  3. Advice about RF nRF24L01+ to send/receive sensory information
29 Posts 3 Posters 11.9k Views 2 Watching
  • Walyson Albuquerque MachadoW Walyson Albuquerque Machado
    Hey. I don't have I2C interface. Do I need it?
    I have one like this, 20x4:
    AWIA
    AWIA
    AWI
    @Walyson-Albuquerque-Machado It is much easier to connect an I2C display (only 2 wires and power).But if you have pins left on your arduino and the patience to solder you're ok.
    an adapter plate:
      I have pins and I have already done this. :stuck_out_tongue_closed_eyes:
        Is that how I send ? Can I use BINARY to my hall effect sensor? I'm using the digital pin to count every time it passes through a magnet.
        MyMessage msg(NODE_ID, V_STATUS);
        float value = 0;
            present(NODE_ID, S_BINARY);
            send(msg.set(value));
        Is that how I receive?
            // Handle incoming message
          Please, someone tell me how to get the voltage that i'm receiving. I've tried many things, I don't know why this doesn't work.
          msgvolt.getFloat();
          I can see the battery in the gateway through serial, but I don't know how to get it to show on the LCD.
          Node:
          #define MY_DEBUG_VERBOSE_RF24
          #define DESTINATION_NODE 0
          #define MY_NODE_ID 10
          #define MY_PARENT_NODE_ID  0
          #define MY_RF24_CE_PIN 9
          #define MY_RF24_CS_PIN 10
          #define MY_RF24_PA_LEVEL_GW RF24_PA_LOW
          #define MY_RF24_CHANNEL 76
          int sensorTensaoDC = A0;
          float valorTensaoDC;
          int amostragem = 1000;
          float mediaTotalTensaoDC = 0;
          float R1 = 28000.0;
          float R2 = 7600.0;
          int sensorValue_aux = 0;
          float voltsporUnidade = 0.005278592; // 5%1023
          float dadosenviados;
          MyMessage msgvolt(4, V_VOLTAGE);
            analogReference(DEFAULT);
            pinMode(A0, INPUT);
             sendSketchInfo("Battery Meter", "1.0");
             present(4, S_MULTIMETER, "Voltage", true);
            for(int i=0; i < amostragem ; i++)
              valorTensaoDC = analogRead(sensorTensaoDC);
              valorTensaoDC =(valorTensaoDC*voltsporUnidade);
              mediaTotalTensaoDC = mediaTotalTensaoDC+ (valorTensaoDC / (R2/(R1+R2)));
            dadosenviados = mediaTotalTensaoDC / amostragem;
             Serial.print(dadosenviados);
             Serial.println(" V");
           send(msgvolt.setDestination(DESTINATION_NODE).set(dadosenviados, 2), 1);
            wait(2000);
          Gateway:
          #define MY_GATEWAY_SERIAL
          #define MY_NODE_ID 0
          #define DESTINATION_NODE 10
          #include <LiquidCrystal.h>
          float dadosenviados = 0;
          LiquidCrystal lcd(3, 2, 7, 6, 5, 4);
            lcd.begin(20, 4);
            lcd.clear();
            lcd.setCursor(5, 0);
            lcd.print("Teste 1.6");
            delay(5000);
            lcd.setCursor(3, 2);
            lcd.print("Carregando...");
            delay(5000);
            lcd.clear();
                sendSketchInfo("Battery Meter", "2.0");
                present(4, S_MULTIMETER);
          void receive(const MyMessage &msgvolt) {
            saveState(msgvolt.sensor, msgvolt.getFloat());
           dadosenviados = msgvolt.getFloat();
          request(4, V_VOLTAGE, 10);
          void incomingMessage(const MyMessage &msgvolt) {
              lcd.clear();
              lcd.setCursor(0, 0);
              lcd.print("TENSAO");
              lcd.setCursor(7, 0);
              lcd.print(dadosenviados);
              lcd.print("VOLTS");
              lcd.setCursor(0, 1);
              lcd.print(msgvolt.getFloat());
              wait(1000);
                Serial.print("Battery Voltage: ")`;
          AWIA 1 Reply Last reply
            msgvolt.getFloat();
            Node:
            float R1 = 28000.0;
            float R2 = 7600.0;
              pinMode(A0, INPUT);
              wait(2000);
            Gateway:
              lcd.begin(20, 4);
              lcd.clear();
              delay(5000);
              delay(5000);
              lcd.clear();
                lcd.clear();
                lcd.print("VOLTS");
                wait(1000);
            AWIA
            AWIA
            AWI
            wrote on last edited by AWI
            #21
            @Walyson-Albuquerque-Machado a few things :
            • the receive routine should be the only place where you receive and read the incoming messages. So skip the incomingmessage routine and add its functionality to receive.
            • you don't need to 'request' anything as the node already sends messages all the time.
            • savestate writes only byte (8 bit) values, so you need to decompose a float to bytes in order to save it. (best to use an 'union' for that)
            Be aware that the gateway (node 0) receives the messages from all nodes connected. You need to make sure that that the incoming message is the one to display.
