  2. Bug Reports
  3. Type mistake
Type mistake
4 Posts 2 Posters 2.2k Views 2 Watching
  • TON RIJNAARDT
    TON RIJNAARDT
    TON RIJNAARD
    It is no bug but a type mistake
    select the correct Port from the Tools menu then open the Serial Monitor to view the debug messages. Note: the default Baud Rate for MySensors is 112500
    This to your information
    Greatz Ton
    • TON RIJNAARDT TON RIJNAARD
      Greatz Ton
      Thanks for reporting this @TON-RIJNAARD, much appreciated.
      Where did you find the mistake? Was it in a Sketch? If so, which sketch? Was it on a page? If so which page?
      • TON RIJNAARDT
        TON RIJNAARDT
        TON RIJNAARD
        It is on this page
        https://www.mysensors.org/build/debug
        Build and upload the sketch with the above debug flag enabled in MyConfig.h.
        Keep the sensor connected to your computer and enable the Serial Monitor in the Arduino IDE. Tools>Serial Monitor.
        Set the baud-rate to 115200.
          It is on this page
          @TON-RIJNAARD Thanks! I have fixed the page, it now says 115200.
