[solved] Problem with ioBroker and MySensors 2.0
Hi, I have iobroker running on a rasPi3 and an instance of mysensors configured. This is working so far. On a nodeMCU, mysensors 2.0 is used. I can pass data between.
cheers
@hek Hello, I am the developer of ioBroker and adapter of mySensors for ioBroker. One of the user has a Problem with the sketch. And I automatically too. Accordingly to log output:
2;1;1;0;0;23.5 1;8;1;0;2;0 1;7;1;0;39;-12.17 1;255;3;0;0;75 1;5;1;0;36;1 1;2;1;0;1;63.38 1;2;1;0;0;12.87 1;2;1;0;38;12.56 1;2;1;0;39;-43.80 1;1;1;0;23;17.69 1;255;3;1;0;1475773988 0;255;0;0;18;2.0.0 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1 0;255;3;0;9;No registration required 0;255;0;0;18;2.0.0 0;255;3;0;14;Gateway startup complete.(from bottom to top) there is no representation messages about datapoints. And I thought, that this information is required to describe the received information. In my driver I send "'0;0;3;0;19;force presentation'" message to receive the representation information jsut after connection esteblishment.
Why the sketch do not send representation info? There is no use on data without to know the name and configuration for that. -
Accordingly to http://forum.iobroker.net/viewtopic.php?f=12&t=3577&start=20#p36227 he has 2.0 Serial with
Seeeduino for the gateway (serial)
Seeeduino for the chicken shed
Sensebende for the temperature sensor
Raspberry pi 2 and 3 for the controllerBTW, is it not the good idea to print the version out in log? What is this? 0;255;0;0;18;2.0.0
And this one must be a sketch: http://forum.iobroker.net/viewtopic.php?f=12&t=3577&start=20#p36212
I have this one log from him:
0;255;3;0;9;TSP:MSG:READ 2-2-0 s=2,c=1,t=1,pt=2,l=2,sg=0:0 2;1;1;0;0;23.5 0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.5 1;8;1;0;2;0 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=8,c=1,t=2,pt=1,l=1,sg=0:0 1;7;1;0;39;-12.17 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=7,c=1,t=39,pt=7,l=5,sg=0:-12.17 1;255;3;0;0;75 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:75 1;5;1;0;36;1 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=5,c=1,t=36,pt=2,l=2,sg=0:1 1;2;1;0;1;63.38 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=1,pt=7,l=5,sg=0:63.38 1;2;1;0;0;12.87 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=0,pt=7,l=5,sg=0:12.87 1;2;1;0;38;12.56 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=38,pt=7,l=5,sg=0:12.56 1;2;1;0;39;-43.80 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=39,pt=7,l=5,sg=0:-43.80 1;1;1;0;23;17.69 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=23,pt=7,l=5,sg=0:17.69 1;255;3;1;0;1475773988 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=0,pt=0,l=10,sg=0:1475773988 0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=0,pt=0,l=10,sg=0,ft=0,st=ok:1475773988 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=1,pt=0,l=0,sg=0: 0;255;0;0;18;2.0.0 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1 0;255;3;0;9;No registration required 0;255;0;0;18;2.0.0 0;255;3;0;14;Gateway startup complete. 0;255;3;0;9;TSM:READY 0;255;3;0;9;TSM:GW MODE 0;255;3;0;9;TSM:RADIO:OK 0;255;3;0;9;TSM:INIT 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)Is the information you required there?
@hek said:
Ok, it sends 9 presentations in a row....
Where can you see that?
It is really strange I have my answer ready and wait for 2 minutes to send it out. In this time you answer on my previous question and my answers looks silly because the it is old. -
@hek
We're making progress. I'm already seeing both nodes in ioBroker Objects tree. The sensebender node also reports temperature and humidity.
