  3. Is it possible to run more than one pin to an interrupt for sleep/wake purposes?
55 Posts 7 Posters 19.3k Views 5 Watching
  • AWIA AWI
    @karl261 That's how it is supposed to be. When the library "scans" the keyboard it succesively pulls one of the rows (or colums) and check in the colums (or rows) if there is a connection. To have interrupts detected either the rows of colums should be set to low to detect a change. That would mean adapting the library (if possible) -or- (more fun) build your own routine by using Rob Tillaarts basic library from your previous post.
    I don't have any PCF8574 to play with...
    karl261K
    karl261K
    karl261
    @AWI Yes, basically, 4 inputs should be set to high in the library, and 4 inputs to low. Rows and columns. I had a look at the library examples yesterday, but so far it is beyond my programming skills. As far as I understand from all the docs this is theoretically possible.
    Then, if done so, the pcf should detect a change in the low/high of the input pins and also detect what key was pressed. Or better the library interprets the received data by i2c correctly.
    • AWIA AWI
      @karl261 There is no clue reading through the articles. I suggest you try to force an interrupt by pulling one pin low in idle. If that works, we go from there.
      There are a few 16key & 8key more simple examples ;) with touch keypads
      karl261K
      karl261K
      karl261
      @AWI Yeah, I guess just getting another keypad would be the easiest solution. Pitty though. I like my keypad and the fact that it is self-adhesive on the outside of the case.
      • karl261K
        karl261K
        karl261
        Or I go back to my three proposed solutions. For example solution 3) works fine. I tested it.
        • AWIA AWI
          karl261K
          karl261K
          karl261
          @AWI I think this Library sounds very promising. What do you think? At least it talks about high and low.
          http://playground.arduino.cc/Main/I2CPortExpanderAndKeypads
          AWIA 1 Reply Last reply
          • karl261K karl261
            AWIA
            AWIA
            AWI
            @karl261 At least it is a more comprehensible library but it does not deal with interrupts (yet).
            Are you able to do the following experiment?
            • Using the library you quoted, execute the following sketch
            #include <i2ckeypad.h>
            #define ROWS 4
            #define COLS 3
            // With A0, A1 and A2 of PCF8574 to ground I2C address is 0x20
            #define PCF8574_ADDR 0x20
            i2ckeypad kpd = i2ckeypad(PCF8574_ADDR, ROWS, COLS);
              Serial.begin(9600);
              Wire.begin();
              kpd.init();
              Serial.print("Testing keypad/PCF8574 I2C port expander arduino lib\n\n");
              pcf8574_write(pcf8574_i2c_addr, 0xf0);
            • measure the input/output pins of the pcf8574 (should be 4 pins low/ 4 pins high)
            • measure the power consumption of the pcf8574 (hope it is next to nothing)
            IF the above is true we can easily rework te sketch to use the interrupt.
            karl261K 2 Replies Last reply
            • AWIA AWI
              #define ROWS 4
              #define COLS 3
                Serial.begin(9600);
                Wire.begin();
                kpd.init();
              karl261K
              karl261K
              karl261
              wrote on last edited by karl261
              #35
              @AWI Thanks. I am in the train now and I am spending my time to try to understand how things work. I also made some progress in my brain. My idea is similar, but you already have a sketch ready. :-) I will try it out, I guess on Saturday. Until then I will try to deepen my knowledge of the libraries.
              It is also possible with the "original" library, but you are right: the "new" library is much clearer.
              • AWIA AWI
                #define ROWS 4
                #define COLS 3
                  Serial.begin(9600);
                  Wire.begin();
                  kpd.init();
                karl261K
                karl261K
                karl261
                #36
                @AWI I found this library:
                https://github.com/skywodd/pcf8574_arduino_library
                There is a lot of talk about interrupt functionality and it seems to be somehow implemented. But I don't fully understand how it works. Maybe you can make something out of it?
                Oh, and maybe in even more detail with some examples, I have not read it yet:
                https://github.com/RalphBacon/PCF8574-Pin-Extender-I2C
                ...but it looks like a software interrupt rather than a hardware interrupt??? I am confused.
                ... at least for the last example: It does not need any library. It's all quite clear in one sketch.
                • karl261K karl261
                  AWIA
                  AWIA
                  AWI
                  @karl261 the last sketch does not work with interrupts. It just mentions them.
