  3. Advice about RF nRF24L01+ to send/receive sensory information
29 Posts 3 Posters 11.9k Views 2 Watching
  • Walyson Albuquerque MachadoW
    I'm trying to do the battery level example and I'm getting this:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=10)
    TSM:FPAR
    TSP:MSG:SEND 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSP:MSG:BC
    TSM:FPAR
    TSP:MSG:BC
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    What does it mean? Why can't I read the serial messages?
    AWIA 1 Reply Last reply
    • Walyson Albuquerque MachadoW Walyson Albuquerque Machado
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSP:MSG:BC
      TSM:FPAR
      TSP:MSG:BC
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      AWIA
      AWIA
      AWI
      @Walyson-Albuquerque-Machado
      Your node does not find a parent (gateway) so no response from another node. For documentation: a little indirect but this post by @mfalkvidd should help.
        Ok, I'm getting there. I appreciate your advices, thanks. :smile:
        Now I can see the battery level in the serial. But I didn't understand how to receive the battery level in the gateway to show on my LCD display.
        Gateway ok:
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:RADIO:OK
        0;255;3;0;9;TSM:GW MODE
        0;255;3;0;9;TSM:READY
        0;255;0;0;18;2.0.0
        0;255;3;0;9;TSP:MSG:READ 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSP:MSG:BC
        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=10)
        0;255;3;0;9;TSP:MSG:GWL OK
        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
        0;255;3;0;9;TSP:MSG:PINGED (ID=10, hops=1)
        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
        10;255;0;0;17;2.0.0
        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        10;255;3;0;6;0
        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
        Node ok:
        TSM:INIT
        RF24:write register, reg=0, value=14
        RF24:read register, reg=6, value=35
        RF24:flushRX
        TSM:RADIO:OK
        RF24:start listening
        RF24:write register, reg=10, value=10
        TSM:FPAR
        RF24:stop listening
        RF24:open writing pipe, recipient=255
        RF24:write register, reg=10, value=255
        RF24:send message to 255, len=7
        RF24:flushTX
        RF24:MAX_RT
        TSP:MSG:READ 0-0-10 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSP:MSG:FPAR (PPAR FOUND)
        TSP:MSG:PAR OK (ID=0, dist=1)
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=10)
        TSM:UPL
        TSP:PING:SEND (dest=0)
        TSP:MSG:PONG RECV (hops=1)
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        Init complete, id=10, parent=0, distance=1, registration=1
        Battery Voltage: 0.00 V
        Battery Voltage: 5.91 V
          Gateway ok:
          0;255;0;0;18;2.0.0
          10;255;0;0;17;2.0.0
          10;255;3;0;6;0
          Node ok:
          TSM:INIT
          RF24:flushRX
          TSM:RADIO:OK
          TSM:FPAR
          RF24:stop listening
          RF24:flushTX
          RF24:MAX_RT
          TSM:FPAR:OK
          TSM:ID
          TSM:UPL
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          AWIA
          AWIA
          AWI
          @Walyson-Albuquerque-Machado Back to one of your previous posts. What kind of LCD display are you using. Do you have one with I2C interface?
            Hey. I don't have I2C interface. Do I need it?
            I have one like this, 20x4:
              AWIA
              AWIA
              AWI
              @Walyson-Albuquerque-Machado It is much easier to connect an I2C display (only 2 wires and power).But if you have pins left on your arduino and the patience to solder you're ok.
              an adapter plate:
                I have pins and I have already done this. :stuck_out_tongue_closed_eyes:
                  Is that how I send ? Can I use BINARY to my hall effect sensor? I'm using the digital pin to count every time it passes through a magnet.
                  MyMessage msg(NODE_ID, V_STATUS);
                  float value = 0;
                      present(NODE_ID, S_BINARY);
                      send(msg.set(value));
                  Is that how I receive?
                      // Handle incoming message
                    Please, someone tell me how to get the voltage that i'm receiving. I've tried many things, I don't know why this doesn't work.
                    msgvolt.getFloat();
                    I can see the battery in the gateway through serial, but I don't know how to get it to show on the LCD.
