
          • karl261K
            karl261K
            karl261
            No progress....
            Maybe this library is better to understand the pcf...
            https://github.com/RobTillaart/Arduino/tree/master/libraries/PCF8574
            Also here are some explanations (in German) and some code examples (in English)...
            http://www.mikrocontroller.net/articles/Port-Expander_PCF8574
            • karl261K karl261
              No progress....
              AWIA
              AWIA
              AWI
              @karl261 There is no clue reading through the articles. I suggest you try to force an interrupt by pulling one pin low in idle. If that works, we go from there.
              There are a few 16key & 8key more simple examples ;) with touch keypads
              karl261K 2 Replies Last reply
              • AWIA AWI
                karl261K
                karl261K
                karl261
                @AWI I think the problem is with the keypad. Because it is not really putting a signal to its pins. The only thing it does is short circuiting them when a key is pressed... No change in high or low.
                I tried for example to pull row 1 to high and column 1 to low. Then the interrupt fires ( I think) but there is no key press detected any more. But I am not sure if the interrupt fires correctly.
                I tested some variations last night, but nothing works. It's all still set up on the breadboard, so if you have some suggestions I am happy to try.
                • karl261K karl261
                  AWIA
                  AWIA
                  AWI
                  @karl261 That's how it is supposed to be. When the library "scans" the keyboard it succesively pulls one of the rows (or colums) and check in the colums (or rows) if there is a connection. To have interrupts detected either the rows of colums should be set to low to detect a change. That would mean adapting the library (if possible) -or- (more fun) build your own routine by using Rob Tillaarts basic library from your previous post.
                  I don't have any PCF8574 to play with...
                  • AWIA AWI
                    karl261K
                    karl261K
                    karl261
                    @AWI Yes, basically, 4 inputs should be set to high in the library, and 4 inputs to low. Rows and columns. I had a look at the library examples yesterday, but so far it is beyond my programming skills. As far as I understand from all the docs this is theoretically possible.
                    Then, if done so, the pcf should detect a change in the low/high of the input pins and also detect what key was pressed. Or better the library interprets the received data by i2c correctly.
                    • AWIA AWI
                      karl261K
                      karl261K
                      karl261
                      @AWI Yeah, I guess just getting another keypad would be the easiest solution. Pitty though. I like my keypad and the fact that it is self-adhesive on the outside of the case.
                      • karl261K
                        karl261K
                        karl261
                        Or I go back to my three proposed solutions. For example solution 3) works fine. I tested it.
                        • AWIA AWI
                          karl261K
                          karl261K
                          karl261
                          @AWI I think this Library sounds very promising. What do you think? At least it talks about high and low.
                          http://playground.arduino.cc/Main/I2CPortExpanderAndKeypads
                          • karl261K karl261
                            AWIA
                            AWIA
                            AWI
                            @karl261 At least it is a more comprehensible library but it does not deal with interrupts (yet).
                            Are you able to do the following experiment?
                            • Using the library you quoted, execute the following sketch
                            #include <i2ckeypad.h>
                            #define ROWS 4
                            #define COLS 3
                            // With A0, A1 and A2 of PCF8574 to ground I2C address is 0x20
                            #define PCF8574_ADDR 0x20
                            i2ckeypad kpd = i2ckeypad(PCF8574_ADDR, ROWS, COLS);
                              Serial.begin(9600);
                              Wire.begin();
                              kpd.init();
                              Serial.print("Testing keypad/PCF8574 I2C port expander arduino lib\n\n");
                              pcf8574_write(pcf8574_i2c_addr, 0xf0);
                            • measure the input/output pins of the pcf8574 (should be 4 pins low/ 4 pins high)
                            • measure the power consumption of the pcf8574 (hope it is next to nothing)
                            IF the above is true we can easily rework te sketch to use the interrupt.
                            • AWIA AWI
                              #define ROWS 4
                              #define COLS 3
                                Serial.begin(9600);
                                Wire.begin();
                                kpd.init();
                              karl261K
                              karl261K
                              karl261
                              #35
                              @AWI Thanks. I am in the train now and I am spending my time to try to understand how things work. I also made some progress in my brain. My idea is similar, but you already have a sketch ready. :-) I will try it out, I guess on Saturday. Until then I will try to deepen my knowledge of the libraries.
                              It is also possible with the "original" library, but you are right: the "new" library is much clearer.
                              • AWIA AWI
                                #define ROWS 4
                                #define COLS 3
                                  Serial.begin(9600);
                                  Wire.begin();
                                  kpd.init();
                                karl261K
                                karl261K
                                karl261
                                #36
                                @AWI I found this library:
                                https://github.com/skywodd/pcf8574_arduino_library
                                There is a lot of talk about interrupt functionality and it seems to be somehow implemented. But I don't fully understand how it works. Maybe you can make something out of it?
                                Oh, and maybe in even more detail with some examples, I have not read it yet:
                                https://github.com/RalphBacon/PCF8574-Pin-Extender-I2C
                                ...but it looks like a software interrupt rather than a hardware interrupt??? I am confused.
                                ... at least for the last example: It does not need any library. It's all quite clear in one sketch.
                                • karl261K karl261
                                  AWIA
                                  AWIA
                                  AWI
                                  @karl261 the last sketch does not work with interrupts. It just mentions them.
                                  I would stick with the previous suggestion. Measure the current when you set some outputs to low (low is active 1)
                                  • AWIA AWI
                                    karl261K
                                    karl261K
                                    karl261
                                    @AWI Yes, I will work with the test sketch on the weekend. It is clear to me now how to set pins of the PCF8574 to HIGH or LOW, and from there we can see.
                                    • AWIA AWI
                                      karl261K
                                      karl261K
                                      karl261
                                      #39
                                      @AWI Finally:
                                      Yes, it works as expected. 4 pins are 0 V and 4 pins are 3.3 V. The chip is using 2.5 uA.
                                      I had to change a little bit the library, it did not compile and was slightly outdated, also the function we wanted to use was private, but I just did the changes in the library.
                                      I also needed to update to the latest arduino from 1.6.5 to 1.6.12, because i got an error: collect2.exe: error: ld returned 5 exit status. Now it works.
                                      Where do we go from here?
                                      • karl261K karl261
                                        @AWI Finally:
                                        AWIA
                                        AWIA
                                        AWI
                                        @karl261 Thats good news! What you now have is 4 rows high/ 4 colums low (or v.v.). Now short a column with a row and and expect :baby: an interrupt (= keypress). If that is the case, you can create (or copy) a routine to read the key or keys pushed.
                                        karl261K 3 Replies Last reply
                                        • AWIA AWI
                                          karl261K
                                          karl261K
                                          karl261
                                          @AWI yeah, I kind of thought the same. I'll try to have rows high and colls low and see if the interrupt pin finally triggers. I should have some pull up on the interrupt pin. Then I'll need to see if I need any pull up or down on the other lines..,
                                          Hope I'll get something done this weekend.
                                          12.5k
