  3. IOBroker
  4. [solved] Problem with ioBroker and MySensors 2.0
Scheduled Pinned Locked Moved IOBroker
20 Posts 5 Posters 9.2k Views 6 Watching
    That's weird. The serial protocol hasn't changed between the 1.5->2.0 version.
    stefaanvS BluefoxB 2 Replies Last reply
      stefaanvS
      stefaanvS
      stefaanv
      @hek
      According to the ioBroker people, it's definitely because of 2.0. Here is the link to the forum. http://forum.iobroker.net/viewtopic.php?f=12&t=3577
      Looking at the logs, it seems the adapter has a problem to find the beginning of the MySensors messages. Did something change wrt end-of-line charcters ?
        Hmm. do you have the possibility to compare the serial log on your gateway when running 1.5/2.0? Might help to determine what goes wrong.
        • stefaanvS
          stefaanvS
          stefaanv
          OK. Will take some time, I'll have to recompiler the 1.5 version. It'll be interesting to see if the 1.5 version works with ioBroker out of the box.
          • mysensors-6043M
            mysensors-6043M
            mysensors-6043
            Hi, I have iobroker running on a rasPi3 and an instance of mysensors configured. This is working so far. On a nodeMCU, mysensors 2.0 is used. I can pass data between.
            cheers
              BluefoxB
              BluefoxB
              Bluefox
              @hek Hello, I am the developer of ioBroker and adapter of mySensors for ioBroker. One of the user has a Problem with the sketch. And I automatically too. Accordingly to log output:
              2;1;1;0;0;23.5
              1;8;1;0;2;0
              1;7;1;0;39;-12.17
              1;255;3;0;0;75
              1;5;1;0;36;1
              1;2;1;0;1;63.38
              1;2;1;0;0;12.87
              1;2;1;0;38;12.56
              1;2;1;0;39;-43.80
              1;1;1;0;23;17.69
              1;255;3;1;0;1475773988
              0;255;0;0;18;2.0.0
              0;255;0;0;18;2.0.0
              (from bottom to top) there is no representation messages about datapoints. And I thought, that this information is required to describe the received information. In my driver I send "'0;0;3;0;19;force presentation'" message to receive the representation information jsut after connection esteblishment.
              Why the sketch do not send representation info? There is no use on data without to know the name and configuration for that.
                Is it from a separate node or sensors attached to the gateway the presentation is missing?
                Do you have the sketch?
                Which version on the node/gateway?
                • BluefoxB
                  BluefoxB
                  Bluefox
                  Accordingly to http://forum.iobroker.net/viewtopic.php?f=12&t=3577&start=20#p36227 he has 2.0 Serial with
                  Seeeduino for the gateway (serial)
                  Seeeduino for the chicken shed
                  Sensebende for the temperature sensor
                  Raspberry pi 2 and 3 for the controller
                  BTW, is it not the good idea to print the version out in log? What is this? 0;255;0;0;18;2.0.0
                    Might be best to ping @stefaanv here...
                    How does the log look on the node where the presentation messages is sent from?
                    Do you get failed transmissions?
                    • BluefoxB
                      BluefoxB
                      Bluefox
                      And this one must be a sketch: http://forum.iobroker.net/viewtopic.php?f=12&t=3577&start=20#p36212
                        Ok, it sends 9 presentations in a row.... Might be too much depending on how the radio is powered and decoupled.
                        Introducing a wait(50) between each presentation message could resolve the problem.
                        • BluefoxB
                          BluefoxB
                          Bluefox
                          I have this one log from him:
                          0;255;3;0;9;TSP:MSG:READ 2-2-0 s=2,c=1,t=1,pt=2,l=2,sg=0:0
                          2;1;1;0;0;23.5
                          0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.5
                          1;8;1;0;2;0
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=8,c=1,t=2,pt=1,l=1,sg=0:0
                          1;7;1;0;39;-12.17
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=7,c=1,t=39,pt=7,l=5,sg=0:-12.17
                          1;255;3;0;0;75
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:75
                          1;5;1;0;36;1
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=5,c=1,t=36,pt=2,l=2,sg=0:1
                          1;2;1;0;1;63.38
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=1,pt=7,l=5,sg=0:63.38
                          1;2;1;0;0;12.87
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=0,pt=7,l=5,sg=0:12.87
                          1;2;1;0;38;12.56
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=38,pt=7,l=5,sg=0:12.56
                          1;2;1;0;39;-43.80
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=39,pt=7,l=5,sg=0:-43.80
                          1;1;1;0;23;17.69
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=23,pt=7,l=5,sg=0:17.69
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=0,pt=0,l=10,sg=0:1475773988
                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=0,pt=0,l=10,sg=0,ft=0,st=ok:1475773988
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=1,pt=0,l=0,sg=0:
                          0;255;0;0;18;2.0.0
                          0;255;0;0;18;2.0.0
                          0;255;3;0;9;TSM:READY
                          0;255;3;0;9;TSM:GW MODE
                          0;255;3;0;9;TSM:RADIO:OK
                          0;255;3;0;9;TSM:INIT
                          Is the information you required there?
                          • BluefoxB
                            BluefoxB
                            Bluefox
                            Where can you see that?
                            It is really strange I have my answer ready and wait for 2 minutes to send it out. In this time you answer on my previous question and my answers looks silly because the it is old.