                  I would stick with the previous suggestion. Measure the current when you set some outputs to low (low is active 1)
                  • AWIA AWI
                    karl261K
                    karl261K
                    karl261
                    @AWI Yes, I will work with the test sketch on the weekend. It is clear to me now how to set pins of the PCF8574 to HIGH or LOW, and from there we can see.
                    • AWIA AWI
                      karl261K
                      karl261K
                      karl261
                      #39
                      @AWI Finally:
                      Yes, it works as expected. 4 pins are 0 V and 4 pins are 3.3 V. The chip is using 2.5 uA.
                      I had to change a little bit the library, it did not compile and was slightly outdated, also the function we wanted to use was private, but I just did the changes in the library.
                      I also needed to update to the latest arduino from 1.6.5 to 1.6.12, because i got an error: collect2.exe: error: ld returned 5 exit status. Now it works.
                      Where do we go from here?
                      • karl261K karl261
                        @AWI Finally:
                        AWIA
                        AWIA
                        AWI
                        @karl261 Thats good news! What you now have is 4 rows high/ 4 colums low (or v.v.). Now short a column with a row and and expect :baby: an interrupt (= keypress). If that is the case, you can create (or copy) a routine to read the key or keys pushed.
                        karl261K 3 Replies Last reply
                        • AWIA AWI
                          karl261K
                          karl261K
                          karl261
                          @AWI yeah, I kind of thought the same. I'll try to have rows high and colls low and see if the interrupt pin finally triggers. I should have some pull up on the interrupt pin. Then I'll need to see if I need any pull up or down on the other lines..,
                          Hope I'll get something done this weekend.
                          • AWIA AWI
                            karl261K
                            karl261K
                            karl261
                            @AWI Ok, so far so good. If I connect 4 high wires to rows and 4 low wires to columns (or vice versa, no idea) then the interrupt pin indeed changes to 0. If I connect the interrupt pin of the IC to D3of the Arduino and then both through a pull up of 10 kOhm to Vcc, the interrupt is at 3.3 V. If I press a key it goes down to 0.040 V. That should be enough to read it as low.
                            That sounds good, doesn't it? The question is, whether the key library still works...
                            • karl261K karl261
                              AWIA
                              AWIA
                              AWI
                              wrote on last edited by AWI
                              #43
                              @karl261 Certainly and it can be pretty straight forward from here. Stick to the library you use (this), it contains all you need. You need to let MySensors catch the interrupt (in the sleep function) and have the callback routine (receive) execute char key = kpd.get_key(); as described in the example.
                              • AWIA AWI
                                karl261K
                                karl261K
                                karl261
                                @AWI It does not compile... I get this stupid error again:
                                But I don't know what to do with it.
                                • karl261K
                                  karl261K
                                  karl261
                                  current code
                                  sketch
                                  #define ROWS 4
                                  #define COLS 4
                                  #define PCF8574_ADDR 0x38
                                  #define PCF8574_PIN_CONFIG 0xf0
                                  i2ckeypad kpd = i2ckeypad(PCF8574_ADDR, ROWS, COLS, PCF8574_PIN_CONFIG);
                                    Serial.begin(9600);
                                    Wire.begin();
                                    kpd.init();
                                  //  pcf8574_write(pcf8574_i2c_addr, 0xf0);
                                    if(key != '\0') {
                                          Serial.print(key);
                                  .cpp
                                   *  i2ckeypad.cpp v0.1 - keypad/I2C expander interface for Arduino
                                   *  Copyright (c) 2009 Angel Sancho <angelitodeb@gmail.com>
                                   *  All rights reserved.
                                   *  Original source from keypad v0.3 of Mark Stanley <mstanley@technologist.com>
                                   *  (http://www.arduino.cc/playground/Main/KeypadTutorial)
                                   *  LICENSE
                                   *  This program is free software: you can redistribute it and/or modify
                                   *  it under the terms of the GNU General Public License as published by
                                   *  the Free Software Foundation, either version 3 of the License, or
                                   *  (at your option) any later version.
                                   *  This program is distributed in the hope that it will be useful,
                                   *  but WITHOUT ANY WARRANTY; without even the implied warranty of
                                   *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
                                   *  GNU General Public License for more details.
