  3. Battery powered sensor last 1 week
29 Posts 7 Posters 10.5k Views 6 Watching
  • Martin TellblomM Martin Tellblom
    @scalz said:
    always powere
    Alright, as you proberbly understand I'm not a electronics engineer :) so please explain that to me.
    This is how its setup:
    Everything is build on @sundberg84 Easy/Newbie PCB (This is my LAB PCB that I try out on before soldering, easier to chane components to see if someone of the cheap once are broken)
    Sensor Vcc connected to 3,3V, GND to GND and sensor to D3.
    So what do I have to do to turn of the sensor when I put the arduino to sleep?
    sundberg84S
    sundberg84S
    @Martin-Tellblom - instead of wire power from VCC to the sensor you could try power it through D3 or another IO pin.
    Then you set this pin to HIGH to power the sensor and then LOW before you sleep the node.
    If you have a multimeter you could measure the ampere when you sleep the node.
    • Martin TellblomM
      Martin TellblomM
      Martin Tellblom
      Alright so if I connect the Vcc sron the sensor to D2 (since I use D3 for measurement) and set that HIGH before I measure, should I have a sleep for it to power up aswell?
      Something Like this?
        digitalWrite(SOIL_POWER_PIN , HIGH);
        delayMicroseconds(25);
        moisture = analogRead(SOIL_SENSE_PIN);
        digitalWrite(SOIL_POWER_PIN , LOW);
      MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
      sundberg84S Nca78N 2 Replies Last reply
        sundberg84S
        sundberg84S
        @Martin-Tellblom - Yes, something like that.
        Dont use delay, use wait(); if tou want to create a pause for reading.
        Martin TellblomM 2 Replies Last reply
        • sundberg84S sundberg84
          Martin TellblomM
          Martin TellblomM
          Martin Tellblom
          @sundberg84
          OK,
          I have now changed to the below code and changed to a SOIL sensor with the LED still on
          The LED is lit up even after digitalWrite(SOIL_POWER_PIN , LOW); so I don't think its working
            wait(25);
            wait(25);
            if (oldMoisture != moisture) {
              send(msgSoil.set(moisture, 0));
              sendBatteryLevel(moisture);
              oldMoisture = moisture;
            //Check Battery Level
              // Power up radio after sleep
              oldBatteryPcnt = batteryPcnt;
            sleep(SLEEP_TIME);
            Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            @sundberg84
            Stupid me, forgot defining it as output pinMode(SOIL_POWER_PIN, OUTPUT); in the setup
            It's working now
            • sundberg84S
              sundberg84S
              Good! @Martin-Tellblom If you can measure how much uA it consumes in sleep() mode you can then calculate the life expectancy. Around 100uA is fine in my world with a booster and pro mini.
              Martin TellblomM 1 Reply Last reply
                Martin TellblomM
                Martin TellblomM
                Martin Tellblom
                I thought I could do that with my multimeter but I get no value
                  sundberg84S
                  sundberg84S
                  @Martin-Tellblom - Put the multimeter in series with VCC. Dont forget to change the input on your multimeter.
                  cimba007C 1 Reply Last reply
                    cimba007C
                    cimba007C
                    cimba007
                    wrote on last edited by cimba007
                    @sundberg84
                    Be aware that depending on the mesurement range a multimeter could introduce a big burdan voltage.
                    Just simple and short: To measure in the mA range you the multmeter measures the voltage drop accross a series resistor with an value .. call it A.
                    Switching to the µA range the mutltimeter switches to a much larger resistor (e.g. 1000times A) to measure a significat enough voltage drop. With the wrong voltage range .. measuring µA while the board is consuming in the mA range might lead to a huge voltage drop and your circuit not working at all.
                    So do this:
                    • Switch to mA mode .. take your measurement .. wait until you KNOW for sure your circuit is in sleep mode (add some messages on the serial console) and THEN switch to µA range.
                    • Martin TellblomM
                      Martin TellblomM
                      Martin Tellblom
                      I don't think my multimeter is good enough for this, It seems like it put in some power due if I
                      I will try this when I get home today and see if I need a new multimeter or not :)
                        and with a multimeter only, due to burden voltage and depending of the multimeter precision, you won't get the true power consumption, an approx which is still nice, you can know what "looks" power consumption and tendancy. Even if you're using a nice expensive Fluke. Best precision for this is uCurrent Gold+multimeter ;)
                        • Martin TellblomM
                          Martin TellblomM
                          Martin Tellblom
                          wrote on last edited by Martin Tellblom
                          @scalz
                          Or just simply take percentage and date/time and then a few days later see what has changed percentage wise ...
                          Its to simple I know but if 1% battery power equals 4 days the sensor probably last for about 9-10 month (the last percentage I suppose you don't get any communication with :) )
                            @scalz
                            sundberg84S
                            sundberg84S
                            @Martin-Tellblom - Im not sure it works that way. It depends on which battery you use.
                            Voltage tends to drop faster in the end for normal AA batteries.
                            My sensors doesnt drop that much (maybe 5%) the first 6 months.
                            • Martin TellblomM
                              Martin TellblomM
                              Martin Tellblom
                              @sundberg84 Hmm What you are saying is that I need to buy a new and better Multimeter :) This is the reason I was waiting for ..... :9
                                sundberg84S
                                sundberg84S
                                @Martin-Tellblom - I hope you dont give up! Battery operations was the hardest part for me to figure out...
                                • Martin TellblomM
                                  Martin TellblomM
                                  Martin Tellblom
                                  I only have two kind of sensors that I need to be battery operated and that's the plants warning that they are out of water and soon gonna die and the dogs water bowl warning that they soon gonna die (KIDDING). The dogs bowl I like to measure the levels and have that to compare with the temperature, just for fun.
                                  I hope I get this working aswell, It wont be pretty with a cable around the few plants we got
                                  • N
                                    N
                                    Nicklas Starkel
                                    @Martin-Tellblom , I'm in this mess as well. Just ordered a new Multimeter off aliexpress :)
                                    @sundberg84 , have you tried other batteries? I bough some ultrafire 3.7V 8800mAh and will try these.
                                    They were cheap so no loss if they do not work out..
                                      Hello, you should use another digital pin than D2 as it is used by MySensors library and on the EastPCB it is connected to the INT pin of the NRF24. I had problems using D2 pin before because of this reason. Use D4,5,6,7 or 8 and you will be sure to have no problem.
                                      • N Nicklas Starkel
                                        sundberg84S
                                        sundberg84S
                                        @Nicklas-Starkel - Nope I have not, but @AWI has experienced with some other batteries and i know he recommends some sort to be able to avoid the booster.
                                        • Martin TellblomM
                                          Martin TellblomM
                                          Martin Tellblom
                                          Alright, my sensor has used 5% battery in 124,5 hrs that means that 100% is almost 104 days. Don't know how low the battery works but let say 20% at that is 83 days.
                                          I will start another test with D4 and see how that goes .....
