  2. Announcements
  3. 💬 Building a MQTT Gateway
81 Posts 30 Posters 48.7k Views 28 Watching
    wrote on last edited by hek
    This thread contains comments for the article "Building a MQTT Gateway" posted on MySensors.org.
    • N
      N
      Nicklas Starkel
      Quick question.
      I have built GatewayW5100MQTTClient according to mysensors.
      It works and relays my nodes.
      However, my old gateway with MqTT delivered the messages with my selected prefix and then node/child number + variable/sensor.
      Ex MyMQTT/1/1/S_TEMP
      Now the new gateway with MqTT delivers node and child and more like this:
      MyMQTT/1/1/x/x/x where X is some number.
      It does not display S_TEMP.
      And what are the extra "numbers"?
      And it also displays when the node starts up some MqTT messages that are empty ex:
      MyMQTT/1/255/3/0/1 with no information.
      I do not know what publishes these..
      For relevance, the sketches I upload are the ones in the new mysensors library, ex Atmospheric Pressure Sensor.
      • FotoFieberF
        FotoFieberF
        FotoFieber
        The new MQTT gateway exposes the serial api to MQTT. It has less functionality.
        The old client gateway was a controller and translated the protocol to more readable messages and had a node-id handling.
        I had the same problem and switched to node-red with a serial gateway.
        N 1 Reply Last reply
          https://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway
          • FotoFieberF FotoFieber
            N
            N
            Nicklas Starkel
            @FotoFieber
            How do you mean it is a problem? Everything works, just needed to know what the extra was :)
            I too use NODE RED, but just listening on MQTT and then putting the info into mysql databases.
            @hek
            Thank you! I have used search, but it is difficult when you do not know what you are searching for :) And all information about 2.0 is overwhelming at the time being for me.
              Thanks, good feedback @Nicklas-Starkel .
              I just updated the main MQTT page, moving some of the instructions from the forum.
              • Ernst79E
                Ernst79E
                Ernst79
                Seems that the W5100 sketch of the MQTT gateway is missing #include <SPI.h>.
                I had to add it before #include <Ethernet.h>.
                • siodS
                  siodS
                  siod
                  As Ernst79 already mentioned: please add #include <SPI.h> as a switch to your code, thank you!
                  still learning...
                    https://github.com/mysensors/MySensors/issues/601
                    • Martin TellblomM
                      Martin TellblomM
                      Martin Tellblom
                      Is it possible to have the MQTT client also act as a network gateway?
                      MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
                        Nope, sorry. You have to have to introduce a broker or controller acting as MQTT server.
                        • Martin TellblomM
                          Martin TellblomM
                          Martin Tellblom
                          The old network gateway with mqtt seems to be removed and the client version is the one that id preferred. Is it possible to have both mqtt server and network gateway in that version?
                            A Former User
                            Sorry for my ignorance but I would like to know how to connect the gateway to the sensor.
                            As I understand it, the radio communication is responsible for it, so can I put arduino + NRF24L01 + sensor at the other end?
                            Thank you!
                            • Martin TellblomM
                              Martin TellblomM
                              Martin Tellblom
                              wrote on last edited by Martin Tellblom
                              The gateway is a arduino with NRF24L01+ (or RFM69) and serial/network/RS485 component. The sensor is another arduino with NRF24L01+ (or RFM69) and the sensor that are attached. The gateway is then acting as a translator from the NRF24L01+ (or RFM69) radiosignal to the medium that can talk to your controller
                                A Former User
                                I thought that the gateway could be done only with the ESP8266 module.
                                • CurlyWurlyC
                                  CurlyWurlyC
                                  CurlyWurly
                                  If you're using an ESP8266 and you find it "SOFT WDT resetting" whenever a node tries to send a message, try moving the wire from GPIO4 to GPIO5 - There are a few esp12E boards which have been incorrectly screen printed - worked for me with this board!
                                  https://twitter.com/bdcatalin/status/663434209265078272
                                  • N
                                    N
                                    Nicklas Starkel
                                    Regarding ACK flag in MQTT.
                                    If a sensor sends data to the gateway, and it requests an ACK.
                                    It is the gateway that responds with an ACK, not the controller.
                                    How do one utilize the ACK flag in MQTT?
                                    Or rather, how do one get the ACK to display in a MQTT message?
                                    int value = debouncer.read();
                                    //We only expect one type of message from controller. But we better check anyway.
                                     if (message.isAck()) {
                                    Should I write a codesnippet like the above but one that sends a message back to the gateway, that the ACK was received?
                                    And also, if an ACK was not received that the sensor should try to send the message again.
                                    • GrahamG
                                      GrahamG
                                      Graham
                                      wrote on last edited by Graham
                                      I have set up an MQTT gateway running on a Wemos D1, and a motion sensor running on an arduino nano.
                                      It seems to work successfully, but I had to define MY_NODE_ID in the sensor sketch because the negotiation for this is done by the controller. Presumably, I'm going to have to program my controller to respond to the mqtt message being sent to negiotiate the id, but I cannot find any documentation on the correct reply. Does someone have a link?
                                      The mqtt message being sent to negotiate the node id was
                                      mygateway1-out/255/255/3/0/3 (null)
                                      • proddyP
                                        proddyP
                                        proddy
                                        I believe the node id will always be 0 for gateways so the examples are a little misleading. For example the output shows connections with a node id of 2 (e.g. mygateway1-out/2/1/1/0/49 55.722519;13.018121;13)
                                        • mppM
                                          mppM
                                          mpp
                                          Can this be used with RabbitMQ as broker?
                                          MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