                                   *  You should have received a copy of the GNU General Public License
                                   *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
                                   *  EXPLANATION
                                   *  This library is designed for use with PCF8574, but can possibly be
                                   *  adapted to other I2C port expanders
                                   *  Wiring diagrams for PCF8574 and 4x3 keypad can be found under
                                   *  examples directory. Library runs correctly without cols pull-up
                                   *  resistors but it's better to use it
                                   *  You can change pin connections between PCF8574 and keypad under
                                   *  PIN MAPPING section below
                                   *  IMPORTANT! You have to call Wire.begin() before init() in your code
                                   *  ... and sorry for my poor english!
                                  #include "i2ckeypad.h"
                                  //extern "C" {
                                  //  #include "WConstants.h"
                                   *  PIN MAPPING
                                   *  Here you can change your wire mapping between your keypad and PCF8574
                                   *  Default mapping is for sparkfun 4x3 keypad
                                  #define COL0  2  // P2 of PCF8574, col0 is usually pin 3 of 4x3 keypads
                                  #define COL1  0  // P0 of PCF8574, col1 is usually pin 1 of 4x3 keypads
                                  #define COL2  4  // P4 of PCF8574, col2 is usually pin 5 of 4x3 keypads
                                  #define COL3  7  // sorry, don't have a 4x4 keypad to try it
                                  #define ROW0  1  // P1 of PCF8574, row0 is usually pin 2 of 4x3 keypads
                                  #define ROW1  6  // P6 of PCF8574, row1 is usually pin 7 of 4x3 keypads
                                  #define ROW2  5  // P5 of PCF8574, row2 is usually pin 6 of 4x3 keypads
                                  #define ROW3  3  // P3 of PCF8574, row3 is usually pin 4 of 4x3 keypads
                                   *  KEYPAD KEY MAPPING
                                   *  Default key mapping for 4x4 keypads, you can change it here if you have or
                                   *  like different keys
                                  const char keymap[4][5] =
                                    "123A",
                                    "456B",
                                    "789C",
                                    "*0#D"
                                   *  VAR AND CONSTANTS DEFINITION. Don't change nothing here
                                  // Default row and col pin counts
                                  int num_rows = 4;
                                  int num_cols = 3;
                                  // PCF8574 i2c address
                                  int pcf8574_i2c_addr;
                                  // PCF8574 i2c pin configuration (high low)
                                  int pcf8574_i2c_pin_cfg;
                                  // Current search row
                                  static int row_select;
                                  // Current data set in PCF8574
                                  static int current_data;
                                  // Hex byte statement for each port of PCF8574
                                  const int hex_data[8] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80};
                                  // Hex data for each row of keypad in PCF8574
                                  const int pcf8574_row_data[4] =
                                    hex_data[ROW1] | hex_data[ROW2] | hex_data[ROW3] |
                                    hex_data[COL0] | hex_data[COL1] | hex_data[COL2] | hex_data[COL3],
                                    hex_data[ROW0] | hex_data[ROW2] | hex_data[ROW3] |
                                    hex_data[ROW0] | hex_data[ROW1] | hex_data[ROW3] |
                                    hex_data[ROW0] | hex_data[ROW1] | hex_data[ROW2] |
                                  // Hex data for each col of keypad in PCF8574
                                  int col[4] = {hex_data[COL0], hex_data[COL1], hex_data[COL2], hex_data[COL3]};
                                   *  CONSTRUCTORS
                                  i2ckeypad::i2ckeypad(int addr)
                                    pcf8574_i2c_addr = addr;
                                  i2ckeypad::i2ckeypad(int addr, int r, int c, int pinc)
                                    num_rows = r;
                                    num_cols = c;
                                    pcf8574_i2c_pin_cfg = pinc;
                                   *  PUBLIC METHODS
                                  void i2ckeypad::init()
                                    // All PCF8574 ports high
                                    pcf8574_write(pcf8574_i2c_addr, pcf8574_i2c_pin_cfg);
                                    // Start with the first row
                                    row_select = 0;
                                  char i2ckeypad::get_key()
                                    static int temp_key;
                                    int tmp_data;
                                    int r;
                                    int key = '\0';
                                    // Search row low
                                    pcf8574_write(pcf8574_i2c_addr, pcf8574_row_data[row_select]);
                                    for(r=0;r<num_cols;r++) {
                                      // Read pcf8574 port data
                                      tmp_data = pcf8574_byte_read(pcf8574_i2c_addr);
                                      // XOR to compare obtained data and current data and know
                                      // if some column are low
                                      tmp_data ^= current_data;
                                      // Key pressed!
