  2. Announcements
  3. 💬 Building a MQTT Gateway
81 Posts 30 Posters 49.7k Views 28 Watching
    Thanks, good feedback @Nicklas-Starkel .
    I just updated the main MQTT page, moving some of the instructions from the forum.
    • Ernst79E
      Ernst79E
      Ernst79
      Seems that the W5100 sketch of the MQTT gateway is missing #include <SPI.h>.
      I had to add it before #include <Ethernet.h>.
      • siodS
        siodS
        siod
        As Ernst79 already mentioned: please add #include <SPI.h> as a switch to your code, thank you!
        still learning...
          https://github.com/mysensors/MySensors/issues/601
          • Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            Is it possible to have the MQTT client also act as a network gateway?
            MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
              Nope, sorry. You have to have to introduce a broker or controller acting as MQTT server.
              • Martin TellblomM
                Martin TellblomM
                Martin Tellblom
                The old network gateway with mqtt seems to be removed and the client version is the one that id preferred. Is it possible to have both mqtt server and network gateway in that version?
                  A Former User
                  Sorry for my ignorance but I would like to know how to connect the gateway to the sensor.
                  As I understand it, the radio communication is responsible for it, so can I put arduino + NRF24L01 + sensor at the other end?
                  Thank you!
                  • Martin TellblomM
                    Martin TellblomM
                    Martin Tellblom
                    wrote on last edited by Martin Tellblom
                    The gateway is a arduino with NRF24L01+ (or RFM69) and serial/network/RS485 component. The sensor is another arduino with NRF24L01+ (or RFM69) and the sensor that are attached. The gateway is then acting as a translator from the NRF24L01+ (or RFM69) radiosignal to the medium that can talk to your controller
                      A Former User
                      I thought that the gateway could be done only with the ESP8266 module.
                      • CurlyWurlyC
                        CurlyWurlyC
                        CurlyWurly
                        If you're using an ESP8266 and you find it "SOFT WDT resetting" whenever a node tries to send a message, try moving the wire from GPIO4 to GPIO5 - There are a few esp12E boards which have been incorrectly screen printed - worked for me with this board!
                        https://twitter.com/bdcatalin/status/663434209265078272
                        • N
                          N
                          Nicklas Starkel
                          Regarding ACK flag in MQTT.
                          If a sensor sends data to the gateway, and it requests an ACK.
                          It is the gateway that responds with an ACK, not the controller.
                          How do one utilize the ACK flag in MQTT?
                          Or rather, how do one get the ACK to display in a MQTT message?
                          int value = debouncer.read();
                          //We only expect one type of message from controller. But we better check anyway.
                           if (message.isAck()) {
                          Should I write a codesnippet like the above but one that sends a message back to the gateway, that the ACK was received?
                          And also, if an ACK was not received that the sensor should try to send the message again.
                          • GrahamG
                            GrahamG
                            Graham
                            wrote on last edited by Graham
                            I have set up an MQTT gateway running on a Wemos D1, and a motion sensor running on an arduino nano.
                            It seems to work successfully, but I had to define MY_NODE_ID in the sensor sketch because the negotiation for this is done by the controller. Presumably, I'm going to have to program my controller to respond to the mqtt message being sent to negiotiate the id, but I cannot find any documentation on the correct reply. Does someone have a link?
                            The mqtt message being sent to negotiate the node id was
                            mygateway1-out/255/255/3/0/3 (null)
                            • proddyP
                              proddyP
                              proddy
                              I believe the node id will always be 0 for gateways so the examples are a little misleading. For example the output shows connections with a node id of 2 (e.g. mygateway1-out/2/1/1/0/49 55.722519;13.018121;13)
                              • mppM
                                mppM
                                mpp
                                Can this be used with RabbitMQ as broker?
                                MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
                                  stephenmhall
                                  Not sure if you want to leave the GPS on there unless that isn't your house with the double hot tub in tha back garden :)
                                  • Mountek AngelM
                                    Mountek AngelM
                                    Mountek Angel
                                    Hi, is it possible to configure the MQTT gateway to let me in to port 5003 via telnet and read the communication message (not MQTT payloads) there also?
                                    • proddyP
                                      proddyP
                                      proddy
                                      Not sure if this helps but for debugging I use MQTT spy (https://github.com/eclipse/paho.mqtt-spy/wiki) for tracking the comms
                                        There is also mqtt fx that can be used to see what's going on on the mqtt server
                                        Mountek AngelM 1 Reply Last reply
                                          Mountek AngelM
                                          Mountek AngelM
                                          Mountek Angel
                                          I know what is going on the MQTT server and I am subscribed to the topics the Mysensors gateway created and publish data to it.
                                          But, I want to know what is going on the GATEWAY as well. I'd like to see messages like these when I telnet to the gateway on port 5003 (that's the default as I remember)
                                          0;255;3;0;9;TSM:INIT
                                          0;255;3;0;9;TSM:RADIO:OK
                                          0;255;3;0;9;TSM:GW MODE
                                          0;255;3;0;9;TSM:READY
                                          IP: 192.168.0.109
                                          0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSP:MSG:BC
                                          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
                                          0;255;3;0;9;TSP:MSG:GWL OK
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
