  3. Gateway ESP8266 Wifi resets after connecting to router
34 Posts 6 Posters 17.5k Views 4 Watching
  • Harry van der WolfH
    Harry van der WolfH
    Harry van der Wolf
    Yes, only that. It helped in my somewhat different situation with an unstable ESPEasy.
    • PetjepetP
      PetjepetP
      Petjepet
      @Harry-van-der-Wolf I tried but I'm still getting the same reset message: Cause:4, boot mode:(3,4).
      I'm stuck here. I also tried another NRF with the same result.
      • PetjepetP
        PetjepetP
        Petjepet
        @Harry-van-der-Wolf and @mfalkvidd . I'm now on Mysensors 2 trying to get my WFI Gateway to run.
        Used new sketch (tried both 0.9 and 1.0 board setting but no luck.
        Serial Monitor now:
        ets Jan  8 2013,rst cause:4, boot mode:(3,6)
        wdt reset
        load 0x4010f000, len 1384, room 16
        tail 8
        chksum 0x2d
        csum 0x2d
        v3de0c112
        ~ld
        repeating
        • sundberg84S
          sundberg84S
          A long-shot but i had some resets due to I didnt set the right flash size.
          I ran the sketch https://github.com/esp8266/Arduino/blob/master/libraries/esp8266/examples/CheckFlashConfig/CheckFlashConfig.ino and found it it was wrong.
          Also I had alot of resets due to what @mfalkvidd said - POWER! I have the ESP 07 and tried to power it with a 3.3v regulator that couldnt provide enough mA.
          • PetjepetP
            PetjepetP
            Petjepet
            wrote on last edited by Petjepet
            @sundberg84 I powered my NodeMCU 1.0 (ESP-12E Module) via USB from my PC. That should not give a powerissue.
            How does your linked sketch work: load it to the NodeMCU and then check the Serial Monitor?
            • PetjepetP Petjepet
              sundberg84S
              sundberg84S
              @Petjepet - Sorry, dont even know if it works with nodeMCU... this is ArdinoESP. My misstake...
                Harry van der WolfH
                Harry van der Wolf
                @Petjepet - Sorry, I don't have a clue. It is simply working for me. I did quite some tries with different versions but either it worked or it didn't. I didn't see this error before. Are you sure you have connected the NRF24L01 correctly?
                • PetjepetP
                  PetjepetP
                  Petjepet
                  #22
                  When using MySensors 1.5, I had this output in the Serial Monitor:
                  ESP8266 MySensors Gateway
                  Connecting to Vierkenshof_G
                  ..Connected!
                  IP: 192.168.1.76
                   ets Jan  8 2013,rst cause:4, boot mode:(3,4)
                  wdt reset
                  tail 0
                  chksum 0x42
                  csum 0x42
                  ~ld
                  Where now using MySensors 2.0, I end up with:
                  wdt reset
                  tail 8
                  chksum 0x2d
                  csum 0x2d
                  v3de0c112
                  ~ld
                  So I don't see the connect to my network anymore (?) and having different boot mode for the reset cause.
                  Tried a different radio, no change.
                  Powered with my iPhone power plug I also do not see the MCU connect to my router.
                  I guess my Amica NodeMCU isn't compatible/has hardware failure.
                  I now ordered the one as presented in the shop.
                  See if that will work.
                  • CurlyWurlyC
                    CurlyWurlyC
                    CurlyWurly
                    wrote on last edited by CurlyWurly
                    #23
                    I have had the same problem - the ESP8266 MQTT gateway device just "WDT resets" when a sensor device tries to send a message.
                    *EDIT 081016
                    In my case, I was using a yellow 0.9 dev board which has a known "screen print" error for pins GPIO4 and GPIO5 - I just swapped these pins over and all was OK - no crashes anymore.
                    https://twitter.com/bdcatalin/status/663434209265078272
                    • CurlyWurlyC
                      CurlyWurlyC
                      CurlyWurly
                      #24
                        Harry van der WolfH
                        Harry van der Wolf
                        wrote on last edited by Harry van der Wolf
                        #25
                        @Petjepet
                        Please see this specific post on pimatic: https://forum.pimatic.org/topic/2234/external-selfmade-pimatic-max-thermostat-control-with-esp8266/17 for an EspEasy esp8266
                        This guy has the exact same crash and he set the spiffs-flash-size to 1M, and then it functioned.
