  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.2k Views 18 Watching
  • rayanR rayan
    @Boots33 said:
    @rayan yes it was meant to be used with push buttons not toggle switches. It will need a few tweaks to make it work. I am at work now so will take a look when I get home.
    ok thank you
    Boots33B
    Boots33B
    Boots33
    wrote on last edited by Boots33
    @rayan Ok had a quick look and I don't think we need to do a lot for this to work.
    The only extra change I have made is to add four new lines at the end of the setup function
       /*--------------------- Added these lines for toggle switch-------------------------*/
      oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
      oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
      send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
      send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
    As you can see the oldValue variables are now set to represent the current state of the toggle switches when the node boots up. this should stop any changes in state being made in the main loop until a switch is toggled.
    The other two lines just send a message to the controller to tell it the switches are off. this should make the controller icons show the correct state
    Below is the full sketch, I have nothing to test it on so give it a try and see how it goes
    #define MY_REPEATER_FEATURE
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define SSR_A_ID 1   // Id of the sensor child
    #define SSR_B_ID 2   // Id of the sensor child
    const int buttonPinA = 18;
    const int buttonPinB = 19;
    const int relayPinA = 5;
    const int relayPinB = 6;
    int oldValueA = 0;
    int oldValueB = 0;
    bool stateA = false;
    bool stateB = false;
    Bounce debouncerA = Bounce();
    Bounce debouncerB = Bounce();
    MyMessage msgA(SSR_A_ID, V_STATUS);
    MyMessage msgB(SSR_B_ID, V_STATUS);
      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
      pinMode(relayPinA, OUTPUT);
      pinMode(relayPinB, OUTPUT);
      // After setting up the buttons, setup debouncer
      debouncerA.attach(buttonPinA);
      debouncerA.interval(5);
      debouncerB.attach(buttonPinB);
      debouncerB.interval(5);
      digitalWrite(relayPinA, RELAY_OFF);
      digitalWrite(relayPinB, RELAY_OFF);
    void presentation()  {
      sendSketchInfo("Mains Controller", "1.0");
      present(SSR_A_ID, S_LIGHT);
      present(SSR_B_ID, S_LIGHT);
      debouncerA.update();
      // Get the update value
      int valueA = debouncerA.read();
      if (valueA != oldValueA) {
        send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
      oldValueA = valueA;
      debouncerB.update();
      int valueB = debouncerB.read();
      if (valueB != oldValueB) {
        send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
      oldValueB = valueB;
        switch (message.sensor) {
          case 1:
            stateA = message.getBool();
            digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
          case 2:
            stateB = message.getBool();
            digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
        Serial.print("from node:");
        Serial.println(message.sender);
    rayanR SGiS 2 Replies Last reply
    • Boots33B Boots33
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValueA = 0;
      int oldValueB = 0;
        oldValueA = valueA;
        oldValueB = valueB;
            case 1:
            case 2:
      rayanR
      rayanR
      rayan
      @Boots33 said:
      i test your code and this is excellent . but there is another tiny problem :)
      when relay is ON then loses power so in app relay is ON (icon) , when power is restored and relay go to OFF in app icon is ON and dont Ack for go to show Off .
      you are best in programming :)
      Boots33B 1 Reply Last reply
      • rayanR rayan
        Boots33B
        Boots33B
        Boots33
        @rayan maybe trying to send the off message before the presentation stops it from sending
        try this , have moved the messages to the main loop where they will only be sent once in the first loop
        #define RELAY_ON 1
        #define RELAY_OFF 0
        int oldValueA = 0;
        int oldValueB = 0;
        int trigger = 0;
         // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
         // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
        if (trigger == 0){
          trigger = 1;
          oldValueA = valueA;
          oldValueB = valueB;
              case 1:
              case 2:
        rayanR pepsonP 4 Replies Last reply
        • Boots33B Boots33
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValueA = 0;
          int oldValueB = 0;
          int trigger = 0;
          if (trigger == 0){
            trigger = 1;
            oldValueA = valueA;
            oldValueB = valueB;
                case 1:
                case 2:
          rayanR
          rayanR
          rayan
          @Boots33
          great.
