  3. [SOLVED] latest git-snapshot causes freezes
46 Posts 6 Posters 13.2k Views 5 Watching
  • cimba007C
    cimba007C
    cimba007
    Only thing I can say so far is that this method-call causes the freez:
    Hardware setup:
    • node = 1mhz arduino pro mini (internal osciallator) with jboard and nrf24
    • gateway = esp8266
    the node is connected to an i2c adxl345 acceleration sensor
     send(_message,true);
    prepare rssi<\r><\n>
    12075 TSF:MSG:SEND,14-14-0-0,s=1,c=1,t=28,pt=0,l=11,sg=0,ft=0,st=OK:rssi: 8|0|2<\n>
    Update<\r><\n>
    12173 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n>
     | hwretry: 0<\r><\n>
    12255 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n>
    12320 TSF:MSG:ACK<\n>
    prepare to sleep<\r><\n>
    12369 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255<\n>
    12419 MCO:SLP:TPD<\n>
    12435 MCO:SLP:WUP=1<\n>
    Gateway
    0;255;3;0;9;TSF:MSG:SEND,0-0-14-14,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n>
    0;255;3;0;9;Sending message on topic: mygateway-out/14/0/1/0/16<\n>
    0;255;3;0;9;TSF:MSG:READ,14-14-0,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n>
    0;255;3;0;9;TSF:MSG:ACK REQ<\n>
    0;255;3;0;9;Sending message on topic: mygateway-out/0/0/1/0/15<\n>
    whole project:
    node-debug-log:0_1475363295558_adxl345_vibrationtest_fabo_rf.rar
    You can see that the output stops while flushing an millis output ...
    I am using my own milliseconds-wrapper but this should make no difference. I can say that the freezes occurs within 1-5minutes with the setup from the attached file.
    I speed up the process of the loop to better reproduce the error. I noticed that the hangup occurs somewhere during the end of the loop. In addition to that he freeze does not occur if I send no messages to the gateway/controller at all but do only internal processing.
    Tomorrow I might clean up my sketch and try a minimal setup and reproduce the hangup.
    One possibility I am looking into is a interference of:
    TWBR = 0;
    At the same time I got a random gateway crash:
    Fatal exception 28(LoadProhibitedCause):<\n>
    epc1=0x402026ac, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000003, depc=0x00000000<\n>
    <\r><\n>
    Exception (28):<\r><\n>
    epc1=0x402026ac epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000003 depc=0x00000000<\r><\n>
    <\r><\n>
    ctx: cont <\r><\n>
    sp: 3ffef980 end: 3ffefbe0 offset: 01a0<\r><\n>
    <\r><\n>
    >>>stack>>><\r><\n>
    3ffefb20:  00000000 3ffeff7c 3ffefdc4 4020589f  <\r><\n>
    3ffefb30:  001e8480 00085f6b 3ffefdc4 40202f98  <\r><\n>
    3ffefb40:  00000001 00000011 00000000 3ffeebac  <\r><\n>
    3ffefb50:  3fffdad0 00085f6b 3ffefc8c 40203282  <\r><\n>
    3ffefb60:  3fffdad0 00085f6b 3ffefc8c 40203bb8  <\r><\n>
    3ffefb70:  3fffdad0 00085f6b 0000ea60 402031bd  <\r><\n>
    3ffefb80:  3fffdad0 00085f6b 0000ea60 4020463d  <\r><\n>
    3ffefb90:  3fffdad0 00000000 0000ea60 4020465e  <\r><\n>
    3ffefba0:  00000001 00000000 0000ea60 40204683  <\r><\n>
    3ffefbb0:  00000000 00000000 3ffeeb80 40204b49  <\r><\n>
    3ffefbc0:  3fffdad0 00000000 3ffeeb80 40204d83  <\r><\n>
    3ffefbd0:  feefeffe feefeffe 3ffeebc0 40100114  <\r><\n>
    <<<stack<<<<\r><\n>
    <\r><\n>
     ets Jan  8 2013,rst cause:2, boot mode:(1,6)<\r><\n>
    <\r><\n>
    <\r><\n>
     ets Jan  8 2013,rst cause:4, boot mode:(1,6)<\r><\n>
    <\r><\n>
    wdt reset<\r><\n>
    tekkaT 2 Replies Last reply
    • cimba007C cimba007
      Hardware setup:
      • gateway = esp8266
      Update<\r><\n>
       | hwretry: 0<\r><\n>
      Gateway
      whole project:
      TWBR = 0;
      <\r><\n>
      <\r><\n>
      ctx: cont <\r><\n>
      <\r><\n>
      >>>stack>>><\r><\n>
      <<<stack<<<<\r><\n>
      <\r><\n>
      <\r><\n>
      <\r><\n>
      <\r><\n>
      wdt reset<\r><\n>
      tekkaT
      tekkaT
      tekka
      @cimba007 You are living on the bleeding edge :) Please provide additional information such as HW setup and debug logs of both, GW and node. Thanks
        Hardware setup:
        • gateway = esp8266
        Update<\r><\n>
         | hwretry: 0<\r><\n>
        Gateway
        whole project:
        TWBR = 0;
        <\r><\n>
        <\r><\n>
        ctx: cont <\r><\n>
        <\r><\n>
        >>>stack>>><\r><\n>
        <<<stack<<<<\r><\n>
        <\r><\n>
        <\r><\n>
        <\r><\n>
        <\r><\n>
        wdt reset<\r><\n>
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @cimba007 Please post new messages instead of editing previous post - this makes it easier in terms of understanding and following the chronology of the thread.
