  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.2k Views 18 Watching
  • rayanR
    rayanR
    rayan
    but this app , every time after the restored power and startup, relay ( related to state of up/down switch) have different state
    Boots33B 1 Reply Last reply
    • rayanR rayan
      Boots33B
      Boots33B
      Boots33
      @rayan yes it was meant to be used with push buttons not toggle switches. It will need a few tweaks to make it work. I am at work now so will take a look when I get home.
      rayanR 1 Reply Last reply
      • Boots33B Boots33
        rayanR
        rayanR
        rayan
        ok thank you
        • rayanR rayan
          ok thank you
          Boots33B
          Boots33B
          Boots33
          wrote on last edited by Boots33
          @rayan Ok had a quick look and I don't think we need to do a lot for this to work.
          The only extra change I have made is to add four new lines at the end of the setup function
             /*--------------------- Added these lines for toggle switch-------------------------*/
            oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
            oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
            send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
            send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
          As you can see the oldValue variables are now set to represent the current state of the toggle switches when the node boots up. this should stop any changes in state being made in the main loop until a switch is toggled.
          The other two lines just send a message to the controller to tell it the switches are off. this should make the controller icons show the correct state
          Below is the full sketch, I have nothing to test it on so give it a try and see how it goes
          #define MY_REPEATER_FEATURE
          #define RELAY_ON 1
          #define RELAY_OFF 0
          #define SSR_A_ID 1   // Id of the sensor child
          #define SSR_B_ID 2   // Id of the sensor child
          const int buttonPinA = 18;
          const int buttonPinB = 19;
          const int relayPinA = 5;
          const int relayPinB = 6;
          int oldValueA = 0;
          int oldValueB = 0;
          bool stateA = false;
          bool stateB = false;
          Bounce debouncerA = Bounce();
          Bounce debouncerB = Bounce();
          MyMessage msgA(SSR_A_ID, V_STATUS);
          MyMessage msgB(SSR_B_ID, V_STATUS);
            pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
            pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
            pinMode(relayPinA, OUTPUT);
            pinMode(relayPinB, OUTPUT);
            // After setting up the buttons, setup debouncer
            debouncerA.attach(buttonPinA);
            debouncerA.interval(5);
            debouncerB.attach(buttonPinB);
            debouncerB.interval(5);
            digitalWrite(relayPinA, RELAY_OFF);
            digitalWrite(relayPinB, RELAY_OFF);
          void presentation()  {
            sendSketchInfo("Mains Controller", "1.0");
            present(SSR_A_ID, S_LIGHT);
            present(SSR_B_ID, S_LIGHT);
            debouncerA.update();
            // Get the update value
            int valueA = debouncerA.read();
            if (valueA != oldValueA) {
              send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
            oldValueA = valueA;
            debouncerB.update();
            int valueB = debouncerB.read();
            if (valueB != oldValueB) {
              send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
            oldValueB = valueB;
              switch (message.sensor) {
                case 1:
                  stateA = message.getBool();
                  digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                case 2:
                  stateB = message.getBool();
                  digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
              Serial.print("from node:");
              Serial.println(message.sender);
          rayanR SGiS 2 Replies Last reply
          • Boots33B Boots33
            #define RELAY_ON 1
            #define RELAY_OFF 0
            int oldValueA = 0;
            int oldValueB = 0;
              oldValueA = valueA;
              oldValueB = valueB;
                  case 1:
                  case 2:
            rayanR
            rayanR
            rayan
            @Boots33 said:
            i test your code and this is excellent . but there is another tiny problem :)
            when relay is ON then loses power so in app relay is ON (icon) , when power is restored and relay go to OFF in app icon is ON and dont Ack for go to show Off .
            you are best in programming :)
            • rayanR rayan
              Boots33B
              Boots33B
              Boots33
              @rayan maybe trying to send the off message before the presentation stops it from sending
              try this , have moved the messages to the main loop where they will only be sent once in the first loop
              #define RELAY_ON 1
              #define RELAY_OFF 0
              int oldValueA = 0;
              int oldValueB = 0;
              int trigger = 0;
               // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
               // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
              if (trigger == 0){
                trigger = 1;
                oldValueA = valueA;
                oldValueB = valueB;
                    case 1:
                    case 2:
              rayanR pepsonP 4 Replies Last reply
              • Boots33B Boots33
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValueA = 0;
                int oldValueB = 0;
                int trigger = 0;
                if (trigger == 0){
                  trigger = 1;
                  oldValueA = valueA;
                  oldValueB = valueB;
                      case 1:
                      case 2:
                rayanR
                rayanR
                rayan
                @Boots33
                great.