          so this is best sketch :)
          thank you
          • Boots33B Boots33
            #define RELAY_ON 1
            #define RELAY_OFF 0
            int oldValueA = 0;
            int oldValueB = 0;
            int trigger = 0;
            if (trigger == 0){
              trigger = 1;
              oldValueA = valueA;
              oldValueB = valueB;
                  case 1:
                  case 2:
            rayanR
            rayanR
            rayan
            @Boots33
            oh , after added this device , happen a Event ! node id of motion sensor and this device is 1 ! and after sense of motion light on in dashborad ! why both Catch node id 1 .
            i dont add #define node id for motion and for this. but both take id 1 and Interference
            • rayanR rayan
              @Boots33
              Boots33B
              Boots33B
              Boots33
              @rayan As far as I am aware if you don't set the id manually then the controller gives out an id. Why it has doubled up I don't know. Did you use that arduino before and it was originally given that address?
              Anyway you will have to delete the node from the mysensors hardware device in Domiticz then clear the eeprom of that arduino using the clearEepromConfig sketch in the mysensors examples and then reload the mains switch sketch. It should then be given a new id.
              rayanR 1 Reply Last reply
              • Boots33B Boots33
                rayanR
                rayanR
                rayan
                @Boots33
                thank you very much
                • Boots33B Boots33
                  @SGi I have used two buttons in my Mains controller project. I have posted just the relay code below to show you what you need to do. I have not used the eeprom to store the state but you could soon add that back in. The main thing you need to do is check to see which sensor the incoming message is for.
                     DESCRIPTION
                     Based on the RelayWithButtonActuator sketch
                  //#define MY_REPEATER_FEATURE
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  const int buttonPinA = 3;
                  const int buttonPinB = 4;
                  int oldValueA = 0;
                  int oldValueB = 0;
                    if (valueA != oldValueA && valueA == 0) {
                    oldValueA = valueA;
                    if (valueB != oldValueB && valueB == 0) {
                    oldValueB = valueB;
                        case 1:
                        case 2:
                  SGiS
                  SGiS
                  SGi
                  • Boots33B Boots33
                       DESCRIPTION
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValueA = 0;
                    int oldValueB = 0;
                      oldValueA = valueA;
                      oldValueB = valueB;
                          case 1:
                          case 2:
                    SGiS
                    SGiS
                    SGi
                    @Boots33 Whoa sorry, here is the code in the proper format/window...
                     * Version 0.1 - SGI
                     * Sketch to control 4 relays for irrigations, including 4 local push buttons..
                    // Define Relays
                    #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                    // Define Sensor ID's
                    #define SSR_A_ID 11   // Id of the sensor child
                    #define SSR_B_ID 12   // Id of the sensor child
                    #define SSR_C_ID 13   // Id of the sensor child
                    #define SSR_D_ID 14   // Id of the sensor child
                    // Define Buttons
                    const int buttonPinA = 1;
                    const int buttonPinB = 2;
                    const int buttonPinC = 3;
                    const int buttonPinD = 4;
                    // Define Variables
                    int oldValueA = 0;
                    int oldValueB = 0;
                    int oldValueC = 0;
                    int oldValueD = 0;
                    bool stateA;
                    bool stateB;
                    bool stateC;
                    bool stateD;
                    // Define Debounce
                    Bounce debouncerC = Bounce();
                    Bounce debouncerD = Bounce();
                    // Define messages to send back to gateway
                    MyMessage msgC(SSR_C_ID, V_STATUS);
                    MyMessage msgD(SSR_D_ID, V_STATUS);
                      // Setup relay pins and set to output then set relays to startup off
                        pinMode(pin, OUTPUT);
                        // Set relay off
                        digitalWrite(pin, 1);
                      pinMode(buttonPinC, INPUT_PULLUP);
                      pinMode(buttonPinD, INPUT_PULLUP);
                      debouncerC.attach(buttonPinC);