        • cimba007C
          cimba007C
          cimba007
          wrote on last edited by cimba007
          Okay .. I am currently investigating:
          TWBR = 0;
          Might be somehow related as removing it causes no hangups so far...maybe I am seeing things with the newest snapshots :D Strangely the code was working fine until I added the mysensor-part ...
          wopps .. again
          264077 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n>
          264142 TSF:MSG:ACK<\n>
          264208 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255<\n>
          264273 MCO:SLP:TPD<\n>
          264290 MCO:SLP:WUP=1<\n>
          .30
          So i2c-speed is probably unrelated .. as even after commeting the TWBR = 0; out the hangup repeated.
          Next I will try to remove the acceleration-sensor readings ...
          • cimba007C
            cimba007C
            cimba007
            And again ...
            145440 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255<\n>
            145489 MCO:SLP:TPD<\n>
            145522 MCO:SLP:WUP=1<\n>
            .152002<\r><\n>
            Update<\r><\n>
            145522 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1<\n>
             | hwretry: 1<\r><\n>
            145522 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:1<\n>
            145522 TSF:MSG:ACK<\n>
            But this time at a differenct part ...
              fabo3axis.readIntStatus();
              sleep(digitalPinToInterrupt(3),RISING,16);
            Removing this as well ..
            • cimba007C
              cimba007C
              cimba007
              and .. again ..
              .79366<\r><\n>
              Update<\r><\n>
              76038 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1<\n>
               | hwretry: 0<\r><\n>
              76038 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:1<\n>
              76038 TSF:MSG:ACK<\n>
              My loop currently looks like this:
                motionSensor.set(1);  motionSensor.waitsend(50);
                uint8_t s = fabo3axis.readIntStatus();
                if(ADXL345_INT_ACTIVITY & s){
                  Serial.print("activity ");
                  Serial.println(millis());
                  Serial.println(s,HEX);
                  motionSensor.set(0);  motionSensor.waitsend(50);
                Serial.println("prepare to sleep");
                Serial.flush();
                // Pending Int-Stati might prevent interrupt!
                //fabo3axis.readIntStatus();
                // helper.h
                //extern unsigned long millis_offset;
                millis_offset += 16;
                Serial.print(".");
                Serial.println(mymillis());
              All referencec to the acceleration sensor removed .. the interrupt should not trigger as the interrupt-register is not "cleard" by issuing the readIntStatus ..
              • cimba007C
                cimba007C
                cimba007
                I forgot to mention that the node is battery powered @ 2x AA-Alkaline-Battery @ ~2,5volt .. no LDO involved .. and an NRF24+LNA+PA version of the NRF24 ..
                I got like 4-5 boards with this exact same setup and they run totally fine with the latest stable release ..
                .. investigating the root cause might be difficulty as my code is a little bit customized with a little wrapper .. will try out a fresh sketch tomorrow ..
                • cimba007C
                  cimba007C
                  cimba007
                  Okay ... I switched back between snapshot from yesterday and stable 2.0.0 and all I can say is that the stable is perfectly fine and the snapshot freezes.
                  prepare to sleep
                  17416 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                  17481 MCO:SLP:TPD
                  17498 MCO:SLP:WUP=1
                  .18
                  Nothing on the code has been changed. Only difference is that I had to modifie latest stable to include a few delays for my slow 1mhz node ..
                  PS: I currently don't have the time to debug this issue further .. last time it took me some days to figure out the delay-issue of slow nodes ...
                  tekkaT 1 Reply Last reply
                    prepare to sleep
                    17481 MCO:SLP:TPD
                    17498 MCO:SLP:WUP=1
                    .18
                    tekkaT
                    tekkaT
                    tekka
                    @cimba007 Could you upload a minimal sketch (ideally without external dependencies) to reproduce this?