                so this is best sketch :)
                thank you
                • Boots33B Boots33
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  int oldValueA = 0;
                  int oldValueB = 0;
                  int trigger = 0;
                  if (trigger == 0){
                    trigger = 1;
                    oldValueA = valueA;
                    oldValueB = valueB;
                        case 1:
                        case 2:
                  rayanR
                  rayanR
                  rayan
                  @Boots33
                  oh , after added this device , happen a Event ! node id of motion sensor and this device is 1 ! and after sense of motion light on in dashborad ! why both Catch node id 1 .
                  i dont add #define node id for motion and for this. but both take id 1 and Interference
                  • rayanR rayan
                    @Boots33
                    Boots33B
                    Boots33B
                    Boots33
                    @rayan As far as I am aware if you don't set the id manually then the controller gives out an id. Why it has doubled up I don't know. Did you use that arduino before and it was originally given that address?
                    Anyway you will have to delete the node from the mysensors hardware device in Domiticz then clear the eeprom of that arduino using the clearEepromConfig sketch in the mysensors examples and then reload the mains switch sketch. It should then be given a new id.
                    • Boots33B Boots33
                      rayanR
                      rayanR
                      rayan
                      @Boots33
                      thank you very much
                      • Boots33B Boots33
                        @SGi I have used two buttons in my Mains controller project. I have posted just the relay code below to show you what you need to do. I have not used the eeprom to store the state but you could soon add that back in. The main thing you need to do is check to see which sensor the incoming message is for.
                           DESCRIPTION
                           Based on the RelayWithButtonActuator sketch
                        //#define MY_REPEATER_FEATURE
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        const int buttonPinA = 3;
                        const int buttonPinB = 4;
                        int oldValueA = 0;
                        int oldValueB = 0;
                          if (valueA != oldValueA && valueA == 0) {
                          oldValueA = valueA;
                          if (valueB != oldValueB && valueB == 0) {
                          oldValueB = valueB;
                              case 1:
                              case 2:
                        SGiS
                        SGiS
                        SGi
                        • Boots33B Boots33
                             DESCRIPTION
                          #define RELAY_ON 1
                          #define RELAY_OFF 0
                          int oldValueA = 0;
                          int oldValueB = 0;
                            oldValueA = valueA;
                            oldValueB = valueB;
                                case 1:
                                case 2:
                          SGiS
                          SGiS
                          SGi
                          @Boots33 Whoa sorry, here is the code in the proper format/window...
                           * Version 0.1 - SGI
                           * Sketch to control 4 relays for irrigations, including 4 local push buttons..
                          // Define Relays
                          #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                          // Define Sensor ID's
                          #define SSR_A_ID 11   // Id of the sensor child
                          #define SSR_B_ID 12   // Id of the sensor child
                          #define SSR_C_ID 13   // Id of the sensor child
                          #define SSR_D_ID 14   // Id of the sensor child
                          // Define Buttons
                          const int buttonPinA = 1;
                          const int buttonPinB = 2;
                          const int buttonPinC = 3;
                          const int buttonPinD = 4;
                          // Define Variables
                          int oldValueA = 0;
                          int oldValueB = 0;
                          int oldValueC = 0;
                          int oldValueD = 0;
                          bool stateA;
                          bool stateB;
                          bool stateC;
                          bool stateD;
                          // Define Debounce
                          Bounce debouncerC = Bounce();
                          Bounce debouncerD = Bounce();
                          // Define messages to send back to gateway
                          MyMessage msgC(SSR_C_ID, V_STATUS);
                          MyMessage msgD(SSR_D_ID, V_STATUS);
                            // Setup relay pins and set to output then set relays to startup off
                              pinMode(pin, OUTPUT);
                              // Set relay off
                              digitalWrite(pin, 1);
                            pinMode(buttonPinC, INPUT_PULLUP);
                            pinMode(buttonPinD, INPUT_PULLUP);
                            debouncerC.attach(buttonPinC);
                            debouncerC.interval(5);
                            debouncerD.attach(buttonPinD);
                            debouncerD.interval(5);
                            sendSketchInfo("Irrigation with Buttons", "0.1");
                            present(SSR_C_ID, S_LIGHT);
                            present(SSR_D_ID, S_LIGHT);
                              send(msgA.set(stateA?false:true), true); // Send new state and request ack back
                            oldValueA = valueA;
                              send(msgB.set(stateB?false:true), true); // Send new state and request ack back
                            oldValueB = valueB;
                            debouncerC.update();
                            int valueC = debouncerC.read();
                            if (valueC != oldValueC && valueC == 0) {
                              send(msgC.set(stateC ? false : true), true); // Send new state and request ack back
                            oldValueC = valueC;
                            debouncerD.update();
                            int valueD = debouncerD.read();
                            if (valueD != oldValueD && valueD == 0) {
                              send(msgD.set(stateD ? false : true), true); // Send new state and request ack back
                            oldValueD = valueD;
                            if (message.type==V_STATUS) {
                                case 1:
                                  digitalWrite(message.sensor+4, stateA ? RELAY_ON : RELAY_OFF);
                                case 2:
                                  digitalWrite(message.sensor+4, stateB ? RELAY_ON : RELAY_OFF);
                                case 3:
                                  stateC = message.getBool();
                                  digitalWrite(message.sensor+4, stateC ? RELAY_ON : RELAY_OFF);
                                case 4:
                                  stateD = message.getBool();
                                  digitalWrite(message.sensor+4, stateD ? RELAY_ON : RELAY_OFF);
                               // Change relay state
                               // digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                               // Store state in eeprom
                               //saveState(message.sensor, message.getBool());
                          • Boots33B Boots33
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            int oldValueA = 0;
                            int oldValueB = 0;
                              oldValueA = valueA;
                              oldValueB = valueB;
                                  case 1:
                                  case 2:
                            SGiS
                            SGiS
                            SGi
                            @Boots33 i just worked out what was wrong the code above... and now understand how the message.sensor number works... now my only issue is why the buttons on pins 2,3,4 work but not pin 1... does pin 1 on the arduino have special use?
