  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 40.4k Views 31 Watching
    I read somewhere that there has been a wireless bootloader for the RFM69 "under development" now for some time, and that it can work without using additional external memory chips (such as a winbond memory chip). Is that true, and if so, has the development completed or is it still unreleased?
    • tekkaT tekka
      Hi all,
      Here is the second pre-release of MYSBootloader 1.3 for testing purposes.
      Download here. Thanks for your feedback.
      MYSBootloader 1.3pre2 (1.3NS)
      • requires MySensors 2.0.x
      • supports OTA FW AND serial FW updates
      • no external flash needed for OTA FW updates (thus, offline update)
      • communicates via assigned parent node (if found)
      • 2kb bootloader size
      • bootloader commands removed (size constraints, STK500 code instead)
      • nRF24 (Channel 76, base address 0xA8A8E1FC00, data rate 250kbs)
      • serial uploads: 115200 baud (16Mhz), 38400 (8Mhz) or 9600 (1Mhz)
      Using Arduino IDE 1.6.12:
      Add these lines (or copy from included add_to_boards.txt file) to the boards.txt file in your Arduino IDE installation folder:
      MYSBL13.name=ATmega328 with MYSBootloader
      MYSBL13.upload.tool=avrdude
      MYSBL13.upload.protocol=arduino
      MYSBL13.bootloader.tool=avrdude
      MYSBL13.bootloader.unlock_bits=0x3F
      MYSBL13.bootloader.lock_bits=0x0F
      MYSBL13.build.mcu=atmega328p
      MYSBL13.build.board=AVR_PRO
      MYSBL13.build.core=arduino
      MYSBL13.build.variant=standard
      ## Arduino with MYSBootloader 1.3pre
      MYSBL13.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8)
      MYSBL13.menu.cpu.16MHzatmega328.upload.maximum_size=30720
      MYSBL13.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048
      MYSBL13.menu.cpu.16MHzatmega328.upload.speed=115200
      MYSBL13.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
      MYSBL13.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
      MYSBL13.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
      MYSBL13.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_16Mhz.hex
      MYSBL13.menu.cpu.16MHzatmega328.build.mcu=atmega328p
      MYSBL13.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
      MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8)
      MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_size=30720
      MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
      MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
      MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
      MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
      MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
      MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_8Mhz.hex
      MYSBL13.menu.cpu.8MHzatmega328.build.mcu=atmega328p
      MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
      MYSBL13.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8)
      MYSBL13.menu.cpu.1MHzatmega328.upload.maximum_size=30720
      MYSBL13.menu.cpu.1MHzatmega328.upload.maximum_data_size=2048
      MYSBL13.menu.cpu.1MHzatmega328.upload.speed=9600
      MYSBL13.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
      MYSBL13.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
      MYSBL13.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
      MYSBL13.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_1Mhz.hex
      MYSBL13.menu.cpu.1MHzatmega328.build.mcu=atmega328p
      MYSBL13.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
      Please read this excellent guide written by @scalz about MySensors OTA programming.
      In brief:
      Copy bootloader *.hex files (from Bootloader folder) to the [Arduino IDE installation folder]/hardware/arduino/avr/bootloaders/MYSBootloader/
      Restart Arduino IDE, choose under Tools | Board | ATmega328 with MYSBootloader |, select correct board under Processor tab. Connect USBasp to sensor node and select Tools | Programmer | USBasp and hit "Burn Bootloader"
      Please use the AVR fuse calculator to retrieve the individual fuse settings. If you need to change frequency, BOD or other settings, change the fuse settings based on the fuse calculator.
      OTA FW updates using MYSController 3315 (included) (refer to @scalz's guide):
      Copy Arduino FW .hex file to MYSController/Firmware folder and edit firmware_config.csv file according to the existing lines.
      Hit "Refresh Repo" in MYSController and the newly copied firmware should appear in the Assign FW dropdown list, ready to be uploaded.
      Read this thread for discussions on MYSBootloader 1.3pre1
      Have fun!
      RedferneR
      RedferneR
      Redferne
      @tekka
      Finally some action here again! Yeah!
      Any chance we can get our hands on the source so that we can change channels/power and finetune led status and such?
        mannkind
        wrote on last edited by mannkind
        jmkhaelJ 1 Reply Last reply
        • tekkaT tekka
          @NiklasO you can use the internal RC oscillator (that is 8Mhz), no need to use external XTAL. For AVR fuse calculator, refer to http://www.engbedded.com/fusecalc/ or http://eleccelerator.com/fusecalc/fusecalc.php?chip=atmega328p and the documentation therein.
          NiklasON
          NiklasON
          NiklasO
          wrote on last edited by NiklasO
          I don't understand the fusecalc yet. I don't know all the terms used on that calc page or how it really works but I'm learning I guess. ;) The Pro Mini clones i got from eBay has this extremely small external 8 MHz (for 3.3V) and 16MHz (for 5V) crystal/oscillator/resonator or what they are called. Why is it there if not needed? Genuine interested here.
            So, I gather there is no RFM69 version?