                            • BluefoxB
                              BluefoxB
                              Bluefox
                              I do not understand, should ioBorker use wait(50) or Sketch? (I guess sketch, but to be sure)
                                In the sketch.
                                stefaanvS 1 Reply Last reply
                                  In the sketch.
                                  stefaanvS
                                  stefaanvS
                                  stefaanv
                                  @hek
                                  We're making progress. I'm already seeing both nodes in ioBroker Objects tree. The sensebender node also reports temperature and humidity.
                                  0_1476000444616_upload-383148d2-26ea-402a-a4a9-8258a2fa346b
                                  Still, none of the measurements from the chicken shed node get through. Underneath is the log from this node, hope you can make any sense of it. I see a lot of FPAR:FAIL's, hope this is something that can be solved.
                                  Stefaan
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSP:ASSIGNID:OK (ID=1)
                                  TSM:FPAR
                                  TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  !TSM:FPAR:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  !TSM:FPAR:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  !TSM:FPAR:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  TSP:MSG:PAR OK (ID=0, dist=1)
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:CHKID:OK (ID=1)
                                  TSM:UPL
                                  TSP:PING:SEND (dest=0)
                                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                  TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  TSP:MSG:PONG RECV (hops=1)
                                  TSP:CHKUPL:OK
                                  TSM:UPL:OK
                                  TSM:READY
                                  Kippenhok_4
                                  Motor stopped at 60735
                                  application started
                                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
                                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                  !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                  !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0
                                  TSP:MSG:READ 0-0-1 s=255,c=3,t=0,pt=0,l=10,sg=0:1476000019
                                  TSP:MSG:ACK msg
                                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=0,pt=0,l=10,sg=0,ft=2,st=ok:1476000019
                                  !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=fail:Kippenhok
                                  !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
                                  !TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=16,pt=0,l=0,sg=0,ft=2,st=fail:
                                  !TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=30,pt=0,l=0,sg=0,ft=3,st=fail:
                                  !TSP:MSG:SEND 1-1-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,ft=4,st=fail:
                                  !TSP:MSG:SEND 1-1-0-0 s=4,c=0,t=7,pt=0,l=0,sg=0,ft=5,st=fail:
                                  !TSM:UPL FAIL, SNP
                                  TSM:FPAR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  Request registration...
                                  !TSP:SEND:TNR
                                  TSM:FPAR
                                  !TSP:SEND:TNR
                                  TSM:FPAR
                                  !TSP:SEND:TNR
                                  TSM:FPAR
                                  !TSP:SEND:TNR
                                  !TSM:FPAR:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  Init complete, id=1, parent=255, distance=255, registration=1
                                    ... loop ...
                                  !TSP:SEND:TNR
                                  Door Open, Lux 1407.40, luxState 1, camera off, (-)
                                  Battery 12.07V, -11.90mA
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  --NO-- Time = 5, 0:0:5
                                    ... loop ...
                                  !TSP:SEND:TNR
                                  Door Open, Lux 1384.85, luxState 1, camera off, (-)
                                  Battery 12.07V, -11.20mA
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  !TSP:SEND:TNR
                                  --NO-- Time = 10, 0:0:10
                                    Something is not good. It keeps losing parent because it doesn't hear any ack:s sent by the gateway.
                                    Did you put decouple capacitors on both gateway and repeater? Do you use none amplified radios?
                                      stefaanvS
                                      stefaanvS
                                      stefaanv
                                      @hek
                                      Hadn't done any of the decoupling. Will do so next.
                                      However, by moving the controller closer to the shed, The problem is solved !!
                                      0_1476001429124_upload-ffaeb96a-bf60-48e0-a44e-e5bca67cb6d4
                                      Thanks a million for the support !
                                      jopebeJ 1 Reply Last reply
                                      • stefaanvS stefaanv
                                        @hek
                                        jopebeJ
                                        jopebeJ
                                        jopebe
                                        @stefaanv
                                        Hallo, have the same problem.
                                        I cannot see my node in IO-Broker. Read all the threads in this forum and in IObroker.
                                        Same issue with inclusion mode. Don`t know, what else I can do.
                                        I use the original Ethernet-Gateaway-Sketch from MySensors page, the original Temp-hum-sketch from MYsensors page and installed sometimes MYsensors-adapter in IOBroker.
                                        I use the gateway as TCP-client.
                                        What can I do?
                                        Here the seriell protocol:
                                        IP: 192.168.178.56
                                        0;255;3;0;9;TSP:SANCHK:OK
                                        0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                        0;255;3;0;9;TSP:MSG:BC
                                        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
                                        0;255;3;0;9;TSP:CHKUPL:OK
                                        0;255;3;0;9;TSP:MSG:GWL OK
                                        0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                        0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
                                        0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                        0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.0
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.7
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.9
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
                                        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
                                        The node was switched on all the time. There is a row of "0;255;3;0;9;TSP:SANCHK:OK".
                                        Then I switched the node of and on again. Now came other infos and I can see the temperatur and the humidity, but not before I switchesd off and on.
                                        Strange.
                                        In IObroker there is nothin to be seen.
                                        Perhaps I use the wrong (chnages wrong?) sketch. Ha sanybody a sketch for the gateaway that runs better?
                                        Thank You in advance
