  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.3k Views 18 Watching
  • Boots33B
    Boots33B
    Boots33
    Haven't tried it but this might work
    move the line _____ oldValueA = valueA; ____up into the if statement
    and remove ______ && valueA == 0 ____ from the if conditional
     debouncerA.update();
      // Get the update value
      int valueA = debouncerA.read();
      if (valueA != oldValueA ) {
        send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
       oldValueA = valueA;
    rayanR 1 Reply Last reply
    • Boots33B Boots33
         oldValueA = valueA;
      rayanR
      rayanR
      rayan
      wrote on last edited by rayan
      @Boots33
      this is great
      but have a tiny problem
      with power off/on , relay state is unstable every time . i could not fix this . can you fix ? with power off/on relay to be high every time . different state of relay and button have influence on relay state after power off/on . often with power off/on , there are a change state low to high or high to low quickly.
      in other means , in startup if switch be down or up , dont Make sure relays are off when starting up
      also state in web is not correct
      Boots33B 1 Reply Last reply
      • rayanR rayan
        @Boots33
        this is great
        Boots33B
        Boots33B
        Boots33
        @rayan It might be easier if you post your code so we can see where the changes need to be made.
        • Boots33B Boots33
          rayanR
          rayanR
          rayan
          @Boots33
          this is your code :)
          #define MY_REPEATER_FEATURE
          #define RELAY_ON 1
          #define RELAY_OFF 0
          #define SSR_A_ID 1   // Id of the sensor child
          #define SSR_B_ID 2   // Id of the sensor child
          const int buttonPinA = 18;
          const int buttonPinB = 19;
          const int relayPinA = 5;
          const int relayPinB = 6;
          int oldValueA = 0;
          int oldValueB = 0;
          bool stateA = false;
          bool stateB = false;
          Bounce debouncerA = Bounce();
          Bounce debouncerB = Bounce();
          MyMessage msgA(SSR_A_ID, V_STATUS);
          MyMessage msgB(SSR_B_ID, V_STATUS);
            pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
            pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
            // After setting up the buttons, setup debouncer
            debouncerA.attach(buttonPinA);
            debouncerA.interval(5);
            debouncerB.attach(buttonPinB);
            debouncerB.interval(5);
            digitalWrite(relayPinA, RELAY_OFF);
            digitalWrite(relayPinB, RELAY_OFF);
            pinMode(relayPinA, OUTPUT);
            pinMode(relayPinB, OUTPUT);
          void presentation()  {
            sendSketchInfo("Mains Controller", "1.0");
            present(SSR_A_ID, S_LIGHT);
            present(SSR_B_ID, S_LIGHT);
            if (valueA != oldValueA) {
            oldValueA = valueA;
            debouncerB.update();
            int valueB = debouncerB.read();
            if (valueB != oldValueB) {
              send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
            oldValueB = valueB;
              switch (message.sensor) {
                case 1:
                  stateA = message.getBool();
                  digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                case 2:
                  stateB = message.getBool();
                  digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
              Serial.print("from node:");
              Serial.println(message.sender);
          • rayanR
            rayanR
            rayan
            you are set value for relay in code
            but i dont know why after start up . . .
            • rayanR rayan
              Boots33B
              Boots33B
              Boots33
              @rayan so are you saying that when the node is first booted up you want the relay to always to be turned on?
              • Boots33B Boots33
                rayanR
                rayanR
                rayan
                @Boots33
                i want if power of home be off and after time on again , so all of relay ( with switch up/down with each state) to be off. now in this code after startup relay is unstable for 1s and my light is on and aff quickly :)
                also if lights are off , if power off/on , so some of relay go to ON in startup !
                • rayanR rayan
                  @Boots33
                  Boots33B
                  Boots33B
                  Boots33
                  @rayan So if the house looses power you want the relays to be turned off when power is restored?
                  • Boots33B Boots33
                    rayanR
                    rayanR
                    rayan
                    @Boots33
                    yes, all of lights are on or off (some on some off) so when looses power and power is restored , i want all of lights be off also in web and app light = off , so with key in app or change state of switch turn on again ...
                    • rayanR
                      rayanR
                      rayan
                      but this app , every time after the restored power and startup, relay ( related to state of up/down switch) have different state
                      • rayanR rayan
                        Boots33B
                        Boots33B
                        Boots33
                        @rayan yes it was meant to be used with push buttons not toggle switches. It will need a few tweaks to make it work. I am at work now so will take a look when I get home.