                      debouncerC.interval(5);
                      debouncerD.attach(buttonPinD);
                      debouncerD.interval(5);
                      sendSketchInfo("Irrigation with Buttons", "0.1");
                      present(SSR_C_ID, S_LIGHT);
                      present(SSR_D_ID, S_LIGHT);
                        send(msgA.set(stateA?false:true), true); // Send new state and request ack back
                      oldValueA = valueA;
                        send(msgB.set(stateB?false:true), true); // Send new state and request ack back
                      oldValueB = valueB;
                      debouncerC.update();
                      int valueC = debouncerC.read();
                      if (valueC != oldValueC && valueC == 0) {
                        send(msgC.set(stateC ? false : true), true); // Send new state and request ack back
                      oldValueC = valueC;
                      debouncerD.update();
                      int valueD = debouncerD.read();
                      if (valueD != oldValueD && valueD == 0) {
                        send(msgD.set(stateD ? false : true), true); // Send new state and request ack back
                      oldValueD = valueD;
                      if (message.type==V_STATUS) {
                          case 1:
                            digitalWrite(message.sensor+4, stateA ? RELAY_ON : RELAY_OFF);
                          case 2:
                            digitalWrite(message.sensor+4, stateB ? RELAY_ON : RELAY_OFF);
                          case 3:
                            stateC = message.getBool();
                            digitalWrite(message.sensor+4, stateC ? RELAY_ON : RELAY_OFF);
                          case 4:
                            stateD = message.getBool();
                            digitalWrite(message.sensor+4, stateD ? RELAY_ON : RELAY_OFF);
                         // Change relay state
                         // digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                         // Store state in eeprom
                         //saveState(message.sensor, message.getBool());
                    • Boots33B Boots33
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValueA = 0;
                      int oldValueB = 0;
                        oldValueA = valueA;
                        oldValueB = valueB;
                            case 1:
                            case 2:
                      SGiS
                      SGiS
                      SGi
                      @Boots33 i just worked out what was wrong the code above... and now understand how the message.sensor number works... now my only issue is why the buttons on pins 2,3,4 work but not pin 1... does pin 1 on the arduino have special use?
                      • SGiS SGi
                        Boots33B
                        Boots33B
                        Boots33
                        #26
                        @SGi great that you worked it out and improved your understanding of mysensors as well. 😊. Probably good to post the fix so others may also gain from the thread.
                        I think digital pins 0 and 1 are also used for serial communication so probably best to avoid them wherever possible. If you turn off debugging they will probably work but you may have problems uploading sketches too. The analogue pins can also be used as digital pins if you need a few more.
                        • Boots33B Boots33
                          #define RELAY_ON 1
                          #define RELAY_OFF 0
                          int oldValueA = 0;
                          int oldValueB = 0;
                          int trigger = 0;
                          if (trigger == 0){
                            trigger = 1;
                            oldValueA = valueA;
                            oldValueB = valueB;
                                case 1:
                                case 2:
                          pepsonP
                          pepsonP
                          pepson
                          #define RELAY_ON 1
                          #define RELAY_OFF 0
                          int oldValueA = 0;
                          int oldValueB = 0;
                          int trigger = 0;
                          if (trigger == 0){
                            trigger = 1;
                            oldValueA = valueA;
                            oldValueB = valueB;
                                case 1:
                                case 2:
                          Thanks this code works ok. But by switch i must still connect to GND to keep change status. Is possible to change it to give only impuls GND to change status Relay ? I want use switch monostable.
                          And anybody tell me how i can clear all eeprom in my Arduino Mini Pro. I want clear eeprom before upload sketch.