                    Node:
                    #define MY_DEBUG_VERBOSE_RF24
                    #define DESTINATION_NODE 0
                    #define MY_NODE_ID 10
                    #define MY_PARENT_NODE_ID  0
                    #define MY_RF24_CE_PIN 9
                    #define MY_RF24_CS_PIN 10
                    #define MY_RF24_PA_LEVEL_GW RF24_PA_LOW
                    #define MY_RF24_CHANNEL 76
                    int sensorTensaoDC = A0;
                    float valorTensaoDC;
                    int amostragem = 1000;
                    float mediaTotalTensaoDC = 0;
                    float R1 = 28000.0;
                    float R2 = 7600.0;
                    int sensorValue_aux = 0;
                    float voltsporUnidade = 0.005278592; // 5%1023
                    float dadosenviados;
                    MyMessage msgvolt(4, V_VOLTAGE);
                      analogReference(DEFAULT);
                      pinMode(A0, INPUT);
                       sendSketchInfo("Battery Meter", "1.0");
                       present(4, S_MULTIMETER, "Voltage", true);
                      for(int i=0; i < amostragem ; i++)
                        valorTensaoDC = analogRead(sensorTensaoDC);
                        valorTensaoDC =(valorTensaoDC*voltsporUnidade);
                        mediaTotalTensaoDC = mediaTotalTensaoDC+ (valorTensaoDC / (R2/(R1+R2)));
                      dadosenviados = mediaTotalTensaoDC / amostragem;
                       Serial.print(dadosenviados);
                       Serial.println(" V");
                     send(msgvolt.setDestination(DESTINATION_NODE).set(dadosenviados, 2), 1);
                      wait(2000);
                    Gateway:
                    #define MY_GATEWAY_SERIAL
                    #define MY_NODE_ID 0
                    #define DESTINATION_NODE 10
                    #include <LiquidCrystal.h>
                    float dadosenviados = 0;
                    LiquidCrystal lcd(3, 2, 7, 6, 5, 4);
                      lcd.begin(20, 4);
                      lcd.clear();
                      lcd.setCursor(5, 0);
                      lcd.print("Teste 1.6");
                      delay(5000);
                      lcd.setCursor(3, 2);
                      lcd.print("Carregando...");
                      delay(5000);
                      lcd.clear();
                          sendSketchInfo("Battery Meter", "2.0");
                          present(4, S_MULTIMETER);
                    void receive(const MyMessage &msgvolt) {
                      saveState(msgvolt.sensor, msgvolt.getFloat());
                     dadosenviados = msgvolt.getFloat();
                    request(4, V_VOLTAGE, 10);
                    void incomingMessage(const MyMessage &msgvolt) {
                        lcd.clear();
                        lcd.setCursor(0, 0);
                        lcd.print("TENSAO");
                        lcd.setCursor(7, 0);
                        lcd.print(dadosenviados);
                        lcd.print("VOLTS");
                        lcd.setCursor(0, 1);
                        lcd.print(msgvolt.getFloat());
                        wait(1000);
                          Serial.print("Battery Voltage: ")`;
                      msgvolt.getFloat();
                      Node:
                      float R1 = 28000.0;
                      float R2 = 7600.0;
                        pinMode(A0, INPUT);
                        wait(2000);
                      Gateway:
                        lcd.begin(20, 4);
                        lcd.clear();
                        delay(5000);
                        delay(5000);
                        lcd.clear();
                          lcd.clear();
                          lcd.print("VOLTS");
                          wait(1000);
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      #21
                      @Walyson-Albuquerque-Machado a few things :
                      • the receive routine should be the only place where you receive and read the incoming messages. So skip the incomingmessage routine and add its functionality to receive.
                      • you don't need to 'request' anything as the node already sends messages all the time.
                      • savestate writes only byte (8 bit) values, so you need to decompose a float to bytes in order to save it. (best to use an 'union' for that)
                      Be aware that the gateway (node 0) receives the messages from all nodes connected. You need to make sure that that the incoming message is the one to display.
                      In summary, to receive messages : the receive routine is called automatically when a message is received. You read the message content (store in a global variable) , and display it.
                        wrote on last edited by Walyson Albuquerque Machado
                        #22
                        Ok, I'm going to erase the void incomingMessage(const MyMessage &msgvolt) and the request(4, V_VOLTAGE, 10).
                        Also no savestate.
                        I tried to store in a global variable and display, but I didn't understand It, how do I read!?