                    • cimba007C
                      cimba007C
                      cimba007
                      // http://www.earth.org.uk/OpenTRV/Arduino/bootloader/ATmega328P-1MHz/README.txt
                      #define MY_NODE_ID 14
                      #define MY_BAUD_RATE 9600 // DONT GO HIGHER AS 57600 !!! 115200 might cause DEADLOCKS!!!
                      #define MY_DEBUG_LIGHT
                      //#include "helper.h"
                      //MySensorChild motionSensor = MySensorChild(0, S_MOTION, V_TRIPPED, "");
                      void before()
                        //wdt_enable(WDTO_8S);
                        char datetime[30]; // 22 + 1 should ben enough
                        snprintf(datetime, 30, "%s | %s", __DATE__, __TIME__);
                        #ifdef MY_DEBUG_LIGHT
                        Serial.print(F("SketchInfo: "));
                        Serial.println(datetime);
                        sendSketchInfo("adxl345", datetime);
                      #include <FaBo3Axis_ADXL345.h>
                      FaBo3Axis fabo3axis;
                      //void ADXL_ISR()
                        Serial.begin(9600); // シリアルの開始デバック用
                        Serial.println("Checking I2C device...");
                        //if(fabo3axis.searchDevice()){
                        //  Serial.println("I am ADXL345");
                        Serial.println("Init...");
                        fabo3axis.configuration();
                        fabo3axis.powerOn();
                        //fabo3axis.enableTap();
                        fabo3axis.enableActivity();
                        //attachInterrupt(digitalPinToInterrupt(3), ADXL_ISR, RISING);
                        // http://www.avrfreaks.net/forum/wire-library-increasing-i2c-speed
                        //TWBR = ((F_CPU / 400000) - 16) / 2;
                        TWBR = 0;
                        Serial.print("i2c @ "); Serial.print(TWBR); Serial.println();
                        //wdt_reset();
                        MyMessage msg(0, V_TRIPPED);
                        //motionSensor.set(1);  motionSensor.waitsend(50);
                        //send(msg,true);
                        //uint8_t s = fabo3axis.readIntStatus();
                        uint8_t s = 1;
                        if(false){
                          //Serial.println(millis());
                          msg.set(1);
                          send(msg,true);
                          //motionSensor.set(1);  motionSensor.waitsend(50,60000);
                          Serial.print(s,HEX);
                          msg.set(0);
                          send(msg,true);
                          //motionSensor.set(0);  motionSensor.waitsend(50,60000);
                        //Serial.println("prepare to sleep");
                        Serial.flush();
                        //millis_offset += 16;
                        Serial.print(" | ");
                        Serial.println(hwMillis());
                      bool my_ack_received;
                        if (message.isAck())
                          my_ack_received = true;
                      I suspect the sleep/interrupt combination.
                      Could not remove the accelerometer cause it is the source of the interrupts
                      • cimba007C
                        cimba007C
                        cimba007
                        no sleep = fine
                        no i2c-communiction/no interrupts = fine
                        both = lockup
                        • cimba007C
                          cimba007C
                          cimba007
                          I noticed that I can make the node crash if I trigger some interrupts by force (moving the accelerometer) .. nice ..
                          I guess the sleep/interrupt code has some kind of bug since the latest rework in the developer branch.
                          • ikkeTI
                            ikkeTI
                            ikkeT
                            I hope you catch it, as I believe I'm hit by the same bug. It the happens similar way on Sensebender Micro & NRF24L01+. I have a thread on troubleshooting forum with topic of interrupt mystery. I'm arduino newbie, so I'm not much help. I'm just about to try it on Arduino Pro mini just for comparison.
                            Somehow the enbling of interrupts lock it within a minute or so. If no interrupt enabled, no locking.
                            BR,
                            Ikke
                            cimba007C 1 Reply Last reply
                            • ikkeTI ikkeT
                              BR,
                              Ikke
                              cimba007C
                              cimba007C
                              cimba007
                              @ikkeT Are you using the latest stable or snapshot version?
                              tekkaT ikkeTI 2 Replies Last reply
                                tekkaT
                                tekkaT
                                tekka
                                @cimba007 Thanks, I'll try to reproduce it. What Arduino IDE & AVR Board defs are you using?
                                @ikkeT Same here, can you upload your (minimal) sketch to reproduce and also indicate MySensors, Arduino IDE and AVR board def versions?