Still, none of the measurements from the chicken shed node get through. Underneath is the log from this node, hope you can make any sense of it. I see a lot of FPAR:FAIL's, hope this is something that can be solved.Stefaan
Starting sensor (RNNNA-, 2.0.0) TSM:INIT TSM:RADIO:OK TSP:ASSIGNID:OK (ID=1) TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSM:FPAR:FAIL !TSM:FAILURE TSM:PDT TSM:INIT TSM:RADIO:OK TSP:ASSIGNID:OK (ID=1) TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSM:FPAR:FAIL !TSM:FAILURE TSM:PDT TSM:INIT TSM:RADIO:OK TSP:ASSIGNID:OK (ID=1) TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSM:FPAR:FAIL !TSM:FAILURE TSM:PDT TSM:INIT TSM:RADIO:OK TSP:ASSIGNID:OK (ID=1) TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0 TSP:MSG:FPAR RES (ID=0, dist=0) TSP:MSG:PAR OK (ID=0, dist=1) TSM:FPAR:OK TSM:ID TSM:CHKID:OK (ID=1) TSM:UPL TSP:PING:SEND (dest=0) TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1 TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1 TSP:MSG:PONG RECV (hops=1) TSP:CHKUPL:OK TSM:UPL:OK TSM:READY Kippenhok_4 Motor stopped at 60735 application started TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=ok: TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100 !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0 !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0 TSP:MSG:READ 0-0-1 s=255,c=3,t=0,pt=0,l=10,sg=0:1476000019 TSP:MSG:ACK msg TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=0,pt=0,l=10,sg=0,ft=2,st=ok:1476000019 !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=fail:Kippenhok !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0 !TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=16,pt=0,l=0,sg=0,ft=2,st=fail: !TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=30,pt=0,l=0,sg=0,ft=3,st=fail: !TSP:MSG:SEND 1-1-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,ft=4,st=fail: !TSP:MSG:SEND 1-1-0-0 s=4,c=0,t=7,pt=0,l=0,sg=0,ft=5,st=fail: !TSM:UPL FAIL, SNP TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR Request registration... !TSP:SEND:TNR TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSP:SEND:TNR TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSP:SEND:TNR TSM:FPAR TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc: !TSP:SEND:TNR !TSM:FPAR:FAIL !TSM:FAILURE TSM:PDT Init complete, id=1, parent=255, distance=255, registration=1 ... loop ... !TSP:SEND:TNR Door Open, Lux 1407.40, luxState 1, camera off, (-) Battery 12.07V, -11.90mA !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR --NO-- Time = 5, 0:0:5 ... loop ... !TSP:SEND:TNR Door Open, Lux 1384.85, luxState 1, camera off, (-) Battery 12.07V, -11.20mA !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR !TSP:SEND:TNR --NO-- Time = 10, 0:0:10 -
Something is not good. It keeps losing parent because it doesn't hear any ack:s sent by the gateway.
Did you put decouple capacitors on both gateway and repeater? Do you use none amplified radios?
@hek
Hadn't done any of the decoupling. Will do so next.
However, by moving the controller closer to the shed, The problem is solved !!
Thanks a million for the support !@stefaanv
Hallo, have the same problem.
I cannot see my node in IO-Broker. Read all the threads in this forum and in IObroker.
Same issue with inclusion mode. Don`t know, what else I can do.
I use the original Ethernet-Gateaway-Sketch from MySensors page, the original Temp-hum-sketch from MYsensors page and installed sometimes MYsensors-adapter in IOBroker.
I use the gateway as TCP-client.
What can I do?
Here the seriell protocol:
IP: 192.168.178.56
0;255;3;0;9;TSP:SANCHK:OK
0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
0;255;3;0;9;TSP:MSG:BC
0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
0;255;3;0;9;TSP:CHKUPL:OK
0;255;3;0;9;TSP:MSG:GWL OK
0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.0
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.7
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.9
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
The node was switched on all the time. There is a row of "0;255;3;0;9;TSP:SANCHK:OK".
Then I switched the node of and on again. Now came other infos and I can see the temperatur and the humidity, but not before I switchesd off and on.
Strange.
In IObroker there is nothin to be seen.
Perhaps I use the wrong (chnages wrong?) sketch. Ha sanybody a sketch for the gateaway that runs better?
Thank You in advance