                          if (msgvolt.type==V_VOLTAGE) {
                            digitalWrite(msgvolt.sensor, msgvolt.getFloat());
                        Serial.println(msgvolt.getFloat());
                        Serial.println(dadosenviados);
                        Serial.println(msgvolt.data);
                        This is what I'm getting in the serial:
                        Node:
                        Battery Voltage: 8.68 V
                        RF24:stop listening
                        RF24:open writing pipe, recipient=0
                        RF24:write register, reg=10, value=0
                        RF24:write register, reg=16, value=0
                        RF24:send message to 0, len=12
                        RF24:flushTX
                        RF24:write register, reg=7, value=48
                        RF24:write register, reg=0, value=15
                        TSP:MSG:SEND 10-10-0-0 s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:8.68
                        RF24:read message, len=12
                        RF24:write register, reg=7, value=64
                        TSP:MSG:READ 0-0-10 s=4,c=1,t=38,pt=7,l=5,sg=0:8.68
                        Battery Voltage: 8.69 V
                        Gateway:
                        10;4;1;0;38;8.68
                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=4,c=1,t=38,pt=7,l=5,sg=0:8.68
                        0;255;3;0;9;TSP:MSG:ACK msg
                        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:8.68
                        10;4;1;0;38;8.68
                          Also no savestate.
                          Node:
                          RF24:stop listening
                          RF24:flushTX
                          Gateway:
                          10;4;1;0;38;8.68
                          10;4;1;0;38;8.68
                          AWIA
                          AWIA
                          AWI
                          @Walyson-Albuquerque-Machado Apart from the line digitalWrite(msgvolt.sensor, msgvolt.getFloat()); (what do you want to accomplish here? wrtie a float value to a digital output?) it should be fine. The gateway is receiving the volt message so communication is working.
                          this dadosenviados = msgvolt.getFloat(); variable should hold the value, but does not seem to be executed. Try with a println if the "receive" routine is called at all. As you are receiving values with a gateway (node = 0) this is a special case. I need to emulate this. As we seem to be living in a different timezones it can take a while...
                          So if anybody else has a direct answer...
                            Hello! Hm, I removed the digitalWrite and I don't undestand why it doesn't get the data. I tried to print something in the receive routine and I got nothing. What do you mean about special case?
                            Thanks for the time spent with me.
                              AWIA
                              AWIA
                              AWI
                              @Walyson-Albuquerque-Machado I mirrored your setup and tried to read the messages coming into the gateway, No succes :-(
                              The "special" situation is that it's only recent that a Gateway can have locally attached sensors (and actuators..) As mentioned before the gateway receives messages from all the sensors in a (standard) MySensors netword (node 0) to forward them to a controller.
                              I'm sure I did this before so need to investigate a little further.
                              Basic question is: Does the receive() function in a gateway react to incoming sensor messages?
                                Is my send routine from the arduino + nRF24L01 + sensor correct?
                                Or:
                                send(msgvolt.set(dadosenviados, 2),  1);
                                And the receive routine from the arduino + nRF24L01 ?
                                  if (msgvolt.type == V_VOLTAGE) {
                                Serial.print("Incoming");
                                The configuration of the arduino + nRF24L01 + sensor:
                                The configuration of the arduino + nRF24L01:
                                  Or:
                                  AWIA
                                  AWIA
                                  AWI
                                  @Walyson-Albuquerque-Machado All of the code snippets you show seem to be ok. With respect to the #defines... most of these are default so need to include them (but nothing wrong in showing them). The Verbose output also gives me tooo much information if the radio is working.
                                    #28
                                    @AWI, @mfalkvidd Thank you for your time trying to help me.
                                    I just found a Modified SD library to use pins A0-A3 for software SPI. I got it to work!!! So happy. :laughing:
                                    If anyone interests, the link is below:
                                    0_1475856752676_SD-hardcode-use-pins-A0-A3.zip
                                      AWIA
                                      AWIA
                                      AWI
                                      #29
                                      @Walyson-Albuquerque-Machado Thanks for the lib.
                                      Back to the issue that you are not receiving messages from your voltage sensor on your Gateway node:
                                      What is found is that messages sent to the gateway node are not interpreted by the node but directly forwarded to the serial port to the controller. The #else code below in my MyTransport.cpp is responsible for that. It don't know if it was for a reason but it gives a kind of inconsistency.. it is changed in the development branch..
                                      			// Hand over message to controller
                                      			gatewayTransportSend(_msg);
                                      			// Call incoming message callback if available
                                      			if (receive) {
                                      				receive(_msg);
                                      12.5k
