  3. Gateway ESP8266 Wifi resets after connecting to router
34 Posts 6 Posters 17.5k Views 4 Watching
  • PetjepetP Petjepet
    @mfalkvidd said:
    the watchdog timer kicks in if your code is busy for too long. If you have any delaysor long-running loops, remove them and see if it helps.
    I have the basic sketch for the gateway from MySensors so I think there are no delay nor long-running loops in there.
    Another question: can I run two gateways (the wifi one I'm only testing while my serial one is operational) when nodes are already operational? Will they not get confused about what gateway to work with?
    Change the nrf radio channel in MyConfig.h when uploading the sketches for your new network. Wih different channels the two networks will not interfere with eachother.
    Ok. Good suggestion. In that case I need to build a standard node on that channel as well.
    What happens when running on the same channel. Will existing nodes at all communicate with the new gateway when also the serial gateway is operational?
    Both gateways will answer "find parent" requests. Both gateways will try to send hardware ack for messages. This will lead to undefined behavior.
    • PetjepetP
      PetjepetP
      Petjepet
      @mfalkvidd Thanks.
      I now loaded a sketch using a different frequency and a simple Dallas Temperature node.
      The gateway powered by a direct USB power source (to avoid the power issue). The node is trying to find the parent and gets stuck there.
      The gateway is not available and I guess rebooting (blue leds lights up in I assume reboot sequence).
      So the watchdog timer issue to investigate.
      Maybe try to get firmware v2.0 for the ESP.
      • PetjepetP
        PetjepetP
        Petjepet
        @mfalkvidd I have found someone with the same issue, using a different board version 0.9 vs 1.0.
        WIFI Gateway NodeMCU 0.9 always reset
        @bigjimjeedom was using firmware 2.0.0 ending up with the same error. Not solved in this thread.
        • Harry van der WolfH
          Harry van der WolfH
          Harry van der Wolf
          This may sound very stupid and might not help you at all, but I have a mixed set of 0.9 and 1.0 Nodemcu boards. I had some issues not related with mysensors, but with a 1.0 board flashed as 1.0 and used for ESPEasy (self compiled version).
          Just as a test I recompiled for 0.9 (to my 1.0 board) and then it worked fine. Since then I compile/flash all my 0.9 and 1.0 Esps as 0.9.
          no matter whether it is for EspEasy, "my" mysensors gateway with pimatic rest-API, or the standard mysensors esp8266 mqtt gateway.
          I did not even check whether there are code differences or not between 0.9 and 1.0. For me 0.9 binaries work OK.
          • PetjepetP
            PetjepetP
            Petjepet
            wrote on last edited by Petjepet
            @Harry-van-der-Wolf thank you for this suggestion.
            I will try that one.
            It is only selecting the board 'NodeMCU 0.9 (ESP-12 Module)' instead of 'NodeMCU 1.0 (ESP-12E Module)' as board to upload to, isn't it?
              Harry van der WolfH
              Harry van der Wolf
              Yes, only that. It helped in my somewhat different situation with an unstable ESPEasy.
              • PetjepetP
                PetjepetP
                Petjepet
                @Harry-van-der-Wolf I tried but I'm still getting the same reset message: Cause:4, boot mode:(3,4).
                I'm stuck here. I also tried another NRF with the same result.
                • PetjepetP
                  PetjepetP
                  Petjepet
                  @Harry-van-der-Wolf and @mfalkvidd . I'm now on Mysensors 2 trying to get my WFI Gateway to run.
                  Used new sketch (tried both 0.9 and 1.0 board setting but no luck.
                  Serial Monitor now:
                  ets Jan  8 2013,rst cause:4, boot mode:(3,6)
                  wdt reset
                  load 0x4010f000, len 1384, room 16
                  tail 8
                  chksum 0x2d
                  csum 0x2d
                  v3de0c112
                  ~ld
                  repeating
                  • sundberg84S
                    sundberg84S
                    A long-shot but i had some resets due to I didnt set the right flash size.
                    I ran the sketch https://github.com/esp8266/Arduino/blob/master/libraries/esp8266/examples/CheckFlashConfig/CheckFlashConfig.ino and found it it was wrong.