                            • SGiS SGi
                              Boots33B
                              Boots33B
                              Boots33
                              #26
                              @SGi great that you worked it out and improved your understanding of mysensors as well. 😊. Probably good to post the fix so others may also gain from the thread.
                              I think digital pins 0 and 1 are also used for serial communication so probably best to avoid them wherever possible. If you turn off debugging they will probably work but you may have problems uploading sketches too. The analogue pins can also be used as digital pins if you need a few more.
                              • Boots33B Boots33
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                int oldValueA = 0;
                                int oldValueB = 0;
                                int trigger = 0;
                                if (trigger == 0){
                                  trigger = 1;
                                  oldValueA = valueA;
                                  oldValueB = valueB;
                                      case 1:
                                      case 2:
                                pepsonP
                                pepsonP
                                pepson
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                int oldValueA = 0;
                                int oldValueB = 0;
                                int trigger = 0;
                                if (trigger == 0){
                                  trigger = 1;
                                  oldValueA = valueA;
                                  oldValueB = valueB;
                                      case 1:
                                      case 2:
                                Thanks this code works ok. But by switch i must still connect to GND to keep change status. Is possible to change it to give only impuls GND to change status Relay ? I want use switch monostable.
                                And anybody tell me how i can clear all eeprom in my Arduino Mini Pro. I want clear eeprom before upload sketch.
                                rayanR Boots33B 2 Replies Last reply
                                • pepsonP pepson
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  int oldValueA = 0;
                                  int oldValueB = 0;
                                  int trigger = 0;
                                  if (trigger == 0){
                                    trigger = 1;
                                    oldValueA = valueA;
                                    oldValueB = valueB;
                                        case 1:
                                        case 2:
                                  rayanR
                                  rayanR
                                  rayan
                                  @pepson
                                  go to : file > examples > mysensors > clear eeprom config
                                  and select arduino pro mini from : tools > board > arduino pro or pro mini
                                  • Boots33B Boots33
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValueA = 0;
                                    int oldValueB = 0;
                                    int trigger = 0;
                                    if (trigger == 0){
                                      trigger = 1;
                                      oldValueA = valueA;
                                      oldValueB = valueB;
                                          case 1:
                                          case 2:
                                    rayanR
                                    rayanR
                                    rayan
                                    @Boots33 this your code is good, but there is a small issue .button work just when the connection is ok (radio with gateway) ! and when radio is disconnect or controller is off, so button dont work handy . do you have any idea for this ? that when controller is off the button work handy
                                    pepsonP Boots33B 2 Replies Last reply
                                    • rayanR rayan
                                      pepsonP
                                      pepsonP
                                      pepson
                                      @rayan
                                      Hi
                                      I do this eeprom clear and after that when i upload sketch for relay with buttons , this not working. Any communication with Gateway. Upload sketch successful write.
                                      I need changes in code to button monostable. Now if i want enable RELAY i must still connect pin to GND by button. I want only give impuls GND and relay should have enable. Again give impuls GND should disable relay. The same as working Fibaro relay switch by Z-Wave.
                                      In code should be add option to select buttons:
                                      -Monostable
                                      -Bistable
                                      • pepsonP pepson
                                        @rayan
                                        Hi
                                        -Monostable
                                        -Bistable
                                        rayanR
                                        rayanR
                                        rayan
                                        @pepson
                                        i am beginner and i hope some one help to you
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          Maybe @Boots33 or @SGi help us please