                                      if(col[r] == tmp_data) {
                                        temp_key = keymap[row_select][r];
                                        return '\0';
                                    // Key was pressed and then released
                                    if((key == '\0') && (temp_key != '\0'))
                                      key = temp_key;
                                      temp_key = '\0';
                                      return key;
                                    // All PCF8574 ports high again
                                    // Next row
                                    row_select++;
                                    if(row_select == num_rows) {
                                      row_select = 0;
                                    return key;
                                   *  PRIVATE METHODS
                                  void i2ckeypad::pcf8574_write(int addr, int data)
                                    current_data = data;
                                    Wire.beginTransmission(addr);
                                    Wire.write(data);
                                    Wire.endTransmission();
                                  int i2ckeypad::pcf8574_byte_read(int addr)
                                    Wire.requestFrom(addr, 1);
                                    return Wire.read();
                                  .h
                                  #ifndef i2ckeypad_h
                                  #define i2ckeypad_h
                                  #include <inttypes.h>
                                  #if ARDUINO >= 100
                                  #include "Arduino.h"
                                  #include "WProgram.h"
                                  class i2ckeypad {
                                  public:
                                    i2ckeypad(int);
                                    i2ckeypad(int, int, int, int);
                                    char get_key();
                                    void init();
                                  private:
                                    void pcf8574_write(int, int);
                                    int pcf8574_byte_read(int);
                                  • karl261K karl261
                                    current code
                                    sketch
                                    #define ROWS 4
                                    #define COLS 4
                                      Serial.begin(9600);
                                      Wire.begin();
                                      kpd.init();
                                      if(key != '\0') {
                                            Serial.print(key);
                                    .cpp
                                     *  LICENSE
                                     *  EXPLANATION
                                    //extern "C" {
                                     *  PIN MAPPING
                                      "123A",
                                      "456B",
                                      "789C",
                                      "*0#D"
                                    int num_rows = 4;
                                    int num_cols = 3;
                                     *  CONSTRUCTORS
                                      num_rows = r;
                                      num_cols = c;
                                     *  PUBLIC METHODS
                                      row_select = 0;
                                      int tmp_data;
                                      int r;
                                      int key = '\0';
                                      // Search row low
                                        // Key pressed!
                                          return '\0';
                                        key = temp_key;
                                        temp_key = '\0';
                                        return key;
                                      // Next row
                                      row_select++;
                                        row_select = 0;
                                      return key;
                                     *  PRIVATE METHODS
                                      Wire.write(data);
                                      return Wire.read();
                                    .h
                                    #ifndef i2ckeypad_h
                                    #define i2ckeypad_h
                                    #if ARDUINO >= 100
                                    class i2ckeypad {
                                    public:
                                      i2ckeypad(int);
                                      char get_key();
                                      void init();
                                    private:
                                    AWIA
                                    AWIA
                                    AWI
                                    #46
                                    @karl261 I compiled the thing without any errors...
                                    what I did:
                                    • All the files (including the library) in (sub)folder Keypad
                                    • Saved the sketch as Keypad.ino
                                    • Changed <i2ckeypad.h> to "i2ckeypad.h"
                                    p.s. a google search showed that the error occurs with many for no obvious reason...
                                    • AWIA AWI
                                      what I did:
                                      karl261K
                                      karl261K
                                      karl261
                                      @AWI yes, I checked Google too, but there is now real solution. I can go back to 1.6.5r5 maybe this works.
                                      • AWIA AWI
                                        what I did:
                                        karl261K
                                        karl261K
                                        karl261
                                        @AWI This makes no sense at all! I did what you did, and it compiled. Then I reverted the steps, to my original setup, and it compiles too. WHY? I would be SO HAPPY if somebody could explain.
                                        So the sketch works, but not all keys...
                                        • karl261K
                                          karl261K
                                          karl261
                                          #49
                                          Ok, the keypad works. All keys. Now I have to check the interrupt.
                                          The interrupt is not working any more. At least I don't see it on the Voltmeter. The interrupt pin remains high all the time.
                                          I think this is because to get the key pressed, the library is scanning through the pins and writes different high low states to the ports of the pcf. This kills again the interrupt functionality.
                                          Yes, if I take out the loop function char key = kpd.get_key(); then the interrupt works again, because the library only writes 0xf0 and then it works. When the library is scanning, it does not work anymore.
                                          maybe it is possible to write 0xf0 before going to sleep... Then it won't scan, just wait for the interrupt?
                                          With the knew knowledge of 0xf0 writing I could also test the keypad_I2C library.
                                          12.5k