                    Also I had alot of resets due to what @mfalkvidd said - POWER! I have the ESP 07 and tried to power it with a 3.3v regulator that couldnt provide enough mA.
                    • PetjepetP
                      PetjepetP
                      Petjepet
                      @sundberg84 I powered my NodeMCU 1.0 (ESP-12E Module) via USB from my PC. That should not give a powerissue.
                      How does your linked sketch work: load it to the NodeMCU and then check the Serial Monitor?
                        sundberg84S
                        sundberg84S
                        @Petjepet - Sorry, dont even know if it works with nodeMCU... this is ArdinoESP. My misstake...
                          Harry van der WolfH
                          Harry van der Wolf
                          @Petjepet - Sorry, I don't have a clue. It is simply working for me. I did quite some tries with different versions but either it worked or it didn't. I didn't see this error before. Are you sure you have connected the NRF24L01 correctly?
                          • PetjepetP
                            PetjepetP
                            Petjepet
                            #22
                            When using MySensors 1.5, I had this output in the Serial Monitor:
                            ESP8266 MySensors Gateway
                            Connecting to Vierkenshof_G
                            ..Connected!
                            IP: 192.168.1.76
                             ets Jan  8 2013,rst cause:4, boot mode:(3,4)
                            wdt reset
                            tail 0
                            chksum 0x42
                            csum 0x42
                            ~ld
                            Where now using MySensors 2.0, I end up with:
                            wdt reset
                            tail 8
                            chksum 0x2d
                            csum 0x2d
                            v3de0c112
                            ~ld
                            So I don't see the connect to my network anymore (?) and having different boot mode for the reset cause.
                            Tried a different radio, no change.
                            Powered with my iPhone power plug I also do not see the MCU connect to my router.
                            I guess my Amica NodeMCU isn't compatible/has hardware failure.
                            I now ordered the one as presented in the shop.
                            See if that will work.
                            • CurlyWurlyC
                              CurlyWurlyC
                              CurlyWurly
                              wrote on last edited by CurlyWurly
                              #23
                              I have had the same problem - the ESP8266 MQTT gateway device just "WDT resets" when a sensor device tries to send a message.
                              *EDIT 081016
                              In my case, I was using a yellow 0.9 dev board which has a known "screen print" error for pins GPIO4 and GPIO5 - I just swapped these pins over and all was OK - no crashes anymore.
                              https://twitter.com/bdcatalin/status/663434209265078272
                              • CurlyWurlyC
                                CurlyWurlyC
                                CurlyWurly
                                #24
                                  Harry van der WolfH
                                  Harry van der Wolf
                                  wrote on last edited by Harry van der Wolf
                                  #25
                                  @Petjepet
                                  Please see this specific post on pimatic: https://forum.pimatic.org/topic/2234/external-selfmade-pimatic-max-thermostat-control-with-esp8266/17 for an EspEasy esp8266
                                  This guy has the exact same crash and he set the spiffs-flash-size to 1M, and then it functioned.
                                  • PetjepetP
                                    PetjepetP
                                    Petjepet
                                    @Harry-van-der-Wolf thank you for the info!
                                    I'm not so familiar with these hardware items: what is the 'spiffs-flash-size' and how to adjust it?
                                      Harry van der WolfH
                                      Harry van der Wolf
                                      #27
                                      In your Arduino software under "Tools" ("Hulpmiddelen" assuming you are using the Dutch version) you select the platform you flash for. In this case probably Nodemcu 0.9 or Nodemcu 1.0.
                                      In that same menu you have "Flash size". In that submenu you can select 4M(3M SPIFFS) and 4M(1M SPIFFS). Default is the first one but in your case try the second one.
                                      SPIFFS is SPI Flash File System. See here: https://nodemcu.readthedocs.io/en/master/en/spiffs/
                                      PetjepetP 1 Reply Last reply
                                      • Harry van der WolfH Harry van der Wolf
                                        PetjepetP
                                        PetjepetP
                                        Petjepet
                                        @Harry-van-der-Wolf I tried your suggestion without luck.
                                        I'll wait for my other MCU to arrive and try again.
                                          Harry van der WolfH
                                          Harry van der Wolf
                                          I accidentally ran into this topic for a completely different reason. One of the posters mentioned that he had the same issues as you have due to an unstable power connector.
                                          Another try?