                        • PetjepetP
                          PetjepetP
                          Petjepet
                          @Harry-van-der-Wolf thank you for the info!
                          I'm not so familiar with these hardware items: what is the 'spiffs-flash-size' and how to adjust it?
                            Harry van der WolfH
                            Harry van der Wolf
                            #27
                            In your Arduino software under "Tools" ("Hulpmiddelen" assuming you are using the Dutch version) you select the platform you flash for. In this case probably Nodemcu 0.9 or Nodemcu 1.0.
                            In that same menu you have "Flash size". In that submenu you can select 4M(3M SPIFFS) and 4M(1M SPIFFS). Default is the first one but in your case try the second one.
                            SPIFFS is SPI Flash File System. See here: https://nodemcu.readthedocs.io/en/master/en/spiffs/
                            PetjepetP 1 Reply Last reply
                            • Harry van der WolfH Harry van der Wolf
                              PetjepetP
                              PetjepetP
                              Petjepet
                              @Harry-van-der-Wolf I tried your suggestion without luck.
                              I'll wait for my other MCU to arrive and try again.
                                Harry van der WolfH
                                Harry van der Wolf
                                I accidentally ran into this topic for a completely different reason. One of the posters mentioned that he had the same issues as you have due to an unstable power connector.
                                Another try?
                                  I just build my ESP8266 Wifi gateway with a NodeMCU Lua board and an NRF24L01+ and loaded the standard sketch as distributed in MySensors 1.5.4 library with ESP8266 v2.1.0 according to the board manager in Arduino 1.6.8, using board 'NodeMCU 1.0 (ESP-12E Module)'.
                                  The same MySensors library I used to build a Serial Gateway and a few nodes with success.
                                  However when uploading the sketch to the NodeMCU and starting the Serial Monitor I see rebooting after successful wifi connection:
                                  ..Connected!
                                  IP: 192.168.1.76
                                  wdt reset
                                  tail 0
                                  chksum 0x42
                                  csum 0x42
                                  ~ld
                                  ..Connected!
                                  IP: 192.168.1.76
                                  I do not understand the 'cause: 4, boot mode:(3,4)'.
                                  What could be wrong?
                                  TheoLT
                                  TheoLT
                                  TheoL
                                    Another try?
                                    PetjepetP
                                    PetjepetP
                                    Petjepet
                                    @Harry-van-der-Wolf thank you for this interesting link.
                                    When using a more stable (other than PC-usb, iPad charger, decicated USB 2A power outlet??) other then USB, how would I be able to feed the module and also Monitor its behaviour with the Arduino IDE?
                                    • PetjepetP
                                      PetjepetP
                                      Petjepet
                                      Today arrived the new MCU (as presented in the shop) and I uploaded the sketch.
                                      Still no success, but with again a new error code:
                                      ets Jan  8 2013,rst cause:4, boot mode:(3,7)
                                      wdt reset
                                      tail 8
                                      chksum 0x2d
                                      csum 0x2d
                                      v3de0c112
                                      ~ld
                                      mode:(3,6) changed to mode:(3,7)
                                      I powered by USB on PC (for serial Monitor), USB on 2.0A output and seperate 5V directly to pin on MCU (how to monitor when not using USB on MCU?).
                                      It won't work. I think the concept is not stable enough (resets are common issues I see on the net).
                                      I'll have to give up on this I guess.
                                      • PetjepetP
                                        PetjepetP
                                        Petjepet
                                        I gave it a try again by using some suggestions on the net like changing the radio CS connection from GPIO15 to GPIO5.
                                        No effect.
                                        In the comments of the sketch I read:
                                        I guess these are not needed when using the NodeMCU as presented in the MySensors store?
                                          Harry van der WolfH
                                          Harry van der Wolf
                                          It is not necessary for any esp8266 having a usb port as you program these directly via that usb port.
                                          So. indeed: the nodemcu doesn't need it and neither does the Wemos.
                                          The esp-07, also available, does need that setup to flash/program it.