                                cimba007C ikkeTI 2 Replies Last reply
                                  @cimba007
                                  just an idea..i don't know if it can help at all..but it looks there is a while loop in FaBo3Axis::readI2c
                                  do you think if adding some debug here you get something??
                                  i was just thinking..a freeze that's weird..no wdt?
                                  • tekkaT tekka
                                    cimba007C
                                    cimba007C
                                    cimba007
                                    @tekka Arduiono 1.6.12
                                    apm96.upload.tool=avrdude
                                    apm96.upload.protocol=arduino
                                    apm96.upload.speed=9600
                                    apm96.bootloader.tool=avrdude
                                    apm96.bootloader.extended_fuses=0x06
                                    apm96.build.board=AVR_APM96
                                    apm96.build.mcu=atmega328p
                                    apm96.build.f_cpu=1000000L
                                    apm96.build.core=arduino
                                    apm96.build.variant=standard
                                    I changed the fuses to include BDOUT @ 1,8Volt
                                    VCC of my setup is 2-3Volt
                                    • scalzS scalz
                                      @cimba007
                                      cimba007C
                                      cimba007C
                                      cimba007
                                      @scalz Thanks for the hint with the while-loop. I changed the i2c-read the following way:
                                      void FaBo3Axis::readI2c(uint8_t register_addr, uint8_t num, uint8_t buffer[])
                                        Wire.beginTransmission(_i2caddr);
                                        Wire.write(register_addr);
                                        Wire.endTransmission();
                                        Wire.requestFrom(_i2caddr, num);
                                        int i = 0;
                                        uint8_t limit = num;
                                        while(Wire.available() && limit--)
                                      	Serial.print("r");
                                          buffer[i] = Wire.read();
                                          i++;
                                      Now it should under no circumstanced read more then the number given. Sadly this had no impact:
                                       | 34291
                                      34291 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                                      34357 TSF:MSG:ACK
                                      134390 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                      r34471 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                                      34537 MCO:SLP:TPD
                                      34553 MCO:SLP:WUP=1
                                       | 34553
                                      34553 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                                      34553 TSF:MSG:ACK
                                      134553 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                      Just before the sleep ..
                                      I then added a Serial.flush() to the "r"-output ..
                                      	Serial.print("readI2c");
                                      	Serial.flush();
                                        int i = 0;
                                      	Serial.print("r");
                                      	Serial.flush();
                                          i++;
                                      54706 MCO:SLP:WUP=1
                                       | 54706
                                      54706 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                                      54706 TSF:MSG:ACK
                                      154706 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                      Now the freeze is clearly before entering the sleep function ..
                                      but then .. on another round ..
                                       | 56623
                                      56623 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                                      56623 TSF:MSG:ACK
                                      156623 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                      readI2c
                                      readI2cgot # from slave: 1
                                      r78987 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                                      79052 MCO:SLP:TPD
                                      79069 MCO:SLP:WUP=1
                                       | 79069
                                      79069 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                                      79069 TSF:MSG:ACK
                                      179069 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                      readI2c
                                      So .. your tip was very good .. it seems to be related to the
                                      -call .. only one questions remains .. why was it working perfectly on the stable library?
                                      Just to be sure I will run exactly the same code in a non-stop loop with the stable library ..
                                          int i = 0;
                                        	Serial.print("r");
                                            i++;
                                         | 34291
                                        34357 TSF:MSG:ACK
                                        34537 MCO:SLP:TPD
                                        34553 MCO:SLP:WUP=1
                                         | 34553
                                        34553 TSF:MSG:ACK
                                        	Serial.flush();
                                          int i = 0;
                                        	Serial.print("r");
                                        	Serial.flush();
                                            i++;
                                        54706 MCO:SLP:WUP=1
                                         | 54706
                                        54706 TSF:MSG:ACK
                                         | 56623
                                        56623 TSF:MSG:ACK
                                        readI2c
                                        79052 MCO:SLP:TPD
                                        79069 MCO:SLP:WUP=1
                                         | 79069
                                        79069 TSF:MSG:ACK
                                        readI2c
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @cimba007 What AVR board defs are you on?
                                        • cimba007C
                                          cimba007C
                                          cimba007
                                          @tekka said:
                                          AVR board def
                                          What do you mean with AVR board def?
                                          https://forum.mysensors.org/topic/4999/latest-git-snapshot-causes-freezes/17
                                          I am using an arduino pro-mini china clone (328p) with 8mhz internal oscillator and DIV_8 fuse.
                                          The bootloader is an "APM Optiboot 1Mhz" .. cant find the link right now.