            • M mannkind
              [[topic:post-is-deleted]]
              jmkhaelJ
              jmkhaelJ
              jmkhael
              @mannkind what other software do you use for ota firmware update?
              thanks
                Not getting an answer here. Should I be asking the question somewhere else?
                • jmkhaelJ jmkhael
                  thanks
                  mannkind
                  • M mannkind
                    jmkhaelJ
                    jmkhaelJ
                    jmkhael
                    @mannkind thank you for your reply. I don't want to get you in trouble regarding the rules. i don't feel it is against the rules to promote open source or contribution around mysensors if it makes the journey more enjoyable. maybe a mod or admin can pitch in and clarify in any case.
                    I understand that the gateway role is to open up integration with other controllers (and we have quite many thanks to that)
                    The problem i am trying to wrap my head around is to have mysensors network attached to my current controller, and ideally be able to update over the air the sketches. how can i begin doing that? i am ready to use 2 or more controller (mycontroller or myscontroller or...), 2 ore more gateways and even maybe have the nodes on two different rf channels.
                    Basically, what is the recommended way to achieve that, while having for the time being at least, another controller attached.?
                    • Velo17V
                      Velo17V
                      Velo17
                      Hello! Will there be a chance to change the radio channel used for the bootloader OTA process?
                      • jmkhaelJ
                        jmkhaelJ
                        jmkhael
                        wrote on last edited by jmkhael
                        @mannkind : thank you for your message. I'll give that a go later on.
                        @tekka , @anyone :)
                        I am trying to make this work using MYSController (from MYSBootloader_V13pre2/). I've followed the instructions above from @tekka, but it feels like the OTA process kicks around quite quick, then it seems to block in a loop
                         [2016-10-17 23:09:29.821 Info] RX	1;255;4;0;0;0A0001005000D4460102
                         [2016-10-17 23:09:29.821 Info] INFO	BL version=258
                         [2016-10-17 23:09:29.821 Info] INFO	Send FW info to node 1: type=A, version=1, blocks=0x0050, CRC=0x46D4
                         [2016-10-17 23:09:29.822 Info] TX	1;0;4;0;1;0A0001005000D446
                        I'll try to keep it going all night, but here are my full log till now.
                        Any idea what is going wrong?
                        0_1476738954886_MySensors_20161017-230018.log
                        M tekkaT 2 Replies Last reply
                        • jmkhaelJ jmkhael
                          @tekka , @anyone :)
                          mannkind
                          • jmkhaelJ jmkhael
                            @tekka , @anyone :)
                            tekkaT
                            tekkaT
                            tekka
                            @jmkhael Looks like a bad radio connection (GW too close / far, interference, power) What happens if you upload the FW via serial link?
                            • tekkaT tekka
                              jmkhaelJ
                              jmkhaelJ
                              jmkhael
                              @mannkind : thanks for the clarifications. My problem is that the node seems to hang at the booting phase in MYSController sa per the screenshot.
                              @tekka that should be it (gw in the 50 cm range). I'll try more tests and get back here in any case.
                              @mannkind, @tekka: How do we interpret the OTA logs?
                              • jmkhaelJ jmkhael
                                jmkhaelJ
                                jmkhaelJ
                                jmkhael
                                @tekka: it was probably a mix of power/distance. when change these two parameters, OTA went fine. thank you
                                What is the best way to handle OTA for sleeping nodes? is there something else todo besides setting the property under settings in MYSController? Do I need to powercycle the node or will MYSController kicks in when the node sleeps/smartSleeps?
                                thank you for your time
                                tekkaT 1 Reply Last reply
                                • jmkhaelJ jmkhael
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @jmkhael MYSController will reboot the node as soon as it wakes up, sends and processes incoming messages.
                                  • tekkaT tekka
                                    jmkhaelJ
                                    jmkhaelJ
                                    jmkhael
                                    @tekka my node wakes up every two minutes (or on pir movement) sends some messages (temperature, light level...) and sleeps right away. will MYSController be able to do that in this small time window? is there something i can code to help it? (heartBeat, wait, smartSomething?)
                                    (as i saw during my few tests, i had to powercycle my node, maybe i wasn't patient enough :))
                                    • jmkhaelJ jmkhael
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @jmkhael place smartSleep() instead of sleep(), before sending any values to the controller - MYSController will pick this up and send a reboot command. Also, you need to mark the node as battery-powered/sleeping node...
                                      • JCLBJ
                                        JCLBJ
                                        JCLB
                                        wrote on last edited by JCLB
                                        #23
                                        Just tried with this release, works great (had no problem with previous release)
                                        The only drawback is the packet bitrate, around 40 per minute with 45 bytes each.
                                        It takes 1h to flash a node. few minutes, just make sure of your wiring as this is a very intensive process compared to node's standard radio use.
                                        Here is a flash running on a test network:
                                        snip
                                        Can we update many nodes at the same time ? haven't tried
                                        • JCLBJ JCLB
                                          snip
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @JCLB This is unusual. A regular sketch ~20kB takes ~2mins. Maybe you are having issues with power supply, bad clones, or other sources of interference.