                        • Boots33B Boots33
                          rayanR
                          rayanR
                          rayan
                          ok thank you
                          • rayanR rayan
                            ok thank you
                            Boots33B
                            Boots33B
                            Boots33
                            wrote on last edited by Boots33
                            @rayan Ok had a quick look and I don't think we need to do a lot for this to work.
                            The only extra change I have made is to add four new lines at the end of the setup function
                               /*--------------------- Added these lines for toggle switch-------------------------*/
                              oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
                              oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
                              send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                              send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                            As you can see the oldValue variables are now set to represent the current state of the toggle switches when the node boots up. this should stop any changes in state being made in the main loop until a switch is toggled.
                            The other two lines just send a message to the controller to tell it the switches are off. this should make the controller icons show the correct state
                            Below is the full sketch, I have nothing to test it on so give it a try and see how it goes
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            int oldValueA = 0;
                            int oldValueB = 0;
                              oldValueA = valueA;
                              oldValueB = valueB;
                                  case 1:
                                  case 2:
                            rayanR SGiS 2 Replies Last reply
                            • Boots33B Boots33
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              int oldValueA = 0;
                              int oldValueB = 0;
                                oldValueA = valueA;
                                oldValueB = valueB;
                                    case 1:
                                    case 2:
                              rayanR
                              rayanR
                              rayan
                              @Boots33 said:
                              i test your code and this is excellent . but there is another tiny problem :)
                              when relay is ON then loses power so in app relay is ON (icon) , when power is restored and relay go to OFF in app icon is ON and dont Ack for go to show Off .
                              you are best in programming :)
                              • rayanR rayan
                                Boots33B
                                Boots33B
                                Boots33
                                @rayan maybe trying to send the off message before the presentation stops it from sending
                                try this , have moved the messages to the main loop where they will only be sent once in the first loop
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                int oldValueA = 0;
                                int oldValueB = 0;
                                int trigger = 0;
                                 // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                                 // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                                if (trigger == 0){
                                  trigger = 1;
                                  oldValueA = valueA;
                                  oldValueB = valueB;
                                      case 1:
                                      case 2:
                                rayanR pepsonP 4 Replies Last reply
                                • Boots33B Boots33
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  int oldValueA = 0;
                                  int oldValueB = 0;
                                  int trigger = 0;
                                  if (trigger == 0){
                                    trigger = 1;
                                    oldValueA = valueA;
                                    oldValueB = valueB;
                                        case 1:
                                        case 2:
                                  rayanR
                                  rayanR
                                  rayan
                                  @Boots33
                                  great.
                                  so this is best sketch :)
                                  thank you
                                  • Boots33B Boots33
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValueA = 0;
                                    int oldValueB = 0;
                                    int trigger = 0;
                                    if (trigger == 0){
                                      trigger = 1;
                                      oldValueA = valueA;
                                      oldValueB = valueB;
                                          case 1:
                                          case 2:
                                    rayanR
                                    rayanR
                                    rayan
                                    @Boots33
                                    oh , after added this device , happen a Event ! node id of motion sensor and this device is 1 ! and after sense of motion light on in dashborad ! why both Catch node id 1 .
                                    i dont add #define node id for motion and for this. but both take id 1 and Interference
                                    • rayanR rayan
                                      @Boots33
                                      Boots33B
                                      Boots33B
                                      Boots33
                                      @rayan As far as I am aware if you don't set the id manually then the controller gives out an id. Why it has doubled up I don't know. Did you use that arduino before and it was originally given that address?
                                      Anyway you will have to delete the node from the mysensors hardware device in Domiticz then clear the eeprom of that arduino using the clearEepromConfig sketch in the mysensors examples and then reload the mains switch sketch. It should then be given a new id.
                                      • Boots33B Boots33
                                        rayanR
                                        rayanR
                                        rayan
                                        @Boots33
                                        thank you very much
                                        • Boots33B Boots33
                                          @SGi I have used two buttons in my Mains controller project. I have posted just the relay code below to show you what you need to do. I have not used the eeprom to store the state but you could soon add that back in. The main thing you need to do is check to see which sensor the incoming message is for.
                                             DESCRIPTION
                                             Based on the RelayWithButtonActuator sketch
                                          //#define MY_REPEATER_FEATURE
                                          #define RELAY_ON 1
                                          #define RELAY_OFF 0
                                          const int buttonPinA = 3;
                                          const int buttonPinB = 4;
                                          int oldValueA = 0;
                                          int oldValueB = 0;
                                            if (valueA != oldValueA && valueA == 0) {
                                            oldValueA = valueA;
                                            if (valueB != oldValueB && valueB == 0) {
                                            oldValueB = valueB;
                                                case 1:
                                                case 2:
                                          SGiS
                                          SGiS
                                          SGi