            In summary, to receive messages : the receive routine is called automatically when a message is received. You read the message content (store in a global variable) , and display it.
              wrote on last edited by Walyson Albuquerque Machado
              #22
              Ok, I'm going to erase the void incomingMessage(const MyMessage &msgvolt) and the request(4, V_VOLTAGE, 10).
              Also no savestate.
              I tried to store in a global variable and display, but I didn't understand It, how do I read!?
                if (msgvolt.type==V_VOLTAGE) {
                  digitalWrite(msgvolt.sensor, msgvolt.getFloat());
              Serial.println(msgvolt.getFloat());
              Serial.println(dadosenviados);
              Serial.println(msgvolt.data);
              This is what I'm getting in the serial:
              Node:
              Battery Voltage: 8.68 V
              RF24:stop listening
              RF24:write register, reg=0, value=14
              RF24:open writing pipe, recipient=0
              RF24:write register, reg=10, value=0
              RF24:write register, reg=16, value=0
              RF24:send message to 0, len=12
              RF24:flushTX
              RF24:write register, reg=7, value=48
              RF24:start listening
              RF24:write register, reg=0, value=15
              RF24:write register, reg=10, value=10
              TSP:MSG:SEND 10-10-0-0 s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:8.68
              RF24:read message, len=12
              RF24:write register, reg=7, value=64
              TSP:MSG:READ 0-0-10 s=4,c=1,t=38,pt=7,l=5,sg=0:8.68
              Battery Voltage: 8.69 V
              Gateway:
              10;4;1;0;38;8.68
              0;255;3;0;9;TSP:MSG:READ 10-10-0 s=4,c=1,t=38,pt=7,l=5,sg=0:8.68
              0;255;3;0;9;TSP:MSG:ACK msg
              0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:8.68
              10;4;1;0;38;8.68
                Also no savestate.
                Node:
                RF24:stop listening
                RF24:flushTX
                Gateway:
                10;4;1;0;38;8.68
                10;4;1;0;38;8.68
                AWIA
                AWIA
                AWI
                @Walyson-Albuquerque-Machado Apart from the line digitalWrite(msgvolt.sensor, msgvolt.getFloat()); (what do you want to accomplish here? wrtie a float value to a digital output?) it should be fine. The gateway is receiving the volt message so communication is working.
                this dadosenviados = msgvolt.getFloat(); variable should hold the value, but does not seem to be executed. Try with a println if the "receive" routine is called at all. As you are receiving values with a gateway (node = 0) this is a special case. I need to emulate this. As we seem to be living in a different timezones it can take a while...
                So if anybody else has a direct answer...
                  Hello! Hm, I removed the digitalWrite and I don't undestand why it doesn't get the data. I tried to print something in the receive routine and I got nothing. What do you mean about special case?
                  Thanks for the time spent with me.
                    AWIA
                    AWIA
                    AWI
                    @Walyson-Albuquerque-Machado I mirrored your setup and tried to read the messages coming into the gateway, No succes :-(
                    The "special" situation is that it's only recent that a Gateway can have locally attached sensors (and actuators..) As mentioned before the gateway receives messages from all the sensors in a (standard) MySensors netword (node 0) to forward them to a controller.
                    I'm sure I did this before so need to investigate a little further.
                    Basic question is: Does the receive() function in a gateway react to incoming sensor messages?
                      Is my send routine from the arduino + nRF24L01 + sensor correct?
                      Or:
                      send(msgvolt.set(dadosenviados, 2),  1);
                      And the receive routine from the arduino + nRF24L01 ?
                        if (msgvolt.type == V_VOLTAGE) {
                      Serial.print("Incoming");
                      The configuration of the arduino + nRF24L01 + sensor:
                      The configuration of the arduino + nRF24L01:
                        Or:
                        AWIA
                        AWIA
                        AWI
                        @Walyson-Albuquerque-Machado All of the code snippets you show seem to be ok. With respect to the #defines... most of these are default so need to include them (but nothing wrong in showing them). The Verbose output also gives me tooo much information if the radio is working.
                          #28
                          @AWI, @mfalkvidd Thank you for your time trying to help me.
                          I just found a Modified SD library to use pins A0-A3 for software SPI. I got it to work!!! So happy. :laughing:
                          If anyone interests, the link is below:
                          0_1475856752676_SD-hardcode-use-pins-A0-A3.zip
                            AWIA
                            AWIA
                            AWI
                            #29
                            @Walyson-Albuquerque-Machado Thanks for the lib.
                            Back to the issue that you are not receiving messages from your voltage sensor on your Gateway node:
                            What is found is that messages sent to the gateway node are not interpreted by the node but directly forwarded to the serial port to the controller. The #else code below in my MyTransport.cpp is responsible for that. It don't know if it was for a reason but it gives a kind of inconsistency.. it is changed in the development branch..
                            			// Hand over message to controller
                            			gatewayTransportSend(_msg);
                            			// Call incoming message callback if available
                            			if (receive) {
                            				receive(_msg);
                            12.5k