                          rayanR Boots33B 2 Replies Last reply
                          • pepsonP pepson
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            int oldValueA = 0;
                            int oldValueB = 0;
                            int trigger = 0;
                            if (trigger == 0){
                              trigger = 1;
                              oldValueA = valueA;
                              oldValueB = valueB;
                                  case 1:
                                  case 2:
                            rayanR
                            rayanR
                            rayan
                            @pepson
                            go to : file > examples > mysensors > clear eeprom config
                            and select arduino pro mini from : tools > board > arduino pro or pro mini
                            • Boots33B Boots33
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              int oldValueA = 0;
                              int oldValueB = 0;
                              int trigger = 0;
                              if (trigger == 0){
                                trigger = 1;
                                oldValueA = valueA;
                                oldValueB = valueB;
                                    case 1:
                                    case 2:
                              rayanR
                              rayanR
                              rayan
                              @Boots33 this your code is good, but there is a small issue .button work just when the connection is ok (radio with gateway) ! and when radio is disconnect or controller is off, so button dont work handy . do you have any idea for this ? that when controller is off the button work handy
                              pepsonP Boots33B 2 Replies Last reply
                              • rayanR rayan
                                pepsonP
                                pepsonP
                                pepson
                                @rayan
                                Hi
                                I do this eeprom clear and after that when i upload sketch for relay with buttons , this not working. Any communication with Gateway. Upload sketch successful write.
                                I need changes in code to button monostable. Now if i want enable RELAY i must still connect pin to GND by button. I want only give impuls GND and relay should have enable. Again give impuls GND should disable relay. The same as working Fibaro relay switch by Z-Wave.
                                In code should be add option to select buttons:
                                -Monostable
                                -Bistable
                                • pepsonP pepson
                                  @rayan
                                  Hi
                                  -Monostable
                                  -Bistable
                                  rayanR
                                  rayanR
                                  rayan
                                  @pepson
                                  i am beginner and i hope some one help to you
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Maybe @Boots33 or @SGi help us please
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      Here is an example that I'm using with 4 relays and 4 monostable buttons:
                                      #define SN "RelayButtonArray"
                                      #define SV "1.0"
                                      #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                                      #define RELAY_OFF 1
                                      #define noRelays 4                     //2-4
                                      const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
                                      const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
                                      class Relay             // relay class, store all relevant data (equivalent to struct)
                                        public:
                                          int buttonPin;                   // physical pin number of button
                                          int relayPin;             // physical pin number of relay
                                          boolean relayState;               // relay status (also stored in EEPROM)
                                      Relay Relays[noRelays];
                                      Bounce debouncer[noRelays];
                                      MyMessage msg[noRelays];
                                        void before() {
                                        wait(100);
                                        for (int i = 0; i < noRelays; i++) {
                                          Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                                          msg[i].type = V_LIGHT;
                                          wait(100);
                                          Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                                          digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                          send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                                          wait(50);
                                          debouncer[i].interval(30);
                                          wait(50);
                                        sendSketchInfo(SN, SV);
                                        wait(100);
                                          present(i, S_LIGHT);                               // present sensor to gateway
                                        wait(100);
                                        for (byte i = 0; i < noRelays; i++) {
                                          if (debouncer[i].update()) {
                                            if ( value == LOW) {
                                              // save sensor state in EEPROM (location == sensor number)
                                              saveState( i, Relays[i].relayState );
                                        //wait(20);
                                          if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                                            digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                            saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                                        wait(20);
                                      • Tomas
                                      breimannB N T 3 Replies Last reply
                                      • pepsonP pepson
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        int oldValueA = 0;
                                        int oldValueB = 0;
                                        int trigger = 0;
                                        if (trigger == 0){
                                          trigger = 1;
                                          oldValueA = valueA;
                                          oldValueB = valueB;
                                              case 1:
                                              case 2:
                                        Boots33B
                                        Boots33B
                                        Boots33
                                        @pepson The sketch i have in my first post at the top of the page will work for a push button. the one you are using has been modified for use with a toggle switch.
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          ok i test your first sketch. But maybe you can create sketch where we can setvin sketch what button we want use ?
